Arkansas Solar Incentives: What's Actually Available in 2026
- The Federal Credit Homeowners Used to Count On Is Gone
- Net Billing Replaced Net Metering in Arkansas
- Storing Power Now Matters More Than Exporting It
- What Arkansas Doesn't Offer, Compared to Nearby States
- Local Utility Programs Worth Checking
- What Solar Actually Costs in Arkansas
- Is Solar Still Worth It in Arkansas Right Now?
- Conclusion
- FAQs
Arkansas never had a deep bench of solar incentives. And 2026 hasn't handed the state a new one. The federal tax credit used to cover 30% of a system's cost. That stopped applying to new installs at the start of the year. Arkansas itself still has no sales tax break. No property tax exemption. No state rebate to close the gap. What's left is a smaller net billing credit and a handful of local utility programs. Here's what still applies, what changed, and whether solar in Arkansas still pencils out this year.
The Federal Credit Is Gone
For more than a decade, the federal government covered close to a third of a new solar system's cost through the Residential Clean Energy Credit. That changed at the start of 2026, and Arkansas homeowners are feeling it more than most because the state never built anything of its own to fill the gap.
The credit covered 30% of a system's cost. According to the IRS, it no longer applies to systems placed in service after December 31, 2025. On a system priced around $30,000, the credit used to put roughly $9,000 back in a homeowner's pocket. Anyone installing it now pays full price.
What the Loss Means in Practice
Installers across the state have already adjusted their quotes to reflect the higher net cost. Some are steering homeowners toward smaller systems sized closer to actual usage, since a bigger system no longer gets a third of its price offset automatically. Homeowners who had a system installed and running before the end of 2025 can still claim credit, even if they haven't filed yet.
Before it expired, the credit covered more than just panels. Labor, inverters, wiring, permitting fees, and even an added battery all counted. That's part of why the loss stings more than a simple discount would. Homeowners financing a system through a loan lose a planning tool too. A lot of solar loans were built around that tax refund. It was supposed to knock down the loan balance early.
This isn't only an Arkansas problem, either. The same law reshaped how homeowners everywhere plan around solar tax breaks. And the fallout for households outside Arkansas looks a little different depending on where you live. Losing the federal credit is one hit. Arkansas's own change to how solar gets credited on a monthly bill is a separate one.
Act 278: The End of 1:1 Net Metering
Arkansas ended traditional net metering years ago. The replacement pays out at a fraction of what homeowners used to get. Here's how the switch works, and who still gets the old deal.
Arkansas ended traditional 1:1 net metering under Act 278. That's a law passed in 2023. It phased in through September 30, 2024. Anyone who installed solar before that cutoff is grandfathered into the old full retail-rate credit. That protection runs for 20 years, through 2040.
Systems installed after the cutoff fall under net billing instead. Exported power gets credited at the avoided cost rate, not the retail rate. That avoided cost rate typically runs at less than half of retail electricity. That's according to the University of Arkansas Division of Agriculture. The idea behind avoided cost pricing is simple. It reflects what the utility saves by not generating or buying that power itself. That's usually a wholesale-type number, well below the retail rate. Residential systems are capped at 25 kilowatts under the current rules. That covers most home installations anyway.
Before and After the Cutoff
Before Sept. 30, 2024 | After Sept. 30, 2024 | |
Credit type | Net metering | Net billing |
Credit rate | Full retail, 1:1 | Avoided cost (less than half of retail) |
Protection | Grandfathered for 20 years | Standard net billing rules apply |
The practical effect is simple. Exported solar power is worth a lot less than it used to be. That changes how a system should be sized and used. That drop in export value is exactly why more Arkansas homeowners are looking at storing power instead of selling it back.
Exported power only earns the avoided cost rate now. Using that power at home instead is worth roughly twice as much per kilowatt hour. That single fact is reshaping how Arkansas homeowners think about system design.
A battery lets a system store daytime solar production. It can use that power in the evening, or during an outage, instead of exporting it cheap. That timing matters in Arkansas specifically. Summer air conditioning pushes electricity use highest in the late afternoon and early evening. That's right when solar production is already tapering off. A battery bridges that gap instead of pulling pricier power from the grid.
Arkansas sits across both Tornado Alley and Dixie Alley. And severe spring storms that knock down power lines are a real reason backup capacity matters here. It's not just a marketing angle for battery companies. Two EcoFlow systems fit this shift well. It comes down to how much of the home you want covered, and how much you're ready to spend upfront.
Arkansas charges full sales tax on solar equipment, unlike neighboring states that carved out exemptions.
Property Tax Increases: There is no state property tax exemption, meaning adding solar can increase a home's assessed value in some counties.
Zero State Grants or Rebates: Unlike other states, Arkansas offers no state-funded rebate or grant programs for residential solar installations.
No SREC Market: There is no organized Solar Renewable Energy Certificate (SREC) market. Savings come solely through reduced electric bills rather than selling certificates.
