Evergy Outage Map Guide: How to Check, Report, and Stay Prepared
Evergy serves roughly 1.7 million customers across Kansas and Missouri. When the power goes out, the first thing most people want to know is whether Evergy already knows about it and when service might return. The Evergy outage map can answer those questions, while the utility's reporting options give you a way to flag an outage that isn't showing yet. A little preparation helps, too. Save the right outage number for your service area, know what to do around a downed line, and have a backup plan for your refrigerator, lights, phones, and other essentials if repairs take longer than expected.
How to Check the Evergy Outage Map
The Evergy outage map is a good place to start when your power goes out. It shows current outages, the number of customers affected, and estimated restoration times, so you can get a quick picture of what's happening in your area.
Find your outage on the map
Go to outagemap.evergy.com and search around your area to see whether Evergy has already posted the outage. The map separates information by service territory, including Kansas Central, Kansas Metro, and Missouri, which can help narrow down what you're seeing.
The map can also show whether the outage is limited to your neighborhood or affecting a larger area. Restoration estimates may change as crews inspect damaged lines and equipment, so don't be surprised if the time moves later after the initial estimate. You can check the same outage information through the Evergy mobile app, which is useful when you're relying on your phone during a storm. If you want to see how another utility presents similar information, OPPD outage tracking offers a useful comparison for reading outage updates during a major event.
Check the outage details
Once you find your area on the map, look at the number of affected customers and the estimated restoration time. Those details can give you a better sense of whether you're dealing with a small neighborhood outage or a larger event affecting several communities. Keep in mind that a restoration estimate is just an estimate. Crews may find additional damage after they reach the site, especially after severe weather, so check the map again if the original time passes or conditions change.
How to Report an Evergy Outage
If your home has lost power but you don't see the outage on the map, report it to Evergy. You have different phone numbers depending on your service territory, and you can also report the problem online or through the app.
How to Report an Evergy OutageHow to Report an Evergy Outage
Report by phone
The number you need depends on your Evergy service area. Kansas Central customers can call 1-800-LIGHTKS (1-800-544-4857), while customers in Kansas Metro, Missouri Metro, and Missouri West can call 1-888-LIGHTKC (1-888-544-4852) to report an outage. Save the number for your area before storm season so you don't have to look it up when the power is out and your phone battery is running low.
Report online or through the app
You can also report an outage at Evergy's outage reporting page or through the mobile app. This gives you another option if the phone lines are busy after a major storm. Once you've reported the outage, keep checking the map for updates. If the estimated restoration time changes, you may need to adjust your plans for food, heating or cooling, medical equipment, and other electrical needs.
Report downed lines separately
A downed power line needs more than an outage report. Call 911 first, then report the line to Evergy. Stay well away from the line and anything touching it. A line can remain energized even when the surrounding area has lost power.
Backup Power While Waiting on Evergy
Some Evergy storm events have affected 200,000 or more customers at once, with the hardest-hit areas facing restoration that can stretch across several days. That's when having backup power at home becomes more than a convenience. A backup system can keep a refrigerator cold, power lights, charge phones, and support other essential equipment while crews work on damaged lines. The right setup depends on how much of your home you want to keep running. If you're planning for an outage that could last several days, this guide to how long outages can last can help you think through what your household may need.
EcoFlow DELTA Pro Ultra X
•100% Whole-Home Power: Delivers 12–36kW output and 12–180kWh capacity. • Fast Installation: Plug-and-play design installs in 7 days, saving up to 80% on time and cost. • Smart & Reliable: Auto switchover in under 10ms standalone, under 20ms with Smart Home Panel. • High Savings: Saves up to $6,000 per year with a 3-year ROI. • Comprehensive Safety: Provides end-to-end system protection meeting the highest safety standards.
If you only need to keep essential appliances and devices running during an Evergy outage, a portable power station can be a practical option. The EcoFlow DELTA 3 Max provides enough power for everyday essentials. It is also easier to move and store when you don't need it.
