What Is Heat Tape? How It Protects Pipes and How to Use It Safely
What is heat tape, and do you need it? If you have water lines in a crawl space, under a mobile home, or out by the well, it may be the cheapest protection you can buy against a burst pipe. Heat tape is an electric cable that runs along a pipe and keeps it just warm enough to stop ice from forming. Used the right way, it works in the background. Used the wrong way, it can start a fire, and the CPSC has warned about faulty heat tapes for decades. This guide covers types, safe installation, lifespan, and outages.
What Is Heat Tape and What Does It Do?
Heat tape, also called heat cable or heat trace, is an electric heating cable for pipes. It plugs in or is hardwired, and it warms the pipe surface so the water inside stays liquid. Most products use a thermostat, so they only heat when it's cold.
So what does heat tape do on a cold night? According to the CPSC, many heat tapes stay plugged in year-round and switch on through a thermostat as the outdoor temperature approaches freezing. You don't have to remember to plug anything in before the first cold snap.
The Main Types of Heat Tape
Not every product sold as heat tape works the same way. The type you pick affects how much heat you get and where you can use it.
Type
How It Heats
Typical Use
Constant-wattage cable
Puts out the same heat along its full length whenever it's on
Short, simple pipe runs, often with a plug-in thermostat
Self-regulating cable
Adjusts its own heat output as the pipe temperature changes
Longer runs, or spots where some sections get colder than others
Roof and gutter de-icing cable
Melts channels through snow and ice on roof edges and gutters
Ice dams on the roof, not water pipes
That last row matters. The CPSC says heat tapes designed for water pipes shouldn't go on gutters, driveways, or fuel lines.
Constant-Wattage vs. Self-Regulating Cable
For most homeowners, the real choice comes down to the first two types. Constant-wattage cable is simple and usually costs less, but it heats every inch the same way, so it leans on its thermostat to switch off when the pipe is warm enough. That makes it a good fit for a short, straight run you can see and reach.
Self-regulating cable turns its heat up in colder sections and down in warmer ones. If your pipe runs past a drafty vent at one end and a warm furnace room at the other, that flexibility helps. Whichever type you choose, the CPSC's advice is to buy the proper tape for the proper pipe. Measure the pipe's diameter and length first, then pick the tape the maker recommends for that size and pipe material.
Where Heat Tape Makes Sense
If you're wondering what is heat tape for pipes in practical terms, picture any water line sitting in cold air. Common spots include:
  • Crawl space pipes near foundation vents
  • Water lines under mobile and manufactured homes
  • Exposed outdoor pipes along an exterior wall or porch
  • Well and pump lines, including the run from the wellhead to the house
  • RV fresh water hoses during cold-weather trips
Outdoor heat tape for pipes must be rated for outdoor, wet locations. FEMA's winterizing your home guide lists wrapping water pipes in heat tape as one way to keep them from freezing. Most plans for preventing frozen pipes in winter start with insulation and heat tape, then add habits like dripping faucets.
Certification matters too. The CPSC urges homeowners to use heat tapes certified to voluntary safety standards set by Underwriters Laboratories (UL), the Canadian Standards Association (CSA), or the Factory Mutual Research Corporation (FMRC).
Heat tape has one weakness, though. It only works with power, so a winter storm that cuts your electricity puts those pipes back at risk.
What Happens to Heat Tape During a Power Outage?
When the power goes out, heat tape stops heating. The pipe cools to the surrounding temperature, and in a hard freeze that can take only hours. A portable power station can keep an already-installed, code-compliant plug-in heat tape running for a limited time.
Portable Power Keeps Heat Tape RunningPortable Power Keeps Heat Tape Running
Before You Plug Into Backup Power
Backup power only bridges a gap for a setup that was already safe, with the right tape type, a suitable pipe, and a proper install. If you plan to run heat tape from a backup source, keep these conditions in mind:
  • Follow the heat tape maker's rules for thermostats, ground-fault protection, and installation.
  • Check the label watts and cable length, and allow for some energy loss.
