Heat Pumps for Mobile Homes: Types, Sizing, and Installation Costs
Heating and cooling a mobile home involves more than choosing a smaller version of conventional HVAC equipment. The duct system may run beneath the floor, the furnace closet may be tight, and an older electrical panel may have little unused capacity. Thin insulation and air leaks through damaged belly material can also create a larger heating load than the home’s square footage suggests.
A heat pump for mobile home heating and cooling can be a practical replacement for electric resistance heat, an aging furnace, or window air conditioners. This guide covers the main heat pump options for mobile and manufactured homes, proper sizing, installation costs, and the structural, electrical, and code details to check before work begins.
What Types of Heat Pumps Are Best for Mobile Homes?
The existing ductwork often narrows the choices. Sound under-floor ducts may support a packaged or ducted split system. If the ducts are badly damaged or absent, a mini-split can avoid rebuilding the distribution system. Equipment space and room layout matter as well.
Packaged Heat Pumps for Existing Ductwork
A packaged air source heat pump places the compressor, condenser, coil, and air handler in one outdoor cabinet. Supply and return connections carry conditioned air to the home’s ducts, leaving valuable indoor space free.
This arrangement works best when the home has a compatible exterior connection and usable under-floor ducts. Loose boots, torn flex duct, wet insulation, or a failed crossover can release conditioned air beneath the home. The installer should inspect the air path and seal the exterior transitions, not assume the ducts are sound because air reaches each register. The unit also needs a stable pad, proper drainage, and enough room for service.
Ducted Split Heat Pumps for Whole-Home Comfort
A ducted split system pairs an outdoor compressor with an indoor air handler or coil, often placed in the existing furnace closet. It provides central heating and cooling without putting the air-handling section outdoors.
The contractor must look beyond the closet’s width. Airflow direction, return capacity, filter access, drainage, service clearance, and indoor-outdoor equipment compatibility all matter. A cabinet can fit physically and still restrict the blower or be nearly impossible to service. Persistent trouble at one end of a double-wide may also point to a damaged crossover or duct branch rather than insufficient heat pump capacity.
Ductless Mini-Split Heat Pumps for Homes Without Ductwork
A ductless mini split links an outdoor unit to one or more indoor heads through refrigerant lines, wiring, and a condensate drain. By avoiding under-floor ducts, it can be a sensible choice when repairing the original distribution system would be costly.
A single head may handle an open living, dining, and kitchen area, but it will not necessarily keep closed bedrooms at the same temperature. Multi-zone systems can serve separate rooms, though every added head brings more equipment, line routing, drainage, and labor. Settle the indoor locations before approving the quote so airflow is not directed at a bed or chair, and condensate will not drain onto a walkway. With ratings often exceeding 20 SEER2, mini-splits can be efficient, but the zone plan still has to match the layout.
Heat Pump Type | Best For | Ductwork Needed? | Typical SEER2 Range |
Packaged Unit | Saving indoor space; existing ducts | Yes | 13.4–16 |
Ducted Split | Whole-home heating and cooling | Yes | 14.3–18+ |
Ductless Mini-Split | Homes with damaged or no ducts; room-by-room control | No | 18–28+ |
Note: SEER2 ratings are approximate reference values and vary by manufacturer, model, system configuration, and equipment size. Check the manufacturer’s specifications for the exact rating of a specific heat pump.
A geothermal heat pump exchanges heat with the ground through a buried ground loop. Before considering one, check whether the site can accommodate trenching or drilling and whether you have permission to do that work.
How Do You Choose the Right Heat Pump Size for a Mobile Home?
Heat pump size describes heating and cooling capacity, not cabinet dimensions. Extra capacity “just in case” can cause short cycling, noisy airflow, and poor humidity removal. Too little capacity may leave the system running continuously in severe weather and relying heavily on resistance backup. The old furnace nameplate is not proof of the right replacement size, especially if the windows, roof, insulation, or ducts have changed.
Calculate Heating and Cooling Loads
Square footage is a starting point, but it does not show how quickly a home gains and loses heat. A Manual J load calculation considers local design temperatures, insulation, windows, ceiling height, orientation, air leakage, and duct losses. It should describe the home’s current condition rather than a generic mobile-home template.
