Kohler Whole House Generator Cost: MSRP, Installation, and How a Battery Compares
Kohler publishes a starting MSRP for each of its home standby generators, which makes the equipment part of the price easy to find. The total cost of a Kohler whole house generator is a different number. It adds a transfer switch (unless the model includes one), a gas line, a pad, electrical work, permits, and yearly maintenance. This guide breaks down Kohler's whole house generator cost using Kohler's own MSRP figures, lists every installation line item to get quoted, explains RCA vs RCAL models, and compares a battery backup plan for the same critical circuits.
Kohler Generator Prices: What Kohler Lists
Kohler shows a starting MSRP on each model page. Final pricing comes from a dealer. Some models include an automatic transfer switch and some don't.
When you look up Kohler generators prices online, the numbers on the manufacturer's site represent the base equipment only. As Kohler notes on its product pages, "Final pricing will be determined by your dealer based on product customization and installation type."
Here is how the published U.S. product listings compare (checked November 18, 2026). The 26RCA transfer-switch package needs special care: its product page says Included, while Kohler specification G4-315 (26RCA), 4/26g lists an optional RXT switch and separately describes a 26RCAL package. Confirm the exact SKU and included components in a dated dealer quote before treating the switch as included or adding its cost.
Model (Kohler page) | Size | Starting MSRP | Transfer switch |
14RCA | 14 kW | $5,098 | Sold separately |
26RCA | 26 kW | $7,546 | Official sources differ; confirm exact dealer package |
26RCAL | 26 kW | $8,515 | Included |
RCA vs. RCAL: Why the Transfer Switch Matters
The transfer switch affects what is included in the equipment package. Check the full model, package SKU, and quote; do not infer the included hardware from the model suffix alone.
RCA models: The 14RCA product page lists the transfer switch as sold separately. For the 26RCA, the product page and specification sheet differ, as noted above. Ask the dealer to identify the switch model and whether it is included in the specific package being quoted.
26RCAL package: Kohler lists a transfer switch as included, and G4-315 describes a package with a 200A Model RXT switch. The listed $8,515 MSRP is $969 above the 26RCA's $7,546 MSRP; that price difference alone does not establish a standalone switch price.
A compatible automatic transfer switch is part of a safely installed automatic standby system, whether it is supplied in the generator package or purchased separately. Have the dealer specify a service-entrance or critical-circuit arrangement that suits your installation, with safe isolation from the utility supply.
Sizing Up: 14 kW vs. 26 kW
Choosing between a 14 kW and a 26 kW unit depends entirely on what you want to power when the grid goes down.
14 kW (14RCA): Often used for essential circuits or smaller homes. It can typically handle a fridge, lights, internet, a furnace fan, and a smaller central air unit, depending on startup draw.
26 kW (26RCA / 26RCAL): Built for larger homes with heavier electrical demands. It gives you more headroom for multiple AC units, electric water heaters, or well pumps running at the same time.
Standby costs vary widely across manufacturers and fuel types. Before locking in a model size, it helps to compare what whole house generators cost across brands so you know how equipment pricing stacks up against total project expenses.
To compare fairly with a battery, price both against the same list of critical circuits and the same outage length.
Comparing a Home Battery for the Same Critical Circuits
A standby generator and a home battery approach backup power differently. A generator uses natural gas or propane to produce electricity. A battery stores electricity and uses that stored energy during an outage.
Before comparing their prices, make a list of the circuits you need to protect.
For example, your critical-load list might include:
Refrigerator and freezer
Essential lighting
Internet router and networking equipment
Selected kitchen appliances
Heating system controls
Essential outlets
Other priority household circuits
Your list determines the equipment and capacity you'll need.
A battery system is sized around stored energy, output power, and opportunities to recharge. A generator is sized around electrical demand and its available fuel supply.
EcoFlow TITAN 5000
If your outage plan covers critical circuits rather than the whole house, EcoFlow TITAN 5000 is a battery-based comparison. It backs up selected circuits through a Smart Home Panel 10 installed by a licensed electrician and recharges from solar or a generator.
For the same critical-circuit list, price an EcoFlow TITAN 5000 with SHP10 and enough extra batteries for your typical outage length.
Side-by-Side Cost and Runtime Estimates (Example)
To compare a 14 kW Kohler setup and an EcoFlow TITAN 5000 setup, use the same critical loads. The example below assumes an 800W average load and an illustrative 85% usable-energy factor applied to the TITAN 5000's 5,017.6Wh rated battery capacity: 5,017.6Wh × 0.85 = 4,264.96Wh, rounded to 4,265Wh. Dividing by 800W gives about 5.3 hours without recharging. The 85% factor is an estimate selected for this calculation, not an EcoFlow efficiency specification or runtime guarantee. Actual runtime varies with the load and operating conditions; pricing varies by region and date.
