SMUD Power Outage Guide: Check the Map, Report Outages, and Stay Safe in Sacramento
A winter windstorm, a summer heat wave, or a damaged power line can quickly cut power to homes in Sacramento. Power outages can disrupt lights, fridges, air conditioning, internet, and more when SMUD loses power. So, it's important to know where to get updates and how to act responsibly. SMUD serves most of Sacramento County, and other utilities service outlying regions. This article covers how to check the SMUD outage map, report an outage, find out which utility company services your neighborhood, learn common reasons for Sacramento outages, prepare backup power, and be safe while you wait for the power to be restored.
How to Check a SMUD Power Outage
When the electricity goes out, first check if the issue is just in your home or if it affects your neighbourhood. SMUD's web outage info shows current outages and restoration estimates. It's a great first stop. Visit SMUD to see current outages, report issues, and get utility updates. Check your home's breaker panel before reporting an outage. If your breakers seem fine and nearby houses are also out of power, the problem is probably with the utility.
How to Report a SMUD Outage
If your outage does not already appear on the map, you can report it through SMUD's available channels. Check your home's electrical panel before you report. Make sure a tripped breaker isn't causing the problem.
  • Report the outage via the SMUD website or SMUD mobile app. Make your account details accessible if asked.
  • If you need to report an outage or need help with your power service, call 1-888-456-7683.
  • Keep away from fallen power lines and trees in contact with power lines. Do not use damaged electrical equipment and report hazards to the utility.
  • Do not go near utility staff as they work. Give workers room to safely check equipment, clear hazards, and restore power.
  • Never approach a fallen or sparking power line. If there is an immediate danger involving a downed or sparking line, call 911.
If you work from home, losing electricity can also mean losing your internet connection. A backup battery or portable power station can keep your router and other small electronics operating, while planning for keeping Wi-Fi on during power outages can help you maintain communication and receive important outage updates.
SMUD vs. PG&E: Who Powers Your Area?
Several electric utilities serve communities around the Sacramento region. Identifying your provider before an emergency saves time because each utility has its own outage map, reporting process, and restoration information.
SMUD vs. PG&ESMUD vs. PG&E
Utility
Area Served
What to Use During an Outage
SMUD
Most of Sacramento County
SMUD outage map and reporting tools
PG&E
West Sacramento and parts of Yolo County
PG&E outage map and reporting tools
Roseville Electric
City of Roseville
Roseville Electric outage information
SMUD is a community-owned utility that has served the Sacramento area since 1946. PG&E serves several communities outside SMUD's service territory, while Roseville Electric provides electricity within the City of Roseville.
West Sacramento Power Outages
West Sacramento residents should generally check PG&E's outage information rather than SMUD's because PG&E serves the city. This distinction matters during severe weather, when PG&E customers may also receive information about Public Safety Power Shutoffs during periods of elevated wildfire risk. If you live in or near West Sacramento, keep the correct utility outage page bookmarked before an emergency and review PG&E power outage safety tips to understand practical steps for preparing for, responding to, and recovering from a utility outage.
Common Causes of Sacramento Power Outages
Sacramento power outages can happen for several reasons. Severe weather is one of the most noticeable causes, but grid equipment, high electricity demand, and accidental contact with power lines can also interrupt service.
Common Causes of Sacramento Power OutagesCommon Causes of Sacramento Power Outages
Common causes include:
  • Winter windstorms: Strong winds can bring branches or trees into contact with electrical lines, damaging equipment and interrupting service.
  • Atmospheric rivers: Heavy rain and strong winds can damage electrical infrastructure, knock down trees, and contribute to widespread outages.
  • Summer heat waves: Extremely high temperatures can increase electricity demand and put additional stress on electrical equipment, increasing the risk of outages.
  • Equipment failures: Transformers, distribution equipment, and other electrical components can fail unexpectedly and interrupt power to nearby homes and businesses.
  • Vegetation: Trees and branches growing too close to power lines can come into contact with electrical equipment, especially during windy or stormy conditions.
  • Metallic balloons: Mylar balloons can create dangerous electrical faults if they become tangled in or contact overhead power lines.
A power outage in Sacramento's sweltering summers may be extremely painful, as indoor temperatures can climb quickly without air conditioning. However, preparing ahead of time with water, cooling supplies, charged electronics, and a backup power plan will help decrease the impact. Staying safe during heat waves and extreme heat can offer some further preparation advice for times of extreme temperatures.
Backup Power for Sacramento Homes
Sacramento's summer blackouts may be brutal when the temperature climbs into the triple digits, and you don't have air conditioning. A dependable battery backup can assist in keeping vital appliances and devices running during a long SMUD power outage, such as refrigerators, fans, medical equipment, and communication devices.
