Smart Thermostats for Energy Savings: Do They Work?
If you're looking to trim your energy bill, one of the easiest upgrades to make is a smart thermostat. However, the final result may vary from one household to another. Some families will save a lot of money while others see little change. Climate, HVAC type, and daily habits often make the difference. This guide explains everything about smart thermostats for energy savings. It also looks at how these features cut energy use, breaks down realistic savings, and shows who benefits the most.
What Makes a Thermostat Actually "Smart"?
smart thermostats for energy savingssmart thermostats for energy savings
What Makes a Thermostat "Smart"?
A smart thermostat is more than just a device for changing the temperature. It connects your HVAC system to software, sensors, and your other smart devices. This allows it to make temperature changes with less manual input. The main difference between a smart thermostat and an older programmable one is that the smart model connects to your home WiFi network, while the older programmable one only runs on a fixed, manually entered schedule.
Learning Your Routine, Not Just Following a Schedule
One of the smart thermostat benefits is that it learns your routine over time. Besides, it allows you to create a detailed schedule via an app and automatically adjusts the heating and cooling rather than waiting for someone to touch the dial. Most models use occupancy or motion sensors to see if a room, or the whole house, is actually being used before running the system at full strength.
A smartphone app for remote access lets you set the temperature while at work, catch a setting you missed, or check in while on the road. Many newer models also talk to other connected devices in the house, and the push toward shared standards like Matter for smart home energy management is making cross-device coordination less of a pain than it used to be.
How Smart Thermostats Cut Your Energy Use
Energy-saving smart thermostats mainly save energy by reducing unnecessary runtime of the HVAC system. They can adjust the temperature when you're asleep, away, or only using part of the house. This can keep your system from running more than it has to.
How smart thermostats reduce HVAC runtime
  • Automatic temperature setbacks: Changes the temperature when you are sleeping or away.
  • Custom schedules: Aligns with your daily routine without frequent manual adjustments.
  • Geofencing: Works when you're home or away.
  • Learning features: Identifies repeating patterns and automatically adjusts settings.
  • Usage reports: Check where the energy is going and where the opportunities for savings are.
Geofencing uses your phone's location, so it knows when you leave the house or when you're on your way home. Hence, it can relax its guard and then start reconditioning the space before you walk in. Learning algorithms pick up patterns, like what mornings you're up early or what rooms rarely get used, and quietly adjust without you having to reprogram anything.
Smart thermostats vs. basic programmable thermostat
In general, the distinction between a smart energy-saving thermostat and a basic programmable one is a combination of scheduling with geofencing to trim HVAC runtime automatically. So, if the question is: can smart thermostats save you money, the answer is yes. But the thermostat alone does not create energy savings. It just makes it easier to maintain efficient behavior. If it cuts down on redundant runtime, your HVAC system uses less energy.
Thermostats are just one piece of a smart, efficient home. The other piece is making sure the power behind all of it doesn't cut out at the wrong moment.
Building a Smarter, More Resilient Home Energy Setup
Energy efficiency is only one part of the story. Your HVAC system needs dependable power too. This is especially critical in situations of extreme weather. A smart thermostat is only as good as the power to the HVAC system it controls. And it's during the very extremes, such as a heat wave or deep freeze, that dependable power matters most.
Smart energy management combined with whole-house backup power means your furnace, central air, or heat pump continues to run when everything else loses power. A home backup system that runs on batteries is also quiet and has no exhaust, which is important if it has to be near the house or even in a garage.
It's a good gut check to see how a home backup system holds up against a demanding HVAC load before assuming any battery can run a full heating or cooling system through an outage. Adding a whole-home battery can provide another layer of resilience. It can keep critical systems operational during grid power outages. The right system will depend on your HVAC load, home size, and expected outage length.
EcoFlow DELTA Pro Ultra X
•100% Whole-Home Power: Delivers 12–36kW output and 12–180kWh capacity. •Fast Installation: Plug-and-play design installs in 7 days, saving up to 80% on time and cost. • Smart & Reliable: Features a fast 20ms auto switchover when it matters most. • High Savings: Saves up to $6,000 per year with a 3-year ROI. •Comprehensive Safety: Provides end-to-end system protection meeting the highest safety standards.
Does a Smart Thermostat Actually Save You Money?
Wondering: Will a smart thermostat save money? Well, the answer is yes, but it depends on various factors and considerations. Your starting habits matter. The same goes for your climate and HVAC system. A house with frequent temperature setbacks has a lot of savings potential compared to a house that is already managing its thermostat well.
make savings with smart thermostatsmake savings with smart thermostats
What determines your potential savings
Several factors can affect how much you actually save:
  • Your thermostat's past habits: Less temperature control in your home means there's more room for improvement.
  • Climate: Longer seasons with very hot or very cold weather may offer more opportunities to save.
  • HVAC efficiency: The system itself impacts total energy use.
  • Daily routine: For extended periods away from home, automated setbacks can be more useful.
  • Temperature settings: Bigger and more consistent setbacks can provide more opportunities to cut runtime.
ENERGY STAR notes that heating and cooling account for almost half of the average American household's energy bill, which is why a small tweak here has an outsized impact. The U.S. Department of Energy recommends turning back the thermostat 7 to 10 degrees for eight hours a day, which it estimates can save around 10% a year on heating and cooling costs.
Manufacturer claims tend to be on the high side relative to independent estimates, so it's good to see both side by side rather than accepting either one at face value.
