Floor Furnace: How It Works, Whether It Needs Power, and How to Keep It Safe
If your older home has a metal grate in the hallway floor that gets hot in winter, you have a floor furnace. These gas heaters sit in a pit below the floor and push warm air up through the grate, with no ducts. They're simple, and many models don't need electricity at all, which makes them handy in a power outage. But they also bring burn and carbon monoxide risks that need attention. This guide explains how a floor furnace works, how to use and maintain one safely, and when repair or replacement makes sense.
What Is a Floor Furnace and How Does It Work?
A floor furnace is an independent heating unit installed directly below your floorboards. It typically sits in a crawl space or a shallow basement pit. A burner warms a heavy-duty metal heat exchanger. Warm air rises naturally through an open floor grate, while a vent pipe exhausts combustion fumes outdoors.
Gravity and Convection: Heat Without Ducts
Unlike central heating setups, a traditional floor furnace uses zero ductwork. It works entirely by natural convection. As cool air near the floor sinks, it drops into the furnace pit around the outside of the combustion chamber. The gas burner heats this air.
Because hot air is less dense, it floats straight up through the center of the register. Leading manufacturers like Williams Furnace Co. design their classic floor units to circulate warmth strictly by natural convection, without the aid of an electric blower.
Standard Capacity and Specifications
Floor furnaces are built to heat specific zones or modest square footage. Williams offers standard models across two primary residential capacities:
Model Number
Fuel Type
Input (Btu/h)
Heating Output (Btu/h)
Ignition Type
4505622A / 4505621A
Natural Gas / LP
45,000
31,000
Millivolt (Matchless Pilot)
6005622A / 6005621A
Natural Gas / LP
60,000
42,000
These units feature matchless piezo push-button lighters and millivolt control valves. They also include built-in register grille temperature limit switches to prevent overheating.
Check the rating plate and the manufacturer's instructions for your exact floor-furnace model before assuming its fuel or electrical requirements. The Williams millivolt models discussed here operate without household electricity; requirements for other heating equipment must be checked separately.
Unlike a floor furnace, using a gas furnace without electricity usually isn't possible because modern forced-air blowers and zone relays require grid power to run. Because many floor furnaces need no power, the outage question is different from other heaters. Power matters more during repairs.
Does a Floor Furnace Need Electricity? Outages and Repair Days
Most classic floor furnaces require no household electricity to generate heat. In a millivolt system, the standing pilot heats a thermopile (pilot generator), which produces the small electrical output used by the gas-valve and thermostat control circuit. The gas valve itself does not generate electricity. If a winter blizzard knocks out your neighborhood grid, your floor furnace grate keeps radiating heat as long as your municipal gas supply remains active.
The Real Power Challenge: Inspection and Crawl Space Repairs
While you might not need battery power to ignite the burner, maintenance and service days present an entirely different problem. Servicing a floor furnace requires a technician to squeeze into a dark, unconditioned crawl space.
If a specific service procedure requires isolation of electrical circuits near the work area, have the qualified technician identify and isolate those circuits according to the applicable procedure. Do not assume every annual floor-furnace inspection requires shutting off household power.
A technician down in a crawl space cannot perform a meticulous safety inspection in the dark. Flashlights roll away and headlamps quickly lose battery life. Running long extension cords across damp mud from a distant room is unsafe and awkward. You also need to maintain your home Wi-Fi and phone battery to communicate with service pros, order replacement parts, or look up legacy equipment manuals online.
A millivolt floor furnace may keep you warm in an outage, but a service visit is a different story. The technician may shut off gas and power to parts of the house while working in a dark crawl space. An EcoFlow portable power station gives steady light, charged phones, and Wi-Fi for that stretch, without running cords from a neighbor.
A service visit's power needs are small: a work light in the crawl space, phones, and the router. A 1kWh unit covers that for many hours and moves easily to wherever the technician is working.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
Estimated Runtime
Here is how a 1024Wh portable power station handles everyday service and utility outage support tasks:
Work Equipment & Personal Devices
Typical Wattage
EcoFlow DELTA 3 Classic (870Wh usable est.)
