Electricity Generator for Home: Types, Costs, and How to Choose
A backup generator can keep a refrigerator cold, a sump pump running, or a heating system available when utility power fails. Choosing one involves more than buying the unit with the highest wattage. A system suited to a detached house may be impractical for an apartment, while equipment intended for a brief outage may not last through a multi-day interruption.
Choosing an electricity generator for home backup starts with the appliances you need to run, their startup demand, and the fuel or charging options available at your property. This guide compares the main types of home generators, outlines typical costs, and explains how to size and operate backup power safely.
What Are the Different Types of Home Generators?
The term “home generator” covers everything from fuel-burning models to battery options such as a portable power station. Some can run as long as fuel remains available; others must be recharged from the grid or compatible solar panels. Standby units start automatically, while portable equipment generally requires manual setup.
Generator Type
Fuel / Energy Source
Typical Output Range
Best Use Case
Indoor Safe?
Conventional Portable
Gasoline, propane, or dual-fuel
3,000W – 12,000W
Short outages, job sites, budget-conscious homeowners
No (outdoor only)
Inverter Generator
Gasoline or propane
1,800W – 7,500W
Sensitive electronics, quiet suburban neighborhoods
No (outdoor only)
Home Standby
Natural gas or liquid propane
7,500W – 26,000W+
Whole-home automatic backup during multi-day outages
No (permanently outside)
Portable Power Station / Solar
Lithium battery (grid or solar charged)
1,000W – 7,200W+
Apartments, condos, zero-emission indoor or outdoor backup
Yes
Note: Output ranges are approximate market references based on representative product specifications and are not universal industry standards. Actual output varies by model, fuel type, and configuration. Always check manufacturer specifications and follow installation and operating instructions. Fuel-powered generators must be operated outdoors to prevent carbon monoxide poisoning.
Conventional Portable Generators
A conventional portable generator uses a gasoline- or propane-powered engine to drive an alternator. Many models deliver approximately 3,000W to 12,000W, providing enough power for a refrigerator, sump pump, lights, and selected household equipment when properly sized. These generators are commonly used for temporary backup power and can run for extended periods with adequate fuel, subject to the model’s fuel capacity, load, and maintenance requirements.
The trade-offs include noise and routine maintenance. Many conventional portable generators produce approximately 70–80 dBA, depending on the model and operating load. They also require fuel storage and periodic maintenance, including oil changes and inspections or servicing of the spark plug and air filter. Some models may also require carburetor maintenance. Because their exhaust contains carbon monoxide (CO), portable fuel-powered generators must be operated outdoors, at least 20 feet from the home, with exhaust directed away from doors, windows, and vents. Never operate one in a garage or another enclosed or partially enclosed area.
Inverter Generators
An inverter generator also burns gasoline or propane, but it converts the alternator’s output into stable, pure sine wave electricity suitable for laptops, smart appliances, and other sensitive electronics. Its engine can adjust speed as demand changes, which generally lowers fuel consumption and noise at lighter loads.
Many models operate in the 50–60 dB range and are smaller than conventional open-frame units. They usually cost more per watt, however, and a compact model may not support several motor-driven appliances at once. They still produce carbon monoxide and are not safe to operate indoors or in a garage.
Home Standby Generators
A home standby generator is installed permanently outside and connected to natural gas or liquid propane. When utility service fails, an automatic transfer switch isolates the house from the grid, starts the generator, and supplies the circuits included in the installation. Depending on its capacity, the system may support central air conditioning, heating, refrigeration, lighting, and other major loads.
Automatic operation is useful when a property is vacant, or no one can set up portable equipment. Installation may require permits, gas-line work, an equipment pad, and electrical changes, followed by routine service and testing. For that reason, the generator’s retail price represents only part of the project cost.
Portable Power Stations and Solar Generators
Portable power stations store electricity in rechargeable batteries rather than generating it with a combustion engine. They can be charged from a wall outlet or compatible solar panels, run quietly, and produce no exhaust while supplying power. This makes them useful for apartments, condos, and homes where storing fuel or placing an engine generator outdoors is impractical.
Appliances can usually plug directly into the station, and there is no engine oil or stored gasoline to manage. The limitation is finite battery capacity: a high-wattage appliance can use the available energy much faster than lights, phones, or a router.