Typical preliminary ranges include:
Single-wides (600–1,100 sq. ft.): 1.5–2.5 tons
Double-wides (1,200–2,000 sq. ft.): 2.5–3.5 tons
These figures are conversation starters, not ordering instructions. A shaded, well-sealed double-wide may have a smaller load than a drafty single-wide in full afternoon sun. The contractor should select equipment from the completed calculation, then confirm that the blower and ducts can deliver the necessary airflow. For a mini-split, room-by-room results can also show where separate zones are justified.
Consider Insulation and Local Climate
Homes of the same size can perform very differently. Gaps around plumbing, damaged belly material, loose doors, weak skirting, and leaking duct boots can increase the load even when the walls look sound.
Climate changes the calculation as well. An unshaded mobile home in Texas may need substantial cooling, while low-temperature heating capacity and auxiliary-heat cost may matter more in a northern state. Before buying additional tonnage, ask whether air sealing, duct repair, or insulation would reduce the load. Any roof, plumbing, or ground-moisture problem should be corrected before it is covered with new insulation.
Check Low-Temperature Heating Performance
Nominal capacity does not tell the entire winter story. Air-source equipment generally produces less heat as outdoor temperature falls, just as the home needs more. In the Upper Midwest, Northeast, and other cold regions, review the manufacturer’s capacity data at the local winter design temperature rather than relying on a broad “cold-climate” description.
Some cold-climate models are designed to operate at temperatures as low as -15°F or -22°F, depending on the model. Operation at that temperature does not necessarily mean the unit will carry the home’s full load by itself. Ask the contractor to show the available heating output at low temperatures, the expected balance point, and when auxiliary heat is likely to operate.
This information also affects electrical planning. Resistance backup can cover a shortfall, but it uses considerably more electricity. The controls should make auxiliary heat available when needed without turning it into the default source during ordinary winter weather. If you plan to use a home battery during an outage, ask whether the heat pump can run without auxiliary resistance heat and which other loads would be on at the same time.
How Much Does It Cost to Install a Heat Pump in a Mobile Home?
The equipment is only one line on a heat pump quote. Sound ducts and adequate electrical service keep the job simpler; panel work, crossover repair, condensate changes, difficult under-home access, and permits raise the total.
Compare Equipment and Installation Costs
For a typical 1,000 to 1,500 sq. ft. manufactured home, a complete installation generally falls between $4,500 and $12,500, depending on the system and the work required:
Packaged System: $5,000 – $9,000 (installed)
Ducted Split System: $5,500 – $10,500 (installed)
Multi-Zone Ductless Mini-Split (2–3 zones): $6,000 – $12,500 (installed)
Use these ranges to screen proposals rather than predict a local price. Each quote should identify the equipment, labor, removal of the old system, mounting hardware, line set, controls, condensate work, permits, and startup testing. Work beneath the structure or in a tight downflow closet can make a small home surprisingly labor-intensive. Compare the written scopes as carefully as the totals.
Factor in Ductwork and Electrical Upgrade Costs
Many older manufactured homes have 100-amp electrical service, but that rating alone does not mean an upgrade is necessary. A licensed electrician should calculate the home’s existing electrical load, including the range, dryer, water heater, and other appliances, then account for the proposed heat pump and auxiliary heat. A 5kW to 10kW electric heat strip can add approximately 21 to 42 amps at 240 volts, potentially placing significant demand on an already heavily loaded service.
If the load calculation shows that the existing service cannot support the additional equipment, upgrading the electrical panel or service may be necessary. A panel upgrade may cost around $1,500 to $3,000 in some projects, but the total can be higher if the work involves utility coordination, meter replacement, new feeders, disconnects, or grounding modifications. These items should be identified in the contractor’s proposal before installation begins.
Ductwork is another potential source of additional costs. A damaged crossover duct, sagging run, torn belly material, or loose register boot can restrict airflow or allow conditioned air to escape. Before installing the new heat pump, the contractor should inspect the existing ducts, verify their condition and airflow capacity, and identify any necessary repairs or replacements. Costs will depend on the extent of the damage and access beneath the home.
