Ground Blizzard: What It Means When Clear Skies Still Bring Whiteouts
The sky looks clear. The forecast shows little or no new snow. Yet roads across the northern Plains close, because wind is moving snow that fell days earlier.
The National Weather Service (NWS) does not issue a separate warning for this. A ground blizzard is a condition, and it can trigger a Blizzard Warning when blowing snow alone reaches blizzard levels. This article covers three things. First, a plain-English ground blizzard meaning. Second, the warnings and road advisories that signal it is time to stay put. Third, a short plan for staying safe at home if the power lines go down.
What Is a Ground Blizzard? The Short Answer
A ground blizzard is a blizzard made by wind, not by a new storm. Strong gusts pick up loose snow already on the ground and blow it until almost nothing is visible. The NWS uses the term when blizzard conditions come only from blowing and drifting snow.
The official wording
Ground blizzard: Blizzard conditions caused by wind lifting snow already on the ground. The current alert for this hazard is a Blizzard Warning when blizzard criteria are met.
Blizzard: Sustained winds or frequent gusts of 35 mph or greater, plus considerable falling or blowing snow. Visibility frequently drops below a quarter mile for 3 hours or longer.
Blowing Snow: Wind-driven snow that reduces surface visibility. The glossary notes it "can be falling snow or snow that has already accumulated."
A ground blizzard follows the same blizzard wind, visibility, and duration criteria; the snow is lifted from the ground rather than falling from the sky.
Ground blizzard vs. a regular blizzard
Feature | Ground blizzard | Blizzard with falling snow |
Where the snow comes from | Snow already on the ground, picked up by wind | New snow falling, often plus blowing snow |
New snowfall needed? | Little or none (NWS: "little or no concurrent (or new) snowfall" in the Midwest) | Yes, usually several inches |
What drives it | Strong winds, often behind an Arctic cold front | A winter storm system plus wind |
Visibility pattern | Often more sporadic (per NWS Aberdeen) | Can stay low for long stretches |
Typical NWS product | Blizzard Warning | Blizzard Warning |
Wind, not snowfall totals, is what separates these storms. The blizzard and snowstorm difference comes down to that same wind and visibility test.
Knowing the label is step one. The harder question is why a calm-looking day turns dangerous so fast.
How Wind Turns Yesterday's Snow Into Today's Whiteout
Most of these storms follow a familiar setup. Fresh, loose snow sits on open land. Then an Arctic cold front arrives with a sudden jump in wind and a drop in temperature. The gusts lift the snow, and visibility can fall to near zero within minutes.
The three ingredients
Loose snow cover: The NWS says that if "several inches of deep fresh snow" are on the ground, strong wind "will quickly pick up the snow and create whiteout conditions."
Strong wind behind a front: The NWS describes winds that increase "quite rapidly, often reaching gusts of 50 to 60 mph" as an Arctic front passes.
Open, flat terrain: The NWS WSSI tutorial scores heavily forested areas lower than open areas for this hazard. Trees and buildings break up the wind, so open farmland and long rural highways take the worst of it.
Real NWS examples from the Red River Valley
January 8, 2015 (NWS Grand Forks): Less than 2 inches of new snow fell before the wind arrived. Northwest winds of 35 to 50 mph over the existing snow cover produced "near zero visibility in many areas." The highest measured gust was 52 mph at East Grand Forks 7 SE.
February 12, 2020 (NWS Grand Forks): Only about half an inch to 1.5 inches fell, and it "was immediately blown around by the strong winds." Gusts reached the 50 to 60 mph range, and numerous vehicle accidents were reported across eastern North Dakota and northwest Minnesota.
Why the cold makes it worse
Exposure: The NWS notes that anyone stranded in a vehicle or forced to walk outside is "at risk of frostbite or hypothermia."
History: The Children's Blizzard of 1888 "killed an estimated 235 people in the Great Plains," the NWS says, after unseasonably warm air led people to head out without proper winter clothing.
Many of these events start when an Arctic boundary sweeps through. Reading cold front weather patterns can flag a risky day before the wind picks up.
