Early November Mountain Snow Risk: What NOAA's Outlook Really Shows and How to Prepare
A map making the rounds this fall shows a heavy snow risk for western mountains in early November. It’s real, but it’s easy to misread. The map comes from a NOAA outlook that flags a "slight risk" for certain ranges on certain days, not a promise of feet of snow. This article explains what the early November mountain snow risk actually covers, what NOAA’s longer outlooks say about this winter, and how to prepare for closed passes, slick roads, and power outages if a storm does arrive.
Where the early November mountain snow risk map comes from
The viral map traces back to NOAA’s Climate Prediction Center (CPC). It’s the CPC’s Days 8 to 14 U.S. Hazards Outlook. This product looks one to two weeks ahead and updates often. That’s why articles show slightly different dates and areas.
News coverage of the map made October 24, 2026 described a "slight risk of heavy snow" for the Cascades, the Sierra Nevada, and the Colorado Rockies. The newer CPC outlook, made October 25 and valid November 2 to 8, is more specific. It flags heavy snow for the Central Rockies on Monday, November 2. It flags heavy snow for high elevations of the Cascades, Klamath, and northern Sierra Nevada from November 4 to 8. A trough moving toward the Pacific Northwest coast drives that second risk.
The same outlook flags heavy precipitation for the Pacific Northwest and Northern California. It also flags high winds on the Pacific Northwest coast. Every hazard carries a "slight risk" rating. The page gives no snow amounts.
CPC outlook made October 25, 2026. Data as of October 28, 2026.
Area | Hazard | Dates | Risk level |
Central Rockies | Heavy snow | Mon, Nov 2 | Slight |
Cascades, Klamath, northern Sierra Nevada | Heavy snow | Wed to Sun, Nov 4 to 8 | Slight |
Pacific Northwest and Northern California | Heavy precipitation | Wed to Sun, Nov 4 to 8 | Slight |
Coastal Pacific Northwest | High winds | Wed to Sun, Nov 4 to 8 | Slight |
How to read a "slight risk"
A slight risk flags a possibility one to two weeks out. It doesn’t forecast totals for a town or a pass. In the days before travel, switch to your local NWS forecast office. Once a storm gets closer, winter storm watches, warnings, and advisories from your local NWS office replace the long-range map.
Outlooks start the conversation. Local alerts tell you when to act. Once a storm gets closer, winter storm watches, warnings, and advisories from your local NWS office replace the long-range map.
A one-week snow risk is one thing. Whether the whole season will be snowy is a different question that NOAA answers with different tools.
What NOAA's longer outlooks say?
NOAA doesn’t forecast seasonal snow totals. Its monthly and seasonal outlooks give the odds of above, near, or below normal temperature and precipitation. This year, a strong El Niño shaped those odds.
CPC’s October 8 diagnostic discussion keeps an El Niño Advisory in effect. It calls for a strong-to-very strong El Niño from January to March 2027, with a greater than 83% chance. Understanding how El Niño shapes US weather helps explain why the West and the South can see opposite winters.
A drier monthly tilt doesn’t rule out single storms. Early November slight risk and a drier November outlook can both be true. Understanding how El Niño shapes US weather helps explain why the West and the South can see opposite winters.
Snow that falls on high passes can still close roads and down power lines in the towns below, so a small power plan is worth having before the first storm.
Planning power for outages and snow-blocked roads
Mountain storms can close highways and cause outages at the same time. When crews can’t get through, outages last longer. A charged power station can cover phones, lights, and a fridge for a limited stretch.
CDOT calls Colorado’s Chain Law the final step before a highway closes. When roads close, utility crews face the same delays as everyone else.
Food safety matters in a long outage. FoodSafety.gov says a fridge keeps food safe for up to four hours without power. A full freezer holds for about 48 hours if you keep the door closed. NWS also advises a flashlight, a battery-powered NOAA Weather Radio, and extra medication. It warns never to run a generator in an enclosed space.
Cold matters too. Most tips for using power stations in cold weather come down to charging indoors and keeping the unit off cold floors. Keep any power station in the heated part of the house, not in a garage or car overnight.
In snow country, the first hours of an outage are about staying informed and keeping food safe until roads reopen. EcoFlow portable power stations charge from a wall outlet before a storm and run indoors without fumes. One fits a small communications kit. A larger one adds a refrigerator and other higher-energy tasks for a limited time.
Cabin owners and renters who mostly need light, a radio, and charged phones can keep it simple. A 1kWh unit covers that list and sits easily on a shelf near the warmest room.
EcoFlow DELTA 3 Classic (1024Wh)
Light and Communications: A 1,024Wh LFP battery runs LED lamps, phones, and a NOAA Weather Radio during a snow outage.
Know the Cold Limits: Charges between 32°F and 113°F and discharges down to 14°F, per EcoFlow. Keep it indoors where it’s warm.
Charge Before the Storm: 0 to 80% in about 45 minutes on AC. Actual time varies.
More Ways to Refill: Accepts up to 500W of solar input. It can also charge from a car with the EcoFlow 500W Alternator Charger (sold separately), only with the vehicle outdoors and its exhaust pipe clear of snow.
Households that want to keep a fridge cold through a longer closure need more stored energy. A 2kWh unit handles that alongside the communications load, within its limits.
EcoFlow DELTA 3 Max (2048Wh)
Fridge and Phones Together: 2,048Wh supports a suitably sized fridge plus communications for a limited time. See the estimates below.
