Kerosene vs Propane Heater: Which Is Better for Heat, Cost, and Safety?
Kerosene and propane heaters can keep a garage, workshop, or other space warm without relying on a wall outlet. But they use different fuels, and that affects how you store, refill, and operate them. Indoor use also comes with strict safety rules. This guide compares kerosene vs propane heaters, including heat output, fuel handling, and running costs. You'll also find an electric option for personal warmth during an outage when you'd rather avoid running a fuel-burning heater indoors.
Kerosene vs Propane Heater: Key Differences
Kerosene vs Propane Heater: Key DifferencesKerosene vs Propane Heater: Key Differences
Both kerosene and propane heaters burn fuel to produce heat. They also release combustion byproducts, including water vapor and carbon monoxide. Kerosene is a liquid stored in the heater's tank, while propane comes in a pressurized cylinder or tank. That difference affects how you handle and store each fuel.
Factor
Kerosene heater
Propane heater
Fuel form
Liquid, poured into tank
Pressurized cylinder or tank
Fuel energy
About 135,000 Btu per U.S. gallon (EPA default heat content).
91,452 Btu per gallon (EIA)
Refueling
Outdoors, when off and cool (CPSC)
Swap or connect cylinder per manual
Odor
Toyotomi notes possible odor during start-up or shut-down.
Odor is not a safety test; carbon monoxide is odorless.
Indoor use
Only models and places allowed by maker and local rules
Only models rated for indoor use
Heat output and fuel efficiency
Don't assume one fuel always produces more useful heat. Check the heater's Btu-per-hour rating to see how much heat a specific model delivers. A larger rating means more heat output, but the heater's size and the space you're trying to warm matter too. The US Energy Information Administration (EIA) lists propane at 91,452 Btu per gallon. That's a useful figure when comparing fuel energy, but it doesn't tell you how much heat a particular heater will deliver. For kerosene, the EPA lists a default heat content of 135,000 Btu per U.S. gallon. These reference values describe energy in the fuel, not a heater's delivered heat output. Use your fuel supplier's heat-content data when available.
Fuel storage and refueling
Kerosene needs a suitable container and careful handling. The Consumer Product Safety Commission (CPSC) says to use only 1-K kerosene in kerosene heaters. Even a small amount of gasoline mixed into the fuel can create a fire risk. Always refuel outdoors, and wait until the heater has cooled completely. Propane is stored under pressure in cylinders or tanks. Follow the heater manual when connecting or replacing a cylinder, and check that the connections are suitable for the model. Store propane cylinders according to local fire codes and supplier guidance.
Odor and indoor use
Toyotomi notes that its kerosene heaters may produce minimal odor during start-up or shut-down. Smell is not a safety test for either fuel: the CDC states that carbon monoxide is odorless. Check the manufacturer's instructions and local rules before using either type inside a home. Some models are designed only for outdoor use. If you're comparing fuel heat with electric options, our guide to propane vs electric heater costs explains how their power requirements differ. Fuel choice is only one part of staying warm during an outage. If you don't want a combustion heater running indoors, a battery-powered electric option may be worth considering.
A Fume-Free Alternative for Outages: Battery-Powered Personal Warmth
If you don't want to run a fuel-burning heater indoors during an outage, an electric blanket can keep you warm without heating the whole room. A portable power station can run the blanket, along with a lamp or phone charger, for a limited time. A small space heater is another option, but it uses much more battery power. EcoFlow portable power stations offer two ways to handle these loads. The EcoFlow DELTA 3 Classic can power a compatible electric blanket and small devices, while the EcoFlow DELTA 3 Max Plus can run a suitable 120V plug-in heater for short, supervised use. Check the appliance's wattage and estimate runtime before choosing a unit.
EcoFlow DELTA 3 Classic for personal warmth
For one person staying warm overnight, an electric blanket on a low setting is a practical choice. Checking how much power an electric blanket uses helps you estimate how long it can run on battery power. A 1,024Wh battery can run a compatible blanket for several hours, depending on its power use, while leaving some capacity for a lamp and phone.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
EcoFlow DELTA 3 Max Plus for short-term spot heating
If you need more direct heat in one area, a small 120V space heater can provide short-term warmth. The EcoFlow DELTA 3 Max Plus offers 3,000W of output, enough to run a compatible heater after checking its wattage and startup requirements. Its 2,048Wh battery provides more capacity than the EcoFlow DELTA 3 Classic, and you can add compatible extra batteries to extend runtime. Use the heater only for short, supervised periods.
EcoFlow DELTA 3 Max Plus (2048Wh)
•3,000W Output: 6,000W surge. X-Boost mode can run some appliances up to 3,800W, though results vary by device. •Fast Recharging: 5 ways to charge, reaching 0 to 80% in 43 minutes with generator charging. • Expandable Capacity: 2kWh base, expandable to approximately 10kWh with two DELTA Pro 3 Smart Extra Batteries and the EcoFlow Smart Extra Battery Expansion Adapter (sold separately). Pairing with a compatible EcoFlow Smart Generator adds automatic start and stop for longer runtime.
