PECO Rebates for 2026: Fridge, Appliance, HVAC, and Water Heater Amounts Under the New Plan
- PECO Rebates in 2026: Phase V Dates and Current Amounts
- PECO Refrigerator Rebate vs Fridge Recycling: Two Separate Processes
- Keeping Your Refrigerator Running in a PECO Outage: EcoFlow DELTA 3 Max
- PECO HVAC Rebates: Heat Pumps, Mini-Splits, Central AC, and Tune-Ups
- Water Heater, Smart Thermostat, Marketplace, and Home Assessment Offers
- How to Apply for a PECO Rebate: Deadlines, Receipts, and Payment
- Conclusion
- FAQs
If you looked up PECO rebates a few months ago, the numbers you found may already be wrong. PECO's five-year Phase V efficiency plan began June 1, 2026, but individual rebate amounts can change during the plan. This guide gives you the current figures from PECO's own rebate forms. It clears up the most common mix-up, the new-fridge rebate versus fridge recycling. It also covers heat pumps, central AC, water heaters, and the 90-day claim window. Keep one thing in mind, too: an efficient fridge still stops when a storm knocks PECO's lines down.
PECO's rebates come from Pennsylvania's Act 129 efficiency program. It runs in phases of several years, and the Pennsylvania Public Utility Commission approves each one. Phase V covers five program years, June 1, 2026 through May 31, 2031. PECO serves about 1.7 million electric customers in southeastern Pennsylvania.
The Commission approved part of PECO's plan on March 26, 2026 (Docket M-2025-3057328). PECO filed its revised plan on April 30, 2026. Separately, PECO's current water heater rebate page lists $200 for an eligible natural gas tankless model and $50 for an eligible natural gas storage model. Use the current application terms to check your equipment and claim date.
Here's a quick look at current PECO energy rebates for homes, checked on October 21, 2026 against PECO's official application forms and program pages. Amounts and eligibility can change, so confirm the applicable terms before you buy.
Category | Item | Rebate |
Appliances | ENERGY STAR refrigerator | $20 |
Appliances | ENERGY STAR clothes washer | $25 |
Appliances | ENERGY STAR electric or gas dryer | $15 |
Appliances | Dehumidifier / air purifier | $25 each |
Thermostats | ENERGY STAR smart thermostat | $25 post-installation online rebate; $50 eligible instant rebate |
Heating and cooling | Air source heat pump | $200 or $300 |
Heating and cooling | Ductless mini-split | $150 or $300 |
Heating and cooling | Central AC | $150 or $200 |
Heating and cooling | Heat pump / central AC tune-up | $50 / $25 |
Water heating | Heat pump water heater | $350 |
Water heating | Gas tankless / gas storage | $200 / $50 |
Gas heating (PECO gas customers) | Furnace / boiler / conversion | $100 to $500 by type; conversion $400 |
To qualify for a PECO appliance rebate, the product must be new and installed at an eligible residence. PECO electric service is required for the listed electric appliances; the natural gas dryer instead requires PECO residential natural gas service. The appliance application excludes new construction and allows both tenants and owners to apply.
That first line in the table causes more confusion than any other. Buying a new refrigerator and disposing of an old one are separate processes with different rules.
Buying a qualifying new ENERGY STAR refrigerator earns a $20 PECO rebate. Recycling an old one is a separate disposal task. Do not assume a recycling payment is included in the new-appliance rebate.
The new-fridge rebate ($20)
PECO's Phase V appliance form lists the PECO refrigerator rebate as "ENERGY STAR Refrigerator $20." There's no size rule. And unlike some older PECO energy appliance rebates, you don't have to recycle your old unit.
You can claim the PECO fridge rebate by mail or online after you buy. Some participating stores take it off at checkout instead. If you get that instant discount, you can't mail in a second claim for the same fridge.
Per ENERGY STAR's refrigerator guide, certified models are about 9 percent more efficient than the federal minimum. A fridge over 15 years old could be costing you about $95 more a year to run.
Recycling an old fridge or freezer
What about the old fridge in your garage? Montgomery County's appliance recycling guidance says appliances containing refrigerants should go to a qualified handler, and some locations charge a fee. Confirm accepted appliances, refrigerant handling, and any pickup or drop-off fee with the provider before arranging disposal.
The county's guidance also notes that PECO's refrigerator collection program has been discontinued. Check PECO's appliance recycling page or call 888-573-2672 for current options, and use your county's disposal guidance for a full-size refrigerator or freezer. Do not budget for a pickup payment unless current program terms confirm one.
