Rhode Island Energy Rebates in 2026: What the Utility and the State Pay, and How to Track Your Check
Searching for "RI energy rebates" often leads to immediate confusion. The phrase can mean programs run by Rhode Island Energy, your local electric and gas utility. It can also refer to state-level programs managed by the Rhode Island Office of Energy Resources (OER).
Each entity operates its own funding pools, separate rulebooks, and dedicated application trackers. Filing paperwork with one entity will never show up in the database of the other.
This article sorts them into two clear columns. It lists the 2026 Rhode Island Energy amounts for heat pumps, heat pump water heaters, insulation, and gas equipment. It also shows exactly where to track a rebate. One practical note up front: a heat pump makes winter comfort depend on electricity. Outage backup is worth planning as its own line item.
Utility or State? Who Runs Each Rhode Island Rebate
Rhode Island Energy serves over 770,000 customers across Rhode Island through the delivery of electricity or natural gas. The utility operates as an official subsidiary of PPL Corporation.
Meanwhile, the Rhode Island Office of Energy Resources (OER) and Commerce RI run distinct state initiatives. These state programs rely on federal grants and regional carbon-allowance funding. A rebate filed with one agency will never appear in the other organization's tracking system.
Electric service territories also determine your eligibility. According to OER, Rhode Island Energy distributes electricity for 99 percent of the state. Block Island Power Company and the Pascoag Utility District serve the remaining areas. Residents living in Block Island or Pascoag cannot tap into Rhode Island Energy programs like ConnectedSolutions.
Program
Run by
Covers
Where to check status
Heat pump, heat pump water heater, gas heating, thermostat rebates
Rhode Island Energy
Equipment rebates
RIEnergy.com/trackstatus
Home energy assessment, insulation, air sealing
Rhode Island Energy
50 to 100% off insulation (up to $10,000) plus no-cost air sealing
Assessment line 888-633-7947
ConnectedSolutions (batteries)
Rhode Island Energy
Summer battery demand response payments
rienergy@energyhub.com
Home Electrification and Appliance Rebates (HEAR)
OER
Income-qualified electric upgrades
Energy.HEAR@energy.ri.gov
HOMES
OER
Multifamily (5+ units) efficiency
OER.Heatpumps@energy.ri.gov
Clean Heat RI (RGGI round)
OER
Low- and moderate-income heat pumps
portal.cleanheatri.com
Energy Storage Rebate (ESR)
OER
Batteries on Rhode Island Energy's approved list
OER (budget posted every two weeks)
DRIVE EV
OER
New and used EV rebates
Email updates from Energy.DriveEv@energy.ri.gov
Renewable Energy Fund small-scale solar
Commerce RI
Solar grants through installers
401-278-9100
State regulators actively monitor these utility budgets. The Rhode Island Public Utilities Commission approved Rhode Island Energy's 2026 Annual Energy Efficiency Plan (Docket 25-37-EE) under PUC Order No. 25582 on January 16, 2026. This regulatory order establishes utility budgets and energy savings targets rather than setting fixed equipment payouts.
Federal tax rules have also shifted significantly. According to the IRS, Section 25C covered eligible property placed in service from January 1, 2023 through December 31, 2025. Similarly, the IRS states that Section 25D is not available for any property placed in service after December 31, 2025.
Starting your journey usually begins with a professional assessment. Knowing what a home energy audit checks helps you prepare your home and maximize your savings before contractors arrive.
With the two administrative lanes clarified, here is what Rhode Island Energy pays for residential upgrades.
Rhode Island Energy Rebates for 2026: Heat Pumps, Water Heaters, Insulation, and Gas Equipment
Rhode Island Energy's current residential incentives prioritize cold-climate heat pumps and efficient water heaters. Strict equipment standards took effect on January 1, 2026. Most utility rebate claims must be submitted within 90 days of installation.
Rhone Island Energy Rebates for heat pump, water heater, insulationRhone Island Energy Rebates for heat pump, water heater, insulation
Heat pumps
The utility offers two primary rebate tracks based on your home's existing fuel source:
  • Standard rebate: Up to $625 per ton when replacing existing gas, oil, propane, or electric systems. Using a participating contractor is optional for this tier.
  • Enhanced rebate: Up to $1,500 per ton for homes switching from legacy electric baseboard heating. Work must be completed by an approved participating contractor.
  • Financing support: Qualified homeowners can access zero-interest heat loans up to $25,000 to finance remaining installation costs.
Technical standards are now considerably tighter. All heat pumps installed on or after January 1, 2026 must meet ENERGY STAR 6.1 Cold Climate criteria. In addition, systems using high-GWP refrigerants such as R-410A no longer qualify for rebates.
Be cautious when researching incentives online. Many third-party websites still list outdated 2024 rebates of $350 and $1,250 per ton. Always verify incentives against current 2026 utility filings.