For example, the EcoFlow DELTA 3 Max Portable Power Station provides 2,048Wh of battery capacity and 2,400W AC output. It can power essentials such as a refrigerator, Wi-Fi router, and lights, with actual runtime determined by how the system is used. Its portable design is especially convenient for apartments, condos, and homes where a fuel-powered generator would be difficult to operate.
EcoFlow DELTA 3 Max Portable Power Station (2048Wh)
1. 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws. 2. 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. 3. Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product.
How Much Does a Home Generator Cost?
The purchase price is only one part of a generator budget. When comparing electric generators for homes, include the cost of any equipment needed to connect or recharge the system. Installation, electrical connection equipment, fuel or charging, and maintenance all affect the long-term cost. A portable unit may be inexpensive to buy but require regular fuel and engine service; a standby system costs more upfront but operates automatically.
Upfront Costs by Generator Type
Equipment prices vary with output, battery capacity, enclosure design, controls, and included accessories. The following ranges are useful for early budgeting rather than as fixed quotes:
  • Conventional Portable Generators: $500 to $2,500 for models ranging from 3,500W to 10,000W.
  • Inverter Generators: $900 to $4,000, reflecting quieter enclosures and pure sine wave inverter boards.
  • Portable Power Stations & Solar Kits: $1,000 to $4,500+ depending on battery capacity, measured in watt-hours, and whether portable solar panels are included.
  • Home Standby Generators: $3,000 to $12,000 for the generator and automatic transfer switch before installation labor. For a standby project, confirm whether the quote includes the transfer switch, permits, site preparation, and connection to the existing fuel system.
For battery equipment, compare storage capacity as well as inverter output. Understanding how portable power stations work makes it easier to compare stored energy and output across similarly priced units.
Installation and Additional Equipment Costs
A portable gas generator or battery station needs little installation when appliances plug directly into it, although cords must suit the load and location. Heavy-duty outdoor extension cords commonly cost around $50 to $150, depending on gauge and length.
Hardwired equipment is different. A furnace blower, well pump, or ceiling-light circuit may require a manual transfer switch or panel interlock kit installed by a licensed electrician, typically adding roughly $500 to $1,500. The equipment must prevent generator power from feeding into utility lines and must match the home’s electrical panel.
Standby installations involve the most site work. A concrete pad, trenched gas line, gas-meter changes, permits, and automatic-transfer-switch wiring can add several thousand dollars, potentially around $3,000 to $7,000, to the project total. Difficult access or substantial electrical work can raise the final quote.
Fuel, Maintenance, and Operating Costs
Operating cost varies with generator size, connected load, local fuel prices, and the length of the outage. A traditional 7,500W gasoline generator running at half load may burn approximately 0.5 to 0.75 gallons per hour. Over a 24-hour outage, that equals roughly 12 to 18 gallons of gasoline, or about $40 to $65 per day at typical U.S. pump prices.
Fuel must be secured before a storm because local stations may lose power or run short during a widespread outage. Gasoline belongs in approved containers away from ignition sources and living areas. Propane avoids some gasoline-storage concerns but still has to be available when the outage begins.
Fuel-burning units may require oil changes every 50 to 100 operating hours, along with fresh spark plugs, air filters, and annual fuel-stabilizer treatment. Periodic testing matters because a generator left untouched for years may not start when you need it.
Battery-powered systems avoid engine tune-ups and direct fuel purchases. At an electricity rate of roughly $0.17 per kWh, recharging a 2kWh battery from a standard U.S. residential outlet costs less than $0.40 for a full charge. Compatible solar panels can recharge without adding utility energy use, although the time required depends on the available sunlight and the system’s solar input.
EcoFlow DELTA 3 Max Portable Power Station (2048Wh)EcoFlow DELTA 3 Max Portable Power Station (2048Wh)
How Do You Choose the Right Home Generator?
Start with the loads that matter during an outage. Refrigeration, internet access, and a few lights require a different system from a household that also depends on a sump pump, well pump, or heating controls
Calculate Your Home's Power Requirements
Make a written list of the appliances and devices that must operate when the grid is down. Record the running watts for each one, then note any starting or surge demand. Motors and compressors can briefly draw much more electricity when they start than they use once they reach normal speed.
