How to Fix a Heater: Match the Symptom to Your System, Try the Safe Checks, Then Call a Pro
When your house feels cold and the heater stops working, the first question is whether you can fix it yourself or need a technician. The answer depends on your heating system. A furnace, heat pump, boiler, electric baseboard heater, and portable space heater all work differently. Before trying anything, rule out immediate dangers, check the simple things homeowners can safely handle, and know when to stop. If professional repairs take time, a few sensible steps can also help you keep essential devices running while you wait.
Stop First If You Notice Any of These
Some heating problems are more than an inconvenience. They can signal a gas leak, carbon monoxide exposure, or electrical faults. If you notice any of the following warning signs, stop troubleshooting and get help.
Warning sign | What to do |
Rotten-egg smell or hissing near a gas line | Leave immediately without operating switches or using a phone inside. Call 911 or the gas utility from outside. |
Carbon monoxide alarm sounds, or people experience headaches, dizziness, nausea, or confusion | Get everyone outside into fresh air and call 911. |
Smoke, sparks, or a persistent burning smell | Stop using the heater. Turn it off only if safe, and seek professional help. |
Breaker trips repeatedly | Stop resetting it and contact a licensed electrician or qualified technician. |
Carbon monoxide is odorless, so install alarms near sleeping areas and maintain them according to the manufacturer's instructions. Electrical warning signs also matter, and understanding how short circuits can cause dangerous electrical problems helps explain why repeated breaker trips, sparks, or burning odors should never be ignored. If there are no warning signs, proceed with the basic checks.
Symptom, System, Safe Check: A Troubleshooting Map
Start troubleshooting by checking the thermostat settings and power supply to your heating system. Make sure the thermostat is set to heating and the target temperature is correct. Check for a tripped breaker or power interruption without opening equipment or touching wiring. If the problem continues, consult the manufacturer's troubleshooting instructions or contact a qualified technician.
The two checks that apply to almost every heater
Before troubleshooting individual heater components, start with two basic checks: the thermostat settings and the power supply. These simple steps may resolve common heating issues without opening the equipment or handling electrical wiring.
Check the thermostat: Confirm it has power, replace its batteries if needed, and set it to Heat. Raise the temperature several degrees above the current room temperature and wait for the system to respond.
Check the power supply: Look at the relevant breaker and confirm the furnace switch is on. Reset a tripped breaker only once. If it trips again, leave it alone and call a professional.
Find your heater on the troubleshooting map
Use this troubleshooting map to identify common heating problems and the checks you can safely perform yourself. Always follow the manufacturer's instructions and avoid opening equipment or handling gas and electrical components. Call a qualified technician if the issue persists or you notice warning signs.
Symptom | System | Safe owner check | Call a pro when |
No heat; blower silent | Gas furnace | Check thermostat, breaker, furnace switch, and gas valve position | Still no heat or suspected gas/electrical fault |
Weak or uneven heat | Gas/oil furnace | Inspect filter and open vents | Rooms stay cold after checks |
Pilot lights out | Older gas furnace | Follow the manual's relighting steps | Pilot won't stay lit or gas smell occurs |
Brief cool air or outdoor steam | Heat pump | Allow a normal defrost cycle | Defrost runs constantly or ice keeps building |
Poor heat; unit blocked by snow or leaves | Heat pump | Safely clear debris and maintain required clearance | Heavy ice, unusual noises, or error codes |
Cold radiators; unusual pressure | Boiler | Check gauge against the manual's limits | Leaks, relief-valve discharge, or safety shutdown |
One room stays cold | Electric baseboard/wall heater | Check breaker and thermostat setting | Breaker trips again, scorch marks, or no heat |
The space heater shuts off | Plug-in heater | Unplug, cool, and follow manual reset steps | Repeated shutdowns, damaged cord, hot plug, or loose outlet |
When troubleshooting a boiler, never add cold water to a hot boiler, as sudden temperature changes can crack the heat exchanger. Follow your boiler's manual for safe pressure limits, since the values listed for Weil-McLain models may not apply to other systems. Electrical safety matters, too, especially during cold weather when extra heaters increase demand; the same habits used for preventing breaker trips during holiday hosting can help reduce overload risks. If these checks don't restore heat, arrange a service call, as waits can stretch for days during a cold snap.
Waiting on the Repair: Power for Everything Except the Broken Heater
A broken heater can leave more than one problem behind. You may need to keep your phone charged, maintain internet access, and light the rooms you use while waiting for a technician. A portable power station can help with those separate needs, but it will not repair a heater. Never connect a power station to faulty household wiring or use one to bypass a tripped breaker.
Ground rules for this setup
Before using temporary heat, make sure the heater and power source are safe and compatible. Never bypass safety features or restart faulty equipment, and follow the manufacturer's instructions to reduce fire and electrical risks.
Never use a heater that repeatedly trips a breaker or shuts itself off. Do not bypass its safety switches.
If a technician says to keep the heating circuit off, leave it isolated until they confirm it is safe to use.
Check the heater's nameplate and the power station's outlet specifications to confirm compatibility before connecting them.
Plug portable heaters directly into an approved wall outlet. Never use an extension cord or power strip.
Place the heater on a stable, level surface at least three feet from bedding, curtains, furniture, clothing, and other combustible materials.
Never leave a portable heater unattended or running while you sleep.