Comparison Factor | Kohler 14RCA (Estimate) | EcoFlow TITAN 5000 (Estimate) |
Equipment price source | Kohler MSRP $5,098 (ATS sold separately) | EcoFlow page: TITAN 5000 + SHP10 $4,199 (promotional, Nov 16, 2026) |
Added equipment | Transfer switch, concrete/composite pad, gas line | Extra batteries for longer outages |
Installation | Itemized dealer quote | Qualified, licensed electrician quote |
Runtime driver | Natural gas or propane fuel supply | Stored battery energy + recharge (solar, generator) |
800W average critical load | n/a (runs on continuous fuel) | About 5.3 hours (4,265Wh ÷ 800W) |
How to Budget Each Option Fairly
Because prices change frequently, you should recheck both product pages and request formal quotes at the time you are ready to buy. Make sure every quote you collect clearly states your region, the date, the system's continuous output, and the supported backup duration.
Budgeting a Battery System: Storage capacity affects the upfront cost. Under the 85% usable-energy assumption above, one base battery would support an 800W average load for about 5.3 hours without recharging. The load could include a refrigerator, modem, LED lights, and selected outlets, but measure the actual devices and account for their cycling. Longer outages may require additional batteries or a suitable recharge plan. A qualified, licensed electrician must install the Smart Home Panel 10; its grid connection is configured as "No Export."
Budgeting a Gas Generator: Your equipment price is fixed by the kilowatt rating, while your runtime depends on utility gas availability or the size of your propane tank. You trade battery expansion costs for plumbing work, permitting, and ongoing engine upkeep.
Battery backup has its own set of electrical and hardware expenses. To see how capacity scaling affects your bottom line, look at whole house battery backup costs too before deciding which route fits your home.
Back to the generator: the installation line items.
Kohler Generator Installation Cost: What to Get Quoted
Installation often adds a large share to the equipment price. Each home differs. Ask for an itemized quote.
If you search online for Kohler generator installation costs, you won't find an official flat rate from the manufacturer. Kohler explicitly states that "a full installation quote requires a personalized home assessment." Every yard, breaker panel, and gas meter setup is different, which means two neighbors can end up with very different labor and material bills.
Instead of relying on rough guesses, ask your local Kohler dealer for a line-by-line written estimate. A thorough quote should state your region, the date of the estimate, and break down every required component.
Your Itemized Installation Quote Checklist
Use this checklist when reviewing bids from local dealers and contractors so nothing gets left out as a surprise change order later:
Automatic Transfer Switch (ATS): Ask the dealer to name the switch in the quote and specify whether it is included in the exact generator package or priced separately. Confirm whether the installation uses a whole-house service-entrance switch or selected critical circuits. Do not add a second switch charge when the required switch is already included.
Mounting Pad: Standby units sit outdoors on a level concrete slab or a pre-cast composite pad to keep the housing out of standing water and mud.
Fuel Supply Line: For natural gas, a plumber must run a pipe from your meter to the generator pad. Your utility company may also need to upgrade the gas meter to handle the higher flow rate. For propane, you'll need a leased or purchased tank, trenching, and regulators.
Electrical Wiring and Panel Work: Conduit, heavy-gauge copper wiring, whips, and labor to tie the transfer switch into your main breaker panel.
Permits and Municipal Inspections: Local building, electrical, and plumbing permits required by your city, county, or HOA, plus final sign-off inspections.
Startup and Dealer Commissioning: Once installed, a certified technician must test voltage, verify transfer switch operation, check fuel pressure, and register the unit for warranty coverage.
First-Year Maintenance Plan: Many dealers offer a service contract covering oil changes, filters, and annual load testing.
Why Home Assessments Change the Price
During an on-site visit, a dealer checks for physical obstacles that could increase labor time. For example, if your gas meter sits on the opposite side of the house from your main electrical panel, contractors may need to run pipes and conduit across the yard or through a finished basement. This adds material and labor costs.
Local setback rules also affect generator placement. These rules specify how far the unit must sit from windows, doors, vents, and property lines. These requirements determine where the installation pad can go.
Install costs have alternatives depending on how you structure your home's electrical panel. For a deeper look at what drives contractor pricing, dig into standby generator installation costs across different home setups.
Finally, running and upkeep.
Running and Maintenance Costs of a Kohler Standby Generator
Fuel and maintenance continue after installation. Natural gas or propane use depends on load. Schedule service per the manual.
