Dual Fuel Generator vs. Solar Generator: Which Is Better for Your Needs?
Choosing between a dual fuel generator and a solar generator depends on what you need to power and where you’ll use it. Generators running on fuel can deliver strong output when sized for the load, with runtime depending on fuel supply and load. Solar generators can operate quietly indoors in a dry, ventilated location when used as directed, but their runtime depends on battery capacity and recharging ability. This guide compares the two and explains what to consider for home backup, camping, and off-grid use.
What Are Dual Fuel Generators and Solar Generators?
Both produce electricity, but they work differently. A dual fuel generator burns gasoline or propane, while a solar generator pairs a battery power station with solar panels.
How Dual Fuel Generators Work
What is a dual fuel generator? It’s an engine-driven generator that runs on either gasoline or propane (LPG). In gasoline mode, fuel flows from the built-in gas tank to the engine. In propane mode, the generator draws gas from an external tank through a hose and regulator to the generator. The engine drives an alternator to produce AC electricity.
How Solar Generators Work
A solar generator uses compatible solar panels to recharge a battery powered generator. Depending on the model, you can recharge the battery from solar panels, an AC outlet, or a supported vehicle charging source. A charge controller manages incoming power. A built-in inverter converts the battery’s DC electricity into AC power for appliances and devices. Many modern units use lithium iron phosphate (LiFePO4) batteries.
Dual Fuel Generator vs. Solar Generator: What Are the Key Differences?
The two types differ in how they’re powered, how much electricity they can supply, and what they cost to operate. This table covers the main points.
Feature | Dual Fuel Generator | Solar Generator |
Primary Energy Source | Unleaded gasoline & liquid propane (LPG) | Solar radiation, AC grid, vehicle alternator/12V |
Continuous Power Output | High to very high (typically 3,500W – 12,000W+) | Moderate to high (typically 1,000W – 7,200W+) |
Noise Level | Loud (65–78+ dB(A) at 20 ft) | Near-silent (0–35 dB fan hum under heavy load) |
Indoor Usability | Never (fatal carbon monoxide risk; outdoor only) | Safe indoors, inside tents, cabins, and vans (ensure clean air ventilation around cooling vents) |
Upfront Cost | Low to moderate ($600 – $2,500) | Moderate to high ($1,200 – $5,000+ with solar panels) |
Ongoing Running Costs | Regular fuel purchases (gas/LPG), oil, filters, spark plugs | Near-$0 with solar charging (minimal utility cost if using AC grid top-offs) |
Routine Maintenance | Oil changes every 50–100 hrs, fuel stabilizer, spark plug swaps | Keep battery charged; keep vents clear of dust |
Lifespan | 1,500 – 3,000 engine run-hours | 3,000 – 4,000+ charge cycles (approx. 10 years daily use) |
Note: The specifications, price ranges, performance figures, and lifespan estimates are general references and may vary by brand, model, operating conditions, and maintenance practices. Always consult the manufacturer’s specifications for accurate product details.
Fuel Sources and Recharging Options
A dual fuel generator runs on gasoline or propane, giving you an option if one fuel is not readily available. You’ll need to store and handle the fuel safely, and gasoline can degrade over time. Solar generators can recharge from solar panels, a wall outlet, or a vehicle. Solar charging avoids fuel purchases. Whether solar panels need direct sunlight depends on how much output you need. Panels can still generate power in indirect light, usually at a lower output.
Power Output and Runtime
A dual fuel generator can supply steady power to demanding appliances as long as it has fuel and enough output capacity for the load. Larger models may run central air conditioning or power tools, depending on their rated and startup wattage. For a portable power station, usable battery capacity and the connected load determine runtime. Its inverter rating determines which appliances it can run. It can power appliances such as a refrigerator or microwave, but once the battery runs down, you’ll need to recharge it.
Operating Costs and Long-Term Savings
Dual fuel generators often cost less upfront, but fuel, oil, and maintenance add to the long-term cost. Solar generators usually cost more initially, especially when you include panels, but they have lower ongoing expenses. Charging from sunlight costs nothing for fuel. If you recharge from the grid it will add to your electricity bill. How much you save with a solar generator depends on how often you use it and how you recharge it.
Noise, Emissions, and Environmental Impact
Dual fuel generators produce noise and carbon monoxide. Operate a portable fuel generator outdoors, at least 20 feet from doors, windows, and vents, and follow the manufacturer’s placement instructions. Solar generators produce no engine exhaust during operation and can be used indoors in a dry, ventilated space as directed. Cooling fans may be audible under heavy loads.
Maintenance and Ease of Use
A dual fuel generator needs regular maintenance. Depending on the model, this can include checking and changing the oil, cleaning the spark arrestor, servicing spark plugs, and preparing the fuel system for storage. Solar generators require very little routine maintenance. Try to keep the battery charged and clear dust from the vents. You can use the display or companion app to monitor power use and level. There’s no engine to start or service.
Which Generator Is Better for Different Uses?
The best option depends on where you’ll use it, what you need to power, and how you’ll recharge it. Here are a few common situations to consider.
