Virginia Solar Incentives: What's Actually Left in 2026
Virginia homeowners took two hits this year. The 30% federal solar tax credit ended for any system installed in 2026 or later. And the state's own $156 million low-income solar grant got pulled before it ever launched. That leaves fewer incentives than some nearby states offer. But property tax breaks, net metering, and a small SREC market are still around. This post covers what happened. It covers what's still on the table. And it covers whether solar still makes sense for your home right now.
The Federal Credit Is Gone, and Virginia's Own Grant Program Got Cut Too
Two big changes hit Virginia solar owners at once:
First, the 30% Residential Clean Energy Credit stopped applying to any system placed in service on or after January 1, 2026. That credit used to knock a third off the cost of going solar — about $7,500 on a $25,000 system. Homeowners who have their systems installed and running before the end of 2025 can still claim it on last year's taxes; anyone installing from here on out can't. For the full story, see why the federal credit ended [blocked] and what it means for homeowners across the country, not just in Virginia.
Second, Virginia lost its Solar for All grant — a $156 million federal award meant to help around 15,000 lower- and moderate-income households go solar. The federal government clawed it back in August 2025, before the state had even opened applications. Virginia's Attorney General joined more than 20 other states in a lawsuit to fight the cancellation, and the case is still working its way through court.
One big beautiful billOne big beautiful bill
What Virginia Homeowners Still Have
The picture isn't as bad as it sounds. A few real incentives are still standing.
  • Property tax exemption. Virginia lets you skip property tax on the value solar adds to your home. The exact amount depends on your county, city, or town.
  • No state tax credit. Unlike some neighboring states, Virginia never built its own state-level solar tax credit to replace the federal one.
  • No battery incentive. Virginia doesn't offer a state-specific rebate for battery storage, unlike some states now building out storage programs.
Does the upfront cost still feel steep without the federal credit? Look into spreading out solar payments over time before you rule out going solar.
A lot of Virginia homeowners now pair solar with a battery for this reason. Net metering and tax breaks help with the bill. But a battery keeps your lights on when the grid goes down. Hurricane season or not. That's where EcoFlow's DELTA Pro 3 and DELTA Pro Ultra X come in.
EcoFlow DELTA Pro 3
• High Power & Versatility: Delivers up to 4000W (6000W via X-Boost) with 120V and 240V outputs to run a 3-ton central AC and essential appliances. • Continuous Power: Maintains stable 120/240V output at 4000W during pass-through charging. •Endless Energy: Compatible with portable generators and auto-recharges using the EcoFlow Smart Generator 4000. •Durable Battery Life: EV-grade LFP battery retains 80% capacity after 4000 cycles.
EcoFlow DELTA Pro Ultra X
•100% Whole-Home Power: Delivers 12–36kW output and 12–180kWh capacity. • Fast Installation: Plug-and-play design installs in 7 days, saving up to 80% on time and cost. • Smart & Reliable: Features a fast 20ms auto switchover when it matters most. • High Savings: Saves up to $6,000 per year with a 3-year ROI. • Comprehensive Safety: Provides end-to-end system protection meeting the highest safety standards.
Property tax relief is nice, but the real ongoing savings still come down to net metering.
Net Metering in Virginia
Net metering is the part of solar that actually pays you back month after month. Here's how it works in Virginia. Dominion Energy and Appalachian Power both credit your solar power at the full retail rate. That's a one-to-one trade. Send a kilowatt-hour to the grid. Get a kilowatt-hour of credit back.
Feature
How it works in Virginia
Credit rate
Full retail rate, one to one
Unused credits
Roll over month to month
Annual settlement
Leftover credits roll over or get paid out at a lower rate
System size limit
Must stay under 25kW and under 100% of your yearly usage
That size cap matters more than most homeowners realize. A system built to cover 100% of your usage, or a bit less, tends to make the most financial sense anyway. Oversizing your system rarely pays off once you hit that cap.
Net metering rules aren't the same everywhere. How net metering differs by state is worth a look if you're comparing Virginia to a neighboring state.
Virginia's Thin SREC Market
SRECs are a second way solar can put money back in your pocket — though in Virginia, that market isn't very deep yet. You earn one Solar Renewable Energy Certificate for every megawatt-hour your panels produce, and a typical home system makes about 6 to 10 of them a year. Each certificate is sold to a utility, usually through an aggregator.
Recent Virginia prices run between $20 and $30 per credit — well below the $40 to $55 range in neighboring Maryland — so on the low end that might only add up to $150 or $200 a year. Real money, just not a lot of it. (Virginia's program does cap SREC value at $75, but that's a ceiling, not what most homeowners actually see.) New to SRECs? Learn how solar certificates get sold before you count on that income.
Local and Utility-Specific Programs Worth Checking
are solar panels worth it in virginiaare solar panels worth it in virginia
A few programs depend on where you live. Others depend on what kind of property you own.
Property tax exemption amounts differ by locality. Check with your specific county, city, or town instead of assuming a standard rate. Some counties exempt the full added value. Others cap it or phase it in over a few years. A quick call to your local commissioner of the revenue clears this up fast.
VirginiaSAVES offers financing for nonprofits, local governments, and businesses going solar. It doesn't apply to homeowners, though. Dominion Energy and Appalachian Power run net metering a bit differently from each other. Both have also proposed rule changes that state regulators are still reviewing. Keep an eye on your specific utility's page for updates, since a rule change could shift how much your credits are actually worth.
Some of these local rules work a lot like government-backed solar financing programs in other states. They just run through a different office. With the local details covered, the bigger question is whether any of this still adds up.
Is Solar Still Worth It in Virginia Right Now?
Losing the federal credit and the Solar for All grant both stretch out your payback period. That part is real. Without the 30% credit, most Virginia homeowners are looking at a longer wait before their system pays for itself. Some estimates put it a few years later than before.
But property tax exemptions, net metering, and SREC income are all still there, and they still add up over time. Electricity rates also keep climbing in Virginia, which makes any system that cuts your bill worth more each year, not less. Lower-income households lost the most here. They were the group Solar for All was built to help. That won't change until the lawsuit ends.
Want a broader look at whether the numbers work out for a typical home? Run your own numbers before you decide.
Virginia's solar incentives shrank in 2026. The federal tax credit ended, and a $156 million low-income grant program got pulled. What's left still matters: property tax exemptions, full retail-rate net metering, and a modest SREC market. Check your county's exemption, register for SREC sales, and watch the Solar for All lawsuit for updates. And if you're going solar anyway, pair it with backup power. EcoFlow's DELTA Pro 3 and DELTA Pro Ultra X both work well alongside a Virginia solar setup.
Is there still a solar tax credit in Virginia in 2026?
No federal credit applies to systems installed in 2026 or later. Virginia never had its own state-level credit to replace it.
What happened to Virginia's Solar for All program?
The federal government canceled the $156 million grant in August 2025 before Virginia opened applications. Virginia's Attorney General joined a multi-state lawsuit to try to reverse the cancellation.
Does Virginia have net metering?
Yes. Dominion Energy and Appalachian Power both credit exported solar power at the full retail rate, one to one, with some size limits on the system.
How much are Virginia SRECs worth?
Recent prices typically run between $20 and $30 per credit, well below what neighboring Maryland pays. The program caps value at $75, but most homeowners see far less.
Are solar panels still worth it in Virginia?
Yes, for most homeowners, though payback now takes longer without the federal credit. Property tax exemptions, net metering, and SREC income work for many households. Pairing your system with a battery like the EcoFlow DELTA Pro 3 also means backup power when the grid goes down.
