How to Prepare for an Ice Storm: Essential Tips for Your Home
An ice storm can be underway before it looks serious. Rain falls, traffic moves, and then ice appears on porch railings and parked cars. Tree limbs begin to bow.
Once the yard glazes over, preparation becomes unsafe. Use the earlier forecast window to clear gutters, move vehicles from trees, and buy what the household needs if roads or power remain out.
How Should You Prepare Your Home Before an Ice Storm?
What is an ice storm? It is a period of freezing rain that coats exposed surfaces with ice. Use the last dry stretch to circle the property. Check the roof, gutters, and branches first, followed by the faucets, exposed plumbing, doors, and windows.
Inspect the Roof, Gutters, and Downspouts
Empty the gutters and check the bends in each downspout, where hidden debris often collects. Meltwater needs to drain somewhere other than beside the foundation.
View the roof from the yard, using binoculars or a phone’s zoom. Look for lifted shingles, shifted flashing, or a gutter separating from the fascia. In the attic, old stains or damp insulation may reveal a leak before it reaches the ceiling.
Make sure boxes and loose insulation are not blocking vents near the eaves. Clear airflow helps limit the uneven roof temperatures where meltwater refreezes.
Once ice appears, put the ladder away. The rungs may freeze before the glaze is obvious from below. A new leak, sag, or cracking sound calls for a roofing professional, not a closer look from the roof.
Trim Tree Branches Near the House and Power Lines
Consider where a large branch would land if it broke. Limbs above the roof, driveway, utility connection, or main walkway deserve attention before the forecast turns bad.
A dead limb, split trunk, or tree leaning toward the house is an obvious concern. Sound wood can also fail once ice builds up. Ask an arborist about larger risks and move vehicles away before the rain freezes.
Do not cut anything near a power line. The branch may be energized or could shift into the wire while it is being trimmed. Report it to the utility or hire a tree professional qualified to work around electrical equipment.
Protect Pipes From Freezing Temperatures
Remove the hose from the outdoor faucet so trapped water can drain. Close its indoor supply valve if there is one, empty the outside run, and fit the insulated cover.
Check the garage, attic, crawl space, unfinished basement, and cabinets on exterior walls. A focused frozen pipe prevention check should include adding insulation to bare water lines in these colder areas.
Open the doors beneath a vulnerable sink during the coldest weather so room air can reach the pipes. Move cleaning products first if children or pets are present. A small cold-water drip may also help protect a particularly exposed line.
Avoid a deep thermostat setback during the coldest weather. For an empty house, 55°F is a commonly used minimum. Clear the path to the main water valve and show other adults where it is.
Test the valve before winter if it has not been moved in years. Do not force a corroded or stuck handle on the night of the storm. A plumber can replace a questionable shutoff while the house is still dry and warm.
Seal Drafty Doors and Windows
Run the back of your hand around closed windows and exterior doors. Replace worn weatherstripping, fit a sweep beneath a drafty door, and use suitable caulk around window frames without covering drainage openings.
Temporary film or a heavy curtain may help older windows. Let direct sun in, then close the curtain before evening. If the heat fails, shut unused rooms but leave registers, return grilles, and combustion-air openings clear.
What Should You Have Ready Before an Ice Storm?
When organizing emergency supplies for an ice storm, imagine an ordinary day without a working stove, an easy trip to the store, or reliable internet. That produces a more useful list than buying a generic kit and forgetting where it is stored.
Choose an indoor storage place that remains accessible in the dark. Use a winter storm emergency kit checklist to confirm the essentials, and keep the flashlight near the front of the shelf, not underneath the water and blankets. Everyone in the household should know where the kit is.
Preparedness Category | Essential Items to Stage | Target Supply Duration |
Water & Sustenance | One gallon of water per person per day, ready-to-eat food, snacks, and a manual can opener | Three days at minimum; longer where roads often remain closed |
Safety & Visibility | Flashlights, headlamps, spare batteries, first-aid items, and a battery or hand-crank radio | Enough for several evenings without electricity |
Backup Electricity | A charged power station, correct cables, and cords rated for the intended load | Based on the devices and hours of runtime required |
Pet & Family Care | Medication, infant necessities, pet supplies, blankets, hygiene items, leashes, and carriers | The same period as the household food and water supply |
Stock Food, Water, and Emergency Essentials
Allow one gallon of water per person per day. A household of four needs 12 gallons for three days, plus water for pets or medical care.
Choose food that can be eaten without refrigeration or much cooking. Canned fish or beans, crackers, nut butter, granola, and dried fruit are practical choices. Keep a manual can opener with the cans.
Check that prescriptions will last, then restock first-aid, hygiene, and infant supplies. Keep some cash and important numbers on paper. For powered medical equipment, know the battery runtime and where the user can go if it runs out.