Equipment
Rebate
Key rule
Heat pump water heater, 55 gal or less, UEF 3.3+
$625
Electric customers only; replacing an oil, propane, or gas water heater doesn't qualify; limit 2
Heat pump water heater, over 55 gal, UEF 2.7+
$150
Same
Gas furnace
$525
Gas heating form
Gas boiler
$775
Gas heating form
Combined boiler and water heater
$950
Gas heating form
Tankless gas water heater
$600
Gas heating form
ENERGY STAR storage water heater
$70
Gas heating form
ENERGY STAR smart thermostat
Up to $75 each, limit 2
Listed on the gas heating form
Fridge or freezer recycling
$50 each, up to 2 a year
Working unit; listed rate classes
Deadlines require strict attention. Both electric and gas forms cover installations completed between January 1 and December 31, 2026. Applications must be postmarked or submitted online within 90 days of installation. For water heaters installed during December 2026, the final submission deadline is February 28, 2027.
Home energy assessment and insulation
Before replacing equipment, Rhode Island Energy customers can book a no-cost Home Energy Assessment. Single-family homes and multi-family properties with up to four units qualify for significant weatherization assistance:
  • Receive 50 to 100% off approved home insulation improvements, capped at $10,000.
  • Get no-cost targeted air sealing to eliminate drafts and cold spots.
  • Call 888-633-7947 to schedule your baseline home energy assessment.
Income-eligible customers may qualify for 100% covered insulation, air sealing, and replacement appliances. Discount-rate electric customers heating with baseboard units might even receive a no-cost heat pump upgrade. Income-qualified households can call 401-351-1800 to review options.
Domestic hot water represents a major chunk of monthly utility bills. Reviewing how heat pump water heaters save energy clarifies why equipment efficiency and UEF ratings determine your rebate amount.
Switching to a heat pump introduces an important reality that rebate applications never mention. When a winter storm takes down the local power lines, your primary heating system shuts off too.
Planning Outage Backup After a Heat Pump Upgrade: EcoFlow TITAN 5000 With Smart Home Panel 10 (240V)
A heat pump can make your home more comfortable through a Rhode Island winter. But it also means your heating system depends on electricity. During an extended outage, your heat pump, electric water heater, and range may stop working unless you have suitable backup power.
Rhode Island Energy's efficiency rebates don't automatically cover a home battery. Treat backup power as a separate project, with its own equipment costs, electrical work, and installation requirements.
Why winter outages deserve attention
Coastal New England winters bring severe storm risks. According to the National Weather Service, nor'easters are most frequent and most violent between September and April. The NWS explicitly warns that a nor'easter can easily cut utility power and leave your home in the dark.
The National Weather Service also notes that heavy ice accumulations bring down large tree limbs and topple utility poles. When your home relies entirely on electricity for heat, an extended outage becomes an urgent safety issue.
Four checks before sizing your home backup system
Before purchasing any home battery backup system, work through these practical load calculations:
  1. Circuit voltage: Circuit voltage: Check whether target appliances run on standard 120V or heavy-duty 240V circuits. Outdoor heat pump condensers and electric ranges typically require 240V power. Heat pump water heaters are commonly 240V, but some models run on 120V, so verify the nameplate and circuit requirements for each unit rather than assuming by category. The EcoFlow TITAN 5000 delivers 120V/240V split-phase power natively through the Smart Home Panel 10 (240V).
  2. Starting and running wattage: Compare your equipment's operating wattage against the continuous 7,200W output of the battery unit. Manufacturer specifications do not publish a temporary surge rating. Because compressor startup draws vary widely, have a licensed electrician confirm that your specific heat pump can start safely on battery power.
  3. Required backup energy: Multiply the average power draw of your critical loads (W) by the hours you need coverage (h) to get the energy required (Wh). If you're starting from daily consumption (Wh/day), multiply it by the number of days of backup you need instead. A single EcoFlow TITAN 5000 battery holds roughly 5,000Wh of raw capacity. Up to six units can connect together to deliver 30,000Wh (30kWh) of whole-home capacity.
  4. Panel installation: Integrating a transfer system like the Smart Home Panel 10 (240V) requires a licensed electrician. Always get a formal quote for professional panel installation to include in your project budget.
Practical load sizing in cold weather
Consider this realistic storage estimate:
Usable energy = 5,017.6 Wh x 0.85 = 4,265 Wh.
A standard refrigerator consumes roughly 1,700Wh per day based on typical DOE EnergyGuide label ratings. That single refrigerator uses about 40% of one battery's daily output.
Running a whole-house central heat pump on a sub-freezing night requires significantly more energy. Size your backup setup strictly for critical sub-circuits unless you install multiple battery expansion packs.
