How to Choose a Fish Finder Battery: Voltage, Amp Hours, Lithium vs Lead Acid, and Recharging at Camp
The screen goes dark halfway through the morning bite, a mile from the launch. The right fish finder battery is not the biggest one. It matches the unit's voltage range, holds enough amp hours for a full day, survives spray, and gets recharged correctly between trips. This article covers the specs to read on the unit, a simple sizing formula with a worked example, lithium vs lead acid, safe wiring with a fuse, and how to top up the battery at a campsite with no outlet.
What a Fish Finder Battery Needs to Match
Most small fish finders run on 12V DC. That power comes from a dedicated battery or the boat's own system. The best starting point is the unit's specification page or manual, not a battery ad. A fish locator battery has to satisfy three numbers on that page.
Fish finder screen displaying voltageFish finder screen displaying voltage
  • Input voltage range: The battery's voltage has to fall inside this window.
  • Current draw: Measured in amps, this figure drives the runtime math below.
  • Fuse size: The maker lists the fuse rating that protects the wiring and the unit.
Not every fish finder runs on 12V, so readers should check their own model's range first.
Example: what one maker lists
The Garmin STRIKER Vivid owner's manual shows what a spec page lists.
  • Voltage and current: Input voltage runs from 12 to 20 Vdc, with a rated current of 1.5A.
  • Fuse: The manual calls for a 3A, 250V fast-acting fuse.
  • Water rating: The manual rates the fish finder itself IPX7. That means it withstands incidental exposure to water up to 1 m for up to 30 minutes. The rating covers the display unit only. It does not cover the battery or its connections.
Typical draw is usually lower than the rated current. The maker's spec page for the exact model lists it.
Battery types for fish finders
Fish finder batteries fall into three common groups, and each fits a different kind of trip.
Battery type
Typical use
Charging
Watch out for
Sealed lead acid (SLA / AGM), small 12V
Low-cost portable fish finder kits
Lead-acid charger matched to the battery
Heavier for the same capacity; deep discharges shorten life
Lithium iron phosphate (LiFePO4), small 12V
Kayaks and ice fishing where weight matters
LiFePO4-compatible charger (Dakota Lithium: 14.4V recommended)
Charge only within the maker's temperature range (Dakota Lithium: 32°F to 113°F)
Boat starting or house battery
Larger boats with fixed wiring
Onboard charger or engine
Electronics noise and voltage dips; wire per the fish finder's installation guide
A lithium battery fish finder setup can cut weight on a kayak or an ice sled. That is the main draw, not a promise of better results in every case. Sealed lead acid costs less but weighs more for the same capacity.
Anyone shopping for a lithium battery for fish finder use should read the charger notes closely. Dakota Lithium's 12V 10Ah page recommends 14.4V, with 15V as the maximum. It also says lead acid chargers fill that battery to only 80% of capacity. The maker rates it at up to 80% capacity after 2,000 cycles in recommended conditions.
The gap between LiFePO4 and lithium-ion cells shows why the charger matters. Once voltage and chemistry are set, size the battery so it lasts the whole trip.
How to Size a Fish Finder Battery
Battery size comes down to amp hours divided by current draw. A fishfinder battery with more amp hours simply holds more energy. The formula is short, and the result is only an estimate.
  • Runtime formula: Runtime (hours) ≈ battery capacity (Ah) ÷ current draw (A). It gives a rough number, not a measured one.
  • Worst-case example: A 10Ah battery divided by 1.5A (the Garmin STRIKER Vivid rated current) gives about 6.7 hours. Typical draw is lower, so real runtime is usually longer.
  • Other loads: GPS, a livewell pump or lights on the same battery all shorten runtime. Add their amps before dividing.
  • Reserve: Plan to return with charge left instead of running the battery flat.
  • Cold days: Cold reduces usable capacity, so ice fishing calls for a larger battery. The maker's datasheet shows the drop at a given temperature.
A full-size battery only helps if it starts the day full. That is hard at a campsite with no outlet.
Recharging a Fish Finder Battery at Camp or on Shore
On a multi-day trip, the fish finder battery needs a recharge every night, but the campsite may have no power. The safe method matches the one used at home. Use the battery's own matched charger, plugged into a 120V source, on dry ground away from the water. A portable power station can supply that 120V on shore. Anyone running a lithium battery for fishfinder trips should confirm the charger first.
Fishing kayak at evening campsiteFishing kayak at evening campsite
Shore charging steps
  1. Dry and inspect: Bring the dedicated battery ashore and dry it off. Look over the terminals and the case.
  2. Match the charger: Use the charger the battery maker recommends for that chemistry. A 12V LiFePO4 charger suits a LiFePO4 battery, for example.
  3. Check the temperature: Dakota Lithium says to charge its battery only between 32°F and 113°F.
  4. Set up safely: Plug the charger's AC cord into the power station. Keep everything on a dry, level surface away from spray, and stay nearby.
  5. Unplug and reconnect: Unplug when the charger shows full. Reconnect the battery to the fish finder before launch.
Labeled estimates
These figures are estimates. The 0.85 value is an assumed charger efficiency.
