Will Reptile Lamps Run Up an Electric Bill? How to Calculate the Real Cost
A basking bulb, a ceramic heater, and a UVB tube can each run for hours every day, so it's fair to ask: will reptile lamps run up an electric bill? For most keepers, a single lamp adds only a few dollars a month. A room full of enclosures is a different story. Below, you'll see how many watts a heat lamp uses, how to work out the monthly cost with your own electricity rate, and a few simple ways to trim it. We'll also cover how to keep enclosures warm if the power goes out.
How Many Watts Does a Reptile Heat Lamp Use?
Every lamp in your enclosure has a watt rating, and that number drives most of what you pay. It helps to know where to find it and what can change it.
Reading the Watt Rating on Bulbs and Heaters
If you're trying to figure out what your lamp costs, start with the label. The wattage is printed right on the bulb or its box. For example, one common basking bulb line comes in 25W to 150W sizes, with bigger bulbs for larger enclosures.
So how many watts is a heat lamp in a typical setup? It depends on what's in the tank. Ceramic heat emitters, deep heat projectors, and UVB fixtures each carry their own watt rating, so check every label instead of guessing.
How Thermostats and Dimmers Change Real Use
Your controls matter, too. A thermostat or dimmer means the lamp isn't pulling full power all day. It cycles off or dims once the enclosure is warm, so real use is lower than label watts times hours.
Your bill is measured in kilowatt-hours, not watts, and the two are easy to mix up. Once you understand the difference between kW and kWh, any bulb's cost turns into simple math. The U.S. Energy Information Administration gives a handy example in its guide to how electricity use is measured: a 40-watt bulb left on for five hours uses 0.2 kWh.
With the wattage in hand, the monthly cost takes three quick steps. Keep a recent bill nearby.
How Much Does It Cost to Run a Heat Lamp?
Working out the cost takes only a few minutes. You don't need a meter or any special tools.
The Three-Step Cost Formula
How much do heat lamps cost to run? The math is simpler than it looks. You only need the lamp's watts, the hours it's on each day, and your price per kWh.
Watts × hours per day ÷ 1,000 = kWh per day
kWh per day × 30 = kWh per month
kWh per month × your rate = monthly cost
Your rate is printed on your bill, but the national average works as a starting point. In August 2026, the average US residential price was 18.16 cents per kWh, according to the EIA's Electricity Monthly Update. That's a nationwide average that spreads all charges over the kWh sold. Local rates vary widely, so your own bill is the better number.
Monthly Cost by Bulb Size
Here's what that looks like for common bulb sizes. This example assumes 12 hours a day for 30 days at 18.16 cents per kWh, with the lamp on full power and no thermostat cycling.
Bulb (example) | kWh per day | kWh per month | Cost per month |
50W | 0.6 | 18 | about $3.27 |
75W | 0.9 | 27 | about $4.90 |
100W | 1.2 | 36 | about $6.54 |
150W | 1.8 | 54 | about $9.81 |
So how much electricity does a heat lamp use in a month? A 100W bulb on a 12-hour day uses about 36 kWh. So, does a heat lamp use a lot of electricity? On its own, not really, and a thermostat that cycles it off lowers the cost further.
Adding Up a Full Reptile Setup
Do heat lamps use a lot of electricity once you add up a whole reptile room? That's where costs climb. One enclosure might have a basking lamp, a UVB tube, and an overnight ceramic heater. Add up each device's watts and hours, then multiply by the number of enclosures you keep.
Next to what a space heater costs per hour, one basking bulb is a small line on the bill. A 1,500W space heater draws as much power as fifteen 100W lamps running at once.
The math answers the cost question. For many keepers, though, the bigger worry is what happens when the power goes out.
Keeping Reptile Enclosures Warm During a Power Outage
Picture a winter storm that knocks out power overnight, leaving a reptile without its lamp. A power station won't lower what a heat lamp costs to run. Where it helps is keeping a lamp and thermostat going if the grid goes down, which is a separate plan from your bill.
Plan With Your Vet First
Before you think about equipment, talk to your vet or a reptile specialist. Ask what temperature range your species needs during an outage, since that answer shapes your plan. It's also smart to build a pet emergency kit with food, water, and medicine, as the CDC recommends.
