Winter Greenhouse Guide: How to Keep Plants Growing When It Freezes Outside
A greenhouse can keep producing through winter, but closing the door won't protect every plant from a hard freeze. Short days, cold nights, and condensation all affect growing conditions. Some growers use heaters, while others rely on passive solar designs that store daytime heat for the night, such as the deep winter greenhouses developed in Minnesota. This guide covers winter greenhouse performance, insulation, heating, suitable crops, and backup power for essential equipment during an outage.
Does a Greenhouse Work in Winter?
Yes, a greenhouse can work in winter if you match its design and crops to your local climate. Sunlight warms the space during the day, but temperatures can drop quickly after sunset. Insulation, thermal mass, and careful crop selection help manage those changes.
How a greenhouse holds heat
A greenhouse allows sunlight to enter through its glazing, heating the soil, plants, and other surfaces inside. These materials give off heat after dark, but heat continues to leak out through glazing, walls, foundation and openings around doors and vents. The University of Minnesota Extension deep winter greenhouse design uses passive solar heat to store daytime warmth in insulated soil or rock to release at night. It also uses steep, south-facing glazing to absorb more winter sun. Before you choose a setup, consider the amount of sun in your yard, the space available and winter temperatures. Many home growers start with a small greenhouse kit and adapt it to their crops.
What can you grow in a winter greenhouse?
Cold-tolerant crops are usually easier to manage than plants that need warm soil and long days. The University of Minnesota Extension lists several suitable options for deep winter greenhouses:
Lettuce: A practical choice for winter salads, especially cold-tolerant varieties.
Herbs: Several herbs can grow in cooler conditions, depending on the variety and available light.
Brassicas: Crops in this group include plants such as kale and other leafy greens.
Asian greens: These offer several options for cool-season growing.
Sprouts: They can provide fresh produce without requiring the same growing space as mature plants.
Your planting schedule still matters. Short winter days can slow growth, even when the greenhouse stays above freezing. Check the temperature and light needs of each variety before planting, and consider supplemental grow lights if natural daylight isn't enough.
Backup Power for a Winter Greenhouse: Fans, Sensors, and Heat Mats
A power outage on a cold night can shut down circulation fans, temperature monitors, and seedling heat mats when plants need them most. A portable power station can keep selected equipment running for a limited time, but it won't heat the entire greenhouse or guarantee that crops stay above freezing.
Which equipment should you keep running?
Begin with the most important equipment for your plants. There is a temperature sensor so you can monitor the conditions and get alerts. There is a small circulation fan to keep the air moving. Seedling heat mats only heat around the tray and container, not the entire greenhouse. Check each device's wattage and how many hours it needs to run before choosing backup power.
Plan backup power around your needs
On a cold night, a winter greenhouse may depend on a few small electric devices: a sensor, a circulation fan, and heat mats under seedlings. EcoFlow portable power stations can keep selected equipment running during an outage. Store the unit in a dry, sheltered place, such as an attached garage or potting shed, and protect it from greenhouse humidity and condensation. Choose a model based on the loads you need to support and how long you need to run them.
EcoFlow DELTA 3 Classic for monitoring and air circulation
If you mainly need to power a temperature sensor, phone, and small circulation fan, the EcoFlow DELTA 3 Classic's 1,024Wh battery can support these lighter loads for many hours, depending on their actual power use.
EcoFlow DELTA 3800 Gen4 for seedling heat mats
If you need to run several seedling heat mats through cold nights, a larger battery can provide more runtime. The EcoFlow DELTA 3800 Gen4 offers 3,763Wh of capacity and can expand up to 12kWh with compatible extra batteries and the required expansion adapter, sold separately.
How the two products support different greenhouse needs
The EcoFlow DELTA 3 Classic is suited to temperature monitoring, communication, and a small circulation fan. The EcoFlow DELTA 3800 Gen4 offers more capacity for continuous 120V loads, such as seedling heat mats. You can also add compatible extra batteries when you need longer runtime.
Estimate how long a power station can run your equipment
Battery runtime depends on the connected equipment's average wattage and how long it runs. The examples below use placeholder loads. They're estimates, not guaranteed runtimes for a particular fan or heat mat.
Load (example) | Watts used | EcoFlow DELTA 3 Classic (870Wh usable est.) | EcoFlow DELTA 3800 Gen4 (3,199Wh usable est.) |
Sensor + phone + small fan (placeholders 5W + 10W + 25W) | about 40W | about 22 hours | about 80 hours |
Four seedling heat mats at 20W each, thermostat on 60% (placeholder 48W average) | about 48W | about 18 hours | about 67 hours |
Heat mats + fan + sensor (placeholder 90W) | about 90W | about 9.7 hours | about 36 hours |
The estimates use 85% of each battery's rated capacity as usable energy. The calculation is: Usable battery capacity (Wh) ÷ average load (W) = estimated runtime (hours). Replace the placeholder wattages with the figures on your equipment labels or measurements from a suitable power meter. Heat mats with thermostats don't necessarily draw their full rated wattage continuously, so account for their actual duty cycle. Also allow for conversion losses and changes in operating conditions. A battery can run selected electrical equipment, but it can't guarantee that the greenhouse or every plant inside will stay above freezing.
