Split System HVAC: How It Works, the Main Types, and What to Know Before You Buy
Even if homeowners have never heard the word, most American homes with central air employ a split system HVAC. The phrase “split” refers to the fact that the system consists of two primary parts: an interior unit and an outside unit connected by refrigerant lines. This design is typical of central air conditioners, heat pumps, and ductless mini-splits. Knowing how these systems work can help you pick up the proper equipment, handle energy expenses and plan for unexpected power outages. Here’s what you need to know before buying a split system HVAC.
What Is a Split System HVAC and How Does It Work?
A split system HVAC comprises two main parts: an outdoor unit with the compressor and condenser coil, and an indoor unit with the evaporator coil and an air handler or furnace. These components are connected by insulated copper refrigerant lines through which the refrigerant travels. The system works by transferring heat rather than simply creating cool air. During cooling, the indoor coil absorbs heat from your home, and the refrigerant carries that heat outdoors, where the outdoor coil releases it.
Main Components of a Split HVAC System
A split HVAC system consists of indoor and outdoor components that work together to regulate indoor temperature. Each part performs a specific function, from moving refrigerant and transferring heat to circulating conditioned air. Understanding these components makes it easier to see how the system operates.
Component | Location | Main Function |
Compressor and condenser | Outside | Moves refrigerants and releases heat outdoors. |
Evaporator coil | Inside | Absorbs heat from indoor air during cooling. |
Furnace or air handler | Inside | Circulates conditioned air and may provide heating. |
Refrigerant lines | Between units | Transport refrigerant between indoor and outdoor components to transfer heat. |
What Is the Difference Between a Split System and a Mini-Split?
A traditional split HVAC system uses ductwork to distribute conditioned air throughout the home, while a ductless mini-split delivers refrigerant to individual indoor units for room-by-room temperature control. Mini-splits can be useful for home additions, garages, and older houses without existing ducts, and understanding the potential cost of installing a mini-split system can help you evaluate whether it suits your space and budget. Although both systems have indoor and outdoor components, their air distribution methods differ.
Keeping a Split System Running in an Outage: Home Battery Backup
Central air conditioners and heat pumps can demand substantial electricity, especially when their compressors start. Many residential systems operate on 240V circuits, so backing them up requires more than connecting an ordinary battery to an outlet. A suitable home battery system must provide the correct voltage, enough continuous power, and sufficient starting capability for the specific HVAC equipment.
What to Check Before Choosing a Home Battery
Before choosing a home battery to support your HVAC split system, understand the electrical requirements of your equipment. The right backup setup must handle both normal operation and the higher power demand during compressor startup. Consider these important factors to estimate your backup needs.
Rated voltage: Check whether your HVAC outdoor unit requires 208V, 230V, or 240V operation to ensure the battery system is compatible.
Running power: Identify how much electricity the system consumes while the compressor and other components are operating normally.
Starting current: Compressor startup can require considerably more power than normal operation, so choose a backup system that can handle this temporary surge.
Other household loads: Include refrigerators, lighting, water pumps, and other essential appliances when calculating your total backup power requirements.
Expected runtime: Estimate how long you need backup power based on battery capacity, average HVAC consumption, and how frequently the compressor cycles.
EcoFlow TITAN 5000 for Compatible Split AC and Heat Pump Circuits
Keeping a split AC or heat pump running during an outage requires substantial power, including 240V operation, sustained output, and sufficient capacity for compressor startup. The EcoFlow TITAN 5000 offers 7,200W of rated output with 120V/240V split-phase support, making it an option for compatible HVAC circuits when paired with a suitable Smart Home Panel 10 configuration. Before installation, a licensed electrician must verify the equipment's nameplate ratings and actual startup requirements to ensure compatibility.
Understanding Possible Backup Runtime
Battery capacity determines how long a system can supply electricity. For example, consider a hypothetical split AC with an average running demand of 1,800W. Using an estimated 85% usable battery capacity:
Backup Configuration | Estimated Usable Energy | Approximate Runtime |
EcoFlow TITAN 5000, one battery | 4,265Wh | 2.4 hours |
EcoFlow TITAN 5000 with two additional batteries | 12,795Wh | 7 hours |
Actual backup runtime depends on compressor cycling, outdoor temperature, thermostat settings, and other connected appliances, so treat these figures as estimates rather than guarantees. When planning a whole-home backup system, consider your essential loads and required battery capacity, including any additional batteries. Have a licensed electrician verify the complete installation, as EcoFlow requires qualified professionals to install and wire the Smart Home Panel 10.
Types of Split System HVAC
Although split HVAC systems share a basic indoor-and-outdoor design, their heating methods and air distribution can vary. Some use gas furnaces, while others rely on electric heat pumps to provide year-round comfort. Understanding the main configurations can help you compare their heating capabilities, energy requirements, and suitability for your home.
1. Split AC With a Gas Furnace
This configuration combines an outdoor air conditioner with an indoor gas furnace. The air conditioner handles cooling during summer, while the furnace burns natural gas to provide heat during winter. Its built-in blower circulates conditioned air through the home's ductwork, making it a common choice for households in regions with colder winters.
2. Split Heat Pump With an Air Handler
A split heat pump uses the same outdoor equipment for both heating and cooling by reversing the refrigeration cycle. During summer, it transfers indoor heat outside, while in winter, it extracts heat from outdoor air and moves it indoors. Some systems also include auxiliary electric heat strips for additional warmth, although these can significantly increase electricity consumption.
