How to Choose the Right Whole-Home Backup Solution?
What’s the Whole-Home Backup Solution?
Recently, EcoFlow launched the new Whole-home Backup Solution, a one-stop solution to all your home backup problems. To the greatest extent to help you mitigate the impact of power failure, our whole-home backup solution can make your home in a power failure days can also maintain power supply, not be troubled by power failure, and enjoy the fun of life. These Whole-home backup solutions have enough power to run the normal operation of a home, including all large appliances, electronics, and even air conditioning. You can also connect extra batteries to expand capacity and extend battery life.
Advantages of the Whole-Home Backup Solution over Traditional Power Backup Solutions
The typical gas generator optionis probably what most of us consider when considering a home power backup solution, however, this choice may not always be the ideal one. The gas generator emits polluting gases such as CO, Hydrocarbon, and Oxynitride, which have a very high impact on the environment. The high maintenance costs and the space limitation of having to be placed outdoors also make it a poor solution for household power generation. In contrast,EcoFlow whole-home backup solution not only solves the problem of power backup in the event of a power outage but also offers a new generation of consumers the possibility of a pollution-free, noise-free, and easy-to-install electricity solution. Besides, EcoFlow is compatible with solar panels and harnesses free power from the sun.
The EcoFlow Whole-Home Backup Solution can be installed in two ways
EcoFlow Whole-home backup solution provides consumers with the flexibility to choose between installing the system with a Transfer switch/Inlet box or utilizing intelligent power management through a Smart Control Panel. It also works with the interlock kit on the load center if there is no transfer switch installed.
OPTION 1: The flexible way to set up your Whole-Home Backup Solution
Wiring diagram showing two ways to connect a portable power station to a home: through an inlet box and manual transfer switch to the main panel, or via an interlock on the main panel, feeding selected home loads while remaining isolated from the utility grid and meter.Wiring diagram showing two ways to connect a portable power station to a home: through an inlet box and manual transfer switch to the main panel, or via an interlock on the main panel, feeding selected home loads while remaining isolated from the utility grid and meter.
EcoFlow Whole-home Backup Solution:
Starter Kit: EcoFlow DELTA Pro+Transfer Switch 306A1+Generator Cord
Advanced Kit:EcoFlow DELTA Pro*2+Double Voltage Hub+Transfer Switch 306A+Generator Cord
Transfer Switch: Themanual transfer switch that allows you to safely connect a portable generator to your home’s electrical system during a power outage. Transfer Switch forces home circuits to get powered either by Grid only, or by Backup power only. Installation of the Transfer Switch should be done by a licensed electrician or a qualified professional.
Inlet Box: Inlet Box connects the Transfer Switch and leaves a male socket, with Generator Cord (The male socket of the cord should be the local version, e.g. EU/US/AU/SA), you can connect Portable Power Station to Inlet Box then to the Transfer Switch, to work as Back Up Power
Advantage: The most affordable and straightforward solution for short-term outages. Attaining partial home backup is simple, avoiding the diesel generator’s head-splitting noise and all the maintenance expenses. Plug EcoFlow DELTA Pro into your home’s transfer switch to power your critical circuits when a blackout hits. You can also use the Double Voltage Hub to connect Extra Batteries to keep your essentials running for up to a week. The EcoFlow DELTA Pro can be connected directly to Home Circuits as a whole-home backup solution, and can also support local backup circuits in the house. It is a more economical and flexible solution.
For longer outages or homes with higher energy demands, the OCEAN Pro Battery provides a powerful alternative. You can scale up your system to 80kWh with stackable modules and use it with the OceanPro Inverter for high-power applications like HVAC systems or heavy-duty equipment—without relying on fossil fuels.
OPTION 2:The intelligent way to set up your Whole-Home Backup Solution
Diagram of an EcoFlow Smart Home Panel connected to a home electrical panel and two DELTA Pro units, splitting power to 10 backed‑up circuits while other home circuits remain on the grid to run devices like laptops, TVs, refrigerators, kitchen appliances, and lights.Diagram of an EcoFlow Smart Home Panel connected to a home electrical panel and two DELTA Pro units, splitting power to 10 backed‑up circuits while other home circuits remain on the grid to run devices like laptops, TVs, refrigerators, kitchen appliances, and lights.
Smart Control Kit: EcoFlow DELTA Pro+ EcoFlow Smart Home Panel
EcoFlow Smart Home Panel: The EcoFlow Smart Home Panel is a smart home battery system. The EcoFlow Smart Home Panel integrates EcoFlow DELTA Pro with your home to achieve a flexible, expandable home battery solution to store energy for later use. Link up to 10 of your home circuits for uninterrupted power during blackouts
Advantage: This integrated home backup power solution is an eco-friendly and cost-effective alternative to a traditional fuel-powered generator.When a blackout hits, the EcoFlow Smart Home Panel immediately switches to your 10 integrated circuits and draws power from your EcoFlow DELTA Pro(s). You’ll barely notice a loss of power as your chosen circuits stay powered with a mere 20ms switchover time. At the same time, the EcoFlow Smart Home Panel can Control each of your integrated home circuits via the EcoFlow app and get a birds-eye view of your energy consumption habits. Dive into the settings to customize your power use. You can optimize home backup, save money, or custom options to schedule your energy use based on your needs. Once you’re set, you can even control which power source your house uses, all from your phone.
*Installation of the EcoFlow Smart Home Panel should be done by a licensed electrician or a qualified professional.
Two EcoFlow portable power stations plugged into a wall transfer box power a cozy living room at night, as a person relaxes on a sofa in a modern open‑plan home.Two EcoFlow portable power stations plugged into a wall transfer box power a cozy living room at night, as a person relaxes on a sofa in a modern open‑plan home.
EcoFlow's Whole-home Backup Solution isn’t just a product—it’s a modern, sustainable approach to energy resilience. Whether you’re protecting your home from frequent blackouts or aiming for energy independence, EcoFlow offers solutions that grow with your needs. From flexible kits featuring DELTA Pro to industrial-strength backup power enabled by the OCEAN Pro Battery and OceanPro Inverter, EcoFlow now covers everything from short-term blackouts to long-term off-grid living.
Whether the Transfer Switch can be used for apartments?
Yes, a Transfer Switch is highly versatile and can indeed be used in apartments, not just in houses. In an apartment setting, it serves as a crucial component for managing power sources, especially during outages. It allows for a seamless transition between the main power grid and an alternative power source, such as a generator or a home battery system. This ensures that essential appliances like refrigerators, lights, and security systems can keep running. Moreover, the Transfer Switch can also be utilized outdoors. For instance, if you have an outdoor lighting setup or a small outdoor power - dependent device, the Transfer Switch can help in power management, making it a valuable asset in various environments.
Can I install the Whole-Home Backup Solution by myself?
No, you shouldn't install the Whole - Home Backup Solution alone. Components like the Transfer Switch and EcoFlow Smart Home Panel involve high - voltage electrical work. Incorrect installation can lead to risks like electrical fires or shocks. A licensed electrician or qualified professional has the training and expertise to install these safely and according to code, safeguarding your home and family.
If I choose the Option 1 installation method, do I have to purchase an Inlet box?
No, it is not necessary. With Option 1 installation, an Inlet box isn't required. An electrician can directly connect the Generator Cord's zero firewire to the Transfer Switch and the other end to the PPS AC Outlet. While some homes may have an Inlet box already, this method simplifies the process and can cut costs. Just make sure the electrician follows safety procedures during installation.
Home Solutions
