How to Cook Without Electricity: Safe Ways to Keep Meals Going in an Outage
The power goes out at 5 p.m. Your fridge is full, dinner isn't started, and the electric range won't turn on. Now you have two things to figure out: which food needs to be used first and how to heat it without creating a carbon monoxide hazard. Fortunately, you have several options. A gas stovetop may still work, while grills and camp stoves can handle cooking outside. No-cook meals can stretch your supplies, and a portable power station can run some countertop appliances indoors. The right choice depends on what you have, what needs cooking, and how long the outage lasts.
Start With the Fridge: What Food Is Still Safe to Cook
Before choosing a cooking method, check how long the food has been without power. A closed refrigerator keeps food cold for about four hours. A full freezer can hold a safe temperature for about 48 hours, while a half-full freezer lasts about 24 hours if you keep the door closed. Perishable food such as meat, poultry, fish, eggs, and leftovers should be discarded if it has been above 40°F for two hours. Don't taste food to see if it's still safe. An appliance thermometer gives you a much better answer.
Use the food clock to plan dinner
Cook refrigerated perishables first. As frozen food begins to thaw, move those items up the list. Save shelf-stable foods for later because they don't depend on your fridge or freezer.
Food situation | General time limit |
Closed refrigerator | Up to 4 hours |
Full freezer | About 48 hours |
Half-full freezer | About 24 hours |
Perishables above 40°F | Discard after 2 hours |
If you want to avoid throwing out food during the next outage, review this guide on keeping food safe before storm season. A refrigerator thermometer is also worth keeping on hand. Once you know what needs to be cooked first, choose a heat source that fits the space. Some options are fine in the kitchen. Others belong outdoors, no matter how cold or inconvenient it is outside.
Ways to Cook Without Electricity, Indoors and Out
The biggest safety rule is easy to remember: outdoor cooking equipment stays outdoors. Bringing a grill or camp stove into a home, garage, tent, or camper can cause carbon monoxide to build up quickly. For indoor cooking, your options are more limited. A gas burner that can be manually lit may work, while a fireplace, retained-heat cooking, or certain food warmers can handle specific situations.
Gas stovetop with manual lighting
Many gas cooktops use electric ignition, but some burners can be lit manually during an outage. Check your owner's manual first. If manual lighting is allowed, follow its instructions and make sure the burner stays lit. The oven may still need electricity to operate. Never use a gas stove or oven to heat your home.
Outdoor grills and camp stoves
A propane or charcoal grill can be useful when the kitchen is without power, but it belongs outside. The same goes for portable camping stoves. Don't move a grill into the garage because it's raining or snowing. Don't use a camp stove inside the house, even near an open window. Carbon monoxide can build up without an obvious smell or warning. Set up outdoor cooking well away from doors, windows, and vents, and follow the equipment manufacturer's instructions.
Fireplace or wood stove
A fireplace can provide another cooking option during an outage if it's designed for that use. Keep the flue open so smoke can leave the home, and make sure the fireplace and chimney are in good working order. A wood stove may also support cooking if the model is designed for it. Don't improvise with equipment that isn't meant for cooking.
Solar oven and retained-heat cooking
A solar oven can work on a sunny day without electricity or gas, but it's not reliable during every storm. For retained-heat cooking, bring food to a boil, then cover and insulate the pot so it keeps cooking. Small warmers, chafing dishes, and fondue pots can warm some foods, but they're better for warming than full cooking. Keep fuel, matches, a lighter, and a manual can opener in your power outage supply checklist before the next storm.
Cooking method | Indoor use | What you need | Best for |
Gas burner | Yes, if the manual allows it | Gas supply and manual lighting method | Stovetop meals |
Grill | No | Propane or charcoal | Outdoor cooking |
Camp stove | No | Fuel and outdoor setup | Simple hot meals |
Fireplace | Yes, when designed for cooking | Working flue | Basic heating and cooking |
Solar oven | Outdoor | Direct sunlight | Sunny days |
Retained heat | Yes, after initial heating | Pot and insulation | Foods that can finish cooking slowly |
Flame-based cooking gives you useful options, but fuel and weather can limit how long you want to rely on it. A battery-powered setup offers another way to cook indoors.
Cooking With a Portable Power Station or Home Battery
A portable power station lets you cook indoors without burning gas, propane, or charcoal. The first number to check is the appliance's wattage, which tells you how much power it needs. The battery's watt-hours then tell you roughly how long it can keep that appliance running.
Check what your appliances need
Countertop cooking appliances can use a lot of power. A Hamilton Beach portable induction cooker draws 1,800W, while its 1.7-liter electric kettle uses 1,500W. The Hamilton Beach microwave draws 1,450W of input power, even though its cooking output is 900W. A Zojirushi rice cooker uses 610W. For a slow cooker, check the rating label on your specific model. The EcoFlow DELTA 3 Max has 2,048Wh of capacity and a 2,400W rated AC output. For a rough runtime estimate, multiply 2,048Wh by 0.85 and divide by the appliance's wattage.
Appliance | Power draw | Estimated runtime |
Induction cooker | 1,800W | About 58 minutes |
Electric kettle | 1,500W | About 70 minutes |
Microwave | 1,450W input | About 72 minutes |
Rice cooker | 610W | About 2.9 hours |
These are full-power estimates. Induction cookers and rice cookers cycle on and off, so actual cooking sessions can last longer. All four appliances are within the EcoFlow DELTA 3 Max's 2,400W rated AC output. Its X-Boost mode supports appliances up to 3,400W, according to EcoFlow. Always check your appliance's rating before connecting it. For a microwave, use the input wattage rather than the cooking output when sizing your backup power. This guide explains how much backup power a microwave actually draws.