Home Backup During Power Outages
During a neighborhood power outage, a dual fuel generator can run household appliances for as long as you have fuel. It must be operated outdoors, so you’ll need to manage fuel and extension cords outside, even in cold, rainy weather. A solar generator can power essential devices indoors without engine noise or harmful exhaust. Battery capacity is an important feature, especially if you want to keep a refrigerator running through a long outage. For example, the EcoFlow DELTA 3800 Gen4 Portable Power Station has a 3,763Wh battery and Fridge Runtime Boost™ technology. This technology can extend a standard refrigerator’s runtime to up to 70 hours under official test conditions. Actual runtime depends on the refrigerator and how it’s used.
Camping and RV Trips
If you’re camping, quiet operation and easy recharging can matter as much as power output. A dual fuel generator can run an RV air conditioner, but its noise and fuel storage may be inconvenient, especially when the campground has quiet hours. A solar power station is quieter and can recharge from solar panels during the day at camp or from a vehicle while driving. The EcoFlow DELTA 3 Max Plus Portable Power Station (2048Wh) offers 3,000W of AC output for appliances such as induction cooktops and travel air conditioners. Use it with portable solar panels, or use an 800W Alternator Charger while driving to recharge before reaching camp.
Off-Grid Living and Remote Worksites
Remote work sites and off-grid cabins have different power needs. Work sites use power tools and often require semi-continuous usage. On the other hand, a cabin’s everyday essential devices may use less power but need to run reliably.
Remote work sites: Circular saws, concrete mixers, and air compressors can require substantial running and startup power. A 10kW dual fuel generator may support multiple tools, depending on their combined wattage and startup requirements.
Off-grid cabins: A solar generator sized for the cabin’s loads can power lights, laptops, water pumps, and satellite internet equipment. A dual fuel generator can provide backup during extended periods of poor sunlight.
How to Choose the Right Generator for Your Needs
Narrowing down what type of generator to purchase is straightforward when you consider your power requirements systematically.
1. Calculate Your Essential Power Requirements
List the appliances you need to run and check their running and starting watts. Look up both values for your refrigerator model before sizing for its compressor. Choose a generator that covers the total running load plus the extra power required when a motor starts, including appliances that remain on. Choosing the right generator size starts with deciding which appliances you need to keep running during an outage.
2. Assess Your Access to Fuel and Charging Sources
Consider whether you have a safe place to store gasoline or propane, and whether there’s room for solar panels in an open and unshaded area. If snow or cloudy weather can limit solar charging for days, check whether you can also recharge from a vehicle or wall outlet.
A dual fuel inverter generator is another option if you want to switch between gasoline and propane while benefiting from more stable power output for sensitive electronics.
3. Compare Upfront Costs and Long-Term Value
To properly compare, include setup and several years of operating costs, not just the purchase price. A dual fuel generator may also require a transfer switch, heavy-duty extension cords, fuel containers, stabilizer, and engine oil. A solar system usually costs more upfront, especially with solar panels, but avoids routine fuel purchases and engine maintenance.
A dual fuel generator may be the better fit if you need high output and can locate it outdoors and run extension cords. You’ll also need to safely store and handle fuel. A solar generator may suit you better if you want to use it indoors and prefer not to do engine maintenance. You will need to monitor battery usage and remember to recharge. As always, check your appliance loads and likely runtime before choosing.
What Are the Disadvantages of a Dual Fuel Generator?
Dual fuel generators produce engine noise, need regular maintenance, and emit carbon monoxide. Operate a portable fuel generator outdoors, at least 20 feet from doors, windows, and vents. Gasoline can degrade in storage, and improper storage can cause fuel system problems. Check the manufacturer’s running and starting watt ratings for each fuel, since output can vary between gasoline and propane.
What Are the Downsides of Solar Generators?
Upfront cost depends on the battery capacity, inverter rating, and whether solar panels are included. Solar recharging time varies with available sunlight, panel wattage, and the unit’s solar input limit. Runtime between charges depends on the usable battery capacity of the setup. Some models support extra batteries or other charging options, such as an AC outlet.
How Long Will a Dual Fuel Generator Run on Propane?
Runtime on a 20-pound propane cylinder depends on the generator model and electrical load. As a general reference, a typical 7,500-watt dual fuel generator may run for approximately 5.5 hours at 50% load on a 20-pound propane cylinder. Actual runtime varies by generator capacity, engine efficiency, and operating conditions. Check the manufacturer’s runtime rating for propane at a load close to what you plan to run.
Can a Solar Generator Run a Whole House?
A properly sized solar generator system can back up a whole home. If you only need a few essential circuits, size the system for those loads. In either case, check the combined running load, startup demand, required voltage, and battery capacity for the backup time you need. To back up a 240 V circuit, use a system that supports 240 V output. A qualified electrician should install compatible transfer equipment or a backup panel for a connection to home wiring.
How Long Will a 3,000-Watt Solar Generator Run a Refrigerator?
A 3,000 W rating describes inverter output. Refrigerator runtime depends on usable battery energy. First, confirm that the inverter can handle the refrigerator’s running and startup power. Then divide the energy available to AC loads in watt-hours (Wh) by the refrigerator’s average draw in watts (W) to estimate runtime in hours. Use a plug-in energy meter to measure average draw over a typical day, or use the EnergyGuide annual energy estimate for a rough calculation.
