How Much Does a Propane Tank Cost to Fill?
Propane prices can look pretty different depending on the tank you're filling. A 20-pound grill tank may cost a few dozen dollars, while filling a large 500-gallon home tank can run well into four figures. Your location, the season, delivery fees, and the amount of propane you need all affect the final bill. Here's what you can expect to pay by tank size, what drives propane prices up or down, and how electric options compare for some common home and backup-power uses.
Propane Fill Costs by Tank Size
Tank size gives you the first clue about how much a refill will cost, but the amount you actually put in matters too. Residential propane tanks are generally filled to about 80% of their water capacity because propane expands as temperatures change. So a 500-gallon tank holds about 400 gallons of propane when filled to its normal maximum.
Tank Size | Typical Fill Cost |
20 lb (grill tank) | $25 - $35 |
100 lb bulk tank | $60 - $150 |
250 gallon (home) | $450 - $1,000 |
500 gallon (home) | $700 - $2,500 |
These numbers are useful for budgeting, but don't treat them as a quote. Propane dealers set their own rates, and prices can change with the season and local supply.
20-pound grill tanks
A standard 20-pound propane tank is the familiar size used with many backyard grills, patio heaters, and smaller appliances. A refill may cost around $25 to $35, although exchange programs and local refill stations can have different pricing. If you use propane mainly for weekend grilling, the cost is relatively easy to manage. A household that relies on propane for heating, cooking, or backup power has a much larger fuel bill to plan for.
250-gallon home tanks
A 250-gallon tank is common for homes that use propane for some combination of heating, cooking, water heating, or other appliances. Since the tank normally isn't filled completely, a refill from a low level won't necessarily mean buying 250 gallons of propane. A typical fill generally costs roughly $450 to $1,000, depending on current local rates. Your actual bill will depend on how many gallons you need, the dealer's per-gallon rate, and any delivery charges.
500-gallon home tanks
A 500-gallon tank can hold about 400 gallons of propane at the usual 80% fill level. Bringing a tank back up to full can cost around $700 to $2,500, depending on current local rates. That's a wide range, and there's a reason for it. A large tank may be used for an entire home's heating system, so a price change of even a few cents per gallon can add up quickly.
What Actually Changes the Price
The number printed on the tank isn't the only thing that determines your bill. Propane is sold by the gallon, and that per-gallon rate can move with the season, local supply, and delivery costs. Typical residential propane rates generally run around $2.00 to $3.50 per gallon, with winter prices often running 10% to 20% higher because heating demand increases.
Seasonal demand
Winter is usually the time to pay closer attention to propane prices. Homes across colder parts of the country may use much more fuel for heating once temperatures drop, which can push demand higher. That matters most if you're waiting until the tank is nearly empty before ordering a delivery. A cold snap can arrive quickly, and the price you pay during a high-demand period may be different from the rate available earlier in the year.
Local propane rates
Two households in different parts of the country can pay different prices for the same amount of propane. Local supply, competition between suppliers, transportation costs, and the distance from a propane distributor can all affect the rate. Rural homeowners may also see delivery charges added to the fuel cost. If you have a large tank, it can be worth asking your supplier about the per-gallon rate, delivery fee, minimum order, and any seasonal pricing program before placing an order.
Delivery and refill fees
The advertised propane price doesn't always tell you what you'll pay at the end. Some suppliers add a delivery charge, particularly for rural addresses or smaller orders. Ask for the total cost before scheduling a delivery, and compare the full bill rather than just the posted price per gallon. If propane is part of your backup-power plan, it also helps to compare the fuel cost with the generator itself. This guide to propane vs. gas generators breaks down some of those costs and tradeoffs. If you want to avoid buying and storing fuel for every outage, a battery-based power station offers another way to keep essential devices running. That's where an electric backup option can make sense.
An Alternative to Propane for Backup Power
Propane generators can keep your home powered when the grid goes down, but they need a steady supply of fuel. A battery-based power station works from stored electricity instead, so you can charge it before an outage and use that energy when you need it. You also avoid keeping extra propane on hand or arranging a fuel delivery during a storm. For shorter outages and essential loads, that can make backup power easier to manage.
