Hawaii Flooding Right Now: Tracking Lala and Staying Safe
Hurricane Lala brushed the southern coast of the Big Island as a Category 1 storm on Saturday, August 15, 2026. It weakened to a tropical storm and pushed west from there. Five locations across the islands logged more than 35 inches of rain, with Kapalua in Maui County topping the list at 48 inches. Here's what's happened, how to read Hawaii's flood alerts, and how to keep your power on. We'll also cover why the islands flood so fast, and what to do if you're caught in it.
Hawaii Flooding Right Now: The Latest on Lala
Lala moved through the islands fast, but its effects stretched across rainfall, flooding, and power, not just wind. Here's where things stand.
The storm reached the Big Island as a Category 1 hurricane on Saturday, August 15, brushing the southern coast without a direct landfall. It weakened to a tropical storm as it pushed west. Forecasters at the Hawaii Emergency Management Agency flagged early on that it could still regain hurricane strength over open Pacific water.
Five locations across the islands recorded more than 35 inches of rain. Kapalua in Maui County took the top spot at 48 inches. On the Big Island's southern coast, more than 100 homes and eight bridges were damaged, according to Governor Josh Green. At least two homes were swept off their foundations in Naalehu during Saturday evening's flash floods. One death has been linked to the storm: a 90-year-old woman found dead in Naalehu on August 18.
At the peak of the storm, 255,378 customers statewide had lost power, according to the Governor's office. That number has been falling steadily as crews work through the islands. But Hawaiian Electric has warned that some rural pockets, especially in Puna, could stay dark for weeks or longer. If you're staring down an extended outage yourself, it's worth knowing how to keep a home running before the next storm catches you off guard.
Storms crossing the islands can jump between classifications within a single day. Knowing what separates sustained winds under 74 miles per hour from a full hurricane makes it easier to judge how seriously to take the next update.
With the current picture covered, here's how to read the state's alerts as conditions keep changing.
Reading Hawaii's Flood Alerts in Real Time
Hawaii's flood alerts follow three levels, and knowing which one is active changes what you should actually do right now. All three come from the National Weather Service, and the language is intentionally blunt.
Alert level
What it means
Watch ("Be Prepared")
Conditions are favorable for flooding within the next 48 hours or so, but nothing is certain yet. Use this window to review your emergency plan and check your supplies.
Advisory ("Be Aware")
Flooding or nuisance water is present or expected soon. It's usually not severe, but it can still cause real inconvenience or put life and property at risk.
Warning ("Take Action")
Dangerous flooding is happening now or about to happen. This is the most serious of the three. Get to higher ground immediately.
The National Weather Service defines a flood watch as conditions favorable for flooding, and a flood warning as flooding that's imminent or already underway. Knowing exactly where a watch ends and a warning begins decides whether you have hours to prepare or none at all.
Once you know what the alerts mean, the next question is what happens if the power goes out before they're lifted.
Keeping the Power On If You Lose Electricity
Outages during a storm like Lala happen fast, and downed lines can take days, sometimes longer, to fully repair once the flooding itself has receded. The priority during an active outage is usually simpler than people expect.
  • Outages happen fast. Power losses peaked above 255,000 customers statewide and were still north of 100,000 several days later. Downed lines can take days to repair across multiple islands.
  • Backup power priorities. Refrigeration, medical devices, lighting, and communication equipment top the list during a storm-related outage. That matters most when roads are impassable and help may be delayed.
Keeping Power On If You Lose ElectricityKeeping Power On If You Lose Electricity
Watching how many customers are still without power on each island helps residents plan around an outage. It could stretch from hours to days depending on where crews are actively working.
For households weighing an installed home battery rather than just a portable unit, EcoFlow's TITAN series is built for this kind of extended outage. The EcoFlow TITAN Plus delivers 7.2kW from the battery and takes up to 8kW of solar input, which helps when repairs run for days. With Smart Home Panel 10, installed by a qualified electrician, it backs up to 10 selected circuits.
EcoFlow TITAN 5000 Plus
Not every home has room for a large solar array. The standard EcoFlow TITAN supplies the same 7.2kW of 120V/240V output to selected circuits and takes up to 4kW of solar through one input, half the solar input of the EcoFlow TITAN Plus.
EcoFlow TITAN 5000
Zooming out from this storm specifically, it's worth understanding why Hawaii turns rain into flash floods so much faster than most of the mainland.
