Electric Boiler vs Gas Boiler: Running Costs, Efficiency, Upkeep, and Outage Needs for U.S. Homes
- How Electric and Gas Boilers Make Heat
- Running Costs: What Federal Energy Prices Show
- Power Needs in an Outage: EcoFlow TITAN 5000 Classic for Gas Boiler Controls, EcoFlow TITAN 5000 for Small Electric Boilers
- Installation Needs: Electrical Service, Gas Lines, and Venting
- Maintenance, Safety, and Emissions
- Which Boiler Fits Your Home?
- Conclusion
- FAQs
Boilers heat water and send it through radiators, baseboards, or floor tubing. They can run on gas or electricity. Picking between the two isn't only about the price tag. In the U.S., heat made from electricity usually costs a lot more than the same heat from natural gas. But gas boilers bring venting, combustion, and carbon monoxide to manage. This guide uses federal price data and efficiency rules to weigh electric boiler vs gas boiler costs, upkeep, and emissions. It also covers what each one needs in a power outage.
Both types heat water and pump it to your rooms. A gas boiler burns fuel and vents the exhaust. An electric boiler runs current through heating elements. That one difference drives most of the trade-offs in the electric vs gas boiler debate.
An electric boiler turns nearly all its electricity into heat inside your home. But power plants lose a good share of the fuel's energy, which is one reason electric heat often costs more. Gas boilers are rated by AFUE, short for annual fuel utilization efficiency. In plain words, it's the share of fuel energy that becomes heat over a typical season.
Federal Efficiency Rules and ENERGY STAR
Gas boilers must meet federal boiler efficiency standards. Here are the minimums for residential boilers made on or after January 15, 2021:
Boiler type | Federal minimum AFUE | Design rule |
Gas-fired hot water | 84% | No constant-burning pilot; automatic water temperature adjustment (except with tankless domestic coils) |
Gas-fired steam | 82% | No constant-burning pilot |
Electric hot water | None set | Automatic water temperature adjustment (same exception) |
Electric steam | None set | None |
ENERGY STAR certified gas boilers go further, at 90% AFUE or more. That's about 6% above the federal standard, under a spec from January 2024. Still, "nearly 100% at the point of use" and "90% AFUE" measure different things. Efficiency alone won't settle cost.
Are Boilers Gas or Electric?
Are boilers gas or electric? Both, and some burn heating oil, with federal minimums of 86% AFUE for oil hot water models and 85% for steam. Reading up on natural gas pros and cons helps if your street has a gas main but your home isn't hooked up.
Not sure which kind you have? Look without tools or removing covers. A gas pipe and vent pipe point to gas, and the rating plate lists the fuel, plus kW and voltage on electric models.
Efficiency ratings explain how much heat each fuel delivers. Energy prices decide what that heat actually costs you.
The fairest way to compare a gas or electric boiler is the cost of each unit of heat that reaches your rooms. That takes the fuel price, its heat content, and the boiler's efficiency.
Cost per Million Btu Delivered
U.S. homes paid an average of 17.3 cents per kWh in 2025, with 18.2 cents expected in 2026, per EIA's October energy outlook. Natural gas averaged $15.34 per thousand cubic feet (Mcf) in 2025, per EIA residential natural gas prices. One kWh holds 3,412 Btu, and one cubic foot of gas holds about 1,036 Btu. Here's the math for one million Btu (2025 national averages, example only):
Step | Electric boiler | Gas boiler |
Energy for 1 million Btu | 1,000,000 ÷ 3,412 = 293.1 kWh | 1,000,000 ÷ 1,036,000 Btu per Mcf = 0.965 Mcf |
Price (EIA 2025 average) | 17.3¢/kWh | $15.34/Mcf |
Fuel cost per 1 million Btu | 293.1 × $0.173 = about $50.70 | 0.965 × $15.34 = about $14.81 |
Adjust for efficiency | Point-of-use conversion treated as 100% | ÷ 0.84 (federal minimum) = about $17.63; ÷ 0.90 (ENERGY STAR) = about $16.45 |
Delivered heat cost | About $50.70 | About $16.45 to $17.63 |
What Changes Your Result
At these averages, heat from an electric boiler costs roughly three times as much as from a gas boiler. Your rates, fixed charges, and time-of-use pricing can shift that. So can real-world efficiency and how well your home holds heat. Rerun the table with your own bills.