If you need more capacity and faster charging for heavier loads, the EcoFlow DELTA 3 Classic is another option to consider. It offers a 1,024Wh capacity, 1,800W continuous output, and fast AC recharging, making it suitable for keeping essential appliances running during an outage.
If you're weighing propane against electric backup power, the ongoing cost matters just as much as the upfront price. Looking at fuel, charging, and everyday use side by side can give you a clearer idea of which setup fits your needs.
Propane vs. Electric: Which Costs Less Over Time
The long-term cost of an appliance depends on more than its purchase price. Propane systems may cost less upfront, while electric options can offer more predictable running costs based on your household electricity rate.
Propane costs can change over time
Propane appliances often have lower upfront equipment costs, but you'll need to keep buying fuel as you use them. Prices can rise or fall based on the market, season, and where you live, which can make your ongoing costs harder to predict.
Electric costs depend on your utility rate
Electric appliances don't require a separate fuel supply, so their running costs are tied to your household electricity rate and how often you use them. For one common example, this guide to electric vs. propane RV refrigerators compares how the two options differ in everyday use. Regardless of which energy source you rely on, a few simple habits can help keep propane costs from rising unexpectedly.
Tips to Lower Propane Costs
A few simple changes can help you spend less on propane throughout the year. Planning your purchases and avoiding last-minute deliveries can also make your fuel costs easier to manage.
Buy propane before peak winter demand: Pre-buying propane or locking in a price during the summer can help you avoid higher rates when winter heating demand increases.
Look for bulk pricing: Buying larger amounts may give you a lower per-gallon rate than placing smaller, one-off orders. Some homeowners can also save by joining a local propane co-op program.
Keep a 20% to 30% reserve: Don't let your tank run close to empty. Keeping some fuel in reserve gives you more time to schedule a regular delivery and avoid fees that can come with rushed orders.
Compare backup power options: If you're mainly using propane for emergency power, compare the ongoing fuel costs with a battery system. This guide to home batteries vs. propane generators can help you compare the two approaches.
Planning ahead is one of the easiest ways to keep propane expenses under control, especially during periods of high demand.
The cost of filling a propane tank can vary from $25 for a 20-pound grill tank to $700-$2,500 for a 500-gallon home tank. The final bill will depend on your per-gallon rate, the season, how full your tank is, where you live and delivery fees. Purchasing propane before winter demand spikes and having a reserve on hand can help manage costs. Another choice is a battery-powered option, such as the EcoFlow DELTA 3 Plus or DELTA 3 Classic, that can provide backup power and reduce reliance on propane and provide another way to keep essential equipment running.
How much does it cost to fill a 500-gallon propane tank?
A 500-gallon residential tank typically contains approximately 400 gallons of propane when filled to 80% of its maximum. Based on the ranges in this guide, a full refill can cost roughly $700 to $2,500, depending on the local price per gallon, delivery fees, and how much propane the tank needs.
Why does propane cost more in winter?
Propane prices can rise during winter because demand for home heating increases. Regional supply, transportation costs, and weather can also affect the price. The guide estimates that winter prices can run about 10% to 20% higher than during other parts of the year.
Is it cheaper to buy or rent a propane tank?
There isn't one answer for every household. Buying a tank means paying for the equipment upfront, while renting can spread out that cost but may include rental fees and supplier requirements. Compare the tank price, rental charges, propane rate, delivery fees, and how long you expect to use the tank before deciding.
How often does a 250-gallon propane tank need refilling?
That depends on the propane consumption of your home. A home that uses propane for heat will consume fuel much faster than a home that only uses it for cooking or a few appliances. Your home's size, insulation, thermostat setting, weather, and connected appliances all affect how often you'll need a refill.
Is propane or electric cheaper for home heating?
The answer depends on local propane and electricity rates, the efficiency of the heating equipment, and how much heat your home needs. Compare the total operating cost for your specific equipment rather than looking only at the fuel price.