A Fume-Free Backup for Indoor Enclosures
Outages don't follow basking schedules, and cold can stress reptiles quickly. A gas generator isn't an indoor option, since the CDC warns people to never use generators inside a home or garage. A charged power station gives you a quiet, fume-free way to keep a heat lamp and thermostat running indoors for a limited period, depending on battery capacity and the actual load. EcoFlow portable power stations plug in like an outlet, so your enclosure setup stays the same. Size one by the watts your setup draws.
A basking lamp on a thermostat is a modest load. A 1kWh unit can run that kind of setup for several hours, as the estimates below show, and it's small enough to sit on a shelf next to the tank.
Keepers with several enclosures, or anyone expecting longer outages, need more stored energy. A 2kWh unit doubles the energy budget, so the same care plan can run longer or cover more tanks at once.
Estimated Runtime by Setup
Think of it this way: the EcoFlow DELTA 3 Classic covers one enclosure's lamp and thermostat in an emergency, while the EcoFlow DELTA 3 Max covers several enclosures at once or a longer gap between recharges. The table below shows rough runtime estimates for each.
Load (example) | Average watts | EcoFlow DELTA 3 Classic (about 870Wh usable, est.) | EcoFlow DELTA 3 Max (about 1,741Wh usable, est.) |
One 100W lamp on a thermostat, on about half the time | about 50W | about 17 hours | about 35 hours |
Three 100W lamps, same duty cycle | about 150W | about 6 hours | about 12 hours |
These are estimates, not promises. They use capacity × 0.85 for conversion losses, divided by average watts, and assume the lamp is on about half the time. In a cold house the lamp runs more, so runtime gets shorter. A power station also doesn't replace species-specific care from your vet.
If you keep fish as well, the same thinking applies to battery backup for aquariums during outages. Heaters and filters face the same problem when the grid goes quiet.
Back to the bill. A few habits keep lamp costs as low as they can be without changing your animal's care.
Ways to Lower What Your Reptile Lamps Cost
Wondering how to save without cutting corners? The goal is the right heat, not less heat. Most savings come from control and fit. Check with your vet before you change any part of your setup.
Use a thermostat or dimmer. It lets the lamp run only as hard as it needs to, instead of at full power all day.
Put lights on a timer. A timer keeps day and night cycles steady.
Match bulb wattage to the enclosure. An oversized bulb wastes power and can overheat the tank.
Insulate where it's safe. Covering the back and sides of a glass tank can help hold heat, as long as nothing blocks vents or touches hot fixtures.
Keep the reptile room away from drafts. A drafty room makes lamps and heaters work harder to hold temperature.
Small loads add up across the rest of the house, too. Cutting phantom power from idle devices like chargers and game consoles can offset some of what you spend on a heat lamp.
So, will reptile lamps run up an electric bill? For most keepers, not by much. One lamp usually costs a few dollars a month, and at the August 2026 US average rate, a 100W bulb on 12 hours a day comes to about $6.54. Your best estimate comes from your own bulb's watts and your own rate, and thermostats and timers help keep that number in check. If outages are your bigger worry, an EcoFlow DELTA 3 Classic can keep one enclosure's lamp running for a limited time, while an EcoFlow DELTA 3 Max can cover several enclosures or a longer stretch.
Will reptile lamps run up an electric bill?
Usually not by much. A 100W bulb running 12 hours a day costs about $6.54 a month at the August 2026 US average rate, though costs grow with more devices and enclosures.
How many watts does a heat lamp use?
It depends on the bulb. Reptile basking bulbs commonly range from about 25W to 150W, and the rating is printed on the bulb or its box.
How much does it cost to run a heat lamp 24 hours a day?
Take the watts, multiply by 24 hours and 30 days, divide by 1,000, then multiply by your rate. A 100W bulb running nonstop uses 72 kWh a month, which works out to about $13 at 18.16 cents per kWh.
Does a thermostat lower heat lamp costs?
Yes, it does. A thermostat or dimmer keeps the lamp from running at full power when the enclosure is already warm enough. You'll use fewer kWh than the label suggests.
Can a power station lower my reptile lamp bill?
No, it can't. A power station doesn't change how much power the lamp itself uses. Its real value is as backup, keeping lamps and a thermostat running during an outage.