Whatever the fuel, the cheapest heat is the heat you don't lose. Sealing drafts and setting back the thermostat are easy steps toward cutting winter heating costs.
Price isn't the only number that matters. Each boiler's electrical load is very different, especially in an outage.
Most modern boilers need electricity during a power outage. A gas boiler typically needs a small 120V supply for its controls and pump. The 240V electric boiler examples below need much more power for their heating elements; some smaller electric models use 120V. Planning starts with the boiler's nameplate.
Gas Boiler Power Needs
For example, the Utica Oneida condensing gas boiler runs on 120V, 60 Hz through a factory cord and plug. A Taco 007e circulator uses 44W at most. Those loads are small, but the boiler can't run without them.
Electric Boiler Power Needs
Electro Industries offers 240V single-phase boilers from 5kW to 36kW across its lines. Its EMB-M2-15-240-1 Mini-Boiler uses two breakers (60A and 45A), according to the current BI311 installation manual. That model delivers 15kW at 240V or 11.3kW at 208V—about 25% less. In amps (watts ÷ volts), the following illustrative ratings look like this, though your nameplate rules:
Electric boiler rating | Approximate amps at 240V |
5kW | 20.8A |
7kW | 29.2A |
15kW | 62.5A |
20kW | 83.3A |
Labeled Runtime Estimates
Two labeled estimates show the gap. They're examples, not promises, and assume 85% of stored energy reaches the load.
Gas boiler electronics: Say the controls, ignition, and circulator total 250W. That's an assumed figure, so use your nameplate. One 5,017.6Wh EcoFlow TITAN 5000 Classic unit runs them about 17 hours (5,017.6 × 0.85 ÷ 250), but only while gas service continues.
Small electric boiler: A 5kW boiler with all elements on drains one EcoFlow TITAN 5000 unit in about 51 minutes (5,017.6 × 0.85 ÷ 5,000). At 30kWh, it runs about 5.1 hours.
Real runtime varies. Elements cycle with the weather, your thermostat, and the house. Boilers above about 7kW also exceed the EcoFlow TITAN 5000's 7,200W rating.
Matching EcoFlow TITAN to Your Boiler
So the two boiler types need very different backup plans. EcoFlow TITAN home batteries come in a 120V model and a 120V/240V model. Each feeds selected circuits through an EcoFlow Smart Home Panel 10, which a licensed electrician installs. Match the model to your boiler's nameplate first.
The 240V electric boiler examples above are a bigger job. Their elements need many kilowatts, so backup must provide compatible 240V output. An electrician should compare the boiler's kW rating to the system's output and stored energy.
In short, the EcoFlow TITAN 5000 Classic covers a gas boiler's 120V controls and pump. The EcoFlow TITAN 5000 fits only a 240V boiler circuit within its 7,200W output, once an electrician checks the runtime. Knowing how split-phase power works shows why each boiler type needs a different battery.
Those electrical demands also shape installation. They decide breaker size and whether your service can carry the load.
Electric boilers lean on the electrical panel and service. Gas boilers need a gas line, combustion air, and a vent. Either way, you'll need a licensed pro and usually a permit.
Electric Boiler Installation
The 240V electric models discussed above need a large circuit, sometimes two breakers. Their roughly 25% output drop on 208V matters in some apartments and condos wired that way. Have an electrician check your panel and service size before you choose a model.