Knowing how to size a generator for your house starts with the loads that need to run together. Check your specific refrigerator’s running and starting power. Add the running watts of everything that may be on together, then allow for the extra watts drawn during startup. If more than one load may start at once, account for their combined demand.
Staggering loads can make a smaller system practical. A household might let the refrigerator complete a cooling cycle before starting another high-draw appliance rather than operating both at once.
For battery systems, watts describe how much power the inverter can deliver at once, while watt-hours indicate stored energy. A station may start an appliance successfully yet lack enough capacity to run it for the desired time.
Choose the Right Fuel or Charging Source
The best energy source is the one you can store, obtain, and use safely at your property:
  • Gasoline: It is widely available and works with many portable generators, but it requires careful storage and may be difficult to buy during a widespread outage.
  • Propane: It can be stored for long periods without degrading, which makes it practical for equipment used only occasionally.
  • Natural Gas: A utility connection can provide continuous fuel without manual refilling, although supply interruptions remain possible.
  • Grid + Solar Charging: A solar generator can recharge from a wall outlet before an outage and from compatible solar panels when sunlight and system limits allow.
Property conditions may narrow the choice. An apartment resident usually has no safe place to operate an engine generator, while a rural home may already have a large propane tank. Solar charging can extend battery use, but panel placement and seasonal sunlight affect how much energy is actually recovered each day.
Consider Outage Duration and Backup Reliability
A brief interruption and a multi-day outage place different demands on backup equipment. Longer events require a larger energy reserve or a dependable way to replenish it.
If you’re researching how to make an electric generator to power your home, first decide whether you need to run individual appliances or supply hardwired circuits. Have a licensed electrician evaluate any connection to your home’s wiring.
Expandable battery systems allow storage to grow without replacing the original unit. The EcoFlow DELTA 3800 Gen4 Portable Power Station offers a 3,763Wh base capacity, expandable to around 12kWh, with up to 2,000W of solar input. Additional batteries can keep essential appliances operating longer, while solar charging can replenish stored energy during an extended outage. Actual runtime depends on appliance consumption and the sunlight available.
1. Longest Runtime: Powers a refrigerator for up to 70 hours — 17 hours (32.6%) longer than the industry average for 3-4kWh portable power stations. 2. Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power . 3. Compact Yet Powerful: The smallest and lightest portable power station in its class with 3-4kWh capacity and 3,600W output.
Consider who will move the generator, connect the cords, start the engine, or monitor the battery. If no one is home, a manually operated system cannot protect the same loads as an automatic standby generator.
Consider Noise Levels and Installation Requirements
Local ordinances and HOA rules may restrict generator placement or operating hours. Conventional engine generators can be disruptive where houses are close together, while inverter models are generally quieter. Battery stations make little noise beyond their cooling fans.
Fuel-powered portable generators need open outdoor space away from doors, windows, and air intakes. Standby units require a permanent location with the proper clearances and service access. Where outdoor space is limited, an indoor-safe battery station may be more practical.
Before purchasing equipment intended to supply household circuits, discuss the connection with a qualified electrician. The panel configuration, circuit selection, generator inlet, transfer equipment, and available generator output must work together.
EcoFlow DELTA 3800 Gen4 Portable Power StationEcoFlow DELTA 3800 Gen4 Portable Power Station
How Can You Use a Home Generator Safely During a Power Outage?
Most generator hazards involve exhaust, improper electrical connections, fuel, or water. Plan the setup before an outage, when there is time to read the manual and test the equipment.
Operate Fuel-Powered Generators Outdoors
Never operate a gasoline, diesel, or propane generator in a garage, basement, carport, enclosed porch, or shed. Opening a garage door does not provide enough protection.
Carbon monoxide is colorless and odorless, and dangerous concentrations can build before anyone realizes there is a problem.
Place a portable fuel-powered generator at least 20 feet from the home, with its exhaust directed away from doors, windows, and vents of the home and other buildings.
Recheck the area during use in case someone opens a nearby window.
Permanently installed standby generators follow different manufacturer and NFPA 37 clearance requirements. Typical installations require at least 5 feet from windows or vents and between 18 inches and 5 feet from exterior walls, depending on the equipment’s fire-rating certifications. The approved installation instructions and local requirements determine the correct placement for a particular unit.