Once the wind starts, the safest place is usually indoors. That shifts the focus to what a household needs if the lights go out.
Sheltering at Home During a Ground Blizzard: Supplies and Backup Power
The best plan is simple: do not drive into it. Staying home means having light, a way to get alerts, and a plan for food and warmth in case strong winds bring down a line nearby. Gather the basics first. Then decide how much backup power the household needs.
The no-power basics (do these first)
High winds can bring down lines, so an outage is possible, though not certain.
Light and alerts: NWS winter safety advice lists a flashlight with extra batteries and a battery-powered NOAA Weather Radio. Extra food, water, and heating fuel belong on the same shelf.
Carbon monoxide safety: The U.S. Consumer Product Safety Commission says portable generators must never run indoors or in enclosed areas such as garages, basements, and sheds. A working carbon monoxide alarm is part of the plan.
Food safety: FoodSafety.gov says a refrigerator keeps food safe for up to 4 hours during an outage. A full freezer holds a safe temperature for about 48 hours (24 hours if half full) with the door closed.
Holding heat: The NWS advises closing off unneeded rooms and stuffing towels or rags in cracks under doors.
Households that would rather not count on candles and a cooler can use a battery power station to cover a short list of essentials while the wind passes.
The first need during a storm outage is staying reachable. Phones, a Wi-Fi router, and a few LED lights keep weather alerts, road updates, and family check-ins coming in. The EcoFlow DELTA 3 Classic is built around that kind of short list.
Staying reachable is only part of the picture. A longer outage in freezing weather also puts refrigerated food at risk and makes a cold room harder to manage. Households with those needs may want more capacity and a say in which devices get power first. That is where the EcoFlow DELTA 3 Ultra Plus fits.
How the two products divide the job
EcoFlow DELTA 3 Classic: Suits households that mainly need to stay reachable. Phones, a router, and LED lights keep alerts, road updates, and family check-ins flowing.
EcoFlow DELTA 3 Ultra Plus: Suits households that also need a refrigerator running. It can also feed an approved 120V plug-in heating aid, such as a heated blanket or a space heater whose maker allows this type of power source.
What neither one does: Backup power does not improve visibility outside, and it is no reason to drive into a storm. Neither unit is presented as a way to keep a whole house warm for an entire outage.
Sizing it honestly (labeled estimate)
A simple formula gives a rough runtime: runtime (hours) ≈ capacity (Wh) × 0.85 ÷ total load (W). The 0.85 is a planning assumption for conversion losses.
EcoFlow DELTA 3 Classic (example only): 1,024Wh × 0.85 leaves about 870Wh usable. With a placeholder load of 40W for a phone, router, and LED lights combined, that is about 870 ÷ 40, or roughly 22 hours.
EcoFlow DELTA 3 Ultra Plus (example only): 3,072Wh × 0.85 leaves about 2,611Wh usable. Add the refrigerator's average running watts and the heating aid's rated watts from their labels, then divide. A placeholder 100W refrigerator alone would run about 26 hours. A 1,500W space heater would drain the same energy in under two hours.
Surge, cold, and care: A refrigerator's startup surge must stay under the unit's surge rating. Cold rooms and heavy loads shorten runtime, so follow the user manual for low-temperature use. Keep the unit dry and away from snowmelt tracked in at doorways.
The U.S. Fire Administration (FEMA) says to keep anything that can burn at least 3 feet from heat sources. Turn space heaters off when leaving the room or going to bed, and skip extension cords on these appliances.
Before the next Arctic front, a short checklist for winter power outage preparation can sit right next to the weather radio.
Power is only part of staying home. The other part is knowing when officials say the roads are off limits.
Blizzard Warnings, Travel Alerts, and Road Closures
This storm is mostly a travel hazard, so the most useful alerts come from two places. The local NWS office issues the weather warning. The state transportation department decides whether highways stay open. Both deserve a check before anyone leaves the driveway.
NWS products to watch
Watch the current NWS products below. Local criteria and expected impacts determine which alert applies.