Rooftop solar owners must also evaluate emergency recharging methods. Grid-tied rooftop solar inverters shut down instantly during blackouts due to utility anti-islanding regulations. To recharge off-grid, connect ground-mounted or standalone solar panels directly into the system's dedicated 4,000W DC input port. Winter sunlight hours remain limited, so do not assume full daily solar replenishment.
When backing up critical heating circuits, electrical voltage compatibility and hardwired panel connections matter most. The EcoFlow TITAN 5000 addresses these high-draw residential demands directly.
EcoFlow TITAN 5000
The EcoFlow TITAN 5000 serves homeowners seeking dedicated circuit security during unexpected seasonal blackouts. As a Tier 1 residential system, it is not on Rhode Island Energy's ConnectedSolutions supported products list, so it does not currently qualify for the state Energy Storage Rebate or ConnectedSolutions demand-response payments. Check the current list before you buy, since it can change. It should be purchased to back up selected home circuits rather than unconstrained whole-home heating.
Maintaining safety during severe winter weather requires broader planning beyond battery storage. Following a survival guide for winter storm outages ensures your household protects its plumbing, food supplies, and heating equipment safely.
After choosing your heating equipment and completing your installation paperwork, tracking your utility check comes next.
How to Check Your Rhode Island Energy Rebate Status
Rhode Island Energy processes utility equipment rebates through a centralized third-party clearinghouse. Wait approximately ten business days after sending your application before checking the online portal. Processing and check delivery usually take 8 to 10 weeks from the date a complete application is received.
How to track your utility rebateHow to track your utility rebate
Steps to track your utility rebate
  1. Submit your application: Start at Rhode Island Energy's rebate page and follow the instructions for your equipment. Applying online is the faster route. To apply by mail, send the completed form and required documents to P.O. Box 2528, Manchester, CT 06045, using the address block printed on your specific form.
  2. Organize documentation: Keep copies of your utility electric and gas account numbers, equipment model numbers, paid contractor invoices, and AHRI or ENERGY STAR certificates.
  3. Access the portal: After ten days, visit RIEnergy.com/trackstatus. The link redirects directly to the EFI Rebate Status Viewer.
  4. Resolve incomplete claims: If documentation is missing, the clearinghouse places the claim on hold. The 8 to 10 week processing timeline restarts once you supply the requested documents.
  5. Contact program representatives: Use the specific phone number printed on your original form. The 2026 heat pump water heater form lists 1-844-615-8315. For gas heating equipment, call 800-292-2032 or email rienergyrebate@AMConservation.com. General heat pump questions can go to 844-615-8315 or HVAC@CLEAResult.com.
Tracking state-administered rebates
State programs do not appear in the utility's status viewer. Check state initiatives through their direct administrative channels:
  • DRIVE EV: The program office communicates approval notices by email. Rebate checks arrive 4 to 6 weeks following final application approval.
  • HEAR Program: Requires formal OER pre-approval prior to purchasing equipment. There is no public self-service tracker; inquiries must be emailed to Energy.HEAR@energy.ri.gov.
  • Clean Heat RI: Applicants and registered contractors must log into the administrative portal at portal.cleanheatri.com to review project status.
Neighbors across the border work through a similar system, and comparing how Massachusetts solar incentives and Mass Save are structured shows why each state's tracker is separate.
Rhode Island Energy's tracker won't show anything from the state's programs, which have their own rules and, in some cases closed rounds.
State Programs: HEAR, Clean Heat RI, DRIVE EV, Solar Grants, and Storage
Rhode Island's Office of Energy Resources (OER) manages separate electrification programs financed through federal grants and regional carbon auctions. Many state programs enforce strict household income limits. Always confirm qualification standards before signing contractor agreements, as several programs require pre-approval.
HEAR (Home Electrification and Appliance Rebates)
The HEAR program launched on September 17, 2024, supported by roughly $31 million in federal funding. Funding remains active through September 2031, or until total program funds are exhausted.
An important rule change took effect on September 1, 2026. Equipment rebates are no longer available for switching from a fossil-fuel appliance to an electric model. To qualify, homeowners must replace an existing, inefficient electric appliance with an upgraded electric unit.
The state also operates a targeted Retail Pathway pilot, launched on May 4, 2026. This pilot is restricted to eleven Rhode Island municipalities:
  • Barrington, Bristol, East Providence, and Jamestown
  • Little Compton, Middletown, Newport, and Pawtucket
  • Portsmouth, Tiverton, and Warren
Upgraded Equipment or Measure
Low-Income (<80% AMI)
Moderate-Income (<150% AMI)
Electric wiring improvements
100% up to $2,500
50% up to $2,500
Load service center (breaker panel)
100% up to $4,000
50% up to $4,000
Heat pump clothes dryer
100% up to $1,600
50% up to $840
Electric or induction cooking range
100% up to $1,000
50% up to $840
Clean Heat RI
Clean Heat RI launched in September 2023 with $25 million in American Rescue Plan Act (ARPA) funding. In July 2025, OER and the Governor announced $10 million in new funding for a round supported by Regional Greenhouse Gas Initiative (RGGI) proceeds, with installations eligible starting July 21, 2025. Some ARPA-funded low-income projects were still being completed into early 2026.
