Bluetti Elite 300: Specs, Price, and How It Actually Compares
The Bluetti Elite 300 is built around one idea: shrink a 3kWh power station down as small as it'll go. Bluetti markets it as the smallest 3kWh-class unit by volume, and that compact footprint comes with real tradeoffs on output and expandability. This guide covers the Elite 300's full specs and pricing, whether it actually supports an expansion battery, what reviewers have to say, and how it stacks up against the EcoFlow DELTA 3 Ultra for anyone deciding between the two.
Bluetti Elite 300 Specs and Dimensions
Before getting into how the Elite 300 stacks up against anything else, it helps to know exactly what's under the hood. Here's the full spec sheet.
Spec
Bluetti Elite 300
3,014Wh, LiFePO4
AC output
2,400W continuous
Surge output
~4,800W
Solar input
Up to 400W
Alternator input
Up to 800W
Combined charging
1,200W (solar plus alternator)
Cycle life
6,000 cycles
UPS switchover
Under 10ms
Footprint
About 19% smaller than a typical 3kWh-class unit
Price
~$1,199 (frequently discounted from a higher MSRP)
A few numbers worth pulling out on their own:
  • The compact footprint is really the whole point of this unit. Bluetti calls it the smallest 3kWh-class power station by volume, and it ships with a native TT-30 RV outlet, which is exactly why it's become a common pick for RV owners specifically.
  • A rated 6,000-cycle life is high for this capacity class, and it translates to a lower cost per lifetime kWh than a lot of the competition. That's worth weighing against the upfront price. The same kind of tradeoff power station spec basics usually come down to once you look past the sticker.
  • Combined solar-plus-alternator charging tops out at 1,200W, which lands lower than several competitors in this same capacity range that support higher single-source solar input.
  • The under-10ms UPS switchover means it can step fast enough to keep sensitive electronics, like a desktop computer or a home security system, from rebooting during a brief outage.
A quiet grid isn't something anyone should take for granted these days. Weather-driven outages in the US have been trending in a bad direction, and 2024 was the worst year for storm-related outage hours the country had seen in a decade, according to the Energy Information Administration. That's exactly the kind of backdrop that makes a compact, dependable unit like the Elite 300 worth having around the house, not just in the truck bed on a camping trip.
One spec question comes up more than any other for this model, and it deserves a straight answer before going further.
Does the Bluetti Elite 300 Have an Expansion Battery?
No, it doesn't. The Elite 300 is a fixed-capacity unit, and there's no officially supported expansion battery for it. That puts it in a different lane than several other Bluetti models, including the AC300 and the Apex series, which do pair with add-on battery modules.
That's a real design tradeoff, not an oversight. Buyers get a genuinely smaller footprint in exchange for a hard ceiling on total capacity. If you're the kind of buyer who likes the idea of chaining two power stations together as your needs grow, the Elite 300 isn't built for that path. What you buy is what you get, permanently.
Anyone who thinks they might need more than 3,014Wh down the road should factor that in now. Don't assume capacity can be bolted on later the way it can with other Bluetti or EcoFlow lines, because with this one, it can't.
You'll come across enthusiast forums with DIY workarounds claiming to add capacity to the Elite 300. Treat those the same way you'd treat any unsupported modification: interesting to read about, but not something to plan a purchase around. If your household's power needs might grow, whether that's a bigger RV, a home office setup, or just wanting more backup runtime during hurricane season, a unit built for expansion from the start is the safer bet.
With the specs and that expansion ceiling both out of the way, it's worth seeing how the Elite 300 actually stacks up against a similarly sized alternative most shoppers are also looking at.
Bluetti Elite 300 vs EcoFlow DELTA 3 Ultra
These two store almost identical energy on paper, but that's about where the similarities end. Here's the full head-to-head.
Spec
Bluetti Elite 300
3,014Wh
3,072Wh
AC output
2,400W
3,600W
Surge output
~4,800W
7,200W
Solar input
400W (1,200W combined with alternator)
Up to 800W
AC charge speed
Not consistently published
0-80% in about 89 minutes
Cycle life
6,000
Not officially published (10-year rated lifespan)
Expansion battery
Not supported
Not supported on this base model (fixed at 3,072Wh)
Not consistently published, verify before you buy
Up to 5 years
Price
~$1,199
~$1,399 for the base unit
A few things worth calling out:
  • DELTA 3 Ultra delivers 50% more continuous output and a much higher surge rating, which matters a lot once you start thinking about which appliances it can run at the same time rather than just how much energy it stores.
  • The Elite 300 leads on cycle life and price, and its compact size is a genuine advantage if portability matters more to you than output headroom.
  • Solar input is a real gap worth knowing about. DELTA 3 Ultra accepts up to 800W versus the Elite 300's 400W, which matters if you're trying to recharge faster from a bigger panel setup during an extended outage.
  • Charging speed is another gap worth knowing about. DELTA 3 Ultra publishes a clear 0-80% fast-charge time, while Bluetti hasn't consistently published the same figure for the Elite 300, which makes it harder to plan around if quick recharges between trips matter to you.
