Sierra Nevada Winter Storm: How to Read the Warning and Keep Your Home Running Through Outages
A Sierra Nevada winter storm can bury Donner Summit in snow while Reno or the Sacramento foothills get rain. Conditions can change sharply with elevation, even between nearby communities on opposite sides of the crest. This evergreen guide explains how to check whether a warning covers your home, why heavy mountain snow can knock out power, and how to plan backup power around the appliances you need most. Whether you're on the California or Nevada side of the Sierra Nevada, check the latest alerts from the National Weather Service first.
Who Issues a Sierra Nevada Winter Storm Warning, and How to Tell If It Covers You
No single National Weather Service office covers the entire Sierra Nevada. Reno, Sacramento, Hanford, and Las Vegas cover different parts of the range through forecast zones, some of which are separated by elevation. Before changing your plans, check the issuing office and the exact area named in the alert.
Who Issues a Sierra Nevada Winter Storm Warning, and How to Tell If It Covers YouWho Issues a Sierra Nevada Winter Storm Warning, and How to Tell If It Covers You
Forecast offices and their Sierra zones
NWS office
Sierra area it covers (zone examples from its own forecast product)
What to notice
Reno
Greater Lake Tahoe Area (CAZ072, NVZ002); Greater Reno-Carson City-Minden Area (NVZ003); Lassen-Eastern Plumas-Eastern Sierra Counties (CAZ071); Mono County (CAZ073)
Covers both states. The Tahoe zone crosses the California and Nevada line.
Sacramento
Sierra (Yuba-Placer) 3000-5000 ft (CAZ132); Sierra (Sierra-Placer) Above 5000 ft (CAZ133); Sierra (El Dorado-Amador) Above 5000 ft (CAZ136); Sierra (Cal-Tuo) 3000-5000 ft and Above 5000 ft (CAZ138, CAZ139)
Western slope zones are split by elevation band, so an "Above 5000 ft" alert may not apply to a home at 2,500 feet.
Hanford
Mariposa-Madera Lower Sierra (CAZ318); Yosemite NP outside of the valley (CAZ323); Kings Canyon NP (CAZ328); Sequoia NP (CAZ330); South End of the Upper Sierra (CAZ331)
Southern Sierra, national parks, and the foothills above the San Joaquin Valley.
Las Vegas
Eastern Sierra Slopes of Inyo County (CAZ519)
Covers the eastern Sierra slopes in Inyo County, California; the office is based in Nevada.
Zone names and boundaries can change. Use the current forecast on the relevant NWS website rather than relying on an old zone code or a headline that covers a broad region.
Watch, warning, advisory, or blizzard warning?
These alerts describe different levels of concern. Knowing which one applies helps you decide whether to prepare, change travel plans, or stay off the roads.
  • Winter Storm Watch: Conditions are favorable for a significant winter storm. Use the lead time to prepare.
  • Winter Storm Warning: Significant snow, ice, sleet, or blowing snow is expected or occurring. Travel may become very difficult or impossible.
  • Winter Weather Advisory: Wintry conditions are expected, but they don't meet the local warning criteria. Roads may still be slippery.
  • Blizzard Warning: Strong, persistent winds and blowing or falling snow are expected to severely reduce visibility for an extended period.
Each NWS office issues alerts using its local criteria. Don't assume a warning applies to every town in the Sierra just because the mountain range appears in the headline.
Four things to check on the alert itself
Before changing your plans, check four details in the alert:
  1. Issuing office: Reno, Sacramento, Hanford, or Las Vegas.
  2. Area covered: Confirm your zone and any elevation limits, such as above 6,000 feet.
  3. Issue time: Check when the alert was posted or updated.
  4. Alert timing: Note when it starts and expires.
Preparing early also helps. These blizzard preparation tips cover essentials such as food, fuel, and flashlights. Once you confirm the warning covers your area, the next concern is what heavy, wet snow can do to trees, roofs, and power lines.