The two products serve different needs. The EcoFlow DELTA 3 Classic powers a compatible electric blanket, lights, and phones for personal warmth. The EcoFlow DELTA 3 Max Plus can run a verified 120V plug-in heater for short, supervised spot heating. Compatible extra batteries, sold separately, can extend its runtime.
Estimated runtime for blankets and space heaters
The estimates below use 85% of each battery's stated capacity as usable energy. Actual runtime depends on the device's power draw, conversion losses, and how often its thermostat cycles.
Load (example)
Watts used
EcoFlow DELTA 3 Classic (870Wh usable est.)
EcoFlow DELTA 3 Max Plus (1,741Wh usable est.)
Electric blanket on low (placeholder 50W average)
about 50W
about 17 hours
about 35 hours
1,500W space heater on high, running continuously (label example)
about 1,500W
about 0.6 hours
about 1.2 hours
Same heater cycling about half the time on low (placeholder 750W average)
about 750W
about 1.2 hours
about 2.3 hours
These are planning estimates, not guaranteed runtimes. The 50W blanket and 750W average heater loads are placeholders. Replace them with measured or labeled figures before making a purchase decision. To estimate runtime, divide usable battery capacity by the device's average wattage. For example, 870Wh divided by 50W gives about 17.4 hours. A 1,500W heater uses that same energy much faster.
Kerosene and Propane Heater Safety Rules
Kerosene and propane heaters need careful handling because both burn fuel and can produce carbon monoxide (CO). Follow the heater manufacturer's instructions and local rules, even if you've used a similar model before. The CPSC provides guidance on fuel, ventilation, clearances, and maintenance.
Kerosene and Propane Heater Safety RulesKerosene and Propane Heater Safety Rules
Refuel and store fuel safely
For kerosene heaters, use only 1-K kerosene. Refuel outdoors after the heater has been turned off and allowed to cool. Never fill past the tank's full mark, and don't use gasoline or other fuels in place of kerosene. For propane heaters, follow the manual when connecting or replacing cylinders. Keep fuel containers away from heat sources and follow local storage requirements. Never modify fuel connections or use a cylinder that the heater isn't designed to accept.
Prevent carbon monoxide exposure
Carbon monoxide has no smell, so you can't detect it by scent. Install working CO alarms in your home, especially near sleeping areas, and follow the alarm manufacturer's placement instructions. The CPSC also advises keeping doors open to the rest of the house when using an unvented fuel-burning space heater. Never leave a space heater running when you go to sleep or leave the area. If a CO alarm sounds, get everyone outside into fresh air and call emergency services. Don't reenter until the space has been checked and declared safe.
Keep heaters away from anything that can burn
The CPSC recommends keeping space heaters at least three feet away from bedding, furniture, drapes, and other objects that can catch fire. Place the heater on a stable surface where it won't tip over, and keep children and pets away from it. Have gas and kerosene space heaters inspected annually by a qualified technician. Also check local rules before using a kerosene heater indoors, as some states and cities restrict their use. For more on CO risks from fuel-burning equipment, read our guide to carbon monoxide safety.
Which Costs Less to Run: Kerosene or Propane?
The cheaper option depends on local fuel prices and how much heat you need. Instead of comparing the price per gallon, compare the cost per million Btu to get a clearer picture of what each fuel delivers. To calculate it, divide the price per gallon by the fuel's Btu per gallon, then multiply by 1,000,000. The EIA lists propane at 91,452 Btu per gallon. For kerosene, use the figure provided by your fuel supplier or heater manual. Since fuel prices vary by location and season, check current prices before choosing a heater. Fuel is also one of several budget ways to stay warm in winter, so include maintenance and storage costs when planning your heating budget.
Choosing between a kerosene and propane heater comes down to fuel handling, the heater's approved use, and local fuel prices. Both need careful operation, proper clearances, and working CO alarms. Never leave a fuel-burning space heater on while you sleep. If you'd rather avoid combustion heat during an outage, the EcoFlow DELTA 3 Classic can power a compatible electric blanket, while the EcoFlow DELTA 3 Max Plus can run a suitable 120V space heater for a limited time under supervision. Check the actual wattage before relying on either option.
Is kerosene or propane better for indoor heating?
Use only a heater that the manufacturer rates for indoor use, and check local rules. Both fuel types require careful ventilation and a working CO alarm. Follow the heater's instructions for clearance, fuel, and operation.
Which produces more heat, kerosene or propane?
Compare the Btu-per-hour rating of the heaters rather than assuming one fuel always produces more heat. The EIA lists propane at 91,452 Btu per gallon. For kerosene, check the fuel supplier or heater manual.
Can I use a kerosene heater in my house?
Only if the heater is approved for indoor use and local rules allow it. Use 1-K kerosene, refuel outdoors after the heater cools, maintain proper ventilation, and install a working CO alarm. Never leave it running while you sleep.
Is it safe to sleep with a propane heater on?
No. The CPSC advises against leaving a space heater running when you go to sleep or leave the area. Turn it off before bed and follow the manufacturer's safety instructions.
Can a power station run a space heater?
A power station can run a compatible plug-in space heater for a limited time, provided the heater's voltage and wattage stay within the unit's limits. A 1,500W heater can use a 2kWh battery in about an hour. An electric blanket draws much less power and is usually the better option for longer personal warmth.
Home Solutions
