Gas Water Heater Battery Backup: How to Keep Hot Water Running in an Outage
A lot of people are caught off guard the first time a power outage leaves them with cold showers, even though their water heater runs on gas. The gas makes the heat, but many modern heaters need electricity for the igniter, the control board, and the exhaust fan. No power means no hot water. A small gas water heater battery backup can fix that for many models. This guide covers which heaters need power, how much they draw, how to size a backup, and what to check with the maker first.
Does a Gas Water Heater Need Electricity?
It depends on the type you have. Many tankless models and power-vent tanks need a 120V outlet for their controls and fan. Some standard tank heaters with a standing pilot don't plug in at all, so they can keep heating through a blackout.
Gas water heater type | Needs 120V power? | Works in an outage without backup? |
Tankless (indoor or outdoor) | Usually yes, for controls, igniter, and fan | Usually no |
Power-vent tank | Yes, for the exhaust fan | Usually no |
Standard atmospheric-vent tank with standing pilot | Often no | Often yes |
How Much Power a Gas Heater Uses
The power draw is smaller than most people expect. The Rinnai RUCS75i spec sheet lists a 120V, 60Hz supply with 89W in normal use and 1.3W on standby. It also lists 167W for anti-frost protection and a 2.3A maximum current.
Why do so many newer heaters need an outlet at all? Older tanks used a standing pilot that burned all the time and vented exhaust up a chimney by natural draft. Many newer designs swap that for electronic ignition and a fan that pushes exhaust out through a side wall. That design saves gas, but it ties your hot water to the grid.
How to Check Your Own Heater
To check your own heater, look for a power cord or wiring running into the unit. Then read the electrical section of the owner's manual or the rating label on the side. Look for the voltage, the watts in normal use, and any separate figure for standby or freeze protection. If you only see amps, check the manual for a watt figure rather than guessing. Figuring out whether your gas water heater needs electricity starts with that cord.
If your heater does need power, a battery backup is the simplest way to keep it going. Here's how to work out how much battery you actually need.
Sizing a Gas Water Heater Battery Backup
The gas heats the water, and the battery only runs the electronics. That's a small load next to an electric water heater. You size the backup by the heater's watts, any pump on the same line, and how long your outages tend to last.
Start With the Real Electrical Loads
Think of your hot water system in two parts. The burner runs on natural gas or propane, which keeps flowing in most outages. The fan, control board, and igniter are what stop, and they're the only loads your battery carries.
A recirculation pump adds its own watts. In cold climates, frost protection can draw more than normal use on a freezing night. Your heater's spec sheet lists these numbers, so you don't have to guess.
It also helps to keep two numbers apart. Watts tell you how much power a device pulls at one moment, so they decide whether a battery can run it at all. Watt-hours tell you how much energy it uses over time, so they decide how long the battery lasts. A gas heater is easy on both counts, which is why a mid-size battery can carry it for days.
Check the Maker's Rules First
Before you pick a battery, read what your heater maker says about backup power. Some brands require a pure sine wave. Many need a proper ground, because the flame sensor may depend on it. Hardwired heaters need a licensed electrician. A battery backup for water heater electronics is also a different job from running a high-power electric tankless heater, and this setup isn't meant for those. No battery is a match for every model, so the manual comes first.
Safety is another reason batteries fit this job. The CDC's carbon monoxide basics say to run generators outside, more than 20 feet from windows, doors, and vents. A battery doesn't burn fuel, so it can sit indoors next to the heater with no fumes.
Matching a Battery to Your Home
A gas water heater's electronics draw so little that a battery can run them for a long stretch. EcoFlow portable power stations deliver pure sine wave AC, which many heater makers ask for on their control boards. The best fit depends on what else shares the outlet: the heater alone, or the heater plus a recirculation pump through a longer outage.
For one tankless heater on its own outlet, a 1kWh unit goes a long way. With a draw under 100W while running and almost nothing on standby, it can cover several days of normal showers, based on the estimates below.
Homes with a recirculation pump, or rural homes that face long outages, need more stored energy. A 2kWh unit covers the heater and pump together and still leaves room for a lamp or a Wi-Fi router.
In short, the EcoFlow DELTA 3 Classic suits one compatible 120V gas water heater's controls and fan. The EcoFlow DELTA 3 Max suits a heater plus a recirculation pump, or a longer outage window.
Energy Estimates for a Typical Day
The math is simple. Multiply each load's watts by the hours it runs to get watt-hours (Wh) per day. Then divide the battery's usable capacity by that daily total. The figures below are estimates. They use the Rinnai numbers above, a pump at an assumed 40W, and about 85% of each battery's rated capacity as usable energy.
Load (example) | Energy per day | EcoFlow DELTA 3 Classic (about 870Wh usable, est.) | EcoFlow DELTA 3 Max (about 1,741Wh usable, est.) |
Rinnai RUCS75i: 89W for 1.5 hours of hot water use, plus 1.3W standby for 22.5 hours | About 163Wh | About 5 days | About 10 days |
Same heater plus a recirculation pump at an assumed 40W for 4 hours a day | About 323Wh | About 2.7 days | About 5.4 days |
Freezing night: anti-frost at 167W for 6 hours | Adds about 1,000Wh per night | More than its usable capacity | About 58% of usable capacity |
Your numbers will differ, so plug in your own heater's watts. Say your heater lists 70W in use and 2W on standby, and your family runs hot water for about two hours a day. That works out to roughly 140Wh plus 44Wh, or about 184Wh a day. Divide the battery's usable energy by that total and you have a rough count of days.