Why Heavy Sierra Snow Knocks Out Power, and Who to Call on Each Side of the Lake
Mountain snow can be heavy enough to bend tree limbs onto power lines and put added stress on roofs. Wet snow carries much more weight than light, dry flakes, so a storm's impact depends on more than how many inches fall.
Snow weight in numbers (FEMA P-957)
Snow or ice on the roof
Approximate weight
1 foot of light, dry fresh snow
About 3 lb per sq ft
1 foot of wet, heavy fresh snow
About 21 lb per sq ft
1 inch of ice
A little less than 5 lb per sq ft
1 foot of ice
About 57 lb per sq ft
These figures show why a heavy, wet storm deserves attention even if snowfall totals don't look extreme. Drifts can also pile up unevenly near dormers, rooftop equipment, or lower roofs beside taller sections. Uneven loading can create additional stress.
Roof warning signs to take seriously
Heavy snow can put significant pressure on a roof. Watch for sagging ceilings, new cracks in walls, popping or creaking sounds, cracked wooden supports, or doors and windows that suddenly stick. These can signal dangerous structural stress. If you notice any of these signs, leave the building promptly and contact a qualified professional. Don't climb onto a snow-covered roof to inspect or clear it.
FEMA recommends using a nonmetallic snow rake from the ground and leaving at least 2 inches of snow on the roof. For anything beyond that, hire a licensed, insured roofing contractor. Pay particular attention to snowdrifts near dormers, rooftop equipment, and lower roofs beside taller sections, where uneven buildup can put extra stress on the structure.
Your utility depends on which side of the crest you live
Area
Electric utility (verified operating company)
How to reach it in an outage
Reno, Sparks, Carson City and northern Nevada
Sierra Pacific Power Company d/b/a NV Energy
Check the NV Energy Outage Center and map for current outage information and restoration updates.
California side of the Lake Tahoe Basin
Liberty Utilities (CalPeco Electric) LLC (CPUC: about 49,000 customers in and around the California side of the basin)
Use the Liberty Outage Center to access the outage map and report an outage.
Western slope and foothills in California
Varies by town (investor-owned, municipal and co-op utilities)
Check the utility named on your bill and use its outage map
Heavy snow, falling branches, and damaged power lines can cause outages across the Sierra Nevada, sometimes days after a storm has passed as snow melts and runoff creates further problems. Learn more about how snow and melt can cause outages. Check your local utility's outage page for updates and restoration estimates. In the Reno, Sparks, and Carson City areas, check NV Energy; on the California side of Lake Tahoe, check Liberty Utilities. If a power line is down or there is immediate danger, call 911 first. To prepare for an outage, identify the essential appliances and devices your household needs and choose backup power based on their actual electricity requirements.
Planning Backup Power Around the Loads Your Sierra Home Can't Lose
A power outage doesn't mean every appliance needs to stay on. Start with the refrigerator, a few lights, internet equipment, and any equipment your household relies on for heat or water. Then check each device's voltage and power requirements before choosing a backup system.
Sort your must-run loads by voltage first
Load group
Typical voltage
Where to find the real numbers
Refrigerator, LED lights, Wi-Fi router, phone chargers
120V
Nameplate, ENERGY STAR listing, or adapter label
Gas furnace blower and controls
Often 120V
Furnace nameplate; confirm with an HVAC pro
Submersible well pump, some heating equipment
Often 240V
Pump or equipment nameplate; licensed electrician
These are typical examples, not guarantees. Check the actual equipment before planning your backup setup. A well pump, for example, may need much more power to start than it uses while running. The same goes for other motor-driven equipment. Have a licensed electrician check starting requirements, circuit limits, and compatibility before connecting a home battery to your electrical panel.
