Condensing Furnace: How It Works, What It Saves, and What It Needs to Run
A condensing furnace recovers heat that older gas furnaces send outside through the exhaust vent. That extra heat helps it reach higher efficiency ratings, which can lower fuel use over the heating season. The design also comes with a few installation requirements, including plastic vent pipes and a drain for the water produced during operation. And because the furnace relies on electricity for its fans and controls, a power outage can stop the heat even when the gas supply is still available.
What Is a Condensing Furnace and How Does It Work?
A condensing furnace has a second heat exchanger to pull more heat out of the combustion gases before they exit the house. As the exhaust cools, water vapour condenses to liquid and drains off. This process helps the furnace turn more of its gas supply into usable heat.
How the two heat exchangers work
A standard gas furnace sends hot combustion gases through a primary heat exchanger. The furnace blower moves household air across the outside of that exchanger, warming the air before it travels through the ductwork. A condensing furnace adds a secondary heat exchanger to capture heat that would otherwise leave through the exhaust. The process works in a few stages:
The burner heats the primary exchanger. Natural gas or propane burns inside the furnace, heating the metal surfaces of the primary heat exchanger.
The secondary exchanger recovers more heat. Combustion gases pass through the second exchanger, where they cool further. This releases additional heat into the air moving through the furnace.
Water vapor turns into liquid. As the exhaust cools, moisture condenses. The furnace collects this liquid and sends it to a drain or condensate pump.
The remaining exhaust leaves the home. A draft inducer fan moves the cooler gases through the vent pipe and outside.
Many condensing furnaces use sealed combustion. They draw combustion air from outdoors rather than relying on air inside the house. The exact arrangement depends on the furnace model and installation.
What the AFUE rating tells you
AFUE stands for annual fuel utilization efficiency. It measures how much of a furnace's fuel energy becomes heat for the home over a heating season. A 95% AFUE furnace, for example, converts about 95% of its fuel energy into usable heat under the rating test. ENERGY STAR sets different efficiency requirements for gas furnaces in the United States:
Region | ENERGY STAR minimum AFUE |
U.S. South | 95% |
U.S. North | 97% |
These ratings help explain why condensing models are common in colder parts of the country, where furnaces may run for long stretches during winter. Your climate and heating schedule still matter when comparing models. Before buying, compare heat pumps and furnaces for your climate and home. A high AFUE rating also doesn't tell you the full cost of owning a furnace. Installation, fuel prices, maintenance, and the condition of your ductwork all affect what you spend over time.
Condensing furnaces and power outages: What needs electricity?
A condensing furnace uses gas to produce heat, but electricity keeps its fans, controls, and other components running. When the power goes out, the furnace stops heating even if your gas supply is still on. A backup power plan can keep smaller devices running or, with the right electrical setup, support the furnace itself. When planning backup power, the same basics of running a gas furnace without electricity apply to condensing models, too.
Which furnace components need power?
The furnace relies on electricity for its draft inducer fan, blower motor, and electronic controls. Some models also use a condensate pump to move water away from the unit. The blower and other motors can draw more power when they start, so check both running and startup requirements before choosing a backup source.
Plan backup power around your needs
EcoFlow offers two backup options for different needs. The EcoFlow DELTA 3 Classic can power lights, phones, and a Wi-Fi router while the furnace is off. The EcoFlow DELTA 3000 Gen4 can support a verified 120V furnace setup through a transfer device installed by a licensed electrician. A power station isn't going to make your furnace more efficient or solve your venting or drainage problems. Check the power requirements of the furnace and make sure there is enough gas supply. The EcoFlow DELTA 3000 Gen4 is listed to ship in early December 2026, so check delivery timing before planning around it.
EcoFlow DELTA 3 Classic for essential backup power
If your priority is keeping lights and communication available while the furnace is off, a 1,024Wh power station can cover smaller household loads and keep phones charged for outage updates.
EcoFlow DELTA 3000 Gen4 for furnace backup
If you want to keep the furnace running during an outage, its 120V blower, controls, and condensate pump need backup power. The EcoFlow DELTA 3000 Gen4 offers a 3,072Wh battery and 3,600W output for a verified setup installed through a suitable transfer device by a licensed electrician.
How the two products support different outage needs
The EcoFlow DELTA 3 Classic keeps essentials like lights, phones, and a router running while the furnace is off. The EcoFlow DELTA 3000 Gen4 is designed for a different setup: it can support a verified 120V furnace circuit through a transfer device installed by a licensed electrician.
Estimate how long a power station can run your loads
Runtime depends on the power station's usable battery capacity and the average wattage of the connected devices. The following figures are estimates based on the example loads below, not guaranteed runtimes for every furnace.
Load (example) | Watts used | EcoFlow DELTA 3 Classic (870Wh usable est.) | EcoFlow DELTA 3000 Gen4 (2,611Wh usable est.) |
Lamps + router + phones (placeholders) | about 50W | about 17 hours | about 52 hours |
Furnace blower, inducer, controls, condensate pump while running (placeholder 600W) | about 600W | about 1.4 hours | about 4.4 hours |
Same furnace cycling about 40% of the time (placeholder 240W average) | about 240W | about 3.6 hours | about 11 hours |
These estimates use 85% of each battery's rated capacity as usable energy. The calculation is: Usable battery capacity (Wh) ÷ average load (W) = estimated runtime (hours). The 50W and 600W loads are placeholders. Replace them with the wattage listed on your devices or measured by a qualified electrician. Actual runtime will also vary with conversion losses, startup demand, and how often the furnace cycles. A furnace that runs continuously will use battery capacity much faster than one that cycles on and off.
