What Is Power Factor? How It Works, Why It Matters, and How to Fix It
Your electric meter doesn't tell the whole story. Some of the power sent to a building never does any useful work. It just moves back and forth on the wires. Power factor is how engineers measure that gap. It matters for factories, offices, and even the backup power you buy for your home. So what is power factor, exactly? This guide explains it in plain English. It covers the basic formula and how different loads behave. It also covers why low values cost money and how power factor correction works.
What Is Power Factor in Electrical Systems?
Power factor shows how well a device turns electricity into useful work. It's a number between 0 and 1. The closer it gets to 1, the less power goes to waste on the wires.
The Formula and the Three Types of Power
Power factor compares two kinds of power. Here's the formula:
Power Factor = Real Power (kW) ÷ Apparent Power (kVA)
Real power does the actual work. Apparent power is the total the utility has to send. If both numbers match, the power factor is 1. If apparent power is higher, the power factor drops below 1. A third type, reactive power, explains the gap between them.
Type
Unit
What It Does
Real power
Watts (W) or kW
Runs motors, heats, and lights things up
Reactive power
VAR or kVAR
Builds magnetic fields in motors and transformers
Apparent power
VA or kVA
The total load the wiring has to carry
Reactive power doesn't spin a shaft or heat a room. But motors need it to create their magnetic fields. That extra flow still travels through the wires. If you work with these units often, a quick refresher on how amps, volts, and watts connect makes the math easier.
A Simple Way to Picture It
The Department of Energy uses a helpful image. Picture a horse pulling a rail car down a track. The horse walks beside the track, so it pulls at an angle. Only part of its effort moves the car forward. That forward pull is real power. The sideways pull is reactive power. The total effort is apparent power. The wider that angle, the lower the power factor, and the harder the horse works for the same result.
People often mix up power factor and efficiency. Efficiency compares the power going in with the work coming out, since some is always lost as heat. Power factor is about timing between current and voltage. A motor can be efficient and still have a low power factor. So it helps to check both numbers on a spec sheet.
How Different Loads Affect Power Factor
Not every device behaves the same way. The type of load decides whether current and voltage stay in step. That timing is what sets the power factor.
What Is the Power Factor of a Resistive Load?
A purely resistive load has a power factor of 1. That's also called unity. Current and voltage rise and fall at the same time, so all the power turns into heat or light. Space heaters, toasters, electric kettles, and old-style incandescent bulbs all work this way. So do the heating elements in an electric water heater.
Motors and transformers are different. They're inductive loads, so current lags behind voltage. That lag pulls the power factor below 1, which is called a lagging power factor. Air conditioners, pumps, fans, and fridge compressors all fall into this group.
Capacitors do the opposite. In a capacitive load, current leads voltage, which creates a leading power factor. Capacitive loads are less common on their own. But this effect is exactly what makes them useful for fixing low power factor.
Real buildings mix all three types. A home or shop runs heaters, motors, and electronics at once. So the overall power factor is a blend of everything that's on. Many electronics also have a lower power factor when they use basic power supplies. Better designs add built-in correction to fix that. For most homes, small loads like phone chargers barely move the needle. The big motors are what count.
Motor loads also care about the shape of the power wave. That's one reason pure sine wave inverters matter for pumps and compressors. Rough power can make motors run hot and noisy.
Why Power Factor Matters for Bills and Backup Power
what is power factor correctionwhat is power factor correction
Low power factor isn't just a textbook idea. It raises current, wastes energy in the wires, and can add fees to a bill. It also changes how you size backup power for motor loads.
Many utilities charge extra when power factor falls below 0.95. A Department of Energy fact sheet on power factor points this out. These fees mostly hit commercial and industrial customers. Some utilities bill business demand in kVA instead of kW. In that case, a low power factor raises the demand charge directly. Most homes are billed only for the energy they use.
Low power factor causes other problems too:
  • Higher current flows through the same wires.
  • More heat builds up in cables and transformers.
  • Voltage can drop, which strains motors.
  • Less capacity is left for new equipment.
What It Means at Home
Here's a quick example. Say a motor uses 1,000 watts of real power. At a power factor of 0.8, it needs 1,250 VA. On a 120-volt circuit, that's about 10.4 amps. At a power factor of 1, the same work takes only about 8.3 amps.
That extra current matters when you run a home on battery power. A power station has to handle the full load, not just the watts. Some generators and UPS units list both a watt rating and a VA rating. When those differ, the VA number sets the real limit for motor loads. Motors also pull a burst of current at startup. Knowing the difference between starting and running watts helps you avoid overloads.