Startup Margin: 2,400W rated output and 4,800W surge help with compressor startup. Check the fridge nameplate.
Recharge When Power Returns: 0 to 80% in about 68 minutes from a wall outlet or generator.
Not a Heater: Use it for critical loads, not space heaters or snow equipment. Heating loads drain a 2kWh battery fast.
How do the two products divide the job?
The EcoFlow DELTA 3 Classic handles communications and lighting. The EcoFlow DELTA 3 Max adds a suitably sized fridge and other higher-energy tasks. These runtimes are estimates.
Load (example) | Watts used | DELTA 3 Classic (1,024Wh × 0.85 = 870Wh) | DELTA 3 Max (2,048Wh × 0.85 = 1,741Wh) |
Phones, weather radio, LED lamp | 20W (example) | about 43 hours | about 87 hours |
13.9 cu ft top-freezer fridge (ENERGY STAR listing: Frigidaire FFHT1425V, 332 kWh/yr ÷ 8,760 hours) | about 38W average | about 23 hours | about 46 hours |
Fridge + communications | about 58W | about 15 hours | about 30 hours |
Method: capacity (Wh) × 0.85 (a planning assumption for conversion losses) ÷ load (W).
Cold affects every battery, so placement matters. Most tips for using power stations in cold weather come down to charging indoors and keeping the unit off cold floors.
The other half of early-season snow prep happens in the car, before you head up a pass.
Mountain travel prep: traction laws, chains, and a car kit
Early November storms often catch drivers on summer tires. Mountain states have rules for that, and fines when drivers ignore them. Check the road before you go, and pack for a long wait.
Colorado
The Traction Law applies on I-70 from Morrison to Dotsero between September 1 and May 31, or whenever conditions require. CDOT can apply it on any state highway. Passenger vehicles need at least 3/16-inch tread with all-weather or winter-rated tires. Otherwise, they must carry chains or an approved traction device. Fines are $100 plus a $33 surcharge. If noncompliance closes a lane, the fine is $500 plus a $157 surcharge. Check COtrip.org before you drive.
California
Caltrans says to always carry chains in winter mountain driving. You must stop and put them on when signs require it. Check Caltrans QuickMap or call the Highway Information Network at (800) 427-7623.
Washington
Pass conditions appear on WSDOT’s mountain passes page. Check it before you go.
Knowing what belongs in a winter car kit saves a scramble on the morning of the first storm. NWS suggests:
Phone, charger, and spare batteries
Blankets and dry clothing
Flashlight and first-aid kit
High-calorie food and water
Shovel and windshield scraper
Sand or cat litter
Jumper cables and paper maps
A packed car kit turns a closed pass into an inconvenience instead of an emergency. Knowing what belongs in a winter car kit saves a scramble on the morning of the first storm.
Back home, early snow brings its own checklist, from heating fuel to carbon monoxide alarms.
At home in snowy countries: outage and heating safety
Heavy, wet early-season snow can bring down branches and power lines. Outages in the cold make heating the riskiest part of the day. Plan safe heat sources before the first flakes fall.
Refill heating fuel before you run low. Deliveries may be delayed for days.
Use a properly vented fireplace, wood stove, or space heater with fire safeguards.
Test smoke alarms monthly. Keep a working carbon monoxide detector, with its outside vent clear of snow.
After a storm, check that snowdrifts aren’t blocking furnace vents.
Never use a generator, grill, or other gas, propane, or charcoal device inside your home, garage, or carport. Keep generators at least 20 feet from doors, windows, and vents, per the CDC.
To hold heat, close off unused rooms, block drafts under doors, and close curtains.
Stay away from downed lines. Call 911 if anyone is in danger. Report outages through your utility’s official outage page.
Long outages in snow need a different plan than a quick summer blackout. Surviving a winter storm power outage gets easier when heat, food, and light each have a backup.
The early November mountain snow risk comes from NOAA’s CPC Days 8 to 14 Hazards Outlook. It shows slight risks for the Central Rockies, Cascades, Klamath, and northern Sierra. Longer outlooks lean drier in parts of the West under a strong El Niño. Watch local NWS alerts, and check COtrip, QuickMap, or WSDOT before you drive. Pack a car kit. An EcoFlow DELTA 3 Classic covers lights and communications, and an EcoFlow DELTA 3 Max adds a fridge.
What is the early November mountain snow risk map?
It’s NOAA’s Climate Prediction Center Days 8 to 14 Hazards Outlook. The version circulating in late October 2026 showed slight risks of heavy snow for western mountain ranges in early November.
Which mountains have a heavy snow risk in early November 2026?
The CPC outlook made October 25, 2026 lists the Central Rockies for November 2. It lists the Cascades, Klamath, and northern Sierra Nevada from November 4 to 8. Check the latest CPC update, since it changes often.
Is this winter going to have a lot of snow?
NOAA doesn’t forecast seasonal snow totals. Its November outlook favors below-normal precipitation in parts of the West, linked to a strong El Niño. Single storms can still bring heavy snow.
Does snow in November mean a snowy winter?
Not necessarily. Early-season storms and seasonal totals follow different patterns. NOAA’s outlooks give odds, not guarantees.
Can a portable power station heat my home during a snow outage?
No. A unit like the EcoFlow DELTA 3 Max is meant for critical loads such as a fridge, lights, and phones. Heating appliances drain it quickly, so use a safe, vented heat source instead.