Condensing Furnace Installation: Venting and Drainage
A condensing furnace needs a suitable exhaust route and a way to remove the water it produces. These requirements affect where an installer can place the unit and how it connects to the rest of the home.
Plastic vent pipes and combustion air
Because a condensing furnace cools its exhaust gases, the vent system handles cooler, moisture-rich exhaust than a conventional furnace chimney. Many models use PVC or another approved plastic vent material. The manufacturer specifies the permitted material, pipe size, length, slope, and termination location. The furnace may also need a separate air intake pipe, particularly when it uses sealed combustion. The installer must follow the model's instructions and local building and mechanical codes. Don't assume an existing metal chimney or vent can be reused.
Condensate drain and pump
The cooling process creates liquid condensate that must leave the furnace. Some installations use a gravity drain. Others need a condensate pump to move the water to a suitable drain. In colder areas, the installer must protect any condensate lines that could freeze. A blocked or frozen drain can cause the furnace to shut down or leak water, so it needs to remain accessible for inspection and maintenance.
Check the existing chimney and nearby appliances
Replacing an older furnace can affect other appliances that share its chimney. A gas water heater, for example, may still depend on that vent after the furnace is removed. Have the installer check the venting, combustion air, and drainage before work begins. For another heating option, see our guide to electric furnace wattage and cost. Also install working CO alarms. The CDC recommends battery-powered or battery-backup models that continue working during an outage.
Is a Condensing Furnace Worth It?
A condensing furnace can be a good choice when a home needs regular heating and the fuel savings justify the higher-efficiency equipment and installation requirements. The benefit tends to matter more in colder climates, where the furnace runs more often. In milder areas, the difference in seasonal fuel use may be smaller.
Compare the full installation cost
Ask HVAC contractors to quote the complete installation, not only the furnace itself. The work may include new vent pipes, a condensate drain or pump, electrical connections, and changes to the existing chimney or combustion-air setup. Before choosing a model, compare:
AFUE rating: Check the furnace's efficiency and the ENERGY STAR requirements for your region.
Installation work: Ask whether the home needs new venting, drainage, or electrical work.
Heating needs: Have the contractor perform a load calculation rather than choosing a furnace based only on the size of the old unit.
Fuel costs: Compare local natural gas or propane prices and how much heat the home needs.
Maintenance: Ask what the manufacturer recommends for annual service and condensate system checks.
You can also check with your local utility for current furnace rebates. Programs and eligibility change, so confirm the terms before including a rebate in your budget.
Check current tax credit rules
The federal Energy Efficient Home Improvement Credit covered qualifying improvements placed in service through December 31, 2025. According to the IRS, it doesn't apply to a furnace installed in 2026. Don't include the expired credit in your cost estimate. You can check the IRS energy-efficient home improvement credit guidance for the applicable dates and rules. Fuel prices also affect long-term savings. Comparing gas furnace and solar heating costs can help put your heating expenses in a broader context, but the systems serve different roles and need to be assessed against your home's actual energy use.
A condensing furnace recovers more heat from combustion gases with a second heat exchanger, which helps it reach high AFUE ratings. It also needs approved vent piping, a condensate drain, and electricity for its fans and controls. Before installing one, get a heating load calculation and confirm the venting and drainage plan with a qualified contractor. For outages, the EcoFlow DELTA 3 Classic can keep smaller essentials running while the EcoFlow DELTA 3000 Gen4 can support a verified 120V furnace circuit through a suitable transfer device installed by an electrician. Check actual load requirements and product availability before choosing a backup setup.
What is a condensing furnace?
A condensing furnace is a high-efficiency gas furnace with a second heat exchanger. It cools exhaust gases to recover additional heat, producing liquid condensate that drains away.
What AFUE rating does a condensing furnace have?
ENERGY STAR requires gas furnaces to meet at least 95% AFUE in the U.S. South and 97% AFUE in the U.S. North to earn its label. Individual models may have higher ratings.
Does a condensing furnace need a drain?
Yes. The secondary heat exchanger cools exhaust gases enough to produce liquid condensate. The furnace needs a suitable drain or condensate pump to remove that water.
Does a condensing furnace work without electricity?
No. The furnace needs electricity for its draft inducer, blower, electronic controls, and sometimes a condensate pump. It generally stops heating during a power outage unless a compatible backup power setup supplies those loads.
Can a portable power station run a condensing furnace?
It may be possible if the furnace's electrical loads are compatible with the power station's output and battery capacity. A fixed furnace circuit needs a suitable transfer device installed by a licensed electrician. Check startup and running wattage before choosing a unit.
Is there a federal tax credit for a condensing furnace in 2026?
No. The IRS says the Energy Efficient Home Improvement Credit applied to qualifying property placed in service through December 31, 2025. It doesn't cover a furnace installed in 2026.