  • Keep the GFCI protection your manual requires. The CPSC says to plug heat tapes into a GFCI-protected outlet using the 3-prong plug, so use a GFCI adapter if your backup source lacks that protection.
  • Use an extension cord rated for the load and location.
  • Keep the power station indoors, dry, and within its low-temperature limits.
Even then, a power station can't guarantee continuous freeze protection. Runtime depends on battery capacity, the actual load, and how often the thermostat calls for heat.
Choosing a Power Station for Heat Tape
Start with the label on your heat tape. Some tapes list total watts, while others list watts per foot, so multiply by the length if that's how yours is rated. If you run more than one tape, or a separate plug-in thermostat or controller, add those watts too. That total tells you whether one small unit can handle the job or whether you need more stored energy.
In a winter outage, a few hours of heat on your most exposed pipe can make a real difference. An EcoFlow portable power station can run a code-compliant plug-in heat tape that's already installed, while the unit sits inside the house where it stays dry and warm. Size it by the tape's wattage, its length, and how long you need to bridge.
One short self-regulating run on a crawl space line is a small load. A 1kWh unit like the EcoFlow DELTA 3 Classic can carry it through many overnight outages, especially when the tape's thermostat cycles it off part of the time.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
Several runs, like a well line plus crawl space pipes, add up quickly. A 2kWh unit like the EcoFlow DELTA 3 Max doubles the stored energy, so you can keep more pipe protected or protect the same run for longer.
EcoFlow DELTA 3 Max (2048Wh)
•2,400W Output: 4,800W surge. X-Boost mode can run some higher-wattage appliances up to 3,400W, though it works by lowering voltage, so results vary by device. • Fast Recharging: 4 ways to charge, reaching 0 to 80% in 68 minutes with wall or generator charging. • Easy to Carry: About 44.8 lb (20.3 kg), 13% lighter than EcoFlow's previous 2kWh model. •10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit. •Warranty: Up to 5 years (3-year standard plus a 2-year extension when you register in the EcoFlow App).
Estimated Runtimes for Heat Tape
The EcoFlow DELTA 3 Classic fits one calculated low-wattage 120V plug-in heat tape, while the EcoFlow DELTA 3 Max suits several runs and their controllers with higher total energy needs. Here's how that plays out with example loads.
Load (example; use your label watts)
Average Watts
EcoFlow DELTA 3 Classic (870Wh usable, est.)
EcoFlow DELTA 3 Max (1,741Wh usable, est.)
One 6 ft constant-wattage tape rated 42W (example), thermostat on half the time
About 21W
About 41 hours
About 83 hours
Three runs totaling 150W (example), on half the time
About 75W
About 12 hours
About 23 hours
These are estimates using battery capacity × 0.85 ÷ average watts, and the wattages are examples, so use the watts on your own tape. Colder weather makes the thermostat run more, which shortens runtime.
Heat tape belongs on any checklist for preparing for winter power outages. With backup planned, the next step is installing heat tape safely in the first place.
How to Use Heat Tape Safely: CPSC Guidelines
The CPSC has published heat tape safety guidance for years, because faulty tapes start fires. In a 1996 release, the agency estimated that each year about 1,500 fires, 10 deaths, and 100 injuries resulted from faulty electric heat tapes. Your heat tape maker's instructions come first, and these rules cover the rest.
Follow CPSC Guidelines for Heat Tape SafetyFollow CPSC Guidelines for Heat Tape Safety
CPSC Installation Rules to Follow
If you're learning how to use heat tape, start with these CPSC rules:
  1. Plug the 3-prong plug into a 3-prong outlet so the tape is grounded, and use an outlet protected by a GFCI.
  2. Apply the tape directly to the pipe, never on top of the insulation covering it.
  3. Don't wrap heat tape over itself unless the maker's instructions allow it.
  4. Add insulation over the tape only if the maker advises it, and use non-flammable fiberglass, not foam or vinyl that could catch fire.
