Is Gas Cheaper Than Electric? It Depends What You're Asking
The honest answer is that it depends on what you are running. For home heating and everyday appliances like furnaces, water heaters, and ranges, natural gas usually costs less per unit of energy delivered. For cars, electricity wins by a wide margin, often costing less than half as much to fuel per mile. Once solar panels and battery storage enter the picture, though, the comparison can flip. Using your own stored power costs close to zero once the system is paid off. This guide walks through each scenario so you can see exactly where your household lands.
Home Heating and Appliances: Is Gas Cheaper Than Electric?
gas cheaper than electricitygas cheaper than electricity
Furnaces, water heaters, ranges, and clothes dryers are the appliances where the gas-versus-electric question comes up most. On pure operating cost, natural gas usually wins here, and the numbers back that up clearly.
Natural gas is often a lower-cost heating fuel than electricity across U.S. markets, although the actual savings depend on local utility rates, appliance efficiency, and the type of electric heating being compared, and gas-compatible appliances tend to cost less to run than their electric counterparts. In its November 2025–March 2026 winter forecast, the U.S. Energy Information Administration projected average household heating expenditures of about $642 for natural gas and $1,133 for electricity. That is a meaningful gap, and it tends to hold up even in years when gas prices climb.
Gas cannot do everything, though. A home still needs electricity for lighting, air conditioning, electronics, and appliances that are not gas-compatible. So the gas savings only apply to the specific loads gas can actually serve. Homeowners comparing gas furnace costs against solar heating on a single appliance usually see this same pattern show up on paper. Regional rates vary significantly, so homeowners should compare their local gas and electricity prices rather than assume one fuel will always be cheaper.
Winter heating cost snapshot (EIA forecast, November 2025 to March 2026)
Fuel type
Average household cost this winter
Natural gas
About $642
Electricity
About $1,133
Propane
About $1,210
Heating oil
About $1,390
That comparison covers gas and electricity bought from a utility. A home that generates and stores its own power changes the math entirely.
When Electricity Gets Cheaper Than Gas: Solar and Battery Storage
The cost comparison above assumes buying both fuels from a utility. Electricity generated by rooftop solar and stored in a home battery is not priced the same way.
Once a solar and battery system is paid for, the additional cost of using self-generated electricity can be relatively low, although the overall economics still depend on system costs, battery degradation, maintenance, and local utility rates. For a household weighing whether to switch some appliances to electric, this changes the calculus. Once self-generated power covers a meaningful share of daily use, the electric side of the comparison can become cheaper. That holds true even against a low gas rate.
The size of that shift depends on your system size and your local utility rates. It helps to see what solar panels save on a monthly bill before deciding whether a switch is worth it.
EcoFlow DELTA Pro Ultra X
1. 100% Whole-Home Power Station: Delivers 12–36kW output and 12–180kWh capacity. 2. Plug & play design, installed in 7 days. Save up to 80% on time and cost. 3. Smart & reliable when it matters most, 20ms auto switchover. 4. Save up to $6000/year, 3-year ROI. 5. End-to-end system protection, the highest safety standards.
EcoFlow DELTA Pro 3
1. Powerful and Versatile: Delivers both 120V and 240V outputs with up to 4000W in a single unit, capable of powering a 3-ton central AC and all other essential appliances. Exclusive X-Boost technology allows the unit to exceed its rated output, providing up to 6000W of power when needed. 2. Continuous Output While Charging: Provides stable, uninterrupted power at 120/240V with a maximum continuous output of 4000W, even during pass-through charging. Endless energy: Compatible with portable generators, auto recharging when connecting with EcoFlow Smart Generator 4000. 3. Longer Life Cycle: Retains 80% capacity even after 4000 cycles, thanks to advanced EV-grade LFP battery technology.
EcoFlow 400W Rigid Solar Panel
1. A 23% conversion rate to sunlight 2. All-black design that fits any house style 3. Built to last with an IP68 waterproof rating 4. Fast and Easy Installation 5. Up to a 10-year warranty
Generating your own power changes the long-term math. Switching from gas to electric, or the other way around, still carries a real upfront cost worth knowing about.
The Real Cost of Switching Between Gas and Electric
Real Cost of Switching Between Gas and ElectricReal Cost of Switching Between Gas and Electric
Converting a home from gas to all-electric, or the reverse, is not free. The price tag depends heavily on what already exists in the house.
Moving from all-electric to gas often means digging to install new gas lines. Where natural gas service is not available nearby, that can mean adding a propane tank instead. Moving from gas to electric-only typically means capping the existing gas lines and possibly adding new circuits and wiring for larger electric appliances. That kind of work includes capping old gas lines and running new circuits for an electric range or heat pump. It is similar in scope to a broader home rewiring project, and its typical costs offer a useful reference point.
  • New gas line installation, or a propane tank where natural gas is not available
  • Capping and safely sealing existing gas lines that are no longer in use
  • New electrical circuits and added panel capacity for larger appliances
  • The appliances themselves, since gas and electric models are rarely interchangeable
Total costs typically run from several hundred to several thousand dollars, depending on the scope of the work. Converting solely to save a modest amount each month can take years to pay off. The switch tends to make more sense when it is paired with a renovation already underway or a move toward solar.
