What Size Generator Do I Need for My Home and Power Needs?
Choosing the right generator size takes more than picking the largest model on the shelf. Undersize it and you may not have enough power when you need it; oversize it and you're paying for unused capacity. So what size generator do I need? It depends on the appliances you plan to run, their startup and running wattage, and whether you're powering essentials or the whole home.
Whether you're sizing for camping, storm season, or home backup, this guide covers the key factors. For essential home, camping, and RV power needs, the EcoFlow DELTA 3 Plus Portable Power Station is one option worth considering, while larger backup needs may call for a higher-capacity system.
Understanding Generator Size and Wattage
Two things matter before shopping: output capacity and startup power. Miss either and you'll probably land the wrong unit.
What Does Generator Size Mean?
Generator size, in plain terms, means electrical output measured in watts (W) or kilowatts (kW). A kilowatt is just 1,000 watts.
A higher watt rating means you can run more devices at once. But grabbing the biggest generator on the lot isn't automatically smart. Figure out what you'll actually use during an outage, then pick something with enough output to cover it safely.
Running Watts vs. Starting Watts
Appliances usually pull power in two different ways.
  • Running watts is the steady draw while operating.
  • Starting watts is that extra jolt a motor needs the instant it fires up.
Refrigerators, pumps, air conditioners, that kind of motor-driven gear can gulp far more at startup than once settled. Briggs & Stratton says starting demand can run two to three times normal wattage, depending on the appliance.
Appliance
Example Running Watts
Example Starting Watts
Refrigerator
200W
600W
Lights
100W
Wi-Fi router
20W
Laptop
60W
Small pump
800W
1,500W+
Take these as ballpark numbers. Check the actual label before trusting any of it, since what watt generator do I need genuinely depends on what's sitting in your house.
Skip the startup wattage and you're setting yourself up to undersize the whole thing.
How to Calculate What Size Generator You Need
If you're thinking, I need a generator what size do I need? Start by listing the appliances you expect to power and checking their wattage.
Step 1: Make a List of Appliances You Need to Power
Start small. Don't assume every appliance has to keep running just because the power's out. A decent starting list:
  • Refrigerator
  • Essential lights
  • Wi-Fi router
  • Phone chargers
  • Laptop
  • Furnace controls or blower
  • Sump pump
  • Medical equipment
Separate the must-haves from the nice-to-haves, and your capacity needs drop fast.
Step 2: Add Up Running Watts and Starting Watts
For anyone asking how many watts generator do I need, add your running loads together and then account for the highest startup surge. Time for some quick math. Say you're running a refrigerator at 200W with a 600W startup, lights at 100W, a router at 20W, and a laptop at 60W.
Running loads add up like this: 200 plus 100 plus 20 plus 60 lands you at 380W.
Now factor in the surge. That fridge compressor needs 600W just to kick on, so whatever's powering everything has to absorb that spike too.
Throw in a couple more pumps or motors and this math gets messier fast. Manufacturers want you to account for both running and starting numbers, not just guess.
Step 3: Choose a Generator With Enough Capacity Headroom
Don't go buying something that just squeaks by your max on paper. Room to breathe helps avoid overloads, absorb a surprise load, and ride out startup spikes without tripping.
What Size Generator Do I Need for Different Situations?
Where and how you're using it changes things quite a bit.
What Size Generator Do I Need for Basic Home Backup?
If your main question is what size generator do I need for my house, first decide whether you only want to cover essentials or support larger household loads. A short outage usually needs 1,000 to 2,000W to cover: refrigerator, lights, router, phones, laptop, small electronics.
The EcoFlow DELTA 3 Plus Portable Power Station brings 1,024Wh capacity and 1,800W AC output, which handles most essentials for home, camping, or RV use.
1,024Wh capacity and 1,800W AC output. Suitable for essential home backup, camping, RV use, and everyday electronics.
What Size Generator Do I Need for a Whole House?