Expense Category | Typical Cost Range | Notes / Variables |
Heat Pump Equipment & Labor | $4,500 – $11,000 | Tonnage, brand efficiency (SEER2 rating) |
Electrical Panel Upgrade | $1,500 – $3,000 | Upgrading 100A panel to 200A service |
Duct Repair / Crossover Replacement | $800 – $2,200 | Mending tears, re-insulating underbelly lines |
Permits & Inspection Fees | $150 – $500 | Varies by county and park regulations |
The categories should not be added together automatically. Not every project needs every item, and some contractors include portions of the work in the main installation price.
Estimate Monthly Heating and Cooling Costs
Weather, thermostat settings, electricity rates, duct leakage, insulation, sizing, and auxiliary-heat use all affect operating cost. A household replacing baseboard resistance heat also starts from a different point than one replacing an efficient gas furnace.
As a broad planning range, winter electric-bill reductions may reach 30% to 50% when a heat pump replaces electric resistance heating. In cooling mode, a high-SEER2 inverter system may reduce summer electricity costs by $40 to $90 per month compared with inefficient window units or older central equipment. Neither range is guaranteed. Savings will be smaller if the home remains leaky, electricity is expensive, or resistance backup operates frequently.
For a more useful forecast, compare past seasonal energy use with the proposed system’s expected local performance. Ask the contractor to identify the assumed electricity rate and auxiliary-heat use; without those inputs, a savings projection is difficult to evaluate. How many watts a heat pump uses depends on its operating conditions, so use the proposed model’s data and expected runtime when estimating seasonal kWh.
Explore Local Rebates and Incentives
Incentives need to be confirmed before they are included in the budget. The former federal Section 25C credit covered 30% of eligible project costs, up to $2,000 for qualifying heat pumps, but it does not apply to property placed in service after December 31, 2025. A 2026 installation should not be priced on the assumption that this credit remains available.
According to the U.S. Department of Energy’s Home Energy Rebates Program, state, Tribal, and territorial programs may offer HOMES or HEEHR rebates, with eligibility and savings requirements varying by program. Some utilities also provide incentives for replacing electric resistance heating with a heat pump. For example, Silicon Valley Clean Energy offers $500 for standard applicants and $1,500 for income-qualified households, while Puget Sound Energy offers a $1,500 rebate for qualifying conversions. Check current program availability and eligibility before signing a contract, as some programs require advance rebate reservations, income verification, an approved contractor, or qualifying equipment.
What Should You Know Before Installing a Heat Pump in a Mobile Home?
Manufactured-home construction affects appliance listing, airflow direction, duct pressure, electrical connections, drainage, and service access. Those details should be resolved before equipment is ordered.
Check Manufactured Home Equipment Requirements and Local Codes
The home’s manufacturing date can affect which construction and installation standards apply:
Manufactured on or after June 15, 1976: Federal HUD manufactured-home standards apply. Heating appliances and cooling equipment must meet applicable listing or certification requirements and be installed according to their listings and manufacturer instructions. Before selecting a heat pump, confirm that the equipment is approved for manufactured-home applications and that the indoor and outdoor units are compatible. Check airflow requirements, installation clearances, and the home’s existing duct configuration.
Manufactured before June 15, 1976: These homes predate the federal HUD Code. Applicable state-specific manufactured-home regulations, along with relevant local building, mechanical, and electrical requirements, may govern HVAC upgrades and other alterations. Check with the appropriate state or local authority before installation.
Local permitting requirements may also apply to electrical upgrades, duct modifications, and outdoor equipment placement. Residents of leased manufactured-home communities should check their lease and community rules for additional installation or exterior modification restrictions. The contractor’s agreement should specify who is responsible for obtaining permits and scheduling required inspections.
Confirm Installation Space and Clearances
The outdoor unit needs a stable, level base with room for airflow, drainage, and service. Use the selected model’s instructions to check intake, discharge, and service clearances from walls, skirting, fencing, and other obstructions. Keep the cabinet away from roof runoff and leave access to the service panels; in snowy areas, the base may also need additional elevation.