Before you replace your fridge, find out how many watts refrigerators use. Then compare that with the EnergyGuide label on the new model.
A more efficient fridge lowers your bill. But it still can't keep food cold once the power goes out.
An efficient fridge cuts how much power you need. A battery gives you power when the grid can't. PECO's appliance rebates don't apply to power stations, so budget for backup separately.
Why does this matter? FoodSafety.gov's power outage tips say a fridge keeps food cold for about 4 hours with the door closed. A full freezer holds its temperature for about 48 hours, or 24 hours if half full. Local outages can last far longer. The June 3, 2020 derecho is a good example. The NWS derecho event review says it left hundreds of thousands of customers in southeast Pennsylvania without power.
So how do you size backup for a fridge? Start with three checks:
Voltage: Plug a compatible 120V home fridge straight into the unit. Check the volts and amps on its nameplate.
Starting surge: Compressors draw a brief surge when they kick on. Compare your fridge's nameplate or manual with the station's surge rating.
Daily energy: A full-size fridge might use about 1.5 kWh a day. Your EnergyGuide label gives a better number.
EcoFlow DELTA 3 Max holds 2,048Wh. Some energy is lost in conversion, so multiply by 0.85 (a planning guess). That leaves about 1,740Wh. Divided by 1.5 kWh a day, that runs the fridge alone for about 1.2 days, or roughly 28 hours. Frequent door openings or extra loads will shorten it.
Recharging matters between outages, too. EcoFlow DELTA 3 Max reaches 0 to 80% in 68 minutes on AC, so you can top it up fast when power returns. Since a fridge puts the biggest demand on surge and stored energy, the card below leads with those.
EcoFlow DELTA 3 Max suits a home that wants to keep a few things on in a typical outage. Think a compatible 120V fridge, a Wi-Fi router, and lights. Check their combined running loads and starting surges against the unit's ratings. This fridge-backup example does not cover a central HVAC or whole-home heating system. Any connection to home circuits requires compatible equipment and a licensed electrician. PECO appliance rebates do not cover the power station.
When the lights go out, the PECO outage map and updates help you plan for hours or a full day. Next up are PECO's larger rebates. These are for heating and cooling, and they depend on system ratings.
Comparing heat pump quotes? PECO pays HVAC rebates by efficiency tier. It uses the system's AHRI whole-system rating, not the "up to" SEER2 number in an ad. Systems must be ENERGY STAR certified. Ask your contractor for the AHRI certificate before you buy.
The table below shows PECO rebates for eligible electric heating and cooling equipment. Check the central AC and air source heat pump form, ductless heat pump form, maintenance form, or ECM fan motor form for the full requirements that apply to your system.
Equipment | Requirement | Rebate |
Air source heat pump | 15.2 to 17.0 SEER2, 11.0+ EER2, 7.8+ HSPF2 | $200 |
Air source heat pump | 17.1+ SEER2, 11.0+ EER2, 7.8+ HSPF2 | $300 |
Ductless mini-split | 15.2 to 17.0 SEER2, 11.0+ EER2, 7.8+ HSPF2 | $150 |
Ductless mini-split | 17.1+ SEER2, 11.0+ EER2, 7.8+ HSPF2 | $300 |
Central AC | 15.2 to 15.9 SEER2, 12.0+ EER2 | $150 |
Central AC | 16.0+ SEER2, 12.0+ EER2 | $200 |
Heat pump tune-up | Invoice shows refrigerant check, filter, blower, coil cleaning | $50 (once per calendar year per system) |
Central AC tune-up | Same | $25 |
ECM fan motor | Propane and oil furnaces not eligible | $50 |
Contractors can apply for you through PECO's Trade Ally portal. Confirm local licensing and permit requirements with your contractor before installation; rebate eligibility does not replace those requirements.
PECO gas customers have their own list in the natural gas heating application. An eligible furnace earns $100 at 95.0 to 96.9% AFUE or $400 at 97% and up; both tiers also require no more than 2% air leakage and an ECM fan motor. An eligible boiler earns $250 at 90% AFUE and up, or $500 for a combi boiler at 94% and up that is the primary system for both space and water heating. The separate natural gas heating conversion rebate is $400 when the main or sole heating fuel is converted to natural gas, subject to that program's requirements.
The two heat pump styles qualify at different amounts. Compare mini-split and ducted heat pump costs to see which fits your house. It depends a lot on whether you have ducts.
Water heaters, thermostats, and a few smaller products round out the list. They pay less, but they're often the easiest to claim.
These offers are smaller, but several can be claimed instantly or online. Each water heater rebate requires you to replace an old unit. Marketplace prices change with store listings.