Connect Your Generator to Your Home Properly
Never plug a generator into an ordinary wall outlet. This practice, known as backfeeding, can send electricity through household wiring and onto utility lines. It creates a potentially fatal electrocution risk for lineworkers and can damage the generator when grid service returns.
For direct appliance use, choose heavy-duty, outdoor-rated 12-gauge or 10-gauge extension cords suited to the load and distance. Inspect the cords and keep all connections out of standing water.
Hardwired circuits require properly installed transfer equipment. A transfer switch or approved interlock keeps the generator and utility supply from energizing the panel at the same time. Have a licensed electrician install the inlet and switching equipment.
Follow Electrical and Carbon Monoxide Safety Guidelines
Keep a fuel-powered generator dry without enclosing it. An open-sided generator canopy or tent designed for ventilation can protect the unit from rain while allowing exhaust and heat to escape. Never operate electrical equipment with wet hands or allow plugs and receptacles to sit in pooled water.
Install battery-backed carbon monoxide detectors on every level and outside sleeping areas. If an alarm sounds, move everyone into fresh air and contact emergency services rather than searching for the source.
Add fuel only after the generator is off and the engine has cooled completely. Store fuel in approved containers and follow the manufacturer’s instructions for refueling and shutdown. Battery stations produce no combustion exhaust while operating, but they still need dry surroundings and clear ventilation openings.
Before storm season, charge the battery and test the appliances you expect it to run.
The best electricity generator for home backup depends on what must remain powered, how long local outages usually last, and which fuel or charging sources are practical at the property. A conventional portable generator offers substantial output at a relatively accessible price. An inverter generator adds quieter operation and stable power for sensitive electronics, while a permanently installed standby system automatically supports selected household circuits. Battery power stations are useful where indoor operation, low noise, and simple setup matter most.
Whichever option you choose, size it from actual running and startup loads. Include installation, fuel, maintenance, and recharging in the budget, and decide how the equipment will connect before an outage. Proper placement and transfer equipment are central to using backup power safely.
What Is the 80% Rule for Generators?
The 80% rule recommends running a generator at no more than 80% of its maximum rated continuous wattage during extended use. Operating near 100% capacity for hours at a time overheats alternator windings, accelerates engine wear, and leaves zero headroom for sudden motor surges when a refrigerator or sump pump cycles on. Leaving a 20% buffer ensures stable voltage and extends the lifespan of your equipment.
What Should You Not Plug into a Generator?
Avoid plugging high-draw resistive heating appliances—such as electric space heaters, hair dryers, central electric furnaces, and electric water heaters—into standard portable generators, as they can instantly overload the circuit. You should also avoid connecting high-end desktop computers to conventional open-frame generators unless you use a pure sine wave inverter generator or battery power station to prevent voltage-spike damage.
What Is the Lifespan of a Home Generator?
A well-maintained air-cooled home standby generator typically lasts 15 to 20 years (or roughly 2,000 to 3,000 operating hours), while larger liquid-cooled models can run well beyond 5,000 to 10,000 hours. Portable gas and inverter generators generally average 500 to 1,500 operating hours depending on engine build quality and regular oil and filter changes. Modern LiFePO4 (lithium iron phosphate) portable power stations generally deliver 3,000 to 4,000 full charge cycles before dropping to 80% of their original battery capacity, translating to roughly 10 years of regular use.
Is It Illegal to Run a Generator All Night?
Running a generator overnight is not illegal under federal law, though many U.S. cities, counties, and HOAs enforce quiet-hour noise ordinances—often capping sound at 50 to 60 decibels between 10:00 PM and 7:00 AM. While emergency storm exemptions sometimes apply, running a loud 75-decibel open-frame generator all night can still trigger neighbor complaints or fines, making quieter inverter models or silent battery stations much better choices for overnight power.
Can I Run a Refrigerator on a 2000 Watt Generator?
Yes, a 2,000-watt generator can easily run a standard household refrigerator, which typically uses 150W to 250W while running and spikes to around 800W to 1,200W when the compressor kicks on. That leaves roughly 800W to 1,000W of spare capacity to simultaneously power a Wi-Fi router, LED lamps, and phone chargers, provided you avoid plugging in high-wattage kitchen appliances like a microwave or coffee maker at the same time.
Solar Generators
