EPA vs CARB: What the Two Emission Standards Mean When You Buy a Generator
You're comparing two portable generators online. Same wattage, same frame, almost the same price. One listing says "EPA." The other says "CARB compliant" and costs a little more. So what's the difference? Both labels are emissions certifications for small gas engines, but they come from different agencies with different rules. California's rules are also changing fast, and a federal review in 2026 added a new twist. Below, you'll find a side-by-side look at EPA vs CARB, how to check a label, California's timeline, and the one safety risk neither label covers.
EPA vs CARB: Who Sets the Rules for Small Engines
The U.S. Environmental Protection Agency (EPA) sets nationwide exhaust and evaporative standards for small gas engines. The California Air Resources Board (CARB) sets its own, stricter standards for engines sold in California. A generator can carry one certification or both.
EPA's rules in 40 CFR Part 1054 cover new nonroad spark-ignition engines rated at or below 19 kW, which includes most portable generators. Manufacturers need a separate certificate of conformity for each engine family, and each certificate covers one model year.
CARB calls these engines Small Off-Road Engines, or SORE. It uses the same 19-kilowatt line, and equipment needs CARB certification before it can be sold new in California. Here's how the EPA vs CARB certification systems compare:
EPA
CARB
Where it applies
New engines sold anywhere in the US
New engines sold in California
Engines covered
Spark-ignition engines at or below 19 kW
Small off-road engines at or below 19 kW
Proof of approval
Certificate of conformity
Executive Order
Where to look it up
EPA's Small NRSI Engine Certification Data
CARB's Executive Orders database
Where it's headed
Phase 3 limits stay in place
Generator standard set to reach zero in model year 2028
What EPA's Phase 3 Limits Look Like
EPA groups nonhandheld engines, like the ones in most portable generators, by size. Class I engines are under 225 cc. Class II engines are 225 cc and up. The Phase 3 limits cap hydrocarbons plus nitrogen oxides (HC+NOx) at 10.0 grams per kilowatt-hour for Class I and 8.0 for Class II. Carbon monoxide is capped at 610 grams per kilowatt-hour for both.
These numbers matter because they show how EPA works. It sets a ceiling for each engine class and lets manufacturers prove they stay under it. CARB starts from the same idea but sets tighter limits, and for generators, it's moving toward a limit of zero.
California's changes are why many buyers start asking about these labels. If you live there, it helps to know the alternatives as California restricts generators. Either way, both systems show up on the engine label.
What Is CARB Compliant? Reading and Checking a Generator's Label
"CARB compliant" means the engine and equipment family hold a CARB Executive Order for sale in California. It doesn't mean the generator is emission-free, quiet, or safe to run indoors.
How to Check EPA vs CARB Certification on a Generator
A product page badge is only a claim. In any EPA vs CARB generator comparison, you can confirm both labels yourself.
To check EPA certification:
  1. Find the "EMISSION CONTROL INFORMATION" label on the engine. It shows the manufacturer, engine family, build date, and emission compliance period in hours.
  2. Search that engine family in EPA's Small NRSI Engine Certification Data report, which is updated daily.
To check CARB certification:
  1. Search CARB's Executive Orders for off-road spark-ignited engines and equipment.
  2. Pick the right category: SSIE-EXH (exhaust), SSIE-EVAP (evaporative), or SSIE-ZE (zero emission).
  3. Confirm the Executive Order matches the brand and engine family of the unit you're buying.
"50-state" isn't a legal term. It's shorthand for a unit that holds both EPA certification and a CARB Executive Order, so it can be sold new anywhere.
What a CARB Label Doesn't Tell You
A CARB label answers one question: can this engine be sold new in California? It doesn't tell you how loud the generator is, how much fuel it burns, or how long it runs on a tank. Many CARB-certified units are inverter models, but the label says nothing about power quality.
The label also says nothing about indoor safety. A CARB-compliant engine still produces carbon monoxide, so the same placement rules apply to every gas generator. Treat the label as one item on your checklist, not the whole decision.
Buying vs. Using
According to CARB's small engine FAQ, California residents can keep using, servicing, and repairing their gas equipment for its useful life. Stores may also keep selling existing inventory that's CARB-certified.
What About Other States?
For generators, "CARB states" lists don't hold up. CARB's FAQ says federal law bars other states from adopting California's standards for spark-ignition engines under 50 horsepower.