Minimal State Intervention: The state government has not created broader incentives to offset federal policy changes, though a few smaller, local programs exist.
State-level help is thin. But individual utilities in Arkansas still offer rebates that can stack with a solar install. None of these are solar-specific. But they add up.
Entergy Arkansas: Efficiency rebates from about $3 to $350 for qualifying upgrades
CenterPoint Energy Arkansas (formerly Arkansas Oklahoma Gas): Rebates from $100 to $500 for high-efficiency water heaters and furnaces
SWEPCO: Rebates generally from $6 to $500 depending on the upgrade
Advance Arkansas PACE financing: Available for commercial, industrial, and nonprofit properties, but there's currently no active residential PACE program in the state
Eligibility rules for these programs shift from year to year. Current government-backed solar financing options can look different by the time you sign a contract. It pays to confirm the details first. Utility rebate programs also tend to have limited annual funding. A program open in January can run dry by summer. Confirm current status directly with the utility, rather than going off last year's numbers.
Programs aside, most homeowners really just want to know two things. What does a system cost, and how long until it pays for itself?
Cost and payback
A 5-kilowatt residential system in Arkansas runs around $17,000 before credits, based on current per-watt pricing in the state.
Estimated payback lands around 10 years for a typical system, once monthly bill savings are factored in.
Arkansas residents pay a bit over 13 cents per kWh on average, well below the national average, which keeps payback timelines from stretching too far.
That 10-year estimate assumes average sun and average usage. Understanding how a payback period actually gets calculated helps separate a realistic number from an installer's optimistic pitch.
Paying for it
Larger systems and added battery storage push upfront costs higher, but they also shorten how long an outage affects the household.
A cash purchase gets the full benefit of every dollar saved.
A solar loan spreads the cost out but adds interest on top.
Either way, get quotes from more than one installer — per-watt pricing in Arkansas varies more between companies than most homeowners expect.
Timeline
Installation usually takes four to eight weeks from signed contract to switch-on.
Permitting and utility interconnection approval eat up most of that time, not physical installation.
A local installer who already knows your utility's process tends to move faster than one working outside their usual territory.
Incentives matter. But the sticker price and payback timeline are what most homeowners care about most. Here's where those numbers land right now.
For most Arkansas homeowners, yes, but the case now hinges on using your own power rather than selling it back, so size the system to your bill and run your own roof numbers instead of counting on incentives to carry it.
Losing the 30% federal credit stretches out payback for every new install. There's no way around that. Net billing's lower export rate makes a system's sizing matter more than it used to. Oversizing now earns a much smaller return. Arkansas's electricity rates aren't rising as sharply as some coastal states. That keeps the case for solar here more modest than in a state with steeper rate hikes.
Homeowners with high summer cooling bills, or real concerns about storm-driven outages, are the exception. For them, solar paired with a battery still holds up on its own merits. Every incentive on this list matters less than math for your own roof and your own bill. Running the numbers for a typical household beats letting any single credit or rebate decide for you.
Arkansas's solar incentives were thin before 2026, and they're thinner now. The federal credit is gone. There's no state sales tax break, property tax exemption, or rebate program to soften that loss. Before signing anything, check current avoided cost rates with your utility. Look into local efficiency rebates. Size any new system around your own use, not exports. If backup power matters more than ever, the EcoFlow DELTA Pro Ultra X covers a whole home end to end. The EcoFlow DELTA 3 Max offers a lighter, more affordable place to start.
Does Arkansas still have a solar tax credit in 2026?
No. The federal Residential Clean Energy Credit stopped applying to systems installed after December 31, 2025. Arkansas never created a state-level credit to replace it. Homeowners installing solar in Arkansas now pay full price.
What is net billing, and how is it different from net metering?
Net metering credited exported solar power at the full retail rate. Net billing, which Arkansas switched to after September 30, 2024, credits it at the lower avoided cost rate instead. That's often less than half of retail.
Is my old solar system still grandfathered into net metering?
If your system was installed and interconnected before September 30, 2024, yes. Arkansas grandfathers those systems into full retail-rate net metering for 20 years, through 2040.
Does Arkansas offer a sales tax or property tax exemption for solar?
No. Arkansas charges full sales tax on solar equipment and has no state property tax exemption. Installing panels can even raise a home's assessed value in some counties.
How much does a solar system cost in Arkansas?
A typical 5 kilowatt system runs around $17,000 before credits. Payback lands around 10 years once bill savings are factored in. Pairing it with a battery like the EcoFlow DELTA 3 Max adds backup capability without a huge jump in cost.
Is solar still worth it in Arkansas without the federal tax credit?
For many homeowners, yes, especially with high summer cooling bills or storm-related outage risk. Pairing panels with a battery like the EcoFlow DELTA Pro Ultra X makes the most of a smaller export credit by keeping power at home instead of selling it back cheap.