Keep in mind that real use moves around. Guests, laundry, and cold incoming water in winter can all push the heater to run longer. A tankless water heater battery backup covers you for a limited period, depending on battery capacity and the actual load. With tankless heaters on a battery, the wiring often decides what's possible.
Before connecting anything, check a few things with the heater maker. Here's what to look for.
How to Connect a Battery Backup to a Gas Water Heater Safely
Plug-in heaters are the easy case. Hardwired heaters need an installer. Either way, the heater maker's rules come first.
Plug-In Heaters
If your heater has a standard cord, plug it directly into a grounded three-prong outlet on the power station. Don't use an extension cord or adapter plug unless your heater's maker clearly allows it. The Rinnai RUCS75i used as the example in this article does not: its manual bans extension cords and adapters and calls for a direct connection to a properly grounded outlet. So place the power station close enough for the heater's own cord to reach.
Test the setup on a calm day. Turn on a hot tap and make sure the burner fires. Let it run a few minutes and check the display for warning lights.
After the test, recharge the battery and keep it topped up. An outage rarely comes with much notice, so a half-charged unit in the closet won't help much.
Hardwired Heaters
Some heaters are wired straight into a junction box with no plug. If yours is hardwired, a licensed electrician can install an approved inlet or transfer switch. This lets the heater's circuit switch over to backup power without touching the rest of the panel.
Never backfeed power through a wall outlet with a homemade cord. Power can flow back onto utility lines and put line workers at risk.
Grounding, Waveform, and Safety Checks
Next, read the manual for notes on waveform, grounding, and flame sensing. Some heaters need a solid ground to sense the flame at all. If your heater shows an error code while it runs on battery, stop and contact the maker before you try again.
Any gas appliance in your home calls for working carbon monoxide alarms. The CPSC's outage safety tips advise battery-operated alarms or alarms with battery backup on each level of the home. That way they keep working when the grid doesn't.
Your heater style also shapes the backup you need. Among the tankless water heater pros and cons is their need for steady power. A battery isn't the only way to keep hot water flowing in an outage, though.
Battery Backup vs Generator vs UPS for a Gas Water Heater
Each option fits a different home. Batteries are quiet and safe indoors. Generators run longer on fuel but must stay outside.
Option | Pros | Cons |
Portable power station | Runs indoors, quiet, no fumes | Limited capacity |
Small UPS | Low cost | Short runtime, may not be pure sine wave |
Generator | Long runtime with fuel | Outdoors only, 20 feet from openings (CDC), noise |
Which Option Fits Your Home
Here's how each option stacks up for a typical home. Pick the one that matches how long your outages tend to last.
Portable power station: This works well as a battery backup for tankless water heater use. It sits by the heater, makes no exhaust, and recharges from the wall once power returns. Many models can also act like a UPS, so the heater stays plugged into the battery while the battery stays plugged into the wall. When the grid drops, the battery takes over on its own, even if you're asleep or away.
Small UPS: A computer-style UPS can carry a heater through a short blip. But many cheaper units put out a stepped waveform that some control boards won't accept.
Generator: A generator can run for days if you keep it fueled. It must stay outdoors, and someone has to refuel it in bad weather. The CDC's outage safety message calls for keeping generators at least 20 feet from the house and having a proper CO detector inside.
Generator plus battery: Some homeowners pair the two. The battery runs the heater indoors, and the generator recharges it by day.
Outages are where hot water planning starts. Some homes fold hot water into a broader whole-home backup power solution that also covers the fridge, lights, and furnace blower.
Many gas water heaters need 120V power for their controls and fans. The load is small, so a gas water heater battery backup is a practical fix, and one Rinnai model lists just 89W in use and 1.3W on standby. Check your heater's power needs, size by watts and hours, and follow the maker's grounding and waveform rules. The EcoFlow DELTA 3 Classic fits one heater, while the EcoFlow DELTA 3 Max adds room for a pump.
Does a gas tankless water heater work without electricity?
Most don't. A gas tankless model uses 120V power to run its controls, igniter, and fan. So an outage stops the hot water even though gas still flows. The unit can't light the burner or clear exhaust safely without that power. That's why a gas tankless water heater battery backup is a common add-on in outage-prone homes.
How many watts does a gas tankless water heater use?
It varies by model, so check your spec sheet. As one example, the Rinnai RUCS75i lists 89W during normal use and just 1.3W on standby. Its anti-frost protection uses 167W, which matters on freezing nights. Other models will list different numbers, so use your own heater's figures when you size a battery.
Can I run my gas water heater on a battery backup?
In many cases, yes. A battery backup for gas water heater electronics works best with a 120V plug-in model. The maker should allow it, and the battery must meet its power needs. If you're planning a battery backup for tankless gas water heater models that are hardwired, hire a licensed electrician.
How long will a battery run a gas water heater?
It comes down to how much you use hot water and how cold it gets. As an estimate, a 1kWh unit with about 870Wh usable could run a heater drawing 89W for about 10 hours of active heating. Standby adds little, so a battery backup for gas tankless water heater use can stretch across several days.
Does a standard gas tank water heater need power?
Many standing-pilot tank models don't need power at all. Power-vent tanks do, because their exhaust fan runs on electricity. The quickest check is to look for a power cord. If you find one, size it the same way you'd size a backup battery for tankless water heater models: add up the fan and control watts.