Whole house backup is a different beast. Now HVAC, refrigerators, pumps, lighting, and kitchen appliances all fight for the same power at once.
Most homes end up needing 5,000 to 10,000W or more, depending on load, not the square footage on the listing.
For bigger battery backup, the EcoFlow DELTA Pro Ultra pushes 7,200W continuous AC power with a 6,144Wh battery, expandable as needs grow.
6,144Wh battery capacity with 7,200W continuous AC output. Expandable for larger home backup needs and higher-demand appliances.
What Size Generator Do I Need for Camping and RV?
RV owners and campers typically fall in the 1,000 to 3,000W range, depending on fridges, coffee makers, lights, laptops, and RV electronics.
Portable power stations shine here. They're quiet, easy to haul around, and there are no gas cans to lug.
If renewable charging is important, compare portable power stations vs. solar generators or explore EcoFlow solar generators.
Generator Size Chart for Common Power Needs
Usage Scenario
Approximate Output Range
Phones, router, lights
500-1,000W
Essential home electronics
1,000-2,000W
Camping or RV equipment
1,000-3,000W
Several household essentials
3,000-5,000W
Larger home backup loads
5,000-10,000W+
Extensive whole-home backup
10,000W+
Common Mistakes When Choosing a Generator Size
  • Going too small is the most common mistake, leading straight to overloads that can't handle a startup surge.
  • Buying way more than you need just means a bigger price tag, more fuel burned, and a heavier machine to drag around.
  • People also forget runtime matters as much as wattage, so think about how long backup power actually needs to run.
  • Fuel setups need an eye on supply, storage, refueling, and upkeep.
  • Battery folks should think about capacity, real-world usage, and whether the system expands later.
Generator vs. Portable Power Station: Which One Should You Choose?
Feature
Fuel Generator
Energy source
Gasoline, propane, or other fuel
Stored electricity
Noise
Engine noise
Generally quieter
Fuel storage
Required
Not required
Exhaust
Produced during operation
No combustion exhaust at point of use
Maintenance
Engine and fuel maintenance
Lower routine maintenance
Runtime
Can continue with available fuel
Depends on battery and recharging
Indoor operation
Must remain outdoors
Can support indoor use when directed
Fuel generators still hold their own when long runtime and easy fuel access matter. Portable power stations tend to win over people who'd rather have a quiet, simple setup, and something flexible enough to move between the house, RV, or campsite.
Final Checklist Before Choosing a Generator Size
  • Calculate running watts for your essential appliances
  • Check starting wattage for refrigerators, pumps, HVAC, and other motor-driven gear
  • Decide which appliances genuinely need emergency power
  • Estimate how long backup actually needs to last
  • Leave yourself reasonable headroom
  • Think through fuel availability or battery capacity
  • Weigh portability, noise, charging, storage, and maintenance
At the end of the day, generator size comes down to what you want powered, how many running watts that takes, and what those appliances need to fire up. Nail your essential loads down first, then leave a little extra room for reliable operation.
Running the numbers once, even scribbled on paper like a rough generator sizing calculator, beats guessing wrong later. If quieter operation and skipping fuel storage sound appealing, a portable power station is worth a look too. Ready to simplify your backup power setup? Explore the EcoFlow DELTA 3 Plus Portable Power Station and see if it fits your power needs.
What size generator do I need to run a refrigerator?
Something that covers the running watts plus the startup surge the compressor throws when it kicks on.
Is a 3000 watt generator enough for a house?
It covers several essentials fine, but don't expect it to run a whole home or a big HVAC system.
What size generator do I need for a 2,000 square foot house?
Square footage alone won't tell you. Add up the wattage of whatever you actually want backed up.
How do I calculate generator size?
Add your running watts, factor in the startup numbers, and leave a little room on top. Once you know how many watts of a generator you need for your own place, shopping gets a lot easier.
Tips
