Inland Flash Floods: Is Your Home at Risk?
Inland flash floods can happen at any moment. From intense bouts of rainfall to poor drainage within your city, these floods pose a serious risk to homeowners and can cause tremendous structural damage to properties in their wake.
While these floods are unpredictable and can occur at any time, there are many ways you can prepare your home in case a disaster were to strike. Below, we dive into the important facts you need to know to better understand your specific flood risk, as well as the steps you should take to keep you and your loved ones safe.
Understanding Inland Flood Risk and Map Designations
When buying your home, you may have noticed that your property was designated to be in a specific flood zone. These zones are ever-changing and ultimately highlight the probability of flooding in your general location.
There are many different zone levels, though the highest risk zones are known as SFHAs, or Special Flood Hazard Areas. These locations are more likely to flood on an annual basis than lower-risk areas and typically require homeowners to have some level of flood insurance for their property.
Lower-risk zones, also known as Zones B, C, and X, still stand a chance of annual flooding, though the probability is much lower, and flood insurance is more of a recommendation rather than a requirement.
How Frequent Flooding Impacts Homes and Who Is Affected
Frequent flooding is a frightening phenomenon that causes structural damage and harms the foundational integrity of buildings over time. Mold, wood rot, and electrical damage are the primary concerns when it comes to frequent flooding.
Homeowners who live in coastal regions or in low-lying, flood-prone zones are most commonly affected by flash flooding. People living in these areas may be faced with hefty repair costs and expensive insurance policies just to keep their homes as safe as possible in the midst of being located in a zone that floods frequently.
EcoFlow DELTA 3 Max Plus
Insurance Realities: Do You Need Flood Coverage?
A general homeowners insurance plan will not cover flood damage, so in some cases, it may be worth your while to consider adding on some type of flood coverage. That being said, you should always talk to your agent to get a better understanding of your risk levels, such as whether you live in a designated flood zone or not.
Some zones may require you to carry this level of coverage to account for the heightened flood risk, though in many cases it may be recommended, but not required.
Assessing Your Property's Exposure: Elevation, Sources, and Exposure
Not all properties are created equally, and some may be more prone to the damage of flash floods than others.
A first step into understanding your property’s potential exposure to the damages of flash floods comes from taking a look at your elevation. Low-lying areas that are at or below ground level have a much higher probability of flooding. Properties that are more elevated can still flood, though they will stand a better chance of facing minimal damage.
Another important factor to take into consideration is how close you are to flooding sources. Lakes, creeks, and retention ponds can quickly overflow and flood surrounding areas, so be aware of your property’s proximity to these danger zones.
DELTA 3 Max Plus Portable Power Station
The EcoFlow DELTA 3 Max Plus delivers 3000W of reliable power (6000W surge) with X-Boost™ to handle heavy-duty appliances. Charge to 80% in just 43 minutes, expand up to 10kWh, and control circuits smartly via the app. Durable, whisper-quiet, and backed by up to 5 years of warranty, it’s power you can count on anywhere.
Safety First: What to Do During Inland Floods
  • Avoid Standing Water: Floodwater is inherently dangerous because you cannot see what is inside it. Keep your distance from any standing water and downed power lines, and do your best to pass this message along to anyone you may come in contact with.
  • Seek Higher Ground: Flash floodwaters can move very quickly, so it is always best practice to get as high as you can. Don’t be afraid to leave your house to seek higher ground if water were to make its way into your home.
  • Stay Together: In the commotion and chaos of a flash flood, it can be easy to panic. Do your best to stay calm and on top of the situation by keeping track of your family members. Stay high and dry until it is safe to relocate.
  • Secure Backup Power: Have a portable power station like the EcoFlow DELTA 3 Max Plus handy; you’ll be able to keep your essential appliances running if the power goes out.
Are You Safe in Your House During a Flash Flood?
Staying in your home does not guarantee your safety during a flash flood. These natural disasters happen very quickly, and water can make its way into your home before you know it. Be on the lookout for signs of rising water and don’t be afraid to move if necessary.
Will FEMA Pay for a Flooded House?
If you are located in a designated federal disaster zone, there’s a good chance that you will qualify for FEMA assistance if your house were to flood. That being said, this coverage is not guaranteed and should not be relied on without first doing the proper research to understand if you live in a qualified area.
Should I Worry About a Flash Flood Warning?
If you have received a warning that flash flooring is imminent, you should take action immediately. As the name suggests, flash floods move very quickly and leave little time for you to prepare. Practice an emergency escape plan and ensure your entire family is prepared in case flooding conditions worsen.
Ready To Prepare Your Home for Inland Flash Floods With EcoFlow Portable Power Stations?
The possibility of flash floods is frightening and should be taken seriously, especially if you live in low-lying, flood-prone areas. With the tips above, you can absolutely keep you and your family safe even if a disaster were to strike.
Don’t hesitate. Now is the perfect time to equip your home with backup power systems for the rainy season. EcoFlow’s DELTA 3 Max Plus will give you peace of mind and reliable access to power all year long.
Home Backup