What SORE Doesn't Cover
CARB says SORE excludes larger portable generators, stationary generators, and diesel engines. So a home standby generator falls outside it, though local air district rules can still apply. If your real need is a fridge and router through a short outage, a battery may be the simpler fix.
When Your Backup Needs Are a Fridge and Wi-Fi: A Battery Option With No On-Site Fuel
If you mainly need a refrigerator, a Wi-Fi router, and a few lights through a shorter outage, a battery power station can do it with no fuel burned at your home. It isn't an engine, so engine certifications don't apply. CARB's FAQ says manufacturers "are not required to certify battery electric equipment."
A battery won't run endlessly like a fueled generator, so when it runs down, you recharge it. That's why sizing comes first.
Size by Load, Then by Runtime
  • Refrigerator: An ENERGY STAR certified 17.6 cu. ft. top-freezer model (Conservator GRHS1762T) is rated at 360 kWh per year, about 0.99 kWh per day.
  • Router: The eero 7 lists typical use of 7W, about 0.17 kWh per day.
  • Both together: About 1.16 kWh per day.
The EcoFlow DELTA 3 Max stores 2,048Wh. If you plan for about 15% conversion losses, that leaves roughly 1,740Wh, or about 1.5 days for the fridge and router together. A bigger or older fridge shortens it, so check your EnergyGuide label, and compare your fridge's starting load with the unit's 4,800W surge rating.
How to Run the Numbers for Your Own Home
Your own appliances may use more or less than this example. Start with the yellow EnergyGuide label on your fridge. It lists estimated yearly energy use in kWh. Divide that number by 365 to get a daily figure. For smaller devices, check the label watts and multiply by the hours you expect to run them each day.
Add those daily totals together. Then compare the total with the usable capacity of any battery you're considering. If the number comes out close, pick a bigger battery or plan to recharge more often. Also remember that fridges and other motors draw extra power for a moment when they start. That's why the surge rating matters as much as the capacity.
On AC power, it recharges from 0 to 80% in 68 minutes, so plan how you'll recharge during longer outages. The card below shows what the EcoFlow DELTA 3 Max adds in capacity, surge, and recharge speed.
EcoFlow DELTA 3 Max (2048Wh)
•2,400W Output: 4,800W surge. X-Boost mode can run some higher-wattage appliances up to 3,400W, though it works by lowering voltage, so results vary by device. • Fast Recharging: 4 ways to charge, reaching 0 to 80% in 68 minutes with wall or generator charging. • Easy to Carry: About 44.8 lb (20.3 kg), 13% lighter than EcoFlow's previous 2kWh model. •10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit. •Warranty: Up to 5 years (3-year standard plus a 2-year extension when you register in the EcoFlow App).
The EcoFlow DELTA 3 Max fits short outages and plug-in essentials. It won't replace a fueled generator for multi-day whole-house loads, central AC, or well pumps. Comparing gas generators and power stations can help you decide. For California gas buyers, the bigger question is what changes next.
California's Zero-Emission Timeline for Small Engines and Portable Generators
CARB's 2021 amendments originally scheduled most new small engines to go zero emission in 2024, with a slower phase-in for portable generators. The rules needed EPA authorization first, so full implementation came later. A 2026 federal review adds more uncertainty.
  • December 9, 2021: CARB approves the amendments. As adopted, most new small off-road engines were scheduled to be zero emission starting in 2024. Portable generator standards were set to become 40 to 90 percent more stringent starting in model year 2024.
  • January 5, 2025: EPA authorizes CARB's SORE regulations, according to CARB's FAQ.
  • Early 2025: With supply short after the Los Angeles wildfires, CARB lets sellers offer 49-state portable generators for six months.
  • Model year 2026: Because the 2025 model year was already underway, CARB defers full implementation to model year 2026. Gas engines and equipment have been certified for model years 2026 and 2027.
  • Model year 2028: Emission standards for smog-forming emissions from new engines are set at zero. CARB says it will keep certifying gas-powered SORE through 2032, and manufacturers may use emission reduction credits to certify engines until then.
  • June 12, 2026: EPA sends the SORE authorization to Congress for Congressional Review Act review, per CARB's FAQ.
  • August 5, 2026: Senate resolution S.J.Res. 205, which would disapprove the authorization, is introduced and referred to committee. A House version, H.J.Res. 214, also exists.