Appliances and heating are one comparison. Cars are a completely different one, and they deserve their own look.
Electric vs. Gas Cars: Which Is Actually Cheaper to Drive?
Electric vs. Gas CarsElectric vs. Gas Cars
Unlike home heating, this comparison is not close. Electricity wins clearly when it comes to fueling a vehicle.
The U.S. Department of Energy has found that electric vehicles are dramatically more efficient at turning energy into miles traveled than gasoline cars. EPA efficiency ratings for model year 2024 EVs range from 53 to 140 MPGe, against 9 to 57 MPG for comparable gasoline and hybrid vehicles.
That efficiency shows up directly in the wallet. In a separate DOE analysis, the electric vehicle models examined had estimated annual fuel costs below $1,000, while comparable gasoline vehicles were estimated at roughly $2,000 to $7,000 per year. EV maintenance costs also tend to run lower per mile, since there is no oil to change and regenerative braking reduces brake wear.
Savings vary by state and by charging habits. It is worth working through how much it costs to charge an electric car before assuming the math automatically favors electric. Home charging during off-peak hours is typically the cheapest option, while relying heavily on public fast chargers narrows the cost advantage.
Whichever fuel type wins on cost, there are real safety trade-offs worth understanding on both sides.
Safety Differences Worth Knowing
Properly installed and maintained systems of either type are safe to live with. The specific risks, though, are different in kind.
Gas appliances carry a carbon monoxide and gas-leak risk if something malfunctions. The U.S. Consumer Product Safety Commission describes carbon monoxide as an invisible killer, since it is colorless and odorless and can cause harm before anyone notices symptoms.
Electric systems carry a different risk: shock and electrical-fire risk from faulty wiring, overloaded circuits, or damaged appliances. Basic habits, like avoiding overloaded outlets and scheduling periodic inspection of older wiring, are the same electrical fire prevention steps homeowners rely on. These precautions are particularly important during the colder months, when homes may rely more heavily on heating equipment and electrical systems.
Both risks are manageable with routine maintenance and basic precautions. Neither option is categorically safer than the other, just different in the type of risk it carries.
With the cost and safety picture covered, here is how to run the actual numbers for your own home.
How to Calculate Your Own Answer
National averages only go so far. The real answer depends on your actual rates and your actual usage.
Electricity is billed in kilowatt-hours, while gas is billed in therms, BTUs, or cubic feet. Comparing the two requires converting to the same unit before any answer means anything for your home.
Pull your actual rates from a recent gas and electric bill, or from your utility's published rate schedule, rather than relying on national averages. Both vary significantly by region and by time of year. For an apples-to-apples comparison on a single appliance, start with the manufacturer's usage estimate in therms or kWh. Multiply that by your actual local rate for each fuel type.
As a quick example, take a gas rate of $1.20 per therm. An appliance using half a therm per hour costs about $0.60 an hour to run. Line that up against the same appliance's electric equivalent in kWh, priced at your own utility rate. That gives you a real answer instead of a national average.
Once you know where you stand, practical steps that lower the electric side of the bill can still help. That holds regardless of which fuel type you land on.
Gas is typically cheaper per unit for home heating and gas-compatible appliances, while electricity wins clearly for cars. Solar and battery storage can flip the home-heating math in electricity's favor by cutting the cost of self-generated power close to zero. Before switching either way, convert your rates to the same unit and factor in the real cost of conversion. If you are leaning toward all-electric appliances, EcoFlow has a practical starting point. The DELTA Pro Ultra X, DELTA Pro 3, and 400W Rigid Solar Panel are worth a look.
Is gas heat cheaper than electric heat?
In most U.S. markets, yes. Natural gas typically costs less per unit of heat delivered than electricity. Government forecasts back this up: this winter, households heating with gas are projected to spend roughly $642 on average, compared with about $1,133 for electric heat.
Is natural gas cheaper than electricity for appliances?
For appliances that can run on either, like ranges, dryers, and water heaters, gas usually costs less to operate. Electricity is still required for lighting, cooling, and anything that is not gas-compatible, so the comparison only applies to shared-load appliances.
Is it cheaper to drive an electric car than a gas car?
Yes, by a wide margin. Federal data shows EV fuel costs typically running under $1,000 a year, compared with $2,000 to $7,000 for gasoline vehicles. EVs are simply far more efficient at converting energy into miles.
How much does it cost to switch from gas to electric appliances?
Costs typically range from several hundred to several thousand dollars, depending on whether new circuits, wiring, or gas line capping is needed. It usually makes more financial sense when paired with a renovation or a move toward solar.
Can solar panels and battery storage make electric cheaper than gas?
Once a solar-and-battery system is installed, it can reduce the amount of grid electricity a household needs to purchase, potentially lowering long-term energy costs. The actual savings depend on system cost, electricity rates, energy consumption, and battery performance.
