What Are the Disadvantages of a Heat Pump? 5 Things to Know Before Installing One
A heat pump can heat and cool a house with the same equipment, and in the right setting it can use considerably less energy than electric resistance heating. That sounds simple enough. The installation decision usually is not.
A heat pump that performs beautifully in one house may disappoint in another. Climate matters, but so do insulation, duct condition, equipment sizing, electricity prices, and the way the controls are configured. The quoted price may also leave out electrical work or other changes the house needs.
Before replacing a furnace, look beyond the efficiency rating on the brochure. These five drawbacks deserve a closer look.
What Are the 5 Major Disadvantages of a Heat Pump?
Most heat pump problems do not come from one universal flaw. They happen when the equipment, building, and local conditions do not line up. A well-planned installation can avoid some of the following issues, but not all of them.
1. High Upfront Installation Costs
The heat pump cost on an invoice is only one part of the installed price. A whole-home conversion may also require a new air handler, refrigerant lines, thermostat wiring, a condensate drain, an outdoor equipment pad, permits, or electrical work. Existing ducts may need to be repaired or resized. In a ductless installation, adding several indoor heads can raise the labor and equipment cost quickly.
This is why two quotes for similarly sized homes can be thousands of dollars apart. One may cover a straightforward equipment replacement. The other may include changes that should have been made to the house years ago.
Geothermal systems involve another level of expense because the ground loop must be drilled or excavated. They can perform efficiently, but the initial cost and site work put them outside many household budgets.
Rebates may soften the total. They do not eliminate the need to compare complete, itemized proposals.
2. Reduced Performance in Extreme Cold
Outdoor air still contains usable heat below freezing. The real concern is not that every heat pump suddenly stops working at a certain temperature. It is that heating capacity and efficiency can change as the weather gets colder.
At the same time, the house is losing heat more quickly. Eventually, the building may need more heat than the equipment can deliver on its own. This point is often called the balance point.
What happens next depends on the system. Electric resistance heat may provide extra capacity, a gas furnace may take over in a dual-fuel setup, or the heat pump may continue running for long periods while indoor temperatures recover slowly.
Cold-climate models are built to maintain more of their capacity at low outdoor temperatures. Even within that category, however, performance varies. Ask the contractor for the proposed model’s heating capacity and efficiency at the winter design temperature for your area. A general promise that a unit “works below zero” does not reveal how much heat it can deliver there.
3. Potential for Higher Electricity Costs
Installing a heat pump will almost certainly increase electricity use if the home previously relied on gas, oil, or propane for heat. That does not automatically mean the total energy bill will rise. The fuel bill should fall at the same time.
The useful comparison is the combined annual cost before and after the conversion.
Local rates make a large difference. So do the heat pump’s seasonal efficiency, the home’s heat loss, thermostat settings, and the amount of auxiliary resistance heat used. A system that spends much of January running its heat strips will have a different operating cost from one that rarely needs them.
A surprisingly high first electric bill can also point to a problem. Incorrect thermostat settings, excessive auxiliary heat, leaking ducts, or poorly sized equipment may all increase consumption. One bill is not enough to judge the entire system, but it is worth investigating a sharp and unexplained increase.
Heating System Type
Cold-Weather Performance
Operating Cost Factors
Standard Heat Pump
Usually moderate to high; electrical or duct changes may add cost
Varies considerably by model and outdoor temperature
Depends on electricity rates and auxiliary heat use
Natural Gas Furnace
Often lower when replacing an existing furnace with usable ducts and gas service
Maintains strong heating output during cold weather
Depends on gas prices, furnace efficiency, and usage
Dual-Fuel System
Usually higher because it combines two heat sources
Heat pump handles milder weather; furnace covers colder conditions
Can shift between fuels, though savings depend on control settings and local prices
4. Dependence on Electricity
A heat pump needs electricity for the compressor, fans, controls, and any electric auxiliary heat. When the power goes out, the system shuts down.
Gas furnaces are not completely independent either. Their blower, ignition, and controls normally require electricity. The difference is that powering a furnace blower may be easier than supplying a central heat pump compressor and a large bank of resistance heat strips.
Backing up a heat pump therefore requires more than looking at average wattage. The plan must account for voltage, continuous demand, startup demand, auxiliary heat, battery capacity, and the approved method of connecting the equipment.
A small portable power station may comfortably operate phones, lights, internet equipment, and other essentials while still being unsuitable for central HVAC. Whole-home equipment can support larger loads, but the specific heat pump and backup system need to be evaluated together. Resistance heat may be the deciding factor.
5. Temporary Heating Loss During Defrost Cycles
Frost can form on the outdoor coil during cold, damp weather. A light coating is normal. If it were allowed to build up, however, it would restrict airflow and reduce performance.
To clear the coil, the heat pump periodically enters a defrost cycle. For a short time, the refrigeration process changes direction so heat can be sent outdoors to melt the frost. Some systems use auxiliary heat to reduce the effect indoors.
You may still notice cooler air from the vents or a brief change in room temperature. People accustomed to the hotter supply air from a furnace often notice it immediately, even when the system is operating correctly.
