Minnesota Solar Incentives 2026: Rebates and Tax Breaks
Minnesota has a bad reputation for solar power. Cold winters and gray skies get the blame. But the real numbers tell a different story. A two-tier net metering law still pays homeowners for extra power. One of the country's largest community solar garden programs is still running strong. Tax breaks and utility rebates are still active in 2026. That's true even with the federal credit gone. This piece covers what still works here. It covers which Minnesota solar incentives still pay out. And it answers the big question. Does solar still make sense in Minnesota?
Does Solar Actually Pencil Out in a Cold, Snowy State?
Snow and short winter days scare people off. That fear makes sense on the surface. But the production numbers don't back it up. Heat is the real enemy of solar output, not cold. Cold weather actually helps a panel run better. It cuts into a panel's output far less than most people think. Here's what actually happens once temperatures drop.
  • Minnesota gets about 4 to 5 peak sun hours a day. The exact number depends on where you live. Duluth and the North Shore sit on the lower end. The Twin Cities and southern Minnesota run a bit higher. That range sounds low next to a desert state. But it's close to what Germany gets. And Germany has far more solar power per person than the U.S.
  • A cold, sunny day is not a loss for your panels. Solar cells lose power as they heat up. So a chilly January day can beat a hot July one. That's watt for watt.
  • Snow does block a panel for a day or two. But dark solar glass warms up fast in the sun. That heat melts the snow at the edges first. The whole sheet usually slides off. This happens before the next storm hits.
  • Minnesota's yearly solar output trails Arizona by about 15 to 20 percent. That's a much smaller gap than people assume. And it's a gap the state's incentives help close anyway.
The climate question is settled. Next up: how Minnesota pays you for extra power.
How Minnesota's Net Metering Rules Actually Work
Net metering sets how much your system earns you. It works on a monthly basis. Minnesota uses a set formula for how a monthly credit gets calculated, just split across two tracks. Which track applies depends on your system size. It also depends on your utility.
  • Systems under 40 kW get credited at the retail rate. That covers almost every home system. The rate resets every year. It's based on total revenue and total power sold. So it shifts a little with electricity prices.
  • Bigger systems get paid a different rate. This covers systems from 40 kW up to 1 MW. Xcel Energy is one utility that uses this range. The rate is called the avoided cost rate. It's roughly what the utility would pay elsewhere for that power. It usually runs lower than the retail rate.
  • Leftover credit at year's end works differently by utility. That difference matters if you make more power than you use.
  • Total system size is capped too. The cap sits at 120 percent of your yearly electricity use. Any community solar subscription you hold counts toward that cap.
Utility type
Investor-owned (e.g., Xcel Energy)
Paid out at the avoided cost rate
Cooperative or municipal utility
Canceled, no payout
Storing Solar Power Through a Minnesota Winter
Minnesota sees more ice storms and heavy snow than most states. Those storms bring down power lines often. A furnace that stops in a cold snap is a real danger. It's not just a hassle. Rural power lines can take longer to fix too. They often take longer than lines in the Twin Cities metro. The good news is that lithium batteries handle cold well. Most people assume otherwise. But battery capacity only drops at very low temperatures. Those temperatures run far below what a Minnesota garage usually sees.
  • A whole-home system keeps things running. It powers your furnace, well pump, and fridge through a multi-day outage. That beats just keeping a phone charged and a few lights on. It matters most for homes on well water. No power usually means no running water there either.
  • A smaller, portable unit still covers the basics. This works for an apartment. It also works for a home that doesn't need whole-home backup. It's easier to size and set up too, without an electrician.
  • Pairing either option with solar panels helps even more. The battery can recharge from the sun during the day. It doesn't need to rely only on the grid. That turns a multi-day outage into something closer to unlimited backup.
Storing Power through a Minnesota WinterStoring Power through a Minnesota Winter
EcoFlow DELTA Pro Ultra X
•100% Whole-Home Power: Delivers 12–36kW output and 12–180kWh capacity. •Fast Installation: Plug-and-play design installs in 7 days, saving up to 80% on time and cost. •Smart & Reliable: Features a fast 20ms auto switchover when it matters most. •High Savings: Saves up to $6,000 per year with a 3-year ROI. • Comprehensive Safety: Provides end-to-end system protection meeting the highest safety standards.