Example estimate for a 120V essentials list
A battery's listed capacity doesn't tell you exactly how long it will power your home. The result depends on the energy each appliance uses, how often it runs, and how much of the battery's capacity is available for planning. Here's an example using a short list of 120V essentials:
Load (source)
Daily energy used in the estimate
Frigidaire FFHT1835X* top-freezer refrigerator, 369 kWh per year (ENERGY STAR listing)
369,000 Wh ÷ 365 = about 1,011 Wh per day
Wi-Fi router with a 12V 2A adapter (TP-Link Archer AX55 spec)
24W maximum × 24 hours = 576 Wh per day (a ceiling, real draw is lower)
LED lighting, example value (replace with your bulbs' labels)
40W × 6 hours = 240 Wh per day
Total
About 1,827 Wh per day
For this example, one EcoFlow TITAN 5000 Classic battery provides an estimated 4,250Wh of usable energy for planning, based on 85% of its 5,000Wh capacity. At an estimated daily usage of 1,827Wh, that works out to about 2.3 days. Adding one EcoFlow TITAN Battery 5kWh expansion battery brings the total capacity to 10,000Wh, or around 4.7 days of estimated runtime. Actual results will vary depending on refrigerator use, room temperature, how often the door is opened, and the other devices connected. Two EcoFlow TITAN models offer different power options, so the right choice depends on the appliances you need to run and whether they require 120V or 240V power.
• 4,000W Whole-Home Essential Power. Run your fridge, microwave, Wi-Fi, lighting, and CPAP all at once. •5–30kWh Expandable Capacity. Get 1 day to 1 week of essential backup. Add batteries anytime, with no installer needed. • <25 dB. Quiet enough for indoor use—quieter than a whisper. • ≤20 ms Automatic Switchover. The lights don't even flicker. • OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day. • North America Highest Safety Standards. UL 9540 certified and tested to UL 9540A, UL 1741 compliant, with EV-grade LFP cells, 24/7 BMS monitoring, and a 5-year warranty.
For homes with 240V appliances, such as certain well pumps or heating systems, the EcoFlow TITAN 5000 Plus offers a higher-voltage option with split-phase output.
• 100% Whole-Home Backup. 7.2–10kW output and 5kW single-circuit capacity power your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter required. • 100% Whole-Home Savings. Save up to $3,100 per year, with ROI in as little as 3 years. •Only 30% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle, from upfront purchase and installation to long-term use. • OASIS 3.0 — Your AI Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day. • Built to North America's Highest Safety Standards. UL 9540A tested and UL 9540 certified, with EV-grade LFP cells and 24/7 BMS monitoring.
The EcoFlow TITAN 5000 Classic suits homes that need backup for 120V essentials, such as a refrigerator, lights, and router, within its 4,000W output limit. It cannot power 240V equipment, such as a compatible well pump or heating circuit. The EcoFlow TITAN 5000 Plus is the option for homes that need 240V power, provided the equipment’s running and startup requirements, circuit limits, and expected runtime are within the system’s capabilities. Connecting either unit to home circuits requires the matching Smart Home Panel 10 and installation by a licensed electrician. Both units must be kept in a suitable, dry indoor location. Neither is designed to be carried during an evacuation or to power an entire home without careful load planning. For more guidance, see how to use backup batteries safely indoors. With your backup power plan in place, use the following checklist to prepare your home in the days and hours before the storm arrives.
A Sierra Storm Checklist: Before the Snow, During the Outage, After It Clears
Mountain roads can close, and crews may need time to reach damaged lines. Preparing a few things ahead of time can make a long outage easier to manage.
When
What to do
When a watch is issued
Check the alert's office, zone, issue and expiry times; charge phones and batteries; fill the car's tank
Before snow starts
Test CO alarms; know where your roof rake is; clear the area around vents and meters
Power goes out
Keep the refrigerator closed: food stays safe up to 4 hours; a full freezer holds about 48 hours, a half-full one about 24 hours
If you run a fuel generator
Outdoors only, more than 20 feet from windows, doors and vents; never in the home or garage, even with doors open
Car in the garage
Never run it in an attached garage, even with the door open
After it clears
Watch the roof for warning signs; stay away from downed lines and call 911
Carbon monoxide is a serious risk during outages. Symptoms can include headache, dizziness, weakness, nausea, and vomiting. Keep working CO alarms in your home, and never run a car in an attached garage, even with the garage door open. It's also worth keeping a basic emergency kit ready before the forecast turns. This emergency kit checklist can help you check supplies such as flashlights, batteries, food, water, and first aid items.