3. Dual-Fuel Split System
A dual-fuel system combines an electric heat pump with a gas furnace to provide flexible heating throughout the year. The heat pump typically handles milder temperatures, while the gas furnace takes over when outdoor conditions become too cold for efficient heat pump operation. When comparing heat pumps and furnace costs, efficiency, and performance, consider your local climate, energy prices, and household heating requirements.
4. Ductless Mini-Split System
A ductless mini-split connects an outdoor compressor to one or more indoor wall-mounted units, delivering heating and cooling without central ductwork. Each indoor unit can control the temperature of its designated space, making this configuration useful for older homes without ducts, room additions, converted garages, small apartments, and households with different room-temperature preferences.
Split System Efficiency Ratings and Sizing
Once you understand the available system types, the next step is comparing efficiency ratings and choosing the correct size. Since 2023, new central air conditioners and heat pumps have been subject to updated Department of Energy (DOE) efficiency standards. These standards use SEER2, EER2, and HSPF2 ratings to measure performance under updated testing procedures.
Understanding SEER2, EER2, and HSPF2
HVAC efficiency ratings help homeowners understand how effectively an air conditioning or heat pump system uses electricity. Each rating measures performance under different operating conditions, including seasonal cooling, specific cooling conditions, and seasonal heating. Understanding these ratings can help you compare equipment and make informed decisions about energy consumption.
SEER2: Measures the seasonal cooling efficiency of an air conditioner or heat pump. A higher SEER2 rating generally indicates greater cooling efficiency over a typical cooling season.
EER2: Measures cooling efficiency under specific operating conditions, typically at a fixed outdoor temperature. It helps compare how efficiently a system performs during particular conditions.
HSPF2: Measures the seasonal heating efficiency of a heat pump. A higher HSPF2 rating generally indicates better heating efficiency and lower electricity consumption for the same heating output.
2023 DOE Minimum Efficiency Standards
The U.S. Department of Energy (DOE) introduced updated minimum efficiency standards for split-system central air conditioners and heat pumps in 2023. These requirements vary by equipment type, cooling capacity, and installation region. The following table summarizes the minimum SEER2 ratings and additional requirements for split systems.
System | North | Southeast | Southwest |
Split AC under 45,000 Btu/h | 13.4 SEER2 | 14.3 SEER2 | 14.3 SEER2 |
Split AC 45,000 Btu/h or higher | 13.4 SEER2 | 13.8 SEER2 | 13.8 SEER2 |
Split heat pump | 14.3 SEER2 | 14.3 SEER2 | 14.3 SEER2 |
How to Choose the Right HVAC Size
Choosing the correct HVAC capacity is essential for maintaining indoor comfort and energy efficiency. An undersized system may struggle to cool your home, while an oversized unit can cycle too frequently and waste energy. A professional Manual J load calculation helps determine the appropriate system size based on the following six factors.
Total conditioned floor area: The total living space that needs heating and cooling helps determine the required HVAC capacity.
Ceiling height and room layout: Higher ceilings and open floor plans can affect how conditioned air moves and how much heating or cooling is needed.
Insulation levels: Proper insulation reduces unwanted heat transfer, helping your HVAC system maintain comfortable indoor temperatures with less energy.
Window size, placement, and exposure: Large windows and direct sunlight can increase indoor heat gain, affecting cooling requirements.
Local outdoor temperatures: Regional climate conditions and seasonal temperature extremes influence the heating and cooling capacity your home needs.
Air leakage and ventilation: Gaps around doors, windows, and other openings allow conditioned air to escape, potentially increasing HVAC energy consumption.
Avoid selecting a system based only on square footage or your previous air conditioner's capacity. Once you have the right equipment, using smart thermostats to manage HVAC schedules and reduce energy costs can further improve efficiency. Also, check your air conditioner's power consumption before planning electrical upgrades or estimating backup power requirements.
A split HVAC system uses indoor and outdoor components connected by refrigerant lines to provide heating and cooling. Common types include split ACs, heat pumps, dual-fuel systems, and mini-splits. Before choosing equipment, compare SEER2 ratings and get a professional load calculation. If you need backup power for a compatible split AC or heat pump circuit, consider the EcoFlow TITAN 5000 with Smart Home Panel 10, professionally installed by a licensed electrician.
What is a split system air conditioner?
A split system air conditioner is a central cooling system with an outdoor unit containing the compressor and condenser and an indoor evaporator coil. Refrigerant lines connect the two units to transfer heat outside the home.
Is a heat pump a split system?
Most central heat pumps use a split-system design. They have an outdoor unit and an indoor air handler connected by refrigerant lines. Unlike standard air conditioners, heat pumps can provide both heating and cooling.
What is the minimum SEER2 for a split AC?
For split-system air conditioners below 45,000 Btu/h, the DOE's 2023 minimum is 13.4 SEER2 in the North and 14.3 SEER2 in the Southeast and Southwest. Additional requirements apply in the Southwest.
What's the difference between a split system and a mini-split?
A conventional central split system generally distributes conditioned air through ducts. A mini-split uses refrigerant lines to connect the outdoor unit directly to one or more indoor heads, so it does not require central ductwork.
Can a home battery run a split system AC?
Yes, some home battery systems can support compatible split-system air conditioners. However, the battery must meet the AC's voltage, continuous power, and compressor starting requirements. The EcoFlow TITAN 5000 provides 7,200W at 120V/240V split-phase, but an installer must verify compatibility before connecting an HVAC circuit.