EcoFlow DELTA 3 Max (2,048Wh)
•2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws. •4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. • Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product. •OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. •Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
DELTA Pro Ultra X covers a full electrical panel, the kind of setup that makes sense for a household running a furnace, well pump, and sump pump off the same backup. DELTA 3 Max fits a household that just needs the basics covered until the power comes back, without the cost or installation time of a whole-home system.
Backup power aside, not every Minnesota household has a roof that works for solar in the first place, and the state has a specific answer for that.
The Community Solar Garden Option for Homes That Can't Go Solar Themselves
Not every home has a roof built for solar. Shaded lots get left out. So do rentals. So do roofs facing the wrong way. Minnesota built a workaround for that exact problem. It's grown into one of the biggest programs of its kind in the country.
  • Minnesota runs one of the largest community solar garden programs around. Residents can subscribe to a share of a shared solar project. No panels on your own roof are needed. The state's Department of Commerce runs the program, not individual utilities.
  • Subscribers can sign up from anywhere in a utility's Minnesota service area. That's a big deal for renters. It also helps homes with shaded lots or bad-angle roofs. You don't even need to own the roof. The subscription follows you, not the property.
  • Minnesota's Low- and Moderate-Income Accessible Community Solar Garden Program sets aside at least 30 percent of each project's capacity. That share goes to income-qualified subscribers. More than half of total capacity goes to income-qualified homes and groups like schools combined. Each garden also needs at least 25 subscribers per megawatt. That keeps one subscriber from owning too much of a project.
  • Subscribers see a credit on their power bill each month. They never touch the equipment or handle repairs. For income-qualified households, the subscription cost is capped below 90 percent of the credit received, so the savings hold up over time instead of fading after the first year.
You might choose rooftop panels. Or you might choose a community solar subscription. Either way, a few statewide tax breaks apply.
Community Solar Garden Community Solar Garden
Tax Breaks and Rebates Minnesota Homeowners Can Still Claim
People often search for a minnesota solar tax credit. What they usually find is something different: real tax exemptions instead. Homeowners chasing solar panels Minnesota incentives can often stack a few of these together. Your utility matters here too. You might have more than one rebate on the table at once.
  • Minnesota exempts solar equipment from its 6.875 percent state sales tax. That break has been in place since 2005. On an average home system, it's worth around $1,500.
  • The value solar adds to your home skips property tax too. Installing panels won't raise your tax bill the way an addition might.
  • Xcel Energy customers can join the Solar Rewards program. It pays about $0.03 per kilowatt-hour of production. That runs for 10 years. It's on top of whatever the system already saves you. Over the full 10 years, that adds up to roughly $2,900 for an average system.
  • Homeowners outside Xcel territory have options too. Minnesota Power's SolarSense program pays based on your system's first-year output. It can reach up to $5,000. Or it can reach 60 percent of installed cost, whichever is lower. Applications go through a lottery with a short window in early March each year, so timing matters. Smaller utilities offer flat rebates as well. Austin Utilities and Owatonna Public Utilities are two examples. Funding on these smaller programs tends to run out fast, though.
  • Battery storage gets its own rebate too. Xcel customers can get around $175 per kilowatt-hour of capacity. Income-qualified households can get an even higher rate.
  • The federal Residential Clean Energy Credit used to cover 30 percent of a system's cost. It no longer applies to systems installed after December 31, 2025. That change hit every state this year, not just Minnesota, and it caught homeowners mid-project when the cutoff hit without much warning.
Incentive
What it's worth
State sales tax exemption
6.875% off equipment cost
Property tax exemption
Added home value not taxed
Xcel Solar*Rewards
About $0.03/kWh for 10 years
Battery storage rebate (Xcel)
About $175/kWh, higher if income-qualified
What a Solar System Actually Costs in Minnesota
Cost is where most solar talk starts. It's also where a lot of it stalls out. Here's the honest range for a Minnesota homeowner in 2026.