Source
Estimated Savings
U.S. Department of Energy (setback scheduling)
Around 10% a year on heating and cooling
Independent third-party studies (smart thermostats generally)
Roughly 10-15% a year
Google Nest (manufacturer estimate)
10-12% on heating, up to 15% on cooling
Ecobee (manufacturer estimate)
Up to 26% a year
The numbers show why there isn't a single savings number that works for all households. A smart thermostat can be a real game changer. But it can't address all sources of energy loss. The manufacturer's figures are from company-sponsored studies and are the best case, not a guarantee. So it is worth treating these figures as an upper bound, not a typical result.
How to measure your actual energy savings
The best way to ensure that changing your thermostat is actually making a difference in your own home is to see where that usage is actually showing up, via an energy monitor that breaks down your bill by device and system. Watching where that usage actually shows up through an energy monitor that breaks down the bill by device and system is the most reliable way to confirm whether a thermostat swap is really moving the needle in your own house.
Now that you know how smart thermostats save energy, it's time to know who actually benefits from these energy-saving devices.
Who Actually Sees the Biggest Savings (and Who Doesn't)
Not all homes have the same potential for savings. The smart thermostat is most useful when there is a clear opportunity to reduce wasteful heating or cooling:
Homes that may benefit the most
A smart thermostat may be particularly useful when:
  • The home is empty for several hours each day.
  • The thermostat was previously kept at one setting all day.
  • The household frequently forgets to adjust the temperature.
  • The home experiences hot summers, cold winters, or both.
  • The HVAC system is compatible with smart thermostat controls.
People who are already manually setting their old programmable thermostat, or who are home most of the day anyway, tend to see much smaller gains. Not all HVAC systems are compatible with a smart thermostat. It can be difficult to install older systems that don't have a C-wire, and some variable-speed heat pumps and electric baseboard systems are designed to run efficiently at a constant level.
When a smart thermostat may not help much
Savings may be limited when:
  • Someone is usually home throughout the day.
  • You already manage a programmable thermostat carefully.
  • Your climate stays relatively mild year-round.
  • Your HVAC system is designed to operate efficiently at a consistent level.
  • Your system has compatibility or wiring limitations.
Getting a clearer picture of where a specific home is actually losing energy, through a home energy audit that flags inefficiencies room by room, often reveals whether a thermostat upgrade or something else, like insulation, is the biggest opportunity.
Getting the Most Out of a Smart Thermostat
Getting the Most Out of a Smart ThermostatGetting the Most Out of a Smart Thermostat
Buying the thermostat is just the start. The choices you make in the settings can have a bigger impact on your results.
  • Set an automatic schedule: Establish heating and cooling schedules for when you are usually home, asleep, or away. This helps prevent your HVAC system from running unnecessarily while keeping your home comfortable when you need it.
  • Use geofencing: Turn on geofencing if your thermostat has it. It knows when you leave and when you return, using your phone's location, and it automatically adjusts the temperature, saving energy without having to change it manually all the time.
  • Limit manual overrides: Resist the urge to turn the thermostat whenever you feel a little too hot or cold. Overriding the system too much messes with any automated schedules and learning functions, and makes it harder for the thermostat to stick to an efficient routine.
  • Properly mount the thermostat: As DOE suggested, position the thermostat away from direct sunlight, air vents, doors, windows, and drafty areas. If it is placed poorly, it may give inaccurate temperature readings that could cause your HVAC system to run longer than necessary.
  • Read energy reports: Review your thermostat's monthly usage summaries and energy reports regularly. These reports can help you recognize trends, find inefficient settings, and make changes that gradually reduce your heating and cooling usage.
Combine the thermostat with a few other simple home-efficiency habits, like sealing obvious drafts and trimming other high-usage appliances, because the savings tend to pile up, not replace each other. Small gains add up. A thermostat can cut down on HVAC runtime. The better the insulation, the less often the system has to run. Energy-efficient appliances help reduce your overall electricity demand.
Smart thermostats can save energy with automatic temperature setbacks, schedules, and other routine adjustments, but savings vary by your climate, HVAC system, and daily routine. They are most useful in homes that are unoccupied for long periods or in need of continuous manual adjustments, but more efficient households will not see much benefit. Before you purchase a smart thermostat for energy savings, make sure it's compatible with your HVAC. Consider getting an energy audit to see where your home needs the most work. A smart thermostat can help make your home more efficient, but it still needs power to keep your HVAC system running. Pairing it with a whole-home backup system like the EcoFlow DELTA Pro Ultra X can add resilience in an outage.
What do smart thermostats do differently from a regular programmable thermostat?
Wi-Fi-enabled smart thermostats can be controlled through an app. Many can also learn your routine, use occupancy sensors, and automatically change settings. A basic programmable thermostat typically runs on a schedule you set yourself.
Does a smart thermostat actually save money, or is that mostly marketing?
Smart thermostats can help you save money by avoiding heating and cooling where it is not needed. The savings are real, but they are not all the same for every household. Marketing claims don't guarantee a particular outcome.
How much can a smart thermostat save on a typical energy bill?
The savings can be enormous. Typical estimates are about 10% to 15% of the cost of heating and cooling. Your actual results will vary by climate, your HVAC system, your schedule, and your previous thermostat habits.
Will a smart thermostat work with any HVAC system?
No. Compatibility depends on the HVAC system and thermostat. Some installations may require a C-wire or other wire modifications. Heat pumps, electric baseboard systems, and multi-stage HVAC systems may need special consideration.
What happens to a smart thermostat and HVAC system during a power outage?
Usually, when the thermostat loses power, it stops working. Unless your HVAC system is hooked to a proper backup power source, it too will shut down. When correctly sized, a whole-home battery can power the HVAC equipment and thermostat during an outage.