Why Hawaii's Terrain Turns Storms Into Flash Floods So Fast
Hawaii's geography turns ordinary rainfall into fast-moving floods in a way most of the mainland doesn't experience. The terrain, as much as the storm itself, decides how much warning residents actually get.
  • Steep, volcanic terrain. Mountains and narrow valleys channel heavy rain into streams and gulches within minutes, leaving far less warning time than flatter terrain gives.
  • Localized rain bands. Heavy rain on the mountains can trigger flash flooding downstream, even in areas that stayed dry or sunny at lower elevations.
  • Islandwide impact. Lala's effects weren't confined to the Big Island. Maui and Kauai both took on substantial rainfall, showing how one storm can hit each island differently depending on its terrain.
This kind of rapid runoff behaves nothing like a slow-rising river flood that builds over days, which is the pattern most mainland residents are used to.
With that context on why it happens so fast, here's what to do if you're actually caught in it.
Staying Safe During and After the Storm
Flash flood advice in Hawaii really splits into two windows: what to do while water is actively rising, and what to check once it recedes. Skipping the second one is a common mistake.
  • During. Avoid stream crossings and natural pools, even if the water looks calm. Flash flooding can hit sunny, dry-looking areas because of rain higher up in the mountains, and stream water can carry leptospirosis.
  • After. Stay off flooded roads and out of standing water, and watch for debris and unstable ground. Check county resources or the National Weather Service for updated conditions before you resume normal activity.
  • Stay connected. Sign up for county emergency alerts (Maui's Maka'ala system is one example), and keep your phone charged with a backup battery on hand.
The same core survival habits apply here as anywhere else: get to higher ground immediately, and never try to walk or drive through moving water.
Once the immediate danger passes, the next step is understanding what's actually covered when the cleanup bills arrive.
Staying Safe During and After the StormStaying Safe During and After the Storm
Checking Your Flood Risk and Insurance in Hawaii
Storm damage and flood damage aren't automatically covered by the same policy, and that surprises a lot of homeowners after the fact. It's worth checking both pieces before the next storm, not during one.
Standard homeowners insurance typically excludes flood damage. You'll usually need separate flood insurance, either through the National Flood Insurance Program or a private carrier, to actually be covered. FEMA's Flood Map Service Center lets any homeowner search their address for an official flood zone designation. That matters island-wide, given how localized Hawaii's flood risk can be.
Flood risk isn't fixed in a state that sees frequent tropical systems. It's worth rechecking periodically rather than trusting an old assessment, especially for homeowners weighing which coverage options actually fit their specific address and elevation.
Hurricane Lala brought record rainfall, swept homes off their foundations, and cut power to hundreds of thousands of customers across Hawaii. The same steep terrain and rain bands will keep making flash floods a fast-moving threat here. Know the difference between a watch, advisory, and warning, sign up for county alerts, and carry separate flood insurance. EcoFlow's upcoming TITAN and TITAN Plus are built for exactly this kind of whole-home resilience.
Is Hawaii flooding right now?
On August 15, 2026, Hurricane Lala tore across Hawaii. It damaged over 100 homes on the Big Island and knocked out power to hundreds of thousands of customers statewide. Conditions can still change quickly during Hawaii's storm season, so check the state's live flood alerts for current conditions in your area.
What's new about Tropical Storm/Hurricane Lala?
Lala moved past the Big Island as a Category 1 hurricane on August 15, 2026, brushing the southern coast before weakening to a tropical storm. Five sites recorded more than 35 inches of rain, with Kapalua on Maui County topping the list at 48 inches.
What's the difference between a flood watch, advisory, and warning in Hawaii?
A watch means conditions are favorable for flooding within about 48 hours. An advisory means flooding is possible but usually not severe. A warning means dangerous flooding is imminent or already happening, and it's the most serious of the three.
Why does Hawaii flood so easily and so quickly?
Hawaii's steep, volcanic terrain funnels heavy rainfall into streams and gulches within minutes, leaving far less warning time than flatter mainland terrain gives. Localized rain bands over the mountains can also trigger flooding downstream even where it never rained at lower elevations.
What should I do if I'm caught in a flash flood in Hawaii?
Move to higher ground immediately, and never try to cross moving water on foot or in a vehicle. Once conditions allow, a whole-home backup option like EcoFlow's upcoming TITAN lineup can help keep essential circuits running if the outage outlasts the flooding itself.
Power Outages