For a home with a well pump, central AC, or a sump pump, backup power needs real headroom. A high-output system with plenty of capacity keeps those motor loads running through an outage. It also leaves room for lights, a fridge, and electronics at the same time.
EcoFlow DELTA Pro Ultra
• Certified Safety: The only portable power station certified to both UL1973 and UL9540 for extreme home reliability. • High-Power Output: Delivers 7.2–21.6kW, powerful enough to run your whole home, including a central AC. •Massive Capacity: Offers 6–90kWh capacity for comfortable whole-house backup lasting weeks. • Smart Integration: Provides auto-switchover, prolonged backup, and energy bill savings via the EcoFlow Smart Home Panel 2. •Flexible Charging: Features 5 charging options so backup plans always have a backup. •Self-Heating Battery: Automatically starts self-heating below 32°F to ensure normal operation in cold weather.
The EcoFlow DELTA Pro Ultra suits homes that want whole-house coverage for days or weeks. Not every home needs that much, though. If you mainly want to cover key circuits and a central AC, a smaller system can do the job. It also rolls from room to room on wheels.
EcoFlow DELTA Pro 3
• High Power & Versatility: Delivers up to 4000W (6000W via X-Boost) with 120V and 240V outputs to run a 3-ton central AC and essential appliances. • Continuous Power: Maintains stable 120/240V output at 4000W during pass-through charging. • Endless Energy: Compatible with portable generators and auto-recharges using the EcoFlow Smart Generator 4000. • Durable Battery Life: EV-grade LFP battery retains 80% capacity after 4000 cycles.
What Is Power Factor Correction?
Power factor correction brings the number back toward 1. It cuts wasted current and can lower demand fees. Most fixes are simple once you know the cause.
How Capacitors Fix It
Capacitors are the most common fix. They supply the reactive power that motors need right on site. That means the utility doesn't have to send it. A capacitor can sit right next to a large motor. Or a bank of them can serve a whole building from the main panel. The DOE fact sheet shows a clear before and after:
Stage
Real Power
Apparent Power
Power Factor
Before correction
100 kW
142 kVA
0.70
After correction
100 kW
105 kVA
0.95
The real work stays the same. But the total load on the system drops by about a quarter. That frees up capacity for more equipment. It helps to understand what kVA means for your system when you read these numbers.
Capacitors aren't the only tool. The DOE's guide to energy management for motor systems covers several related steps. Common ones include:
  • Turn off motors that sit idle or run with light loads.
  • Avoid running equipment above its rated voltage.
  • Replace worn-out motors with energy-efficient models.
  • Size motors to match the job instead of oversizing them.
A motor running near its rated load has a better power factor. A lightly loaded motor wastes more.
To find out where you stand, you'll need a meter that reads both watts and VA. Many digital power meters and clamp meters show power factor directly. For a business, the utility bill may already list it. Look for terms like kVAR, kVA demand, or power factor.
Adding capacitors isn't a DIY job, though. Too much correction can cause its own problems, like voltage spikes. A licensed electrician or engineer should measure the load first. They can size and place the capacitors safely.
Power factor shows how much of the power you pay for does real work. Resistive loads sit at a perfect 1, while motors pull it lower. Low values raise current, waste capacity, and can trigger utility fees. Capacitors and smarter motor use bring it back up. For home backup, size your system for real motor loads. The EcoFlow DELTA Pro Ultra and EcoFlow DELTA Pro 3 offer the output to handle them.
Q1: What is a good power factor?
Anything above 0.95 is usually considered good. Many utilities add fees for commercial customers who fall below that level.
Q2: What is the power factor of a resistive load?
It's 1, also called unity. Current and voltage stay in step, so all the power does useful work.
Q3: Does power factor affect my home electric bill?
Usually not. Most homes are billed only for energy used in kilowatt-hours. Power factor fees mainly apply to businesses.
Q4: What is power factor correction?
It's the process of raising a low power factor, usually by adding capacitors. This cuts wasted current and frees up system capacity.
Q5: Can power factor be higher than 1?
No. Real power can never be more than apparent power. So the highest possible power factor is 1.
Q6: Why does power factor matter for backup power?
Motors pull more current than their watt rating suggests. A system like the EcoFlow DELTA Pro 3 gives motor loads like a central AC the headroom they need.
Home Solutions