Bluetti Elite 300 vs EcoFlow DELTA 3 UltraBluetti Elite 300 vs EcoFlow DELTA 3 Ultra
Put simply, this comparison usually comes down to whether you're buying for right now or buying for what your setup might look like in a couple years. A weekend camper who just needs to run a mini fridge and charge some devices probably won't miss what the Elite 300 leaves on the table. A homeowner who wants more output headroom and a faster recharge for storm season will likely lean toward the DELTA 3 Ultra instead.
• 3600W Powerful Output: 7200W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 4600W, such as clothing steamers, electric dryers, lawnmowers, and electric frying pans. • Long-Lasting, Durable, and Reliable: Equipped with automotive-grade full-tab LFP cells, offering 10 years of reliable power, 24/7 protection BMS, Class-B certification, and EV-grade CTC structure that protects against overnight condensation and off-road bumps during transport. • 2 Easy Ways to Connect to Your Home: Manual Transfer Switch and Inlet Box. • 10ms Auto-Switch: Keep critical devices like NAS systems and servers running smoothly. • 25dB Whisper-Quiet Operation: Ultra-low noise (≤25dB at 600W).
Not everyone weighing these two is only thinking about today’s needs, though. Neither the Elite 300 nor the DELTA 3 Ultra can grow past its fixed capacity, so anyone who suspects they’ll want more room down the line is better served looking one tier up at the EcoFlow DELTA Pro 3, which is built to scale as a household’s power needs change.
EcoFlow DELTA Pro 3
• High Power & Versatility: Delivers up to 4000W (6000W via X-Boost) with 120V and 240V outputs to run a 3-ton central AC and essential appliances. • Continuous Power: Maintains stable 120/240V output at 4000W during pass-through charging. • Endless Energy: Compatible with portable generators and auto-recharges using the EcoFlow Smart Generator 4000. •Durable Battery Life: EV-grade LFP battery retains 80% capacity after 4000 cycles.
Specs and a head-to-head table only tell part of the story. It's worth checking what people who actually own the Elite 300 have to say once the numbers are set aside.
What Reviewers Say About the Bluetti Elite 300
Reviews on the Elite 300 have been pretty consistent since it hit the market, and a few themes keep showing up.
  • Its compact size and native TT-30 RV outlet get flagged again and again as the main reason people choose it over larger 3kWh-class competitors. It's built with power stations built for RV use specifically in mind, not just as an afterthought feature.
  • Its price relative to cycle life comes up as a strong value pitch, especially for buyers who don't need more than 2,400W of continuous output for their setup.
  • The lack of expansion capability is the most common complaint, mostly from buyers who wanted the option to scale up later instead of replacing the whole unit.
  • A handful of reviewers point out that the lower solar input ceiling is a real limitation for anyone hoping to recharge quickly from a large panel setup during an extended outage, though most agree it's a fair tradeoff for the smaller size.
bluetti elite 300 reviewbluetti elite 300 review
RVing isn't a niche hobby anymore, either. It was the second-largest conventional outdoor recreation activity in the country by economic value in 2024, contributing $27.5 billion, according to the Bureau of Economic Analysis. That kind of demand is a big part of why a unit built around a native RV outlet and a small footprint has found its audience so quickly.
The Bluetti Elite 300 is a compact, fixed-capacity 3,014Wh power station priced around $1,199, with strong cycle life and a small footprint, but a lower output ceiling than either EcoFlow option. Choose the Elite 300 if size and price matter most and 2,400W covers what you run. Choose the DELTA 3 Ultra for more output headroom and a faster recharge, or the DELTA Pro 3 if you want a unit that can actually grow with your needs down the line.
What are the full specs of the Bluetti Elite 300?
It's a 3,014Wh LiFePO4 unit with 2,400W continuous output, about 4,800W of surge power, and a rated 6,000-cycle life. Solar input tops out at 400W, and combined solar-plus-alternator charging maxes out at 1,200W.
How much does the Bluetti Elite 300 cost?
It's priced around $1,199, though it's frequently discounted from a higher MSRP. Current listings are worth checking directly, since promotional pricing on this unit has shifted more than once since launch.
Does the Bluetti Elite 300 support an expansion battery?
No. It's a fixed-capacity unit with no officially supported expansion battery, unlike Bluetti's AC300 and Apex-series models. Whatever capacity you buy at purchase is what you're stuck with going forward.
What are the dimensions of the Bluetti Elite 300?
Bluetti markets it as roughly 19% smaller by volume than a typical 3kWh-class power station, which is the whole design premise behind this unit. Exact dimensions are worth confirming on a current listing before you buy, since packaging details can shift between production runs.
How does the Bluetti Elite 300 compare to the EcoFlow DELTA 3 Ultra?
They store nearly the same amount of energy, but DELTA 3 Ultra delivers 50% more continuous output, a much higher surge rating, and a full 0-80% recharge in about 89 minutes. The Elite 300 wins on published cycle life, price, and sheer compactness.
Portable Power Stations