Prepare Flashlights, Batteries, and Emergency Radios
Switch on every flashlight and store the correct spare batteries nearby. A headlamp frees both hands, while a battery lantern lights a room without the fire risk of candles.
Keep a battery-powered or hand-crank NOAA Weather Radio in the kit. Charge phones, power banks, and lights before the storm, and check that their cables are present. A portable power station can extend access to communications when an outage lasts longer than small batteries.
Keep Basic Backup Power Ready
List the devices that would actually run during an outage and check the wattage on each label. Phones and LED lights use little power. A refrigerator has a larger running load and may draw an extra burst when its compressor starts.
The EcoFlow DELTA 3 Classic Portable Power Station can cover phones, lights, a Wi-Fi router, and other compatible essentials. It may also run a refrigerator if the appliance’s starting and running requirements stay within the unit’s limits.
Runtime depends on the combined load. For a rough estimate, divide usable watt-hours by the watts being drawn, then allow for conversion losses and appliances cycling on and off.
Before storm season, connect the devices you expect to use and confirm that the setup works. This is particularly important for a refrigerator or CPAP machine. Testing also reveals missing adapters and cords while there is still time to replace them.
Charge the unit early and keep it dry. Never plug a power station into a wall outlet to energize home wiring. Hardwired circuits require compatible transfer equipment.
Bring Pets Indoors Before the Storm
Bring outdoor animals in before the yard freezes. Gather their food, water, medicine, bedding, waste supplies, carrier, and leash rather than planning to retrieve them later.
Keep outdoor trips short once ice forms. Wipe de-icing material from paws and check between the pads for cuts or packed ice. Make sure identification details are current, since breaking branches and electrical noises can frighten an otherwise calm animal.
Before listing a warming center or hotel in the family plan, find out whether animals are allowed. If they are not, identify the nearby shelter that handles pets. A copy of vaccination records can travel in the carrier.
What Should You Do During an Ice Storm?
Once rain is freezing on contact, leave the errands for another day. Clear ice can make a road or front step slick without changing its color enough to warn you. Keep home backup power equipment dry and operate it only within its approved limits.
Monitor Weather Alerts and Emergency Updates
Start with National Weather Service and local emergency-management updates. During ice storm power outages, check the utility’s own map and report the address if needed. Treat the first restoration estimate as provisional; crews may find more broken limbs or damaged equipment once they reach the circuit.
Read the type of alert, not only the headline. A winter storm watch leaves time to finish preparing. A warning means dangerous conditions are occurring or expected soon, so travel and outdoor work should already be ending.
Put the phone in low-power mode and check updates periodically. Use the radio if mobile service fails. Note warming-center locations and road restrictions; if indoor temperatures keep falling, relocate during an approved travel window rather than waiting until the house is dangerously cold.
Use Heating Systems Safely
Never heat the house with a gas oven or range. Grills, camp stoves, and outdoor propane heaters can release deadly carbon monoxide indoors.
A portable generator belongs outside, more than 20 feet from doors, windows, and vents. Never run one in a garage, even with the door raised. Smoke and carbon monoxide alarms should have working battery backup.
Keep bedding, curtains, furniture, clothing, and paper at least three feet from a fireplace, wood stove, or space heater. Plug an electric heater directly into a suitable wall outlet; a light extension cord may overheat. If a carbon monoxide alarm sounds, go outside and call 911.
Use a fireplace only when its chimney and flue are sound. Furnace and water-heater vents must also remain open, but wait until falling ice and branches no longer make an outside check hazardous.
Without central heat, gather in a smaller part of the house and close unused rooms. Dry layers and blankets require no electricity. A portable battery may start a heater, but the load can empty it quickly.
Keep Refrigerated Food Safe
Keep the refrigerator closed. According to USDA food-safety guidance, it generally protects food for about four hours without power. A full freezer lasts roughly 48 hours; a half-full one is closer to 24.
Use an appliance thermometer instead of guessing or tasting food. Move priority items to an ice-filled cooler kept at 40°F or below. A porch or snowbank is unreliable because temperatures change and animals can reach it.
Before the storm, group frozen foods together and freeze containers of water if space allows. A fuller freezer holds cold longer, and the containers can later become ice for a cooler. Leave room for the water to expand as it freezes.
The EcoFlow DELTA 3 Ultra Plus Portable Power Station (3072Wh) can support a compatible refrigerator along with selected lights, communication devices, or medical equipment. Its capacity can also be expanded with compatible batteries.
Supplying household circuits requires an approved inlet and transfer switch. An improvised connection can energize utility lines and endanger repair crews.