As of October 2026, CARB's rules remain in place while Congress considers a disapproval resolution. Check the status again before you buy.
Why is CARB stricter? CARB says smog-forming emissions from small engines have surpassed emissions from light-duty passenger cars. CARB's FAQ adds that in 2020, portable generators made up 14% of SORE equipment and 19% of SORE NOx and ROG emissions.
What This Means If You're Shopping Now
If you live in California, look for a generator that holds a current CARB Executive Order, and confirm it in CARB's database before you pay. Stores can still sell existing CARB-certified inventory, so you may still find gas models on the shelf. If you already own a compliant generator, you can keep using, servicing, and repairing it for its useful life.
Outside California, EPA certification is what a new generator needs. Still, it's worth watching the federal review. If Congress passes the disapproval resolution, the rules for new sales in California could change.
A room-by-room power outage guide puts the equipment choice in context. Neither label, though, addresses carbon monoxide, the hazard that hurts the most people.
What Neither Label Covers: Carbon Monoxide Safety
EPA and CARB standards limit smog-forming emissions. They don't make an engine safe indoors. Carbon monoxide (CO) is colorless and odorless, so placement is what protects your household.
Carbon Monoxide AwarenessCarbon Monoxide Awareness
Where to Place a Gas Generator
A CPSC safety warning from February 2026 says nearly 100 people die in the U.S. each year from CO poisoning caused by portable generators. CPSC's advice:
  • Never run a portable generator inside a home, garage, basement, crawlspace, or shed. Opening doors or windows won't provide enough ventilation.
  • Run it outside only, at least 20 feet from the house.
  • Look for models with a CO shut-off safety feature.
  • Install battery-operated CO alarms, or alarms with battery backup, on each level of your home.
Where Federal Generator Safety Rules Stand
CPSC's portable generator safety standard is still only proposed. Its April 20, 2023 proposal included a weighted CO limit and shutoff. Its Fall 2025 agenda says staff are weighing voluntary UL and PGMA standards.
Until a final rule arrives, a CO alarm is your backstop. Place one on each level of your home, as CPSC recommends, and replace the batteries regularly. Before storm season, test your alarms and review this guide to carbon monoxide safety and alternatives.
The EPA vs CARB difference comes down to who certifies the engine. EPA covers small gas engines nationwide, while CARB covers California with stricter limits that reach zero for generators in model year 2028, pending a federal review. Before you buy, check the label and search the agency databases. After you buy, run any gas generator outside, at least 20 feet from the house. If your outage needs are mostly a fridge and Wi-Fi for shorter stretches, see whether the EcoFlow DELTA 3 Max fits those loads.
What does CARB compliant mean?
It means the engine and equipment family holds a CARB Executive Order, so the generator can be sold new in California. It doesn't mean the unit is emission-free, quiet, or safe indoors. You can confirm the claim by searching CARB's Executive Orders.
Is CARB stricter than EPA?
Yes. Under the amendments CARB adopted in 2021, portable generator standards were originally scheduled to become 40 to 90 percent more stringent in model year 2024. However, CARB later deferred full implementation to model year 2026 after EPA authorization. As adopted, the smog-forming emission standards reach zero in model year 2028. EPA's Phase 3 limits remain in place nationwide. See CARB's current SORE FAQ for the implementation history.
Can I use a non-CARB generator in California?
CARB's rules cover new sales, not equipment you already own, so California hasn't banned gas generators. CARB says residents can keep using, servicing, and repairing their gas equipment for its useful life. If you're bringing a non-CARB unit in from another state, contact CARB first.
Do other states require CARB generators?
No. CARB says federal law bars other states from adopting California's standards for spark-ignition engines under 50 horsepower, and no state has had that option for more than 20 years. Outside California, a new generator needs EPA certification.
Are home standby generators covered by CARB's small engine rules?
No. CARB says stationary generators and larger portable generators aren't part of its SORE rules. Your local air district may have its own requirements, so check before installing one.
Do battery power stations need EPA or CARB certification?
No. A battery power station has no engine, so EPA and CARB engine certifications don't apply to it. CARB's FAQ says manufacturers "are not required to certify battery electric equipment." Instead of an emissions label, compare battery units by capacity, output, surge rating, and recharge time.
Home Solutions