Crossing Donner, Echo Summit or Mt. Rose When a Storm Is Coming
If you need to drive over the Sierra, check road conditions before leaving and again before you reach the pass. I-80 over Donner Summit, US-50 over Echo Summit, and the Mt. Rose Highway all cross high country where conditions can deteriorate quickly.
Crossing Donner, Echo Summit or Mt. Rose When a Storm Is ComingCrossing Donner, Echo Summit or Mt. Rose When a Storm Is Coming
Where to check road conditions
  • California: Use Caltrans QuickMap for current traffic and road conditions. You can also call the Caltrans Highway Information Network at (800) 427-7623.
  • Nevada: Check Nevada 511 or call 511 within the state. From outside Nevada, call 1-877-687-6237.
Follow posted chain requirements, and don't assume a road is safe because it was open earlier in the day. Conditions can change with elevation and visibility.
What to carry (combined from Caltrans and NDOT lists)
Pack chains, a flashlight with spare batteries, an ice scraper, a shovel, and sand or another traction aid. Bring drinking water, nonperishable food, warm blankets or a sleeping bag, extra gloves and socks, a first aid kit, prescription medication, and a battery-powered radio. Keep your phone charged and save road information numbers before leaving. NDOT recommends using snow tires from October 1 through April 30. If you need chains installed, remember that Caltrans chain installers are independent businesses, not Caltrans employees, and cannot sell or rent chains. Ask for a receipt and note the installer's badge number. Many of these essentials are also useful for other trips, so check this guide to emergency gear for winter road trips before you leave.
A Sierra Nevada winter storm can affect nearby communities very differently. Check the issuing NWS office, your forecast zone, elevation, and alert timing before making decisions. Heavy, wet snow can damage roofs and power lines, so prepare for possible outages before the storm arrives. This week, save your utility's outage page and write down the voltage and power requirements of the appliances you need most. If your list contains only compatible 120V loads, compare the EcoFlow TITAN 5000 Classic. If you also need an approved 240V well pump or heating circuit, discuss the EcoFlow TITAN 5000 Plus with a licensed electrician before choosing a system.
Which NWS office issues winter storm warnings for the Sierra Nevada?
It depends on where you live. NWS Reno covers Lake Tahoe, the Reno-Carson City area, and parts of the Eastern Sierra. NWS Sacramento covers much of the northern and central western slope, while NWS Hanford covers parts of the southern Sierra and its national parks. NWS Las Vegas covers the Eastern Sierra Slopes of Inyo County (CAZ519). Check your exact forecast zone rather than choosing an office by state alone.
Does a Sierra Nevada winter storm warning apply to the foothills?
Not necessarily. Some forecast zones are divided by elevation, so a warning for areas above 5,000 feet may not apply to a lower-elevation home. Check the full alert for your specific zone.
How heavy is wet Sierra snow on a roof?
FEMA's guidance estimates that one foot of fresh, wet snow can weigh about 21 pounds per square foot. The same depth of light, dry snow weighs about 3 pounds per square foot. Drifts and uneven accumulation can add to roof stress.
Who handles power outages around Lake Tahoe?
It depends on which side of the lake you're on. Liberty Utilities serves parts of the California side of the basin, while Sierra Pacific Power Company, doing business as NV Energy, serves northern Nevada. Check your electric bill to confirm your provider.
Can a home battery run a well pump during a Sierra outage?
It may be possible with the right setup. A 240V pump needs compatible split-phase output, and its starting and running requirements must be checked. Have a licensed electrician confirm the pump's load, circuit limits, and compatibility with the battery and matching Smart Home Panel 10 before connecting it.
Power Outages