LED Crawl Space Work Light
20W
About 43.5 hours
Home Wi-Fi Router
10W
About 87 hours
Smartphone Recharges (x2)
20W combined
About 43.5 hours
All Above Running Concurrently
About 50W
About 17 hours
Note: Runtimes are estimates based on standard operating conditions and typical appliance draws.
Keep in mind that a portable power station does not run, repair, or replace your floor furnace. It cannot substitute for proper gas pipe installation, professional venting, or hardwired smoke detectors. Any gas heater calls for awareness of the hidden dangers of carbon monoxide, especially when temperatures drop. Floor furnaces need a few safety habits that other heaters don't.
Floor Furnace Safety: Burns, Clearances, and Carbon Monoxide
Floor furnaces heat quickly, but an open metal grate flush with the floor creates clear physical hazards. You must manage direct burn risks, fire hazards, and exhaust venting with care.
Floor furnace safetyFloor furnace safety
Preventing Severe Contact Burns
The metal floor register gets scorching hot. During continuous winter operation, floor grates can reach temperatures high enough to cause second-degree burns within seconds.
  • Protect toddlers and infants: Small children crawl directly onto metal grates before realizing the danger. Install sturdy hearth gates or safety barriers around the perimeter of the grate.
  • Watch your pets: Dogs and cats love lying near warm airflow, but their paws and fur can burn on contact. Place pet beds a safe distance away.
  • Avoid bare feet and socks: Never walk across the register while the burner is active. Synthetic socks can instantly melt against the hot metal.
Critical Clearances and Fire Hazards
Floor registers collect dust, hair, and dropped items. Dropping combustible materials through the grille directly onto the heat exchanger creates an immediate fire hazard.
Follow strict manufacturer spacing guidelines. For Williams floor furnaces, maintain at least 6 inches of clearance from adjacent walls. Keep curtains, swinging doors, and furniture back at least 12 inches. Always preserve at least 15 inches of open walking clearance along two sides of the grate so people do not trip over it.
Never cover a floor furnace with rugs, mats, or seasonal floor runners. Even when the heat is off, covering the grate traps heat if the thermostat kicks on unexpectedly.
Carbon Monoxide and Venting Guidelines
Gas appliances produce combustion byproducts, including carbon monoxide (CO). Because floor furnaces hang beneath the floorboards in dark, damp crawl spaces, vent pipes can rust, disconnect, or become blocked by animal nests without you noticing.
The Centers for Disease Control and Prevention (CDC) warns that carbon monoxide is an invisible, odorless, and colorless gas. Early symptoms of CO poisoning include headache, dizziness, weakness, nausea, vomiting, chest pain, and confusion.
Monitoring carbon monoxide indoors matters most in homes with older gas heaters. Install battery-powered or battery-backup CO alarms in every hallway adjacent to sleeping quarters. Test them monthly and replace them every five to seven years.
Never install a floor furnace yourself. Williams prohibits self-installation. Separately, check the permitting, inspection, and contractor requirements in your own jurisdiction. Only certified, licensed HVAC professionals should handle gas lines and flue pipes. Regular service keeps a floor furnace safe and working.
Floor Furnace Maintenance, Repair, or Replacement
An unmaintained floor furnace wastes gas and presents safety hazards. Annual servicing extends the equipment's lifespan and protects your home.
Floor furnance maintenanceFloor furnance maintenance
Professional Pre-Season Maintenance Checklist
Have an HVAC technician service your floor furnace every autumn before freezing weather arrives:
  1. Clear the crawl space pit: Clean leaves, dirt, standing water, and cobwebs out of the furnace pit beneath the floor.
  2. Clean burner ports and lint screens: Vacuum dirt and lint from the burner assembly to ensure clean blue combustion flames.
  3. Inspect the thermocouple and pilot: Test the millivolt generator to make sure the safety valve shuts off gas immediately if the flame goes out.