  5. Keep the end cap sealed and off the ground, since water getting into the cap can lead to a fire.
  6. Recheck the installation instructions whenever you switch types or brands.
If your tape has a thermostat, read where it should go. The CPSC notes that some instructions call for placing the thermostat against the pipe under the insulation, while others say to leave it hanging and uncovered. Getting that detail wrong can keep the tape from turning on when you need it, or leave it running when you don't.
Hardwired heat trace is a different job from a plug-in tape. If your system connects directly to a circuit, or you aren't sure the outlet is GFCI-protected, it's worth having a licensed electrician check it before winter.
Extra Care for Mobile Homes
Mobile homes rely on heat tape more than most houses, since their water lines often run through an unheated space under the floor. An older CPSC fire review found that over half of heat tape fires involved mobile homes and trailers. Mobile home owners weighing solar power for mobile homes should count the heat tape circuit too.
Even good heat tape wears out. That's why yearly inspection matters as much as a careful install.
How Long Does Heat Tape Last?
Heat tape doesn't last forever. Heat, UV light, and moisture slowly break down the outer jacket, so inspect it every fall.
So how long does heat tape last? No single number fits every product, since lifespan depends on the cable type, brand, and location. The honest answer to how long does heating tape last is to check the maker's stated service life and warranty for your exact product.
The CPSC does give one firm rule. It strongly urges homeowners to replace uncertified heat tapes more than 3 years old with new tapes certified to UL, CSA, or FMRC standards.
Signs It's Time to Replace Heat Tape
The CPSC advises yearly inspection and replacing any tape that shows wear. Unplug it first, then check its full length for:
  • Discolored surfaces, especially near the plug
  • Charring or melted spots
  • Cuts or breaks in the insulation
  • Bare wires
  • An end cap that's loose, cracked, or resting on the ground
A Simple Fall Inspection Routine
A yearly check doesn't take long, and it's best done on a dry fall day before the first freeze. Work through it in this order:
  1. Unplug the heat tape before you touch it.
  2. Follow the tape along the whole pipe, checking for the warning signs above.
  3. Look closely at the plug, since the CPSC calls out discoloring there in particular.
  4. Make sure the end cap is sealed and kept off the ground.
  5. Check that the thermostat sits where the instructions say it should.
  6. Press the test button on the GFCI outlet, then reset it, so you know the protection still works.
If you find any damage, replace the tape instead of patching it. In practice, the answer to how long does a heat tape last comes down to whether it keeps passing your yearly check. Heat tape inspection belongs on any plan for winterizing your home for safety each fall.
Heat tape is a simple electric cable that warms pipes in cold spots, but it only stays safe when it's certified, plugged into GFCI protection, and inspected every year. Follow the maker's instructions and CPSC guidance, and replace any tape that's damaged or uncertified and more than 3 years old. For outages, the EcoFlow DELTA 3 Classic can bridge one low-wattage run for a limited time, while the EcoFlow DELTA 3 Max fits homes with several runs to cover.
What is heat tape used for?
Heat tape helps keep water pipes, well lines, and hoses from freezing by warming them with an electric cable. You'll usually find it in crawl spaces, under mobile homes, and on exposed outdoor pipes.
How long does heat tape last?
It varies by product, so check the maker's stated life and warranty. The CPSC advises yearly inspection and replacing uncertified tapes more than 3 years old, plus any tape with charring, cuts, or bare wires.
Is heat tape safe?
Heat tape is safe when it's certified, installed according to the maker's instructions, and plugged into a GFCI-protected outlet. Damaged or worn tape is a fire risk, so check it every year.
Does heat tape work during a power outage?
No, heat tape needs electricity to make heat. A portable power station can run an already-installed plug-in heat tape for a limited time, depending on battery capacity and the actual load, but it can't guarantee your pipes won't freeze.
Can you put insulation over heat tape?
Only if the maker allows it. When insulation is approved, the CPSC advises a non-flammable type like fiberglass rather than foam or vinyl, which could catch fire if the tape fails.
Home Solutions