  • A typical home system in Minnesota costs close to the national average. Most land somewhere in the mid-teens to low twenty thousands. That's before incentives.
  • Add up the sales tax exemption, any utility rebate, and Solar Rewards payments. That net cost drops meaningfully, even without the federal credit. Exactly how much depends on your utility and system size, but stacking those three brings the starting price down well before payback math even starts.
  • Payback time varies a lot by household use and utility. But 11 to 12 years is a fair starting guess for a typical system before battery storage, though what actually builds that break-even timeline differs from one house to the next.
  • Battery storage raises the upfront cost further. But it also turns Minnesota's harsh winters into an advantage. The system pays for itself twice. Once on the bill. And once during an outage. A real quote beats any statewide average. Base it on your own roof, use, and utility. Your own mix of incentives can shift the math a lot either way.
Real cost and payback numbers are on the table now. It comes down to one thing. Does this actually add up for a Minnesota homeowner?
Is Solar Still Worth It in Minnesota?
For most homeowners, yes. Here's why math still works, even with the federal credit gone.
  1. Minnesota lost the same 30 percent federal credit every other state lost. That loss stings no matter where you live.
  2. Minnesota still has a strong backstop, though. A two-tier net metering law helps. So do real tax exemptions. So does an active Solar Rewards program. Utility rebates outside Xcel territory help too. So does a community solar option for homes that can't go solar on their own.
  3. The cold-climate production penalty is smaller than most people assume. That knocks out one of the biggest objections. It happens before you even look at the numbers.
  4. A real quote beats a statewide average every time. Base it on your roof, use, and utility, since what pays off for one home doesn't always apply to the next.
That's the real state of mn solar power incentives heading into 2026. Still generous. Just shaped a bit differently than a few years back.
Minnesota's solar incentives hold up better than the state's winter reputation suggests. A two-tier net metering law still pays out in 2026. So do real tax exemptions. So does an active Xcel rebate program. So does a huge community solar garden option. Check if your utility is investor-owned or a cooperative first. That tells you which net metering rule fits. Look into community solar if your own roof isn't a good fit. And since winter outages are a real risk here, pair solar with battery backup. EcoFlow's DELTA Pro Ultra X or DELTA 3 Max can keep the essentials running when a storm hits.
Does Minnesota still have solar incentives after the federal tax credit ends?
Yes. Several programs are still active. These include the state sales tax exemption and the property tax exemption. Xcel's Solar Rewards program is still active too. So are utility rebates like Minnesota Power's SolarSense. The community solar garden program is running as well. Only the federal 30 percent credit went away, at the end of 2025. That loss applies everywhere, not just in Minnesota.
How does net metering work for homes served by a cooperative utility in Minnesota?
Cooperative and municipal utility customers get the same retail rate credit. This applies to systems under 40 kW, just like everyone else. The difference shows up at year's end. Leftover credit expires instead of getting paid out. That's unlike Xcel and other investor-owned utilities. So it pays to size a co-op system close to your actual usage.
What is a community solar garden, and how do I qualify for one in Minnesota?
A community solar garden lets you subscribe to a share of a shared solar project. You skip installing your own panels. At least 30 percent of each project goes to income-qualified households. That gives renters a path in. It also helps homes with bad roofs. Minnesota's Department of Commerce runs the current program.
Do solar panels actually work well in a cold, snowy climate?
Yes. Cold air helps panels run better, not worse. Snow usually slides off a properly angled roof within a day or two. Minnesota's yearly output only trails Arizona by about 15 to 20 percent. That's a smaller gap than most people expect.
How much can battery backup help during a Minnesota winter power outage?
Quite a lot. A whole-home battery like the EcoFlow DELTA Pro Ultra X can help. It keeps a furnace, well pump, and fridge running for days. That matters most for rural homes on well water. A smaller unit like the DELTA 3 Max covers the basics too. It works for an apartment or a simpler backup setup, until the power comes back.