Winter Weather Advisory: Snow or snow and blowing snow meeting local advisory criteria can still make travel hazardous, even when warning criteria are not met.
Blizzard Warning: Sustained or frequent winds of 35 mph or higher, with falling or blowing snow frequently cutting visibility below 1/4 mile for at least 3 consecutive hours.
What state DOT alerts mean
Agency | Alert | What the agency says |
North Dakota DOT | Road closed | "Travel on a closed road is prohibited and extremely dangerous." |
North Dakota DOT | No Travel Advisory | Roads "may become blocked or impassable"; motorists are "strongly encouraged to avoid travel." |
North Dakota DOT | Travel Alert | Weather and road conditions are "rapidly changing." |
Minnesota DOT | No travel advised | "The roadway has deteriorated and/or visibility has been reduced." |
North Dakota: Call 511 or use the ND Roads map at travel.dot.nd.gov.
Minnesota: Use 511mn.org or the 511mn app. These cover state highways only, so check county and city sources for local roads.
MnDOT adds a point worth remembering: plow operators "cannot see any better than other drivers."
Cities and counties may layer on their own rules. Snow emergency levels vary from one county to the next.
Sometimes the wind arrives faster than the forecast, and a driver is already on the road. Here is what the NWS says to do then.
Caught Out Anyway? What to Do If a Ground Blizzard Strands You
If visibility drops while driving, slow down and leave the road at the first safe chance. If the vehicle cannot go farther, stay with it. Walking into blowing snow is how people get lost in open country.
NWS steps if stranded in a vehicle
Stay put: The NWS advice starts with four words: "Stay in the vehicle!"
Heat and fresh air: "Run the motor about 10 minutes each hour for heat," and open a window a little to avoid carbon monoxide poisoning.
Exhaust check: "Clear snow from the exhaust pipe to avoid gas poisoning."
Signal for help: Tie a bright cloth, preferably red, to the antenna or door. After the snow stops falling, raise the hood.
What to carry from November on
NHTSA kit list: A snow shovel, broom, ice scraper, sand or kitty litter for traction, jumper cables, and a flashlight. Add flares and emergency markers, blankets, a cell phone and charger, water, food, and any needed medicine.
Visibility: NHTSA says to "Let your car be seen," with bright markers on the antenna or windows and the interior dome light on.
Travel plans: The NWS suggests telling someone the timetable and the primary and alternate routes.
In an emergency, call 911. A well-stocked trunk matters most on rural highways, and a winter car emergency kit makes the November restock quick.
A ground blizzard is blizzard-level blowing snow with little new snowfall. Strong winds drive it over existing snow, often behind an Arctic front on open land. Watch the local NWS office for warnings, check 511 before any trip, and plan to stay home when officials advise no travel. For lights, alerts, and a cold fridge during the wait, compare the EcoFlow DELTA 3 Classic and the EcoFlow DELTA 3 Ultra Plus against a household appliance list.
How do forecasters define a ground blizzard?
Strong winds lift snow that is already on the ground and create blizzard conditions without much new snow falling. The NWS uses the term when those conditions come only from blowing and drifting snow, with no major storm needed to feed it.
Can a blizzard happen without new snow?
Yes. The NWS says Midwest events develop with "little or no concurrent (or new) snowfall," as long as loose snow covers the ground and the wind is strong. An Arctic cold front often supplies the wind, and the snow is left over from days earlier.
Where do ground blizzards happen most?
They are most common on open, flat land such as the northern Great Plains and the Red River Valley, where little blocks the wind. Forested areas and towns see fewer, because trees and buildings break up the gusts that would lift the snow.
Is it safe to drive during a ground blizzard?
No. Visibility can drop to near zero with little warning, even under a clear sky. Delay travel, and follow state DOT road closures and No Travel Advisories. MnDOT notes that plow operators "cannot see any better than other drivers."
Will a power station help me drive through it?
No. A portable power station can keep phones, a router, and lights running at home, or after a driver has safely stopped. It does nothing for visibility on the road, so it is no reason to drive into a storm with blowing snow.