  4. Examine the heat exchanger: Check thoroughly for hairline cracks, rust spots, or metal fatigue that could leak exhaust into your living space.
  5. Inspect the vent pipe: Confirm the vent pipe is firmly attached, properly pitched toward the outside chimney, and free of corrosion.
  6. Sniff and soap-test for gas leaks: Test all shut-off valves and unions with an approved electronic sniffer or bubble solution.
Energy Efficiency: AFUE Realities
Older floor furnaces lose a significant amount of heat up the chimney. While modern residential wall and floor units achieve decent ratings, they cannot match modern central heating.
Williams floor furnace technical data shows modern millivolt models reach roughly 70% thermal efficiency, with Annual Fuel Utilization Efficiency (AFUE) numbers around 57% to 60%. That means 40 cents of every fuel dollar escapes outside through the chimney vent. If your furnace is several decades old, its real-world efficiency could be much lower.
When to Repair vs. When to Upgrade
If your unit has a faulty thermocouple, a gummed-up pilot tube, or a worn wall thermostat, repairing it is straightforward and inexpensive. However, if the heat exchanger is cracked, replace the unit immediately. A cracked combustion chamber leaks carbon monoxide into your living room.
If it is time for an upgrade, explore these modern options:
  • New Millivolt Floor Furnace: Swapping an old floor furnace for a new Williams unit requires no drywall cuts or ductwork additions, preserving your home's historic layout.
  • Direct-Vent Wall Furnaces: These mount directly to an exterior wall and vent straight outside, eliminating the hazardous crawl space pit and hot floor grate.
  • Ductless Mini-Split Heat Pumps: Mini-splits provide both winter heating and summer air conditioning. They do not burn fossil fuels indoors and deliver high seasonal energy efficiency.
  • Ducted Central HVAC: If your crawl space allows ductwork, a central heat pump or split system delivers even temperatures to every bedroom.
When replacing, compare heat pumps versus furnaces for your climate to determine whether electric heating or gas heating delivers better long-term comfort and monthly savings.
A floor furnace is a ductless gas heater suspended beneath your floorboards, using natural gravity convection to distribute warm air without noisy fans. Many millivolt models operate completely independent of the power grid, keeping your home warm when winter storms knock down power lines.
Living with a floor furnace requires safety diligence. Keep curtains and furniture back from the metal register, teach children to stay clear of the hot grate, install certified carbon monoxide alarms, and book a professional inspection every autumn.
When your heating technician arrives to inspect the crawl space, keep their work lights bright, your cell phones charged, and your home Wi-Fi online with an EcoFlow DELTA 3 Classic portable power station.
What is a floor furnace?
A floor furnace is a self-contained gas heater suspended beneath a home's floor framing, usually inside a crawl space or basement pit. It sends hot air directly up into your living area through a heavy metal floor grate using natural convection, without needing air ducts.
Does a floor furnace need electricity?
Not always. Williams millivolt floor furnaces use a thermopile (pilot generator) heated by the standing pilot to power the gas-valve and thermostat control circuit. These models do not require household electricity. Check the rating plate and manual for the electrical requirements of your exact appliance.
Does a floor furnace work during a power outage?
Yes, provided it is a millivolt or standing-pilot model that does not rely on an external 120V circuit or an electric blower. As long as your municipal gas supply flows uninterrupted, the heater will continue cycling and keeping your home warm without electrical power.
Are floor furnaces safe?
Floor furnaces are safe when maintained properly, but they require caution. The floor register gets hot enough to cause contact burns, making safety guards important for homes with children or pets. Clearances must be strictly observed, and working carbon monoxide detectors are non-negotiable.
Can I install a floor furnace myself?
No. Manufacturers like Williams explicitly prohibit self-installation. Setting up a floor furnace involves structural cutting of floor joists, connecting pressurized gas lines, and installing fire-safe combustion flue venting. All installations must be completed by a qualified, licensed HVAC professional.
Home Solutions