A normal defrost cycle is temporary. An outdoor unit that remains covered in heavy ice, defrosts constantly, or never seems to recover may have an airflow, drainage, sensor, refrigerant, or control problem that needs service.
EcoFlow DELTA Pro Ultra Whole-Home Backup PowerEcoFlow DELTA Pro Ultra Whole-Home Backup Power
Is a Heat Pump Right for Your Home?
The pros and cons of heat pumps depend less on broad labels than on whether a specific system fits your house. A contractor should be able to explain that fit with numbers, not just an equipment brochure.
Evaluate Your Local Winter Climate
Average winter temperature does not tell the whole story. Heating equipment is sized around the colder conditions a home is expected to experience, not an ordinary afternoon in December.
Ask about the winter design temperature for your location. Then compare it with the manufacturer’s published low-temperature capacity for the exact outdoor and indoor equipment combination being proposed.
This matters even in places with relatively mild winters. A house can still lose heat quickly if it has poor insulation, large areas of glass, or significant air leakage.
In a colder region, a properly selected cold-climate heat pump may work very well. Another home may be better served by supplemental heat or a dual-fuel arrangement. The ZIP code alone does not settle the question.
Compare Fuel Prices and Operating Costs
Do not compare the price of one kilowatt-hour directly with the price of one therm of natural gas. The units are different, and the equipment converts them into usable heat at different efficiencies.
To compare winter heating costs, start with a full year of utility bills. Include delivery charges and seasonal rate changes, not only the advertised supply rate. A contractor or energy auditor can then estimate annual consumption using the home’s heating load and the proposed equipment’s performance data.
The system being replaced also matters. Switching from electric baseboard heating, propane, or fuel oil may produce a very different result from replacing an efficient gas furnace in an area with inexpensive gas.
Operating-cost estimates are still estimates. They should show their assumptions clearly enough that you can change the electricity or fuel price and see how the result moves.
Consider Winter Power Outage Risks
Think about what happens if an ice storm interrupts power for six hours. Then consider a two-day outage.
For some homes, the practical plan is to back up communication, lighting, refrigeration, and a small secondary heat source rather than trying to operate the central heat pump. Other households may need a professionally connected whole-home system.
  • For essential devices during a shorter outage: The EcoFlow DELTA Pro Portable Power Station can support selected loads such as a router, lights, phones, and other compatible equipment. Available runtime depends on the combined load and battery configuration. It should not be assumed to run a central heat pump without checking the HVAC system’s actual electrical requirements.
With 3.6-25kWh expandable capacity and 7200W output, it powers 99% of appliances. Features industry-first EV station recharging, 2.7-hour fast charging, and a durable 10-year LFP battery.
  • For larger home loads: The EcoFlow DELTA Pro Ultra Whole-Home Backup Power supports 120/240V whole-home configurations when paired with compatible connection equipment. Whether it can start and operate a particular heat pump depends on the compressor, auxiliary heat, system configuration, and available battery capacity. Have an electrician or qualified installer calculate the loads before treating it as an HVAC backup solution.
The EcoFlow DELTA Pro Ultra is the only portable power station certified to both UL1973 and UL9540. It delivers 7.2-21.6kW, powerful enough to run your whole home even with a central AC. It features a scalable 6-90kWh capacity for weeks of backup. With Smart Home Panel 2 for auto-switchover, 5 charging modes, and self-heating for freezing weather, it’s the ultimate fail-safe power solution.
Backup equipment that supplies household circuits needs an approved transfer method. Never connect a power source to home wiring through an ordinary wall outlet.
What Should You Check Before Installing a Heat Pump?
The work done before the equipment is ordered often matters more than the brand name printed on the cabinet.
Assess Home Insulation and Existing Ductwork
Heat pumps commonly deliver warm air for longer periods rather than the short bursts of very hot air associated with many furnaces. In a drafty house, that gentler output may feel as though the system is always trying to catch up.
Start with the building envelope. Attic insulation, rim joists, exterior penetrations, window gaps, and leaky doors can all contribute to heat loss.
Ducts deserve the same attention. Air leaking into an attic, garage, or crawlspace does nothing for the rooms upstairs. Poorly sized ducts may also create noise, weak airflow, or excessive static pressure.
Sealing obvious leaks and correcting insulation problems can reduce the size of the heat pump the house needs. It may also improve comfort regardless of which heating system you ultimately choose.
Calculate Heating Load and System Size
Square footage is not a complete sizing method.
A proper residential load calculation accounts for insulation, windows, orientation, air leakage, ceiling height, local weather, and other characteristics of the house. Ask for a Manual J calculation rather than accepting a recommendation based only on the size of the old equipment.
Larger is not automatically safer. An oversized unit may cycle too frequently during mild weather and provide poor humidity control in summer. An undersized system may rely heavily on auxiliary heat or struggle during the coldest part of the year.
The load calculation should then be compared with the manufacturer’s performance data at relevant outdoor temperatures. That step connects the needs of the house with the actual capacity of the equipment.
Confirm Electrical Panel and Circuit Needs
Most central heat pumps need dedicated electrical circuits, and many use 240V power. An air handler with electric resistance heat may require another substantial circuit.
