Portable Heater Powered by Batteries: What Works at Camp and What Doesn't
A tiny heater in a product photo can look perfect for a cold night at camp. But a typical 1,500-watt space heater can drain a portable power station in a little over an hour, depending on its capacity and operating conditions. That’s a big difference from what some product listings suggest. Most products sold as battery-powered heaters fall into three groups: wearable electric heat, propane heaters that use batteries for some functions, and plug-in electric heaters that need an outlet or power station. Knowing which type you’re buying helps you avoid carrying the wrong gear into the woods. Here’s how they compare, what the numbers mean, and how to stay warm more safely.
Battery Powered Heaters You'll Find, Sorted by What Makes the Heat
Battery Powered Heaters You'll Find, Sorted by What Makes the HeatBattery Powered Heaters You'll Find, Sorted by What Makes the Heat
Search for a battery-powered heater and you’ll find several products that work in very different ways. Some heat your body directly. Others burn propane to warm the surrounding area, while conventional electric heaters need a steady supply of power from an outlet or power station.
Product (maker, model)
What makes the heat
Battery or power
Heat output stated by maker
Runtime stated by maker
Indoor/outdoor note from maker
Milwaukee M12 Heated AXIS Quilted Jacket (M102G)
Electric heating zones in the jacket
M12 battery (kit includes an M12 REDLITHIUM CP3.0)
Not stated
12 hours on low, 6 on medium, 3 on high
Wearable; not a space heater
DEWALT Cordless Propane Radiant Heater (DXH12B)
Propane
DEWALT 20V MAX or FLEXVOLT batteries
6,000 / 12,000 BTU/hr
"Dual tank capacity for 7hr run-time"
"CSA certified indoor safe (Outdoor use only in Massachusetts and Canada)"
RYOBI 18V ONE+ Hybrid Forced Air Propane Heater (PCL801B)
Propane
Any 18V ONE+ battery or an extension cord
30,000 to 60,000 BTU
Not stated
Outdoor use only. Not for homes, tents, campers, or recreational vehicles. Requires 72 inches of clearance at the front and top, and 24 inches at the rear and sides.
Mr. Heater Portable Buddy (MH9BX)
Propane
No battery
4,000 or 9,000 BTU per hour
About 3 hours at maximum, 6 at minimum (spec table)
Listed as indoor safe, with an Oxygen Depletion Sensor and tip-over shut-off
Lasko MyHeat Personal Ceramic Heater (101)
Electric
120V plug, no battery
200W
N/A (runs while plugged in)
Personal desk heater "designed to warm you directly rather than an entire room"
Lasko 9" Ceramic Table Top Heater (754200)
Electric
1,500W high, 900W low
N/A
Standard home space heater
These products differ in how they generate heat and what powers them. Heated jackets use battery power for personal warmth, propane heaters burn fuel, and conventional electric heaters need an outlet or compatible power station.
  • Heat you wear: The Milwaukee jacket uses electricity to warm its built-in heating zones. It’s a practical option for keeping one person warm without heating an entire tent.
  • Propane with battery assistance: The DEWALT and RYOBI models burn propane. Their batteries provide electrical power for the units, but propane supplies the heat.
  • Propane without a battery: The Mr. Heater Portable Buddy runs on propane and doesn’t need a battery.
  • Plug-in electric heat: The Lasko heaters need a 120V outlet. A compatible power station can supply that power, but the heater’s wattage determines how quickly it drains the battery.
The distinction matters. A wearable heated jacket provides genuine battery-powered warmth, while a propane heater can produce thousands of BTUs per hour because it burns fuel. A small rechargeable device advertised as a tent heater may offer much less heat than its packaging suggests. For cold-weather trips, start with the basics, too. A sleeping bag rated for the expected temperatures, an insulated sleeping pad, and dry base layers can do more for overnight comfort than a small heater. The reason these products perform so differently comes down to energy. Watts measure electrical power, BTUs measure heat energy, and a battery has a finite amount of stored electricity.
