Business Electricity Rates in Texas: What You'll Actually Pay in 2026
Texas commercial electricity rates run about 5.9 cents per kWh for businesses actively shopping the competitive market. The broader EIA average across all commercial accounts, including ones that never shop the market, sits closer to 8.4 to 9.5 cents. Both figures land well below the national commercial average of roughly 14.1 cents per kWh, per the U.S. Energy Information Administration. This article breaks down current rates by city and utility, what drives your rate up or down, and how to pick a plan type. It also covers a cost lever most rate comparison guides skip: cutting usage and demand charges directly instead of just shopping for a lower rate.
Current Texas Business Electricity Rates
Evaluating the current market requires looking at both competitive retail offerings and broader utility data across the state. Understanding these figures helps commercial operations set realistic utility budgets for the year ahead.
  • Businesses that actively shop Texas’s deregulated market are paying an average of about 5.9 cents per kWh as of August 2026, with the lowest published plans starting near 4.81 cents per kWh.
  • The broader EIA survey of all commercial usage, which includes accounts that are not actively shopping the market, puts the average closer to 8.4 to 9.5 cents per kWh.
  • The right number depends entirely on whether a business is actively shopping for the deregulated market rather than sitting on a legacy tariff.
  • Rates vary meaningfully by delivery utility, known as a TDU, across different regional boundaries.
  • Oncor territory, covering Dallas, Fort Worth, and Waco, tends to run among the cheapest for end users, according to rate comparisons published in August 2026.
  • As facility managers navigate these pricing shifts and tightening capacity margins, a closer look at how industrial users adapt reveals why the backup power industry soars on grid fears.
  • AEP Texas North covering Abilene and San Angelo alongside CenterPoint covering Houston run somewhat higher due to different delivery charges layered on top of the energy rate.
  • Texas electricity prices have faced upward pressure in recent years from fuel costs, grid investment, changing demand, and market conditions.
  • The state has stayed well below the national average every year in that stretch despite these upward pressures.
Electricity rates move daily in Texas's deregulated market, so facility managers should always confirm current published rates before citing specific cent per kWh figures in financial projections.
Rate shopping is one lever, but for businesses with meaningful energy use, how much you draw from the grid at your peak moments matters just as much as the rate you are paying per kWh.
Cutting Your Bill Beyond Rate Shopping
Controlling operational overhead means looking beyond your retail contract at how you actually use power during the billing cycle. Managing energy spikes is often the fastest way to trim a business’s utility expenses. Demand charges, based on your highest 15- or 30-minute usage spike in a billing cycle, can account for 30 to 70 percent of a commercial electricity bill. That means two businesses on the identical rate plan can pay very different totals depending on how spiky their usage profile turns out to be. To counter this, battery storage lets a business draw down stored power during its highest demand periods instead of pulling that peak straight from the grid. Facility teams evaluating commercial efficiency strategies can review how small business energy storage cuts electricity costs. When evaluating physical hardware to handle these loads, several commercial grade solutions stand out for business environments.
EcoFlow DELTA Pro Ultra X
1. 100% Whole-Home Power Station: Delivers 12–36kW output and 12–180kWh capacity. 2. Plug & play design, installed in 7 days. Save up to 80% on time and cost. 3. Smart & reliable when it matters most, 20ms auto switchover. 4. Save up to $6000/year, 3-year ROI. 5. End-to-end system protection, the highest safety standards.
EcoFlow DELTA 3 Max Plus (2048Wh)
1. 3000W Powerful Output: 6000W surge output. With X-Boost™ mode,it supports heavy-duty appliances up to 3800W such as refrigerators, coffee makers, washers, and circular saws. 2. 5 Ways to Charge, Ready in Just 43 Mins: Ready in Just 43 mins (0-80%) with generator charging. 3. 2-10kWh Expandable Capacity: Easily scale up, and can achieve longer runtime with an EcoFlow Smart Generator featuring automatic start and stop. 4. Smart Output Priority: Choose which circuits stay powered via the app. Prioritize what matters and extend runtime when it counts most. 5. The adapter is required to connect the 800W Alternator Charger with DELTA 3 Max Plus.
EcoFlow DELTA Pro 3
1. Powerful and Versatile: Delivers both 120V and 240V outputs with up to 4000W in a single unit, capable of powering a 3-ton central AC and all other essential appliances. Exclusive X-Boost technology allows the unit to exceed its rated output, providing up to 6000W of power when needed. 2. Continuous Output While Charging: Provides stable, uninterrupted power at 120/240V with a maximum continuous output of 4000W, even during pass-through charging. Endless energy: Compatible with portable generators, auto recharging when connecting with EcoFlow Smart Generator 4000. 3. Longer Life Cycle: Retains 80% capacity even after 4000 cycles, thanks to advanced EV-grade LFP battery technology.