How to Insulate and Heat a Winter Greenhouse
Reduce heat loss before adding a heater. Insulation and thermal mass help hold daytime warmth, while ventilation controls moisture that can build up in a closed greenhouse.
Seal gaps and insulate exposed areas
Check doors, windows, glazing joints, and the base of the greenhouse for gaps. Even small openings let cold air in and warm air out. Repair loose seals and use greenhouse-safe weatherstripping where needed. You can also add an insulating film or a second glazing layer to reduce heat loss. In some designs, insulating the north wall and foundation helps limit the amount of warmth lost overnight. Make sure any added material is suitable for the greenhouse structure and doesn't block the sunlight your plants need.
Use thermal mass to store daytime heat
Thermal mass absorbs warmth during the day and releases it as temperatures fall. Water barrels and stone are common options for storing heat in a greenhouse. Place them where they receive sunlight, while leaving enough room for plants and airflow. Deep winter greenhouses use insulated soil or rock to store heat from the sun. Home growers can apply the same basic idea on a smaller scale, although the amount of heat stored depends on the materials, sunlight, and greenhouse design.
Add heat where plants need it
Heating the entire greenhouse can take a lot of energy, particularly during a long freeze. Seedling heat mats provide warmth around trays and containers, so you can protect young plants without trying to heat all the air in the space. If you use a greenhouse heater, follow its manufacturer's instructions for placement, ventilation, and safe operation. Don't use a fuel-burning heater in an enclosed space unless the equipment is specifically approved for that setting and installed as directed. Never leave a combustion heater running while you sleep. For another approach, see our guide to heating a greenhouse with solar panels.
Keep air moving and manage condensation
Closing every vent to hold heat can leave moisture trapped inside. Condensation on glazing, leaves, and framing can create conditions that encourage plant disease. Open vents when conditions allow, and use a circulation fan to reduce stagnant air. Check the temperature and humidity regularly, especially after watering or during a stretch of cloudy weather. Your goal is to retain enough heat for the crops while keeping moisture under control.
Best crops for a winter greenhouse
Cold-tolerant crops are a sensible starting point because they generally need less supplemental heat than warm-season vegetables. The University of Minnesota Extension recommends lettuces, herbs, brassicas, Asian greens, and sprouts for deep winter greenhouse growing. Choose varieties suited to your local conditions and check their expected growing temperatures. A greenhouse in Minnesota faces different winter conditions from one in Georgia or the Pacific Northwest. Your planting calendar should reflect those differences. If you're growing herbs for everyday cooking, start with varieties that match your greenhouse's light and temperature conditions. For a smaller setup indoors, you can also consider an indoor herb garden.
A winter greenhouse can keep producing when its design, insulation, and crops match the local climate. Start by sealing gaps, adding thermal mass, and choosing cold-tolerant greens. Use heat mats for seedlings rather than trying to heat the entire space, and keep ventilation in your winter routine to manage condensation. For outages, the EcoFlow DELTA 3 Classic can support monitoring and a small fan, while the EcoFlow DELTA 3800 Gen4 offers more capacity for compatible heat mats. Check actual wattages, runtime needs, and operating conditions before choosing backup power.
Can a greenhouse work in the winter?
Yes. A greenhouse can support winter growing with suitable insulation, thermal mass, and cold-tolerant crops. Deep winter greenhouse designs also use passive solar heat stored in insulated soil or rock.
How do you keep a greenhouse warm in winter?
Seal gaps, add an insulating layer where appropriate, and use thermal mass such as water barrels or stone to store daytime heat. Heat mats can provide warmth for seedlings without heating the entire greenhouse.
What grows in a greenhouse in winter?
The University of Minnesota Extension lists lettuces, herbs, brassicas, Asian greens, and sprouts as suitable crops for deep winter greenhouses. Choose varieties based on your local temperatures and available light.
Do greenhouses need ventilation in winter?
Yes. Ventilation and air circulation help manage humidity and condensation. You may need to adjust vents based on outdoor temperatures and the conditions inside the greenhouse.
Can a battery keep a greenhouse warm during an outage?
A portable power station can run selected equipment, such as temperature sensors, fans, and seedling heat mats, for a limited time. It can't guarantee that the entire greenhouse will stay warm or that plants won't freeze.