For an indoor air handler, measure the service path as well as the closet opening. The filter and panels must remain accessible, condensate must drain correctly, and the return opening must be large enough. Equipment that barely fits can be difficult to maintain and may restrict airflow.
Hire an HVAC Contractor Experienced in Manufactured Homes
A contractor familiar with manufactured homes is more likely to recognize a failed crossover, restricted downflow plenum, inadequate return, or damaged belly material. Ask each bidder for the load calculation, matched equipment model numbers, relevant low-temperature data, and a written scope for duct and electrical work.
The proposal should also cover commissioning, including airflow, refrigerant charge, thermostat setup, drainage, and auxiliary-heat controls. References from comparable mobile-home projects and a clear explanation of warranty service are more useful than a long list of unrelated installations. If outage backup is part of the plan, list the plug-in essentials a portable power station would serve separately from the hardwired HVAC circuit.
Plan for Backup Power for Heat Pump Operation During Outages
Wind, ice, and winter storms can interrupt power when heating matters most. Backup planning begins with the heat pump’s voltage, running wattage, startup behavior, and auxiliary-heat demand. The source must be matched to the actual equipment.
The EcoFlow DELTA 3800 Gen4 Portable Power Station has 3,763 Wh of battery capacity and a rated AC output of 3,600 W at 120 V. For a compatible 120 V mini-split, check the running and startup loads against the unit’s outlet and circuit limits, including any other loads it will serve. Have a qualified electrician confirm how a hardwired unit can be connected.
Larger 240V central heat pumps generally require more powerful backup systems. The EcoFlow TITAN 5000 Plus supports 120V/240V split-phase output, delivers 7.2 kW of continuous battery power, and offers 5kWh of base capacity expandable to 30kWh. This gives households more flexibility to support compatible heating systems during extended outages.
Electric auxiliary heat strips can draw substantial power, so they should be included in the load review rather than treated as a minor accessory. Check the heat pump’s electrical specifications and consult a qualified electrician about backup compatibility and safe transfer-switch installation.
A heat pump can efficiently heat and cool a mobile home, particularly when it replaces resistance heat or aging window units. Packaged and ducted split systems depend on sound airflow paths, while mini-splits need a zoning plan suited to the rooms.
Before choosing equipment, have a contractor familiar with manufactured housing calculate the load, inspect the ducts and belly area, review electrical capacity, and confirm the installation requirements. Compare quotes by scope as well as price, and verify rebates before including them in the budget. That preparation can prevent excess capacity, surprise electrical work, and efficient equipment being installed over an unresolved duct problem.
What's the Cheapest Way to Heat a Mobile Home?
A high-efficiency ductless mini-split heat pump is the cheapest long-term heating method due to its exceptionally low electricity consumption compared to propane or electric resistance furnaces. While space heaters and baseboards have lower initial purchase costs, their high operating draw makes them drastically more expensive month-to-month.
How Can I Keep My Mobile Home Warm During the Winter?
Inspect and seal your underbelly skirting to block frigid drafts, apply heavy-duty weatherstripping to exterior doors, install insulated thermal curtains over single-pane windows, and keep your heat pump filters clean to maintain optimal airflow across the heating coils.
Are Mobile Homes Hard to Heat and Cool?
It depends on the climate and the home’s insulation, air leakage, and duct condition. An older home with damaged insulation under the floor or leaky ducts may take more energy to heat and cool.
Where Do Mobile Homes Lose the Most Heat?
Mobile homes lose the largest share of heat through uninsulated floors, torn crawlspace belly boards, and drafty single-pane aluminum window frames. Ripped crossover duct boots underneath the chassis can also dump massive amounts of heated air directly outside.
What Temperature Will Pipes Freeze in a Mobile Home?
Water freezes at 32°F, but the temperature at which plumbing in a manufactured home begins to freeze depends on pipe insulation, exposure, and how long cold conditions persist. Water supply lines running beneath the home are particularly vulnerable because cold air can circulate through damaged belly wrap or gaps in the skirting, increasing heat loss from exposed pipes.