If you need temporary heat, use a separate, undamaged heater rated for the available power source. Whether a portable power station can run a space heater depends on its continuous output and usable battery capacity.
Choosing a power station for the wait
If you only need to keep communication and lighting available, the EcoFlow DELTA 3 Classic offers 1,024Wh of rated capacity and 1,800W of AC output. For a temporary setup that may also include a compatible small space heater, the EcoFlow DELTA 3 Max offers 2,048Wh of rated capacity and 2,400W of AC output. Actual runtime depends on the connected devices, operating conditions, and conversion losses.
Runtime estimates are not guarantees, because heaters cycle on and off and actual energy use varies. A 2kWh battery may not provide enough energy for overnight heating, so check the heater's wattage, the power station's output limits, and the manufacturers’ instructions before connecting them. Understanding whether a portable power station can run a heater helps you assess its capacity and safety requirements.
Repairs That Belong to a Licensed Technician
Homeowner checks should stop before you open equipment cabinets or handle internal components. Gas, high voltage, refrigerant, and pressurized water systems can cause serious injury or expensive damage.
Furnaces: Burner, igniter, flame sensor, gas valve, combustion, safety-control, and internal electrical repairs.
Heat pumps: Refrigerant leaks, refrigerant charging, and sealed-system repairs. Refrigerant work may require EPA Section 608 certification.
Boilers: Leaks, relief valves, pressure-control faults, gauge glass replacement, and safety shutdowns.
Baseboard and wall heaters: Internal wiring and 240V thermostat replacement, handled by a licensed electrician.
Space heaters: Internal repairs or rewiring. Stop using a damaged unit and check the model for recalls before replacing it.
Owner can | Technician only |
Thermostat batteries and settings | Burners, igniters, gas valves, controls |
Breaker check (once) and furnace switch | Wiring inside the cabinet or heater |
Filter, vents, outdoor unit clearance (power off) | Refrigerant charge and leaks |
Read a boiler gauge | Boiler leaks, relief valve, safety resets |
Repairs involving gas, oil, refrigerant, or electrical components should be left to qualified professionals. For example, a licensed electrician should handle wiring or thermostat replacement on 240V baseboard systems, and a boiler should never be restarted after a safety shutdown until a technician identifies the cause. Understanding the difference between DIY electrical repairs and backup power can help you distinguish safe backup options from repairs that require professional attention. Never open or rewire a damaged space heater; check for recalls and replace unsafe equipment.
Keeping the Fix From Coming Undone
Once your heating system is working again, regular maintenance can help prevent another unexpected breakdown. A few simple checks can improve safety and keep your home comfortable during cold weather. Schedule these tasks throughout the year so you're prepared before temperatures drop.
Book annual service. Have a qualified professional inspect and maintain your heating system before the cold season.
Check filters regularly. Inspect them monthly and clean or replace them as directed by the manufacturer. Homes with pets or heavy dust may need more frequent attention.
Test CO alarms. Check batteries regularly and replace detectors according to the manufacturer's instructions.
Keep outdoor units clear. Remove leaves and other debris around heat pumps, following the manual's clearance requirements.
Use portable heaters carefully. Keep combustible materials at least three feet away and switch the heater off whenever you leave the room or go to bed.
Reduce drafts. Weatherstripping and sealing gaps around windows and doors can help retain indoor warmth without putting extra strain on heating equipment.
Along with routine maintenance, improving your home's insulation and sealing drafts can help reduce heat loss during winter. Following practical steps to reduce winter heating costs can help you use energy more efficiently while keeping rooms comfortable. These preparations are also useful if extreme weather disrupts electricity or heating service.
When your heater stops working, rule out gas leaks, carbon monoxide alarms, and burning smells before checking the thermostat, breaker, and system-specific issues. Follow the manufacturer's safety guidance and call a qualified technician when needed. Keep your heater's manual and model number handy, and schedule annual maintenance before winter. While waiting for repairs, the EcoFlow DELTA 3 Classic can power lights and Wi-Fi, while the EcoFlow DELTA 3 Max may run a compatible space heater briefly if its output and battery capacity allow.
Why is my heater running but not heating?
A dirty filter or blocked vents can restrict a furnace's airflow. A heat pump may also deliver cool air briefly during defrost. If the problem persists, or the outdoor unit develops heavy ice, contact a technician.
How do I reset my furnace?
Check the thermostat settings, breaker, and furnace power switch. Reset a tripped breaker only once. If it trips again, stop and arrange professional service rather than repeatedly resetting it.
Can I fix a gas heater myself?
Limit yourself to basic checks described in the owner's manual. Do not repair gas valves, burners, igniters, or internal electrical parts. If you smell gas, leave immediately and call for help from outside.
Why does my space heater keep turning off?
Tip-over and overheat protection may shut it down. Unplug it, let it cool, and follow the manufacturer's instructions. If shutdowns continue or the plug or cord becomes hot, stop using the heater.
Can a portable power station run a space heater overnight?
No. Assuming 85% of a 2,048Wh battery's capacity is usable, an EcoFlow DELTA 3 Max could run a 1,500W space heater for approximately 1.2 hours (2,048Wh × 0.85 ÷ 1,500W ≈ 1.16 hours), assuming continuous operation and excluding additional conversion losses. Actual runtime may vary depending on power consumption and operating conditions. Never leave a portable space heater running while sleeping.