Why a Battery Makes So Little Heat: Watts, BTUs, and Battery Size
A battery stores a limited amount of energy, so a high-wattage heater can drain it quickly. Comparing watts and BTUs shows why propane heaters produce more heat than battery-powered options. The U.S. Energy Information Administration (EIA) states that 1 kWh equals 3,412 BTUs. Using this conversion, the table below compares the heat output of different heaters.
Heat source
Rated output
Same output in the other unit (our conversion)
Lasko MyHeat (101)
200W
About 682 Btu per hour
Lasko 754200 on low
900W
About 3,071 Btu per hour
Lasko 754200 on high
1,500W
About 5,118 Btu per hour
Mr. Heater Portable Buddy on low
4,000 Btu per hour
About 1,172W of electric heat
Mr. Heater Portable Buddy on high
9,000 Btu per hour
About 2,638W of electric heat
DEWALT DXH12B on high
12,000 Btu per hour
About 3,517W of electric heat
The Mr. Heater Portable Buddy produces 9,000 BTU/hr on high, equivalent to about 2,638W of thermal output. This is a heat-output conversion, not the heater’s electrical power requirement. The EcoFlow DELTA 3 Max provides 2,400W of continuous AC output, while its 2,048Wh capacity measures stored energy. At a hypothetical 2,638W load, that capacity would last about 47 minutes before losses. The propane heater itself runs on fuel, not the power station. Always follow the heater’s safety instructions to reduce carbon monoxide risks.
What this means for "battery heater" listings.
Check the heater’s wattage and battery capacity before buying. Battery capacity may be listed in watt-hours (Wh) or milliamp-hours (mAh), but mAh alone doesn’t show how much energy a battery stores without its voltage. If the heater’s output isn’t clearly stated, don’t assume it can warm a tent. Before connecting an electric heater to a power station, make sure its wattage fits the unit’s continuous AC output and estimate how long it can run. A larger battery offers more runtime, but the heater must still stay within the power station’s limits.
Running a Low-Watt Heat Source From a Portable Power Station at Camp
A portable power station stores electricity and supplies it through its outlets. The appliance you connect determines what that power does, how much it draws, and how long the battery lasts. If you plan to run a heated blanket or another low-watt device at camp, check three things first: the device’s rated power, the environment where you’ll use it, and how long you need it to run. A vehicle or cabin offers different options from a tent, where moisture, cords, and nearby fabric create additional concerns. For shorter stretches of portable power, the EcoFlow DELTA 3 Max provides 2,048Wh of capacity. The EcoFlow DELTA 3 Ultra offers 3,072Wh for trips that need more stored energy. Neither product generates heat on its own, and neither should be treated as a dependable source of overnight warmth.
EcoFlow DELTA 3 Max (2048Wh)
•2,400W Output: 4,800W surge. X-Boost mode can run some higher-wattage appliances up to 3,400W, though it works by lowering voltage, so results vary by device. • Fast Recharging: 4 ways to charge, reaching 0 to 80% in 68 minutes with wall or generator charging. • Easy to Carry: About 44.8 lb (20.3 kg), 13% lighter than EcoFlow's previous 2kWh model. •10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit. •Warranty: Up to 5 years (3-year standard plus a 2-year extension when you register in the EcoFlow App).
If you need more capacity for longer camping trips, the EcoFlow DELTA 3 Ultra offers 3,072Wh of stored energy and 3,600W of output. It can power compatible camping gear for longer than the EcoFlow DELTA 3 Max, depending on the load and operating conditions.
EcoFlow DELTA 3 Ultra (3072Wh)
•3,600W Output: 7,200W surge. X-Boost mode can run some higher-wattage appliances up to 4,600W, though results vary by device. •Fast Recharging: 4 ways to charge, reaching 0 to 80% in 89 minutes with wall or generator charging. • Longer Runtime: Pairs with an EcoFlow Smart Generator for longer runtime on extended trips. • Warranty: Up to 5 years (3-year standard plus a 2-year extension when you register in the EcoFlow App). Register it before camping season starts.