Once your generator is installed on its pad and connected to your electrical panel, ownership costs shift from upfront installation to ongoing operation. A standby generator uses an internal combustion engine, so it burns fuel whenever it runs, including during weekly self-tests. It also requires regular mechanical maintenance to stay ready for the next outage.
Estimating Your Fuel Expenses
Fuel consumption isn't a single fixed number. A 14 kW or 26 kW generator burns more natural gas or propane when your central air conditioner kicks on than it does overnight when only your refrigerator and a few lights are drawing power.
To calculate what an outage will cost you in fuel:
Check the model spec sheet: Read the fuel-consumption units and the 50% and 100% load rows for the exact model. Kohler's 26RCA specification (G4-315, p3) reports both natural-gas and LPG consumption in cubic feet per hour (cfh). Its 60Hz values are 180/290cfh for natural gas and 85/129cfh for LPG at 50%/100% load. These are different load points, not a constant hourly burn rate.
Apply your local fuel rate after converting units: For natural gas priced per CCF, hourly fuel cost = (cfh ÷ 100) × price per CCF. For a price per therm, first convert the gas volume using your supplier's heat-content or billing factor, then multiply therms per hour by the price per therm. The EIA defines CCF and therm units and explains the heat-content conversion. For the 26RCA's LPG figures, G4-315 gives 36.39ft³ per gallon: divide LPG cfh by 36.39 before multiplying by your local propane price per gallon. Use the manufacturer's conversion for the stated fuel conditions; do not multiply cfh directly by a therm, CCF, or gallon price.
Factor in exercise cycles: Standby generators automatically start up once a week or every two weeks for a short diagnostic run, using a small amount of fuel year-round.
Routine Maintenance and Safety Rules
Skipping maintenance can void your warranty and leave you without power during wildfire season or a winter storm. Follow the service schedule in your owner's manual, which typically includes changing the oil, replacing the oil and air filters, inspecting spark plugs, and checking the starting battery every year or after a set number of runtime hours.
Safe placement is just as important as mechanical upkeep. Standby generators produce carbon monoxide (CO), an odorless, colorless gas that can be fatal.
Follow maker clearances: Always install the unit outdoors at the exact distance from windows, doors, soffit vents, and air intakes specified in Kohler's installation manual.
Install CO alarms: Per CDC guidance, install battery-operated or battery-backup carbon monoxide detectors on every level of your home and outside sleeping areas, and test them regularly.
Running costs add up quickly during multi-day grid failures. To plan ahead for extended outages, use our guide to estimate the cost to run a whole house generator based on your local fuel rates.
Kohler whole house generator cost starts with the listed equipment MSRP; the 14RCA, for example, starts at $5,098. Add the cost of any required transfer switch that is not already in the quoted package, plus gas work, a pad, labor, permits, and maintenance. Confirm the exact 26RCA package because its published transfer-switch information differs between official sources.
Here's the takeaway. Get itemized quotes for the same critical circuits and the same outage length. That's the only way to see the real difference between options.
To make the smartest choice for your home, list your critical circuits first and request itemized, written quotes for the exact same loads and outage duration. Comparing a traditional standby dealer bid against an installed EcoFlow TITAN 5000 quote from a licensed electrician lets you see real-world numbers side by side before committing.
How much does a Kohler whole house generator cost?
Kohler publishes starting MSRPs for its home standby generators. For example, the 14RCA starts at $5,098, the 26RCA at $7,546, and the 26RCAL at $8,515. Installation and other project expenses are additional.
Does a Kohler generator include a transfer switch?
It depends on the exact model and package. The 14RCA product page lists the switch as sold separately, while the 26RCAL listing shows it as included. For 26RCA, the current product page says Included, but G4-315 specification 4/26g lists an optional RXT switch and a separate 26RCAL package. Obtain a dated dealer quote identifying the exact SKU and included switch; do not assume either package from the model name alone.
Why can't I get a Kohler install price online?
Kohler notes that a full installation quote requires a personalized home assessment. Factors like the distance between your gas meter and breaker panel, local permit fees, pad prep, and municipal setback rules vary too much from house to house to price online.
Is a home battery cheaper than a Kohler generator?
It depends on your critical loads, typical outage length, and local installation quotes. For short outages on essential circuits, a battery setup may cost less upfront, whereas multi-day outages requiring large battery banks can change the math. Always compare full installed quotes for the exact same circuits.
Can a Kohler generator run indoors?
No. Standby generators burn natural gas or propane and emit carbon monoxide. They must be installed outdoors following Kohler's exact clearance rules and CDC guidance, which recommends placing generators more than 20 feet away from windows, doors, and vents. Your home should also have working battery-operated or battery-backup CO detectors.