The EcoFlow DELTA Pro 3 is also a great option for houses with larger power needs. It can deliver 4,000W of output with 120V/240V capability, and when designed properly, it can also handle demanding household loads.
EcoFlow DELTA Pro 3
•High Power & Versatility: Delivers up to 4000W (6000W via X-Boost) with 120V and 240V outputs to run a 3-ton central AC and essential appliances. • Continuous Power: Maintains stable 120/240V output at 4000W during pass-through charging. • Endless Energy: Compatible with portable generators and auto-recharges using the EcoFlow Smart Generator 4000. • Durable Battery Life: EV-grade LFP battery retains 80% capacity after 4000 cycles.
The EcoFlow DELTA Pro 3 is suited to households that need higher output for central AC, 240V equipment, and multiple essential loads during a prolonged outage. For apartments or smaller homes where the main goal is keeping a refrigerator, fans, lights, and communication devices running, a portable 2kWh-class power station can provide a more manageable backup option.
EcoFlow DELTA 3 Max (2048Wh)
• 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws. • 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. • Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product. • OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. • Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
Staying Safe During a Sacramento Power Outage
Heat can be one of the major concerns during a Sacramento summer power outage. Winter storms pose several hazards, including freezing temperatures, rainy conditions, and damaged trees or power lines.
Staying Safe During a Sacramento Power OutageStaying Safe During a Sacramento Power Outage
  • Drink plenty of water during hot weather and stay hydrated, especially during prolonged heat.
  • Use fans or other safe cooling equipment when available to help maintain a comfortable indoor temperature.
  • Keep refrigerator and freezer doors closed as much as possible to help preserve food during the outage.
  • Unplug sensitive electronics during an outage to help protect them from possible power fluctuations when electricity returns.
  • Never operate a fuel-powered generator inside a home, garage, or other enclosed space. Always use generators outdoors in a well-ventilated area away from doors and windows.
  • Stay away from downed power lines and damaged electrical equipment. Follow instructions from local emergency officials and utility providers.
For emergency planning, follow guidance from organizations such as the CDC extreme heat guidance and Ready.gov, particularly during periods of extreme heat.
Protecting Food During an Outage
Food safety is a problem when an outage lasts several hours. Keep the refrigerator closed as much as possible. A refrigerator that is shut may normally keep food cold for around four hours. If the outage is expected to continue, use coolers and ice when available. A full freezer can generally remain at a safe temperature for longer than a refrigerator, provided the door stays closed. You can also plan your backup power around refrigeration. Understanding how long food can stay in a refrigerator without power helps you decide when backup electricity or another food-storage solution becomes necessary.
A SMUD power outage is easier to manage when you know where to check for updates and how to report an interruption. Use SMUD's outage map, app, and hotline, and check PG&E if you live in West Sacramento. Prepare for both Sacramento's summer heat and winter storms by keeping essential supplies and backup power ready. For higher household loads, the EcoFlow DELTA Pro 3 can provide substantial output, while the DELTA 3 Max offers a portable option for essential appliances and devices.
How do I check a SMUD power outage?
You can check the current outage status through SMUD's outage information and map tools. You can also use the SMUD mobile app to view outage updates. If needed, you can report an outage through SMUD's available channels.
What is SMUD's outage phone number?
SMUD's outage phone number is 1-888-456-7683. You can call this number to report an outage or get information about your electricity service. Keep your account information available if requested.
Does SMUD serve West Sacramento?
No. West Sacramento is located in Yolo County and is served by PG&E, not SMUD. While SMUD provides electricity to most of neighboring Sacramento County, utility boundaries follow county lines, meaning West Sacramento residents receive their electric service through Pacific Gas and Electric.
Why does Sacramento lose power during storms?
Storms can cause Sacramento power outages when strong winds bring trees or branches into contact with power lines. Heavy rain can also damage electrical infrastructure or contribute to equipment problems. Utility crews may need to repair damaged equipment before service can be restored.
How long do SMUD outages usually last?
The length of a SMUD outage depends on its cause, location, and the extent of equipment damage. Some outages may be restored relatively quickly, while major storm-related damage can take longer. Check SMUD's outage information for the latest estimated restoration updates.
What should I do during a summer power outage in Sacramento?
During a summer outage, drink plenty of water and use safe cooling methods such as battery-powered fans when available. Keep refrigerator and freezer doors closed and avoid strenuous activity during extreme heat. If your home becomes dangerously hot, consider moving to an official cooling center.
Power Outages