Setup
Calculation
Estimate
Energy to refill a 12V 10Ah battery from empty through an AC charger
12V × 10Ah = 120Wh; 120Wh ÷ 0.85 (assumed charger efficiency)
About 141Wh from the outlet
EcoFlow DELTA 3 Classic (1024Wh) as the AC source
1,024Wh × 0.85 = about 870Wh usable; 870Wh ÷ 141Wh
About 6 full recharges
Time with a 3A charger
10Ah ÷ 3A
About 3.3 hours (longer as charging tapers)
The charger's label lists its AC input watts, which should replace the assumption. Many 12V LiFePO4 batteries are 12.8V nominal, which shifts the math slightly.
Some limits apply. The fish finder should never connect directly to the power station. The power station should never sit in a boat, a kayak or anywhere spray can reach it. It is not a waterproof battery, marine safety equipment or a life-saving power source.
Campsites rarely have outlets near the water. A portable power station can fill that gap by supplying the 120V the charger needs. One EcoFlow DELTA 3 model fits this dry-land recharging job.
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
The EcoFlow DELTA 3 Classic stays on shore as the 120V source for the battery's own charger. It also charges phones and camp lights, with USB-C up to 100W and 1,800W rated AC output. It does not belong in a boat or kayak, and a larger unit would not change that. The fish finder still runs from its own fused battery.
Larger boats follow a similar process when anglers charge a marine battery from a power station. With a full battery ready, the last piece is mounting and wiring it so water and vibration cannot cut the power.
Mounting, Wiring and Waterproofing the Battery
Loose or corroded connections can cut power to a fish finder. Fuse the circuit, protect the terminals and secure the battery where water cannot pool. Any battery for depth finder use follows these rules.
  • Fuse the positive wire: Install the fuse the maker specifies in the red (positive) wire. Garmin's STRIKER Vivid manual lists a 3A fast-acting fuse.
  • Protect the terminals: Use a battery box or bag. Cover the terminals so a wet tool or paddle cannot short them.
  • Secure the battery: Strap it down so it cannot slide or tip in a kayak or small boat.
  • Follow the install steps: Route wires as the fish finder's installation instructions say.
  • Troubleshoot in order: If the display turns off, check the power source and the fuse first, as Garmin's troubleshooting steps advise.
No battery should be called waterproof unless its maker gives an IP rating. Anglers adding lights and a livewell may want to compare batteries for boat accessories first.
Good habits between trips keep the battery healthy for the next season.
Fish Finder Battery Care Between Trips
A battery left flat in a cold garage can be ruined by spring. Recharge after each trip and store it the way the maker says.
  • Recharge soon: Top the battery up after each trip with the matched charger.
  • Store indoors: Keep it dry and within the maker's storage temperature range. The manual lists the storage charge level.
  • Skip freezing charges: Do not charge a LiFePO4 battery below freezing. Dakota Lithium says to avoid charging below 32°F. Lithium batteries for fish finders face this rule most often during ice season.
  • Clean and inspect: Remove corrosion from the terminals, and check the wires and fuse holder before the season.
Researchers at the U.S. Department of Energy's SLAC National Accelerator Laboratory found that storing lithium-ion batteries below freezing can crack parts of the cathode and reduce capacity. Ice anglers see the biggest swings, since lithium batteries in cold weather lose some usable capacity.
A good fish finder battery matches the unit's voltage range, holds enough amp hours for the day with a reserve, stays fused and protected from water, and is recharged with the charger made for its chemistry. Checking the unit's input voltage, current draw, and fuse size allows for calculating daily runtime by dividing the battery's Ah by the current draw. When taking overnight trips to a campsite without an outlet, packing the matched charger alongside the EcoFlow DELTA 3 Classic provides a dry-land AC source to recharge both the battery and phones.
What size battery do I need for a fish finder?
Divide the battery's amp hours by the fish finder's current draw. A 10Ah battery at Garmin's 1.5A rated current gives about 6.7 hours as a worst-case estimate. Typical draw runs lower, so real runtime is usually longer than that.
Can I use a lithium battery for my fish finder?
Yes, if its voltage fits the unit's input range. Charge it only with a charger made for its chemistry and within the maker's temperature limits. Check the unit's manual first, since not every fish finder accepts every 12V battery.
Do I need a fuse between the battery and the fish finder?
Yes. Use the fuse the maker specifies. Garmin lists a 3A fast-acting fuse for the STRIKER Vivid series. The fuse goes in the red positive wire and helps protect the wiring and the unit if a fault occurs. Skipping it leaves the wiring unprotected.
Can I charge a fish finder battery with a portable power station?
Yes, on dry land. Plug the battery's own matched charger into the power station's AC outlet. Do not connect the fish finder directly to the power station, and never take the power station onto the water or near spray. Keep both on dry ground.
Can I charge a lithium fish finder battery in freezing weather?
Not below the maker's limit. Dakota Lithium, for example, says to charge its battery only between 32°F and 113°F. Let the battery warm into the allowed range first, then use the charger made for its chemistry and stay nearby.
Outdoors