The EcoFlow DELTA 3 Max is a practical choice when you want to bring backup power right to the kitchen counter. For homeowners who want more coverage, the EcoFlow DELTA Pro Ultra X takes a whole-home approach and can keep selected kitchen circuits powered during a longer outage.
The EcoFlow DELTA 3 Max works well for running one countertop appliance at a time. The EcoFlow DELTA Pro Ultra X takes a different approach. As an installed system, it can keep selected kitchen circuits, such as the refrigerator, microwave, and outlets, running without moving or unplugging appliances. For example, 12,000Wh × 0.85 ÷ 1,800W gives about 5.7 hours of continuous induction cooking. That's only an estimate and doesn't account for other loads on the system. Even with backup power, the simplest outage meal is often one that needs little or no heat at all.
No-Cook and Low-Heat Meals That Stretch Your Fuel
Not every outage meal needs a full cooking setup. Using less heat saves propane, charcoal, or battery power for meals that actually need cooking. Ready.gov recommends keeping canned foods, dry mixes, and other staples that don't need refrigeration, cooking, water, or special preparation. Keep a manual can opener with them, too.
Easy no-cook meals for an outage
Keep a few simple meals in your pantry that don't need cooking or refrigeration. These options use common shelf-stable foods and can help stretch your supplies during a longer outage.
Peanut butter wraps: Spread peanut butter on tortillas and add bananas, raisins, or other dried fruit for extra flavor and energy.
Tuna salad: Mix tuna pouches with mayonnaise or other shelf-stable ingredients and serve with crackers or tortillas.
Beans and salsa: Combine canned beans with salsa and eat with tortillas or chips for a quick, filling meal.
Overnight oats: Soak oats in shelf-stable milk and add dried fruit, nuts, or seeds for an easy breakfast.
Canned chicken and crackers: Serve canned chicken with crackers or tortillas, and add shelf-stable condiments for more flavor.
Fruit and cereal: Mix canned fruit with dry cereal for a simple breakfast or light snack.
Trail mix: Combine nuts, seeds, dried fruit, and other shelf-stable snacks for something easy to grab between meals.
Protein wraps: Fill tortillas with ready-to-eat chicken, peanut butter, or other shelf-stable ingredients for a quick meal.
Make one round of heat go further
If you want something hot, boil water once for oatmeal, instant rice, coffee, or similar foods. A kettle can work indoors with suitable backup power, while a camp stove should stay outside. These tips for making coffee without electricity can help keep your morning routine going. If you heat food in a can, Ready.gov advises removing the label, washing and disinfecting the can with 1 part bleach to 10 parts water, and opening it before heating. FSIS recommends discarding deeply dented or heavily rusted cans. Small dents on otherwise sound cans don't necessarily make them unsafe. Whatever method you use, the biggest outage cooking danger isn't undercooked food. It's carbon monoxide.
Carbon Monoxide Rules for Outage Cooking
Carbon monoxide (CO) poisoning becomes more common during outages when people bring outdoor cooking equipment inside. CO has no smell or color, so you may not realize it's building up. Never burn charcoal or use portable gas camp stoves indoors. Keep generators more than 20 feet from windows, doors, and vents, and never use a gas oven to heat your home. CO exposure can cause headaches, dizziness, weakness, nausea, vomiting, chest pain, and confusion. Install battery-operated or battery-backup CO alarms on every level and outside sleeping areas. Never use a charcoal grill inside or barbecue in the garage. If a CO alarm sounds, get everyone outside immediately and call 911 from fresh air. For cooking and home backup, safer alternatives to gas generators can help reduce the risks of fuel-burning equipment.
When the power goes out, start with the food. Keep the refrigerator and freezer closed, follow the four-hour and freezer timelines, and cook refrigerated perishables first. For heat, follow your gas stove manual. Keep grills and camp stoves outside. Use no-cook meals to save fuel and battery capacity when you can. Before the next storm, check your stove manual, stock shelf-stable food and a manual can opener, test your CO alarms, and find the wattage of the appliance you'd most want to run. A portable power station such as the EcoFlow DELTA 3 Max can run compatible countertop appliances indoors without combustion fumes. The EcoFlow DELTA Pro Ultra X takes a whole-home approach by keeping selected circuits powered through an installed system.
How do you cook when the power is out and you have an electric stove?
You can use a manually lit gas burner if your gas cooktop supports it, cook outdoors with a grill or camp stove, use a fireplace designed for cooking, or run a compatible countertop appliance from a portable power station. Never bring a grill or camp stove indoors.
Can I use my gas stove during a power outage?
Many gas cooktop burners can be manually lit during an outage, but check your owner's manual first. The oven may not work because its ignition and gas valve can require electricity. Never use a gas stove or oven to heat your home.
How do you heat food without electricity or gas?
No-cook foods are the simplest option. You can also use a fireplace designed for cooking, a solar oven on a sunny day, or retained-heat cooking after an initial boil. An outdoor grill or camp stove is another option, but both must stay outside.
Is it safe to eat canned food cold?
Commercially canned food can generally be eaten without warming when the can is in good condition. Check for deep dents, heavy rust, bulging, leaks, or other signs of damage. Don't use a damaged can.
Can a portable power station run an induction cooktop or microwave?
It depends on the appliance's input wattage and the power station's rated output. The EcoFlow DELTA 3 Max has a 2,400W rated AC output, while the induction cooker and microwave examples in this guide draw 1,800W and 1,450W respectively. Check the rating label on your appliance before connecting it.
