Pagosa Springs Flooding: What Happened, How to Stay Safe, and Keeping Phones Powered
For the second October in a row, the San Juan River has pushed into Pagosa Springs. This time it rose just over 15 feet at the town gauge. That's higher than last year's flood. Homes were cleared. Bridges closed. Sewer lines broke. Do you live in Archuleta County or have family there? Then you need clear facts from official sources. This guide covers the Pagosa Springs flooding timeline and where to get alerts. It also covers safe water, wells, and how to keep phones and lights on.
What Happened During the October 2026 Pagosa Springs Flooding
Days of heavy rain sent the San Juan River and nearby rivers over their banks in late October 2026. The Town of Pagosa Springs update says the river peaked at just over 15 feet. That was around 5:30 a.m. on Friday, October 23. Local and state leaders had declared emergencies the night before.
Pagosa Springs Flood Timeline
Date (2026)
What happened
Official source
Oct 22
Town declares a local disaster. Gov. Polis declares a state disaster at 8:36 p.m.
Town of Pagosa Springs; Colorado Governor's Office
Oct 23
River peaks just over 15 feet around 5:30 a.m. Flood areas must leave.
Oct 24
Hermosa and San Juan streets can return home. US 160 to Durango reopens, one lane at a time in Aspen Springs.
Oct 27
State and FEMA start a damage review.
Key Details From the Pagosa Springs Flood
People in low areas along the San Juan, Rio Blanco, Navajo, and Piedra rivers had to leave. The governor's order covered Archuleta and other southern counties. It also called in the National Guard. Last year's flood, in October 2025, peaked at 12.82 feet on the USGS gauge (site 09342500). That was the third-largest on record, per Western Water Assessment. Gauge data are early readings and can change. Still, the numbers show Pagosa Springs flooded worse this time.
Why do floods keep coming back? Heavier downpours and more homes in low areas are two reasons US flooding keeps getting worse.
The ground is still soaked. So it helps to know where the next alert will come from.
Evacuation Orders, Alerts, and Road Closures
Archuleta County and the Town send safety alerts by text. Roads and bridges can close fast while crews check for damage. Sign up now, even if the river has dropped.
How to Get Pagosa Flooding Alerts
  • Archuleta County Nixle: Text 81147 to 888777. This is the main source for orders to leave.
  • Town updates: Text "PagosaSprings" to 38276.
  • Roads: Check COtrip.org. As of October 27, parts of North Fifth Street and South Sixth Street are still closed "for the foreseeable future."
  • Weather: NWS Grand Junction issues local forecasts and warnings.
Wet ground means new rain could bring more flooding. Never drive, walk, or go around a barricade. The National Weather Service safety page says "a mere six inches of fast-moving flood water can knock over an adult." Two feet of rushing water can carry away most cars.
If an Evacuation Order Comes
  1. Leave right away.
  2. Grab your meds, papers, phone chargers, and pets.
  3. Use the routes officials give you.
  4. Don't go back until officials say it's safe.
It helps to practice what to do during evacuation. Then your family can leave fast and not forget meds or pets.
Once you're back in a dry home, the next job is staying in touch while power and roads come back.
Keeping Phones, Lights, and a Fridge Running Safely After the Flood
A flood can cut power even in homes the water never reached. A charged power station can keep phones, a router, and lights on while you watch for alerts. But it has one hard rule. Keep it far from floodwater.
Safety Steps Before Using Backup Power
Don't go back inside until officials say it's safe. Make sure the power is off at the panel. Leave wiring repairs to a licensed electrician. Never run a power station in standing water. Never plug in a device that got wet. Keep the unit and its cords off wet floors, too. The Town says floodwater may carry sewage.
Pagosa Springs sits at about 7,000 feet, and October nights get cold. Charge your unit in a warm room, not a garage or car.
Home Comfort During Power OutagesHome Comfort During Power Outages
Protecting Food in the Fridge and Freezer
What about the food in your fridge? FoodSafety.gov outage tips say a closed fridge keeps food cold for about 4 hours. A full freezer holds for about 48 hours if you keep the door shut.
Choosing a Power Station for Phones, Lights, and a Fridge
After a flood, staying in touch comes first. Light and safe food come next. EcoFlow power stations store power ahead of time and run indoors with no fumes. That matters when a home is still drying out.
Maybe you just need to read Nixle texts, keep the router on for insurance calls, and light a dark hall. A 1kWh unit is often enough for that. It's light enough to carry to a dry room upstairs, and the EcoFlow DELTA 3 Classic fits this job.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
Some homes need more than phones and lights. Saving groceries takes a bigger battery. Check each device's label to size it, and the EcoFlow DELTA 3 Max gives you that extra room.
EcoFlow DELTA 3 Max (2048Wh)
•2,400W Output: 4,800W surge. X-Boost mode can run some higher-wattage appliances up to 3,400W, though it works by lowering voltage, so results vary by device. • Fast Recharging: 4 ways to charge, reaching 0 to 80% in 68 minutes with wall or generator charging. • Easy to Carry: About 44.8 lb (20.3 kg), 13% lighter than EcoFlow's previous 2kWh model. •10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit. •Warranty: Up to 5 years (3-year standard plus a 2-year extension when you register in the EcoFlow App).
