Electric Heating Explained: How It Works, What It Draws, and How to Plan for Outages
A baseboard heater ticks quietly in a rental, a heat pump hums outside a new home, and a small space heater warms someone's feet beneath a desk. All three use electric heating, but they work differently and place different demands on your electricity bill and circuits. This guide explains resistance heating and heat pumps, compares real equipment wattages, and shows how to estimate running costs using U.S. electricity prices. We also cover practical steps for handling winter outages, finding an appropriate backup generator or battery, and protecting your living space as temperatures plunge.
What Is Electric Heating? Two Very Different Families
Electric heating refers to systems that use electricity to provide warmth. Most residential electric heating systems fall into two main categories: resistance heating, which converts electrical energy directly into heat, and heat pumps, which use electricity to transfer heat from one place to another.
Resistance heat: simple, direct, and 100% at the point of use
Electric resistance heating converts all the electricity it consumes into heat at the point of use, making it 100% efficient in that sense, according to the U.S. Department of Energy (DOE). However, electricity generation losses can make it more expensive to operate than combustion-based heating. Common options include electric furnaces, baseboard heaters, wall heaters, radiant heating, and space heaters. The DOE also notes that zone heating can save more than 20% of energy compared with heating an entire home, depending on usage.
Heat pumps: moving heat instead of making it
Heat pumps transfer heat rather than generating it directly, making them more efficient than electric resistance heating. According to the DOE, they can deliver up to three times more heat than the electricity they use and reduce heating electricity consumption by up to 75%. Newer cold-climate models can also provide heating in colder regions.
Type | How it heats | Typical voltage | Common use |
Space heater | Resistance | 120V plug-in | Single rooms, offices |
Baseboard and wall heaters | Resistance | Usually 240V hardwired | Rentals, additions, older homes |
Electric furnace | Resistance, staged elements | 240V | Ducted homes without gas |
Radiant floor | Resistance cable or mat | Varies | Bathrooms, kitchens |
Air-source heat pump or mini-split | Refrigerant cycle | 240V outdoor unit | Newer homes, retrofits |
These voltage ranges are general examples, not universal specifications, so always check the equipment nameplate before planning an installation. When comparing ducted and ductless options, understanding mini-split and heat pump costs and efficiency can help you evaluate performance and determine your home's electrical requirements.
How Many Watts Does Electric Heat Use, and What About Outages?
Electric heat can range from a small 750W heater to equipment drawing several kilowatts. That difference determines the circuit required, the electricity consumed, and whether a home battery can support the system during an outage.
Real nameplate examples
The following manufacturer specifications show how voltage, power, and current requirements vary across common heating equipment. Use these examples for reference, and always verify the exact model’s nameplate before planning electrical connections or backup power.
Equipment | Voltage | Listed power or current |
Lasko CC24910 ceramic space heater | 120V | 750W to 1,500W; 6.5A to 12.5A |
Lennox V1EHK electric heat kit, 5kW nominal | 230V | 4.59kW, 19.97A |
Lennox V1EHK electric heat kit, 10kW nominal | 230V | 9.18kW, 39.93A |
Carrier 25HCE4 3-ton heat pump (outdoor unit) | 208/230V | Compressor 15.1 RLA, 75.0 LRA; fan 1.1 FLA |
Based on the Carrier nameplate ratings, the compressor's rated load amps (RLA) of 15.1A and the fan's full load amps (FLA) of 1.1A add up to 16.2A. At 230V, this corresponds to approximately 3,726 volt-amperes (VA) as a rated reference value, not verified operating power in watts. Actual power consumption depends on the equipment's operating conditions and power factor, so use the manufacturer's input power specifications or measured data for the specific heat pump system to estimate running wattage. The 75A locked-rotor rating highlights the importance of accounting for startup requirements when sizing backup power. Any auxiliary or backup resistance heating strips must also be included in the load calculation, as 5kW and 10kW kits can substantially increase demand and may exceed a battery system's output capacity.
Example energy and cost estimates (labeled)
A 1,500W space heater running for one hour uses 1.5kWh of electricity, costing approximately 27 cents per hour at the EIA's Q1 2026 average residential rate of 17.83¢/kWh. Actual costs vary by location and utility plan; this national average also spreads many utilities’ fixed costs across electricity use. For battery backup, a 5,000Wh battery with an illustrative 85% usable-energy allowance could run the heater for approximately 2.8 hours on high, although actual runtime depends on conversion losses and operating conditions.
EcoFlow TITAN 5000 Classic: For compatible 120V heating
When an outage leaves a single room cold, running a compatible plug-in heater may be more practical than trying to power an entire electric heating system. A battery backup can also support essential devices such as lights and a router.
EcoFlow TITAN 5000 Plus: For compatible 240V heating loads
Some homeowners need to consider a 240V heat pump or another approved heating circuit. These systems require more careful planning because their startup demands, auxiliary heating elements, and other household loads can exceed a battery's available output.
The Classic is the more relevant option for a compatible 120V space heater and essential household circuits. The Plus can support approved 240V heating equipment when an electrician confirms the load fits its limits. Neither battery makes a heater more efficient. A licensed electrician must verify startup current, simultaneous loads, circuit compatibility, and installation requirements.