That does not mean every older home automatically needs a 200-amp service. It does mean someone should complete an electrical load calculation before the contract is signed. Include any planned home backup power equipment in that assessment.
An electrician should check the service rating, available panel space, conductor capacity, disconnect requirements, and the heat pump’s nameplate information. Other large electric loads, including an EV charger, range, dryer, or water heater, must be considered as part of the same household system.
Discovering that an expensive panel or service upgrade is necessary after installation begins is an unpleasant surprise. Check early.
Review Available Rebates and Incentives
Incentive information becomes outdated quickly. The federal Energy Efficient Home Improvement Credit previously available for qualifying heat pumps applied to eligible property placed in service through December 31, 2025. Homeowners planning an installation after that date should not assume the former federal credit still applies.
State programs, municipal incentives, manufacturer promotions, and utility rebates may still be available. Their requirements can differ by location, income, equipment rating, and installation date.
Check the current rules before signing a contract. Also confirm whether a rebate must be reserved in advance and whether the contractor or equipment must appear on an approved list.
EcoFlow DELTA Pro Portable Power StationEcoFlow DELTA Pro Portable Power Station
What Are the Alternatives to a Heat Pump?
Deciding against an all-electric heat pump does not leave only one option. The existing fuel supply, climate, and layout of the home may point toward another system or a combination of systems.
Gas Furnaces for High-Heat Output
A gas furnace delivers relatively hot supply air and can provide strong heating capacity during very cold weather. If the house already has suitable gas service, venting, and ductwork, replacing an existing furnace may also involve fewer changes than a full electrification project.
There are trade-offs. The furnace still needs electricity for its controls and blower, so it will normally stop during a power outage unless those components receive backup power. Combustion equipment also requires proper venting, maintenance, and carbon monoxide protection.
Fuel prices and access vary widely. A furnace that is economical in one utility territory may be less attractive in another.
Electric Resistance Heating for Simple Systems
Electric baseboards and wall heaters are inexpensive to install and have few moving parts. They can make sense in a small room, an addition, a lightly used cabin, or an area that needs occasional supplemental heat.
Their weakness is operating cost. Resistance equipment turns electricity directly into heat, while a heat pump uses electricity to move heat from one place to another. That usually allows the heat pump to deliver more heat for the same amount of electricity.
Resistance heating may be simple, but simplicity does not necessarily make it inexpensive to operate through a long winter.
Dual-Fuel Systems for Flexible Heating
A dual-fuel system combines an electric heat pump with a gas furnace. The heat pump handles cooling and provides heat when conditions favor it. The furnace takes over when outdoor temperatures fall or when the controls determine that gas is the better option.
The changeover temperature should not be chosen by habit. It can be based on the heat pump’s capacity, the home’s heating load, local fuel prices, or some combination of those factors.
Dual-fuel equipment offers flexibility, particularly in colder regions or homes with an existing gas connection. It also costs more to install and leaves the homeowner responsible for maintaining two types of heating equipment.
A heat pump can be a very good heating system. It can also be an expensive way to discover that a house has leaky ducts, inadequate insulation, limited electrical capacity, or unusually high electricity rates.
The main drawbacks are not mysterious: installation may cost more than expected, cold-weather output varies by model, auxiliary heat can raise operating costs, outages require careful planning, and defrost cycles may feel different from furnace operation.
Get the heating load calculated. Review the proposed equipment’s performance at local winter temperatures. Ask for an itemized quote, confirm the electrical requirements, and compare total annual energy costs rather than focusing on one utility bill.
Those checks will tell you far more than a general claim that heat pumps are either perfect or unsuitable for cold weather.
What Are Common Mistakes to Avoid When Installing a Heat Pump?
Sizing the unit incorrectly by skipping a professional Manual J calculation is the most common and costly mistake homeowners make. Other frequent errors include neglecting necessary electrical panel upgrades, failing to seal drafty existing ductwork, and setting the outdoor unit directly on the ground where snowdrifts and dripping roof eaves can block airflow.
Can a Heat Pump Cool a House in 100 Degree Weather?
Yes, many modern heat pumps can cool a house in 100°F weather when the system is properly sized for the home’s cooling load and the equipment is rated to operate under those outdoor conditions. Top-tier inverter-driven systems modulate their compressor speeds to maintain consistent indoor temperatures and effectively wring humidity out of the air even during peak summer heat waves.
How Many Hours a Day Should My Heat Pump Run?
Expect a variable-speed heat pump to run between 12 and 18 hours a day during peak winter and summer months, often operating almost continuously at low speeds. Unlike old single-stage furnaces that blast on and shut off abruptly, heat pumps are intentionally engineered to run long, low-power cycles to maintain steady comfort and maximize energy efficiency.
Why Is My House So Cold with a Heat Pump?
Your heat pump is likely struggling because outdoor temperatures have fallen below its optimal operating range or the auxiliary heat strips have failed to engage. Other everyday culprits include dirty air filters restricting airflow, an iced-over outdoor coil stuck in a prolonged defrost cycle, or severe duct leakage dumping heated air into an unconditioned attic or crawlspace.
Home Solutions