EcoFlow DELTA 3 Max (2048Wh)
• 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws. • 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. • Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product. • OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. • Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
Evergy's Service Area and Common Outage Causes
Evergy serves customers across Kansas and Missouri, including the greater Kansas City area. The company was formed through the merger of KCP&L and Westar Energy. The cause of an outage can vary by location and weather. Across Evergy's territory, high winds, thunderstorms, and downed trees account for many significant outages. Major events can affect communities such as Salina, Kansas, St. Joseph, Missouri, and the Kansas City metro.
High winds and thunderstorms
Strong winds can bring down trees and branches. They can also damage poles and affect overhead power lines. Thunderstorms can create several problems at once. This can make restoration more complicated. During a large storm, crews may need to assess multiple damaged areas before they can start making repairs. That's one reason a restoration estimate can change after the initial outage report.
Downed trees and damaged equipment
Trees are a recurring problem for overhead electrical systems. A large branch can take down a line, while a fallen tree can damage poles or other equipment at the same time. For another look at how a utility handles a large storm event, you can read this guide to major outage tracking. Evergy's service territory covers a large area, so storm damage isn't necessarily concentrated in one place. If many communities are affected, crews have more repairs to assess and complete.
Staying Safe During an Evergy Outage
A power outage can create hazards both inside and outside your home. Downed lines, damaged electrical equipment, dark rooms, and fuel-burning generators all require extra care while service is out.
Staying Safe During an Evergy OutageStaying Safe During an Evergy Outage
Keep away from downed power lines
Stay at least 30 to 35 feet away from a downed power line. Evergy treats downed lines as energized until they're confirmed safe. Don't touch the line, a nearby tree, fence, vehicle, or other object that may be in contact with it. Keep kids and pets away from the area, too. Call 911 first, then report the hazard to Evergy.
Check your home's electrical equipment
A damaged meter connection can create another problem after a storm. If the equipment connecting your home's electric meter has been damaged, Evergy may need a licensed electrician to make repairs before power can be restored safely. Don't try to repair damaged electrical equipment yourself. Have the damage assessed by a qualified professional before reconnecting anything.
Keep an outage kit ready
A basic outage kit can make a long evening without electricity much easier. Keep flashlights with spare batteries, phone chargers, bottled water, nonperishable food, necessary medications, a battery-powered radio, and blankets or warm clothing somewhere easy to reach. If you use a portable power station for backup power, keep it charged and ready before an outage.
The Evergy outage map helps Kansas and Missouri customers check whether an outage has been reported. It also shows how many customers are affected and provides the latest restoration estimate. If your outage isn't listed, report it using the phone number for your service area. You can also use Evergy's online and mobile tools. Storms can delay restoration. High winds, thunderstorms, and fallen trees can damage several parts of the system at once. Save the right Evergy number before an outage occurs. Keep an outage kit ready, too. Backup power can also help you manage essential loads during a longer outage.
How do I report an Evergy outage?
You can report an Evergy outage by phone, online, or through the Evergy mobile app. Kansas Central customers can call 1-800-LIGHTKS, while Kansas Metro, Missouri Metro, and Missouri West customers can call 1-888-LIGHTKC.
What's the phone number for Evergy outages?
Kansas Central customers can call 1-800-LIGHTKS at 1-800-544-4857. Kansas Metro, Missouri Metro, and Missouri West customers should call 1-888-LIGHTKC at 1-888-544-4852.
What areas does Evergy serve?
Evergy serves customers across Kansas and Missouri, including the greater Kansas City metro area. Its service territories include Kansas Central, Kansas Metro, Missouri Metro, and Missouri West.
How long do Evergy outages typically last after a major storm?
There isn't one restoration time for every Evergy outage. Major storms can affect large numbers of customers and create multi-day restoration timelines in the hardest-hit areas. Restoration estimates can change as crews assess damage and begin repairs.
Does Evergy have a mobile app for tracking outages?
Yes. The Evergy mobile app provides access to outage information and reporting tools. It can be useful during an active outage because you can check updates and report a problem from your phone.
Power Outages