Winter reality check for solar and batteries
Winter sunlight can be limited, and snow-covered panels may prevent reliable recharging during prolonged outages. Both TITAN units are rated IP20 for indoor use and cannot charge below 32°F, so they need a suitable protected environment. Understanding how 120V and 240V split-phase power works can help you plan compatible appliances and backup circuits. Grid-connected rooftop solar also generally shuts down during outages unless a compatible backup configuration is installed, and panels must connect to the battery’s supported solar input to recharge it.
Pros, Cons, and Safety Rules for Electric Home Heating
Electric heating offers several advantages, particularly because it does not burn fuel inside the home. However, running costs and electrical demands vary widely, and portable heaters require careful handling.
Strengths and trade-offs
Resistance heating and heat pumps both provide combustion-free heating, but they differ in energy efficiency, operating costs, and installation requirements. The table below compares their main strengths and trade-offs to help you evaluate which option better suits your home.
Factor | Resistance heating | Heat pumps |
Point-of-use efficiency | 100% conversion of electricity to heat | Can deliver up to about 3 times the heat energy per unit of electricity |
Running costs | Often higher than combustion heating | Can use up to 75% less heating electricity than resistance systems |
Installation | Often straightforward, depending on system | May require outdoor equipment and professional installation |
Duct losses | Possible with ducted furnaces | Possible with ducted systems; ductless units avoid duct losses |
Space heater and heating safety
Portable heaters require careful use, particularly in homes with children or pets. Follow these precautions to reduce fire risks and keep your heating equipment operating safely.
Maintain clearance: Keep anything that can burn at least three feet away from heating equipment.
Switch off when unattended: Turn portable space heaters off when leaving the room or going to bed.
Use suitable outlets: Plug heaters directly into appropriate wall outlets instead of extension cords or power strips.
Schedule inspections: Arrange annual cleaning and inspection of heating equipment to identify potential problems.
Replace furnace filters: Follow the manufacturer's recommended schedule to maintain proper airflow and performance.
Keep safety controls intact: Never bypass furnace shutdown protections designed to respond to blower failures or restricted airflow.
The U.S. Fire Administration reports that portable heaters accounted for 3% of home heating fires, but 41% of fatal home heating fires during 2017–2019, highlighting the importance of safe operation. During winter emergencies, understanding how much energy a space heater uses can help you plan heating needs without overlooking fire and carbon monoxide risks. Never use a gas range or unvented combustion appliance to heat your home, and always operate fuel-powered generators outdoors, away from windows and doors.
Choosing Electric Heat for Your Climate and Home
The best heating system for a mild-climate apartment may not suit a farmhouse with long, freezing winters. Consider the climate, existing equipment, available electrical capacity, and the rooms you need to heat.
Mild winters: Resistance heating may make sense where heating demand is limited, although heat pumps can still offer lower operating costs.
Cold winters: Compare cold-climate heat pumps and their low-temperature performance. Plan for any backup heat the manufacturer recommends.
Homes without ducts: Ductless mini-splits can provide zoned heating without installing a duct network.
One chilly room: A compatible 120V space heater or appropriately installed baseboard unit may be enough.
Bathrooms and kitchens: Radiant floor heating can add comfort during a renovation. Check the system's wattage and installation requirements before purchasing.
Improving insulation, adding weatherstripping, and sealing drafts can reduce heat loss and help your heating system work more efficiently. Before upgrading, assess which rooms need heating and whether your electrical panel can support the equipment, including options such as electric radiant floor heating and its electricity use. For outage planning, identify essential circuits and calculate their running loads and startup demands. Also, note that the federal Energy Efficient Home Improvement Credit under Section 25C ended for property placed in service after December 31, 2025, so confirm current incentives before budgeting for a new installation.
Electric heating includes resistance systems that convert electricity directly into heat and heat pumps that deliver more heat per unit of electricity. Power requirements range from 1,500W space heaters to multi-kilowatt furnaces. Check your equipment's nameplate for voltage and wattage, then use your local electricity rate to estimate hourly costs. For outage backup, compare the EcoFlow TITAN 5000 Classic for compatible 120V heaters and the EcoFlow TITAN 5000 Plus for approved 240V heating circuits.
What is electric heat?
Electric heat is warmth produced by equipment powered by electricity. Resistance systems include space heaters, baseboards, and electric furnaces, while heat pumps transfer heat from outdoor air or the ground into the home.
Is electric heating expensive?
Resistance heating can cost more to operate than combustion heating. Heat pumps can reduce heating electricity use by up to 75% compared with resistance systems, according to the DOE. Actual costs depend on electricity rates, climate, insulation, and usage.
How many watts does a space heater use?
Many standard plug-in space heaters use up to 1,500W on their highest setting. The Lasko CC24910, for example, lists settings of 750W and 1,500W. Check the rating label on your specific model.
Can a home battery run electric heat during an outage?
Yes, some home batteries can power compatible electric heating equipment. A 120V space heater may fit within a suitable system's output limits, while an electric furnace or heat pump with auxiliary heating elements may require substantially more power. Verify the complete load with an electrician.
Do heat pumps work in cold weather?
Yes. Modern cold-climate heat pumps can provide heating in colder regions. Performance varies by model and outdoor temperature, so compare low-temperature heating capacity and efficiency ratings when selecting a system.