Gas Boiler Installation
A gas boiler needs gas piping, venting, and combustion air. A licensed plumber or gas technician installs them to code. The Utica condensing boiler, for one, is certified only for Category IV or direct vent use. Permits vary by city and county, so check with your building department.
Switching Fuels
Switching fuels adds work, too. Gas to electric often means a new 240V circuit, while electric to gas means a gas line and vent if the home has neither.
After installation, the two types split again. Upkeep and emissions differ a lot.
A gas boiler needs yearly attention because it burns fuel indoors. An electric boiler has no flame or flue, but its emissions depend on how your local power is made.
Carbon Monoxide Safety and Upkeep
The CDC says a qualified technician should service your heating system, water heater, and other fuel-burning appliances every year. Its carbon monoxide safety guidance also calls for battery-operated or battery back-up CO detectors near every sleeping area. Check the batteries when you change your clocks.
An electric boiler has no flue and makes no combustion CO. Keep CO alarms if your home has any fuel-burning appliance or an attached garage. With gas heat, monitoring carbon monoxide levels indoors protects everyone. Electric upkeep follows the maker's manual. Leave electrical work to a licensed electrician.
Emissions and Your Local Grid
A gas boiler's emissions come from burning gas at your home. An electric boiler's depend on your local grid. Where fossil fuels make most of the power, losses at the plant add to its footprint.
With costs, installation, and safety covered, the choice comes down to your own home. A few facts usually decide it.
There's no single winner in the gas vs electric boiler question. The right pick depends on what's already at your house and what energy costs where you live. Use this checklist with your own bills.
Your situation | Leans toward | Why (from this article) |
Gas service at the street or already in the home | Gas boiler | Lower delivered heat cost at 2025 national averages |
No gas service, small space, or limited venting options | Electric boiler | No gas line, flue, or combustion air needed |
Limited electrical panel or service capacity | Gas boiler, or an electrician's service review first | Electric models draw roughly 21A to 150A at 240V |
Priority on no on-site combustion | Electric boiler | No flame or flue; grid mix sets emissions |
Outage backup planned | Either, sized separately | Gas boiler controls and pumps typically need small 120V backup; the 240V electric examples need much more backup power |
Whether you lean toward an electric or gas boiler, get two quotes and run the cost table with your local rates. Heat pumps are worth comparing too.
In the gas boiler vs electric boiler matchup, gas usually costs less to run. At 2025 averages, it's about $16 to $18 per million Btu delivered, versus about $51 for electric. Gas needs venting, yearly service, and CO alarms, while the 240V electric models discussed here need larger circuits. Check local rates and have a licensed pro inspect your service. For outages, the EcoFlow TITAN 5000 Classic suits gas boiler controls. The EcoFlow TITAN 5000 may fit a small 240V electric boiler, and each wires to an EcoFlow Smart Home Panel 10.
Is an electric boiler cheaper to run than a gas boiler?
Usually not. At 2025 U.S. average prices from EIA, a million Btu of delivered heat cost about $50.70 from electricity. From gas, it cost about $16.45 to $17.63. If you're weighing an electric boiler vs gas on cost, your local rates can change that gap.
Are electric boilers more efficient than gas boilers?
At the point of use, yes. Electric boilers turn nearly all their electricity into heat. New gas hot water boilers must reach 84% AFUE. But the cost of electric boilers vs gas boilers comes down to local fuel prices.
Does a gas boiler work during a power outage?
Often not. Many need 120V power for controls, ignition, and the circulator, so check your manual. A 120V backup sized to the boiler's nameplate can keep those parts running. That works only while gas service continues.
How many amps does an electric boiler draw?
It depends on the kW rating. At 240V, a 5kW model draws about 20.8 amps and a 15kW model about 62.5 amps. Some larger units use two breakers, so the gas boiler vs electric choice can hinge on your panel.
Do electric boilers need a chimney or vent?
No. They don't burn fuel, so there are no combustion gases to vent. Gas boilers need venting and combustion air installed to code.