How Long Will It Last? (Estimates)
These are rough guesses. Take the battery size (Wh), multiply by 0.85 for losses, and divide by the load (W). Check each device's label.
Example load
DELTA 3 Classic
DELTA 3 Max
Phone charging, router, and two LED bulbs (about 40W)
About 21 hours
About 43 hours
Same, plus a fridge that averages about 46W (about 400 kWh a year on its EnergyGuide label)
Not advised
About 20 hours
The fridge number is a yearly lab average. Real use changes with room heat and how often you open the door. A fridge also pulls more power when it starts. Does someone in your home rely on medical gear? Get a plan from their provider. Check the device maker's battery advice, too. Don't count on one battery alone.
Power is one part of recovery. Safe water is a bigger one, mainly for homes on private wells.
Drinking Water, Floodwater, and Private Well Safety
Floodwater around Pagosa Springs may be dirty. The Town reported flooded sewage pump stations and a broken sewer line. Treat any water that touched the flood as unsafe until you know it's clean.
During the flooding in Pagosa Springs, Colorado, three sewage lift stations and one pump station went under. Waste spilled, and the Town reported it to state and county health officials. The Town says, "Residents should avoid contact with floodwaters due to possible sewage contamination." As of October 27, the sewer system is stable. Still, try to use less water. Space out laundry and dishes. Follow boil-water orders only from your water provider.
Flooding Impacts Local Sewer SystemsFlooding Impacts Local Sewer Systems
If You're on a Private Well
On a private well? Assume the water isn't safe yet. The CDC's well-disinfection guidance says to drink bottled water after a disaster until you're sure the water is safe. Have a well or pump contractor inspect and disinfect the well, then arrange follow-up testing for total coliform and E. coli or fecal coliform bacteria before drinking it.
Have questions about testing? Call your local health office or CDPHE ToxCall at (303) 692-2606.
It's easier to stay safe when you store water before the river rises. Bottled water is a basic step in preparing your home for floods. It pays off when your well is in doubt.
Once the water is handled, most Pagosa homes face cleanup next.
Cleanup and Recovery Help in Pagosa Springs
Cleanup has its own risks. There may be hidden wiring damage or old building materials. The Town and county have set up debris sites and help lines. Use these before you hire anyone.
Stay Safe During Cleanup
Don't enter a flood-damaged building until officials say it's safe. Floors can give way, and ceilings can fall. Using a generator? The CDC says never run it inside a home, garage, or carport. Keep it outside, at least 20 feet from doors, windows, and vents. Older homes have one more risk. Drywall tape or joint compound may contain asbestos, so let trained pros remove it.
Where to Take Debris and Find Help
The Town's debris and help page lists these sites. Check the hours first.
Site
What it takes
South Yamaguchi, 976 S. 5th Street
Wood debris from town homes only
CSU Extension Office, 344 B Highway 84
Wood debris from county homes only
Archuleta County Landfill, 9179 County Road 500
Appliances, damaged items, and drywall kept apart
Need more help? Call 211 Colorado at 2-1-1, text 898-211, or visit 211colorado.org. The Crisis Cleanup Hotline at 970-283-7325 links you with free volunteer cleanup. Help isn't promised, though, since demand is high.
FEMA's review covers public roads and systems. It doesn't give aid straight to residents. The Town says the review "does not mean federal assistance has been approved" for flooding in Pagosa Springs, CO.
Mountain flash floods move faster than river floods on the plains. Knowing your inland flash flood risk helps you decide what to move upstairs before the next storm.
The October 2026 Pagosa Springs, Colorado flooding pushed the San Juan River past 15 feet. It brought emergency orders and sewer damage. Sign up for Nixle and Town alerts. Stay out of floodwater. Test private wells and use official help lines. To stay in touch during an outage, an EcoFlow DELTA 3 Classic covers lights, phones, and a router. An EcoFlow DELTA 3 Max adds a fridge. Keep either dry and charged before storm season.
How high did the San Juan River get in Pagosa Springs in October 2026?
The Town of Pagosa Springs says the river peaked just over 15 feet at the town gauge. That was around 5:30 a.m. on October 23, 2026. USGS gauge data are early readings and can change.
Is this flood bigger than the 2025 Pagosa Springs flood?
Yes, based on official numbers. The October 2025 flood peaked at 12.82 feet on the USGS gauge. The Town reported just over 15 feet in 2026.
Where can I get Pagosa Springs flood alerts?
Archuleta County's Nixle system is the main source. Text 81147 to 888777. For Town updates, text "PagosaSprings" to 38276. Check COtrip.org for roads.
Is my well water safe after the Pagosa Springs flood?
Assume it isn't until it has been properly treated and tested. The CDC recommends bottled water after a disaster until the water is confirmed safe. Have a well or pump contractor inspect and disinfect the well, then arrange follow-up bacterial testing with local health officials.
Can I run a power station in a flooded basement?
No. Keep any power station, including the EcoFlow DELTA 3 Classic, in a dry room far from water. Never plug in devices that got wet.
Power Outages