Stay Away From Downed Power Lines
A quiet wire is not necessarily a dead wire. Give any fallen line at least 30 to 35 feet of space, and back up farther if it is moving. Wet pavement, pooled water, fences, trees, and vehicles may carry the electricity beyond the wire itself.
Report the location to 911 and the utility. Do not drive across the line or try to lift it with a broom, branch, or tool. Anyone in a vehicle touched by the wire should remain inside unless there is an immediate danger such as fire, then follow the dispatcher’s instructions.
What Should You Do After an Ice Storm?
The quiet after the rain can be misleading. As temperatures rise, ice slides from the roof, broken limbs work loose, and cracks in frozen pipes finally begin to leak.
Check for Ice Damage to the Roof and Exterior
Stand far enough back to see the roof without putting yourself beneath the eaves. A gutter hanging loose, a new dip in the roofline, missing shingles, or ice poised above an entrance all deserve attention.
Continue indoors, checking the attic, upper ceilings, and walls beneath roof valleys. Fresh cracks, wet patches, or sagging material may indicate damage above. Keep people away and leave the roof and accumulated ice to a properly equipped professional.
Look for Frozen or Burst Pipes
Revisit the coldest pipe runs as the indoor temperature climbs. Open the sink cabinets and inspect the basement, garage, crawl space, and other unheated corners. A crack held shut by ice may start dripping only after the pipe thaws.
With all fixtures closed, listen for water where none should be running. Low pressure, a faint hiss, damp drywall, or a growing stain can expose a hidden break. Close the main valve when a leak is found. If water has reached wiring or appliances, do not enter the wet area.
For a frozen pipe that has not split, open its faucet and warm the reachable section a little at a time with a hair dryer, heating pad, or warm towels. Never bring a torch or other flame near it.
Inspect Trees and Outdoor Structures
A broken branch may remain caught overhead until melting ice or a light breeze brings it down. View damaged trees from outside their fall area.
Call an arborist for split trunks, exposed roots, a new lean, or limbs caught above the driveway. The utility should handle anything touching its lines. Keep out of sheds, carports, or awnings that have buckled or shifted.
Check Your Home for Electrical Damage
Utility power normally returns without the homeowner resetting the main breaker. Look at the meter box, service mast, conduit, and incoming wires from several yards away. If anything has moved, contact the utility.
When the current returns, notice how the house responds. A hot-plastic smell, crackling outlet, breaker that trips again, or lights that continue flickering may signal damage. If the panel is dry and safely reachable, switch off the affected circuit and call an electrician. Reconnect large appliances gradually.
Document Property Damage Before Starting Repairs
Take pictures before cleanup changes the scene. Begin with views that show the location and scale of the damage, then move closer for the roof, plumbing, rooms, trees, vehicles, and individual belongings.
Documentation comes after immediate safety. Shut off a leaking pipe and move undamaged property away from water when that can be done safely. Keep every receipt, contact the insurer early, and ask for written estimates before authorizing permanent work.
Ice storms leave little room for last-minute preparation. Clear the gutters, deal with risky branches, protect exposed plumbing, and keep several days of supplies where they are easy to reach. Charge backup batteries before the first flicker. During the storm, avoid unnecessary travel and improvised heating. Afterward, continue watching for roof ice, leaks, damaged wiring, and branches that have not yet fallen.
How Can I Keep My House Warm if I Don't Have Electricity?
The most effective way to stay warm without power is to close off unused rooms and gather your family in a single, well-insulated central room on an upper floor. Dress in layered thermal clothing, hang heavy blankets over windows to block heat loss, and use sleeping bags and extra comforters. Never bring fuel-burning outdoor cookers or unvented combustion heaters indoors, as they create an immediate carbon monoxide danger.
Will Frozen Pipes Unfreeze on Their Own?
Yes, frozen pipes will naturally thaw as ambient temperatures rise, but letting them unfreeze unattended is extremely risky because trapped water expands and may have already split the pipe. Once thawed, high water pressure can cause catastrophic indoor flooding. Keep your main shutoff valve ready, open household taps slightly to relieve pressure, and gently thaw exposed pipes using a hairdryer or warm towels.
Do I Need to Report My Power Outage?
Yes, you should always report an outage directly to your local utility company instead of assuming your neighbors have already done so. Most electric companies rely on customer outage alerts and automated meter pings to map the exact boundaries of a grid failure and dispatch line crews effectively.
Where to Run a Generator During an Ice Storm?
You must only operate a fuel-powered generator outdoors, at least 20 feet away from all doors, windows, and soffit vents, with the exhaust pointing away from the home. Running a generator inside a garage, basement, porch, or under an open window can lead to fatal carbon monoxide poisoning within minutes. If weather conditions prevent outdoor operation, use safe, zero-emission indoor alternatives such as portable battery power stations instead.
