How to Winterize an Above Ground Pool the Right Way
The first hard freeze does not care whether your pool is ready. Water left sitting in a pump housing expands when it freezes, and that is how homeowners end up with a cracked filter housing in November. A skipped closing usually shows up later as a green, swampy mess in April. The good news is that closing an above ground pool is a weekend job, not a contractor job. It just has to happen in the right order. Here is what that order looks like, from the first water test to the last cover strap.
Balance the Water Chemistry First
Look up how to winterize above ground pool equipment, and you will find a dozen different answers. Most people reach for the winterizing kit before they touch a test strip. That order causes problems. Chemicals added to unbalanced water do not work the way the label promises. The imbalance then sits against your liner for five or six months.
Test Before Adding ChemicalsTest Before Adding Chemicals
Test Before You Add Anything
Start with a fresh test kit or strips. You want readings for free chlorine, pH, total alkalinity, and calcium hardness. Old strips give bad numbers, so replace them if they have been in the shed since June.
Adjust in the Right Sequence
Order matters here, because each adjustment pushes the next one around.
  1. Bring total alkalinity into the 80 to 120 ppm range first, since it stabilizes everything that follows.
  2. Set pH next, aiming for 7.4 to 7.6.
  3. Raise free chlorine last, to at least 3 to 5 ppm.
Handle every product one at a time and follow the label. The CDC's pool chemical safety guidance is blunt about this. Keep chemicals in their original containers, and never let two products mix in a bucket or a scoop.
Balanced water at closing does two useful things. It keeps scale off the liner and fittings, and it gives you an easier spring. Everything you do now carries through to opening your pool after winter, which picks up where this process ends.
With chemistry balanced, cleaning the pool thoroughly comes next.
Clean the Pool Before Closing
Anything you leave in the water is still there in March. Leaves break down under the cover, feed algae, and stain the liner. Ten minutes of skimming now saves hours of scrubbing later.
Work through the pool in a simple order. Skim the surface, brush the walls and floor, then vacuum up whatever settles. Check the corners and the ladder area first.
Once the pool is visually clean, shock it. Add pool shock a few days before you close, not the same afternoon. That gap lets the chlorine burn off contaminants that would feed algae under the cover.
After any chemical goes in, run the pump for at least eight hours. Circulation is what actually distributes the treatment. A chemical sitting in one corner of the pool is not doing its job.
That eight-hour run is worth planning around in the fall. If a storm knocks out power midway through, pool maintenance during an outage becomes the urgent question. Closing day raises a related practical point.
Powering Equipment on Closing Day
Closing an above ground pool is not a plug-and-walk-away job. The pump needs to run for hours. You may also want a shop-vac or a small air compressor to clear the plumbing lines. Plenty of above ground pools sit in the middle of the yard, well past the reach of a garage outlet.
Portable Power for Closing DayPortable Power for Closing Day
Running a long extension cord across the lawn works until it does not. Cords get wet and lose voltage over distance. A portable power station puts the outlet where the equipment already is.
If that sounds like your setup, two EcoFlow units cover the common cases.
EcoFlow DELTA 3 Max Plus (2048Wh)
•3000W Powerful Output: 6000W surge output. With X-Boost™ mode, supports heavy-duty appliances up to 3800W such as refrigerators, coffee makers, washers, and circular saws. •5 Ways to Charge, Ready in Just 43 Mins: Ready in Just 43 mins (0-80%) with generator charging. •2-10kWh Expandable Capacity: Easily scale up, and can achieve longer runtime with an EcoFlow Smart Generator featuring automatic start and stop. • Smart Output Priority: Choose which circuits stay powered via the app. Prioritize what matters and extend runtime when it counts most.
The second unit suits smaller pools and shorter jobs, or households that want the option to add capacity later.
•1kWh–5kWh Scalable Capacity: Expandable capacity using DELTA 3, DELTA 2, DELTA 2 Max, or DELTA Pro 3 Extra Batteries (via an Alternator Charger XT150 Output Cable). • 1,800W Output with 3,600W Surge: Delivers a continuous 1,800W AC output (3,600W surge) and reaches up to 2,200W with X-Boost™ technology. • 5 Fast Recharging Methods: Supports versatile charging via AC, Solar, 800W Alternator Charger, Smart Generator 3000 (Dual Fuel), and Multicharging. • 5-Year Warranty Protection: Backed by a comprehensive 5-year warranty for long-term reliability and peace of mind.
Sizing a battery to a pump takes a little math. The guide on powering water filtration pumps walks through pump draw and runtime.