The EcoFlow DELTA 3 Max suits shorter periods of portable power, while the EcoFlow DELTA 3 Ultra offers more capacity for longer trips. Before choosing either, check your heater’s wattage, the conditions where you’ll use it, and the runtime you need. Neither unit should be relied on to heat a tent overnight.
Estimated runtime by heater wattage (labeled estimate)
Formula: capacity (Wh) × 0.85 ÷ load (W). The 0.85 is our planning assumption for conversion losses, not an EcoFlow figure. Heater wattages come from Lasko's product pages. Thermostats that cycle on and off will stretch these numbers; cold batteries and inverter losses will shrink them.
Load
EcoFlow DELTA 3 Max (2,048Wh × 0.85 = about 1,741Wh)
EcoFlow DELTA 3 Ultra (3,072Wh × 0.85 = about 2,611Wh)
Lasko 754200 on high (1,500W)
About 1.2 hours
About 1.7 hours
Lasko 754200 on low (900W)
About 1.9 hours
About 2.9 hours
Lasko MyHeat (200W)
About 8.7 hours
About 13 hours
Every 100W of load from your device's label (illustrative, not a product rating)
About 17 hours
About 26 hours
Actual runtime varies with the load, battery temperature, and conversion losses. A lower-watt personal warmer or compatible heated blanket may use less energy than a 1,500W space heater, but check the device’s label. Plug electric heaters directly into the power station’s AC outlet, never a power strip or extension cord. Keep heaters at least three feet from bedding, clothes, and other combustible materials, and never leave one running unattended in a confined space. Electric heat is limited by battery capacity, while propane produces more heat but brings carbon monoxide risks.
Propane Heaters, Tents, and Carbon Monoxide
Propane heaters produce more heat than battery-powered options, but they also release carbon monoxide (CO), an odorless, colorless gas that can be fatal. The U.S. Consumer Product Safety Commission (CPSC) warns against using fuel-burning heaters or lanterns while sleeping in tents, campers, or vehicles, especially at high altitudes. The CDC reports that unintentional CO poisoning unrelated to fires kills more than 400 Americans each year. Symptoms include headaches, dizziness, weakness, nausea, vomiting, sleepiness, and confusion. If you suspect CO exposure, get everyone into fresh air and seek medical help. Never use a portable gas camp stove indoors.
What “indoor safe” means on a propane heater
The Mr. Heater Portable Buddy and DEWALT DXH12B are marketed for indoor use under specific conditions and include safety features such as oxygen depletion sensors and tip-over shutoffs. These features don't override CPSC guidance about sleeping in tents, campers, or vehicles.
If you use a propane heater where its manual permits, follow the ventilation instructions and shut it off before sleeping. Carry a battery-powered CO alarm in your camping gear and test it monthly. You can also learn more about monitoring carbon monoxide indoors and the risks in enclosed spaces. Since propane heaters shouldn't run while you're asleep in a tent and batteries have limited capacity, focus on warming your body rather than trying to heat the entire tent.
Warm the Camper, Not the Tent: Heat Sources That Work With Small Batteries
Warm the Camper, Not the TentWarm the Camper, Not the Tent
Thin tent walls lose heat quickly, so heating the entire space takes a lot of energy. Gear that warms your body directly can be more useful when you’re camping with a small battery or portable power station. Consider these options when planning a cold-weather trip:
  • Heated clothing: A heated jacket such as the Milwaukee M12 Heated AXIS uses its own tool battery to warm built-in heating zones. The manufacturer lists runtimes of up to 12 hours on low, 6 hours on medium, and 3 hours on high. Actual runtime varies with settings and conditions.
  • Heated blankets or mattress pads: These may draw less power than a full-size space heater, but their wattage varies. Read the product label and use the runtime formula above to estimate how long your power station can supply them.
  • A properly rated sleeping bag: Choose one rated for the expected overnight temperatures. A sleeping pad beneath you helps reduce heat loss to the ground.