As of OER's May 2026 updates, the program remains open exclusively to low- and moderate-income households. Qualifying homeowners can receive up to 60% of heat pump installation costs (capped at $11,500), or $2,500 for a heat pump water heater. Prior home weatherization is mandatory. Check portal.cleanheatri.com for active funding availability.
HOMES (multifamily)
Supported by approximately $32 million in federal funds, the HOMES program targets multifamily buildings with five or more attached dwelling units. To participate, 50% or more of those units must be occupied by low-income residents, defined as households earning under 80% of Area Median Income. Proposed retrofits must achieve at least 20% modeled energy savings.
DRIVE EV
The state provides direct point-of-sale or post-purchase rebates for passenger electric vehicles:
  • New vehicles: Up to $3,000 for battery-electric or fuel-cell vehicles; up to $2,000 for plug-in hybrids.
  • Used vehicles: Up to $2,500 for battery-electric models; up to $1,750 for plug-in hybrids.
  • Price ceilings: Purchase caps stand at $75,000 for new vehicles and $55,000 for pre-owned cars.
  • Filing window: Ensure all application materials are submitted within 120 days of the date of purchase or lease.
Renewable Energy Fund small-scale solar (Commerce RI)
Commerce RI administers small-scale residential solar grants through its Renewable Energy Fund. For 2026, application cycles opened on May 1, July 17, and October 16. Funding blocks close as soon as budgets are committed. Applications must be handled directly by your qualified solar installation contractor.
Energy Storage Rebate (OER)
OER oversees an Energy Storage Rebate with $2 million in dedicated funding. Tier 1 residential systems (rated at 25 kW AC or less) qualify for:
  • Standard rate: $250 per kWh of nameplate battery capacity, capped at $8,000.
  • Income-eligible rate: $500 per kWh of nameplate battery capacity, capped at $16,000.
To qualify for ESR, batteries must be brand-new, installed behind the utility meter, grid-connected, and listed on Rhode Island Energy's approved manufacturer register. EcoFlow systems are not included on that utility-approved list and do not qualify for ESR grants.
Homeowners can calculate combined savings across state, federal, and utility programs by visiting OER's official incentive calculator at energy.ri.gov/energy-incentives/incentive-calculator.
HEAR forms part of a broader federal push toward clean heating. Examining how HEEHRA rebates fund heat pumps provides valuable background on why income tiers and pre-approval rules govern these state offerings.
Rhode Island Energy offers heat pump rebates up to $625 per ton, or $1,500 per ton for eligible electric baseboard homes. Homeowners can also receive $625 for qualifying heat pump water heaters and 50% to 100% off eligible insulation. Meanwhile, OER manages separate programs, including HEAR, Clean Heat RI, and DRIVE EV. Submit your utility rebate application within 90 days. Check RIEnergy.com/trackstatus after ten days, and allow eight to ten weeks for payment.
If your new heat pump makes winter outages a bigger worry, see whether EcoFlow TITAN 5000 with Smart Home Panel 10 (240V) fits the circuits you'd keep running.
How do I check my Rhode Island Energy rebate status?
Wait about ten days after submitting your paperwork, then check RIEnergy.com/trackstatus. If anything looks missing or delayed, call the specific processing telephone number printed on your original application form.
How long does a Rhode Island Energy rebate take?
Processing and payment typically require 8 to 10 weeks after Rhode Island Energy receives a complete, signed application. If any contractor invoices or equipment efficiency certificates are missing, processing is paused until those documents are supplied.
What is the Rhode Island Energy heat pump rebate in 2026?
You can get up to $625 per ton standard, or $1,500 per ton when replacing electric baseboards. Equipment must meet strict ENERGY STAR 6.1 cold-climate criteria and avoid high-GWP refrigerants.
Is Clean Heat RI still open?
The original ARPA funding supported the program from its 2023 launch. A RGGI-funded round announced in July 2025 now serves low- and moderate-income households, with installations eligible from July 21, 2025. Check the official portal to see if active funding blocks remain.
Does a home battery qualify for Rhode Island rebates?
Rhode Island Energy's rebates don't cover home batteries. State Tier 1 storage rebates and ConnectedSolutions require batteries on Rhode Island Energy's ConnectedSolutions list, and EcoFlow isn't listed, so the EcoFlow TITAN 5000 doesn't qualify. Larger Tier 2 systems have separate criteria.
Home Solutions