What Actually Determines Your Business's Rate
When assembling pricing on commercial contracts, retail energy providers consider a variety of operational metrics, and knowing these variables can help business owners position their accounts for better terms. A consistent, predictable usage with a high load factor will generally qualify a business for lower pricing per kWh, as a consistent draw is much cheaper for a provider to serve than a spiky, sporadic facility demand. Contract length is also a consideration. The shortest term plans, from 1 to 6 months, tend to have the lowest advertised rates but can leave you exposed to more market fluctuation at renewal. Longer fixed terms, from 12 to 60 months, provide a slightly higher locked rate in exchange for long term budgeting certainty.
In addition to the contract, the TDU territory dictates where a business is located, which utility provides the electricity and what delivery charges apply, regardless of the retail provider. The type of business is also very important, as well as the size. A 24 hour operation such as a restaurant or manufacturer uses energy very differently than a normal day-time office. Knowing those cost drivers makes it much easier to compare the various plan types offered in the deregulated market place.
Business's RateBusiness's Rate
Fixed, Variable, and Green Rate Plans
The right contract structure will protect a company from unforeseen market volatility, as each plan type has a different risk profile and financial structure. The most popular choice for businesses who want to know exactly what they will pay each month and not have price spikes in high demand seasons are fixed rate plans. Fixed rate plans lock in a set rate per kWh for the term of the contract. Variable rate plans however fluctuate with the wholesale market month to month. These plans offer flexibility and no long term contract commitment, but also real exposure to severe price spikes during high demand summer or winter periods. Meanwhile, green energy plans source all or some power from renewable wind or solar generation, usually costing about the same as standard fossil fuel plans in Texas given the state's enormous wind and solar infrastructure capacity. “Plan type matters, but so does the particular market the business is shopping in, beginning with Texas' largest commercial hub.
Business Electricity Rates in Houston
Houston commercial accounts operate under unique regional conditions that influence overall energy expenditures. Analyzing this specific market reveals how local factors shape utility costs.
  • Houston falls within CenterPoint Energy’s delivery territory, where commercial rates have averaged in the mid six cent range per kWh, with the lowest advertised plans dipping into the high four cent range, according to rate comparisons published in August 2026.
  • These rates sit slightly above the cheapest Oncor territory prices while remaining well under the national commercial average.
  • Coastal exposure and higher average cooling demand push local load profiles and demand charges higher for Houston area businesses compared to similarly sized operations in milder inland markets.
  • Houston's status as a major commercial hub also drives intense provider competition, which helps offset some of the territory's higher baseline delivery costs for businesses that shop the market actively.
Wherever a business is located, one timing mistake causes more overpayment than almost anything else: letting an active contract expire without a renewal plan.
Business Electricity Rates in HoustonBusiness Electricity Rates in Houston
Avoiding the Contract Rollover Trap
Contract management requires strict adherence to renewal timelines to avoid punitive default pricing tiers. Proactive scheduling prevents unnecessary spikes overhead.
  • When a fixed term commercial contract expires without customer action, providers typically roll the account over to a variable holdover rate that is often two to three times higher than the expired fixed rate.
  • Facility managers should start shopping for a renewal 60 to 90 days before a current contract ends to avoid any administrative gap where holdover pricing applies.
  • Commercial operators analyzing equipment investments and backup resilience can examine why home battery backups boom amid outages.
  • The best time to lock in a new rate is during the spring or fall shoulder months, when lower seasonal demand keeps wholesale prices and new contract rates more competitive than during peak summer heat.
Texas business electricity rates still remain much lower than the national average, but the amount a company actually pays is highly dependent on its TDU territory, contract length, load profile, and active management. Operators should shop by utility region, not statewide averages, select plan structures that reflect their predictability of operations, and shop for renewals months in advance. Dependable backup power and peak shaving can be achieved by commercial battery solutions like the EcoFlow DELTA Pro Ultra X, EcoFlow DELTA Pro 3, or EcoFlow DELTA 3 Max Plus, eliminating costly demand spikes altogether.
What is the average business electricity rate in Texas?
Competitive commercial rates average around 5.9 cents per kWh, while broader EIA surveys put overall commercial averages closer to 8.4 to 9.5 cents per kWh, staying well below the national average of 14.1 cents per kWh.
How do I find the best business electricity rate for a small business?
Compare rates within your specific TDU territory, evaluate your load factor and usage profile, shop in shoulder months, and begin renewal comparisons 60 to 90 days prior to the expiration of your current contract.
Why are business electricity rates in Houston different from other Texas cities?
Houston is served by CenterPoint Energy. Delivery fees and greater coastal cooling needs and different load profiles all impact the cost relative to inland areas served by companies like Oncor.
What are demand charges, and how much do they add to a commercial bill?
Demand charges are based on the highest 15 or 30 minute period of power use during a billing cycle and make up anywhere from 30 to 70 percent of a commercial electricity bill.
Can battery storage actually lower a business's electricity bill?
It can, depending on the utility tariff, demand-charge structure, system configuration, and load profile. A properly configured battery system can discharge during peak-demand periods and potentially reduce the amount of power drawn from the grid during those intervals.
Save Bills