  • Dry base layers: Change out of damp clothing before bed and keep dry layers available. Wet clothes can make it much harder to stay warm.
  • A warm place before bedtime: If you have access to a vehicle or cabin, warming up there before bed can help. Never run a vehicle in an enclosed space, and don’t leave its engine running in a garage.
Using a power station in or near a tent.
Keep your power station dry and off the ground, secure cords to prevent trips, and keep heat sources away from tent fabric. Turn off devices you don't need, and keep portable heaters at least three feet from bedding, clothing, and other combustible materials. Always follow each heater's specific clearance and usage restrictions, as some models require greater distances or are restricted to outdoor use. The RYOBI PCL801B, for example, must not be used in tents, homes, campers, or recreational vehicles. Review these power station safety tips for tents before setting up camp.
Keeping batteries working when the campsite freezes
Cold weather can reduce lithium battery performance and limit how much power a power station can deliver. Before a winter trip, check the unit’s charging and discharging temperature limits to make sure it can handle the forecast. The EcoFlow DELTA 3 Max supports charging between 32°F and 113°F and discharging between 14°F and 113°F. The US version of the EcoFlow DELTA 3 Ultra has a charging temperature range of 32°F to 113°F (0°C to 45°C) and a discharging range of 14°F to 113°F (-10°C to 45°C). Do not charge the DELTA 3 Ultra below 32°F (0°C) or operate it outside its specified discharging range. Keep the power station dry and protect it from rain, snow, and moisture during winter camping. Note that storage temperature limits are different from the permitted charging and discharging ranges.
To prepare for a cold-weather trip, charge your power station before leaving home and keep it in a suitable insulated location within its operating limits. Avoid placing it on frozen or wet ground, and don't rely on solar charging alone during short winter days. Cold can affect phones, headlamps, and other battery-powered camping gear, too. Check their operating limits and learn how lithium batteries perform in cold weather before packing for your trip.
A portable heater powered by batteries can provide personal warmth, but it has limited capacity for heating a tent. Heated clothing and compatible blankets offer practical options, while propane heaters produce more heat but pose carbon monoxide risks, especially during sleep. A sleeping bag rated for the weather, an insulated pad, and dry layers remain essential for cold-weather camping. Before packing, check your heater’s wattage, estimate runtime, and account for cold-weather limits. The EcoFlow DELTA 3 Max (2,048Wh) and EcoFlow DELTA 3 Ultra (3,072Wh) can power compatible low-watt devices, but neither replaces proper sleeping gear.
Is there a portable heater powered by batteries that can heat a tent?
Battery-powered electric heat is generally limited by the battery’s capacity. Heated jackets and blankets can warm one person, but a typical portable power station won’t run a high-wattage space heater for long. Propane heaters produce more heat, but CPSC warns against running fuel-burning heaters while sleeping in tents, campers, or vehicles.
What is the best battery-operated heater for camping?
There’s no single best option for every camper. Heated clothing can be practical for personal warmth, while a compatible electric blanket may suit a campsite with a portable power station. Compare the device’s wattage, battery capacity, runtime, and operating requirements before choosing.
Can a portable power station run a space heater?
Yes, if the heater’s power draw is within the power station’s limits, but runtime can be short. Using the estimates in this guide, a 1,500W heater would run for about 1.2 hours on the EcoFlow DELTA 3 Max or 1.7 hours on the DELTA 3 Ultra. Actual results vary with conditions and conversion losses.
Is it safe to use a propane heater in a tent?
Never use a fuel-burning portable heater while sleeping in a tent, camper, or vehicle. CPSC warns that carbon monoxide can build up and cause fatal poisoning. Follow the heater’s instructions and applicable safety guidance, and shut it off before going to sleep.
Can a battery-operated outdoor heater keep you warm all night?
Don’t count on a small battery-powered heater to provide overnight warmth. Runtime depends on the device’s power draw, battery capacity, and temperature. Choose a sleeping bag rated for the expected conditions, use an insulated sleeping pad, and treat any powered heat source as supplemental.
Camping