Water heaters
The water heater application lists $350 for an eligible heat pump water heater, $200 for a natural gas tankless model, and $50 for a natural gas storage tank. The unit must be new, ENERGY STAR certified, and replace an existing water heater. The home must receive PECO electric or natural gas service matching the equipment's fuel type. Complete one application per service address. Choosing an alternate electric supplier does not by itself disqualify you.
Read up on heat pump water heater wiring before you buy. Knowing whether yours needs 240V can save you a surprise electrician bill.
Smart thermostats and the PECO Marketplace
PECO's smart thermostat terms distinguish two offers: a $25 post-installation rebate available by online application only, or a $50 instant rebate at select Home Depot locations and through the PECO Marketplace. These are different claim channels, not rebate tiers based on your heating and cooling system. Check product and customer eligibility, and do not claim twice for the same purchase.
The PECO Marketplace offer page also lists $25 instant rebates on eligible air purifiers and dehumidifiers. Thermostat listings include brands such as Google Nest, ecobee, Amazon, and Sensi. Check the current Marketplace listings and eligibility on the day you buy.
Home energy assessments
PECO's Phase V plan includes home energy checks, both in person and online. Customers with lower incomes may qualify for a free assessment. Ask PECO about current options, eligibility, and prices before you book.
Post-purchase rebates require a timely application. Instant offers instead follow the terms at checkout, so first check which claim route applies.
For the appliance application, PECO must receive the claim within 90 days of purchase. Equipment programs may specify purchase or installation dates; follow the form for your category. For HVAC maintenance, the 90-day window starts on the maintenance date. Applying online is the fastest route listed on the forms. If approved, your check should arrive in 4 to 6 weeks.
Here's how to file a PECO rebate without missing a step. Follow these in order:
Confirm it qualifies. Check PECO service eligibility for the equipment's fuel type and the requirements for your rebate category. Qualifying HVAC equipment also needs the whole-system AHRI rating in the right tier.
Keep your receipt. It must be paid and show the model number, manufacturer, purchase price, and purchase date.
Choose how to apply. You can start at PECO's rebates and discounts page. You can also email pecohomerebates@cmcenergy.com. Or mail it to PECO Home Rebates, 16350 Felton Road, Lansing, MI 48906.
Submit within the applicable 90-day window. Use the purchase or installation date specified by your equipment form, or the maintenance date for an HVAC tune-up. Online or by mail, PECO must receive the application in time.
Watch for your check. Expect it in 4 to 6 weeks, and call 888-5-PECO-SAVE (888-573-2672) with questions.
The PUC's Phase V guidance permits a maximum application period of 180 days, but that does not extend PECO's published 90-day deadlines. For storm season, the PECO customer handbook explains how to report an outage online, enroll in two-way texting at 697326, or call PECO 24/7 at 1-800-841-4141. For downed lines or immediate danger, call 911 first.
Phase V runs June 1, 2026 to May 31, 2031. Current PECO rebates include $20 for an eligible ENERGY STAR refrigerator and $15 to $25 for laundry appliances. Heat pumps and central AC earn $150 to $300, and an eligible heat pump water heater earns $350. Arrange old-appliance recycling separately. Submit post-purchase or maintenance claims within the applicable 90-day window with the required paid receipt. Want your fridge covered in outages too? Compare its nameplate load with EcoFlow DELTA 3 Max to see if it fits.
Does PECO give a rebate for a new refrigerator?
Yes. PECO pays $20 for a new ENERGY STAR refrigerator, and there's no size rule. Apply by mail or online, or take the discount at a participating store. PECO won't pay twice for the same fridge.
How much does PECO pay to recycle a fridge?
Do not assume a payment is available. Montgomery County's recycling guidance notes that PECO's refrigerator collection program has been discontinued. Check PECO's current recycling information and your local disposal options before arranging a pickup; fees and accepted appliances depend on the provider.
What HVAC rebates does PECO offer?
Air source heat pumps earn $200 or $300, and ductless mini-splits earn $150 or $300. Central AC earns $150 or $200, and yearly tune-ups pay $50 for a heat pump or $25 for central AC. Your tier depends on the system's AHRI rating.
How long do I have to submit a PECO rebate?
For appliance purchases, PECO must receive the application within 90 days of purchase. Other equipment forms may use the purchase or installation date. For HVAC maintenance, count 90 days from the maintenance date. Check the applicable form and allow time for mailed claims.
How long does a PECO rebate take?
Approved checks should arrive in 4 to 6 weeks. Your receipt should show the model number, maker, price, and date. That keeps things moving.