With power sorted, lowering the water and protecting the plumbing is the next major step.
Lower the Water and Protect the Plumbing
This is the step that decides whether your equipment survives the winter. Freezing water expands with enough force to split a pump housing or crack a fitting. Any water you leave in a line is a potential break.
How Far to Drop the Water
Lower the water level 4 to 5 inches below the skimmer. That keeps water out of the skimmer throat, where ice damage usually starts.
A skimmer cover plate is the alternative. It seals the opening so you can leave the water higher. Many owners prefer that in windy regions, because a fuller pool holds the cover steadier.
One rule has no exceptions. Never drain the pool completely. The weight of the water braces the liner and walls from the inside. An empty above ground pool can buckle or shift.
Clearing the Equipment
Disconnect the pump, filter, and every plumbing line, then drain them fully. Pull the drain plugs and leave them out for the season. Store them where you will find them in spring.
Some lines will not empty by gravity alone. Blow them out with a compressor or shop-vac, or add antifreeze rated specifically for pools. Standard automotive antifreeze is not a substitute. It should never go near pool plumbing.
Store the pump and filter indoors if you can. A garage shelf beats a season of freeze and thaw outdoors.
With the water and equipment handled, securing the cover is the final step before winter sets in.
Installing and Securing the Winter Cover
A cover that blows off in January undoes everything you just did. Doing it right takes about fifteen extra minutes.
Getting the Cover On Correctly
Add a winter algaecide first, unless the label says not to combine it with shock. Read the label rather than assume. Algaecide is your insurance against a green opening.
Place an air pillow in the center of the pool before the cover goes on. The pillow absorbs the pressure of expanding ice. It also keeps the cover from sagging into the water as snow and debris pile up.
Then install the cover and pull it tight with a cable and winch. A loose cover catches wind like a sail. Tighten it until it sits flush against the top rail. Add cover clips if your yard catches gusts.
Covers earn their keep in other ways too. The EPA's pool water efficiency guidance says a pool cover can prevent up to 95 percent of pool water evaporation, and that it helps the water hold heat.
Checking the Cover Through the Winter
The season is not over once the cover is on. Check it after the first heavy rain, snow, or wind event, then every few weeks. Look for standing water on top, pooling that stretches the fabric, and small tears at the grommets. The National Weather Service winter safety pages flag the storms worth checking after.
A pool cover is one piece of a larger seasonal checklist. If you are already thinking about pipes and gutters, winterizing your home for storms covers the rest of the property. The Consumer Product Safety Commission pool guidance is worth a look too, because a covered pool is still an open body of water.
Winterizing an above-ground pool comes down to four steps in the right order. Balance the water chemistry first. Clean the pool so nothing is left to feed algae. Drain the plumbing and equipment completely. Then secure a tight winter cover with an air pillow underneath. The two costliest mistakes are skipping the chemistry step and draining the pool all the way down, since the water supports the liner and walls. Give yourself a warm weekend afternoon and do the job properly. If the pool sits far from an outlet, a portable power station like the DELTA 3 Max or the DELTA 3 Plus keeps your equipment running out in the yard.
How low should I lower the water in an above ground pool for winter?
Drop it 4 to 5 inches below the skimmer opening. That keeps water out of the skimmer, which is where freeze damage usually begins. A skimmer cover plate is the alternative. It seals the opening so you can leave the water higher, which helps in windy areas.
Can I winterize an above ground pool without draining it completely?
Yes, and you should. A complete drain is one of the most expensive mistakes in above ground pool winterizing. The water pushes outward against the liner and walls, and that pressure keeps the structure stable. An empty pool can shift, buckle, or let the liner wrinkle in the cold.
What chemicals do I need to winterize a pool?
You need a reliable test kit, an alkalinity increaser, a pH adjuster, chlorine or pool shock, and a winter algaecide. Most winterizing above ground pool kits bundle several of these together. Many owners also add a stain and scale preventer. Handle each product separately and follow its label. Mixing pool chemicals is a real safety hazard, not a shortcut.
How long should the pump run after adding winterizing chemicals?
Run it for at least eight hours. Chemicals only work once they are fully circulated. A short run leaves treated and untreated pockets in the water. If you are closing during unsettled fall weather, plan to run for a calm stretch, or have backup power on hand.
What happens if I don't winterize an above ground pool?
Expect some combination of cracked fittings, a damaged pump or filter, a stained liner, and green water by spring. Repairs often cost more than the winterizing supplies would have. The spring cleanup takes far longer too. Knowing how to winterize an above ground pool properly is mostly about avoiding that bill.
Home Solutions
