Average Cost of Electricity a Month in Edmond, OK: Rates, Seasons, and How to Estimate Your Bill
The average cost of electricity a month in Edmond, OK, depends on use and season. Under Edmond Electric's R-1 residential rate, 1,000 kWh in July comes to $99.10 in base charges, and 1,000 kWh in January comes to $84.46. Both figures come before the fuel adjustment and taxes. Edmond runs its own electric utility, so the city sets rates locally. Prices also shift by season, and winter rates drop once use passes a set level. This guide covers the rate, a simple bill estimate, and outage prep that a bill does not cover.
Who Provides Electricity in Edmond, OK?
Most homes in Edmond get power from Edmond Electric, a city-owned utility. The city sets its rates directly. They do not go through the Oklahoma Corporation Commission rate cases that apply to investor-owned utilities. A recent bill confirms the provider for any address. That one check matters, because every rate and example below applies only to Edmond Electric customers on Rate R-1.
Edmond neighborhood power lines at sunsetEdmond neighborhood power lines at sunset
How the Utility Is Set Up
  • City-owned structure: Edmond Electric operates as a city department under the Public Works Authority, per the city's Standard Pricing Schedules. As a municipal Edmond utility, it follows those schedules, not a state rate case.
  • Who Rate R-1 covers: R-1 applies to residential service in one- and two-family dwellings. Condos, apartments, and individually owned attached units fall under it too.
  • Where billing questions go: The City of Edmond, OK, utilities customer service office handles accounts and payments. Outage reports go through Edmond Electric, covered in the next section.
Check the Service Area First
Some Edmond-area addresses may be served by a different company. In that case, that company's own tariff applies, and the R-1 numbers below do not.
This article also covers Edmond, Oklahoma only. Edmonds is a city in Washington, and searches like eden electricity rates can point to a different place entirely. Looking at average electricity bills by state, Oklahoma sits below the national average, but a city utility's rate can differ from the state figure.
Before the rate details, one note on what a bill does not cover: outages.
Bill Planning vs Outage Planning: Where Backup Power Fits
Knowing the rate helps with budgeting. It does not help when the power goes out. Oklahoma storms can cut power even when the bill is paid. Some households set aside a separate emergency budget for small backup power.
Reporting an Outage
Outages go to Edmond Electric through its official outage reporting page. Downed lines are a different case. Anyone who sees one should stay back and call 911. General outage prep tips are also available from Ready.gov.
Where a Small Power Station Fits
Planning ahead is part of getting through an Oklahoma tornado and the outages that follow. The monthly bill covers the power used. It does not cover what happens when a spring storm knocks that power out.
A small EcoFlow portable power station is a one-time emergency purchase, separate from the monthly budget. It can keep lights, phones, and Wi-Fi going for a limited time. It will not change the rate or the bill.
For most Edmond households, the outage short list is light, phones, and the internet. A 1kWh unit can cover that list for many hours. It also switches over in milliseconds when the power drops.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
Runtime estimate (example loads, not a measured result)
Load (example)
Watts used
EcoFlow DELTA 3 Classic (870Wh usable est.)
LED lights + router + two phones (placeholders 20W + 10W + 20W)
about 50W
about 17 hours
Real runtime depends on the watts actually drawn and the battery's condition. Plugging in more devices shortens it.
Now to the rate itself, which decides most of the monthly cost.
Edmond Electric Residential Rates (Rate R-1)
Edmond's residential rate has a monthly customer charge and an energy charge that changes by season. Summer prices rise above a usage threshold, and winter prices drop above one. A monthly fuel adjustment is added on top.
Component
Season (revenue months)
Charge
Basic customer charge
All year
$14.00 per month
Energy, first 1,400 kWh
Summer (June to September)
$0.0851 per kWh
Energy, above 1,400 kWh
Summer
$0.0957 per kWh
Energy, first 600 kWh
Winter (November to April)
$0.0851 per kWh
Energy, above 600 kWh
Winter
$0.0485 per kWh
Energy, all kWh
Shoulder (May and October)
$0.0851 per kWh
Fuel Cost Adjustment (FCA)
Monthly
Set monthly; see your bill
Source: City of Edmond residential rates and the Standard Pricing Schedules. Rates can change, so the city's pages hold the current figures. The schedule lists an effective date of 04-01-17, and the rates page shows the figures now in use.
What the Rate Details Mean
  • Base charge, not total price: The $0.0851 per kWh figure is the base energy charge. It leaves out the fuel adjustment and taxes, so it is not the full price per kWh.
  • Fuel Cost Adjustment: The Director of Edmond Electric or a designee sets the FCA each month. The Director of Finance approves it. The published schedule gives the formula, not a current value, so the bill shows the live number.
  • Minimum charge: The minimum monthly charge is the customer charge plus any applicable riders.
  • Riders: The LIHEAP-1 rider gives certified R-1 customers a $10.42 monthly credit. The cited Pure and Simple Wind Rider schedule lists $0.0170 per kWh for new customers and states that its charge replaces the Fuel Cost Adjustment (FCA), rather than being added to it. Confirm the currently applicable wind-plan rate and terms with Edmond Electric.
Reviewing an electric bill with calculatorReviewing an electric bill with calculator
Seasonal tiers are one of several ways utilities price power, and most efforts to save on electricity bills start with knowing the rate's seasons.
With the rate in hand, a monthly bill takes only a couple of minutes to estimate.
How to Estimate Your Monthly Electric Bill in Edmond
Take the monthly kWh from a past bill. Apply the seasonal tiers. Add the customer charge and taxes, plus the applicable adjustment from the bill. For customers billed under the cited PSWR schedule, use its wind rider instead of the FCA; do not add both to the same electricity use.
Four Steps
  1. Find the kWh used. A past bill lists total kWh for the billing month.
  2. Match the season. June to September is summer, November to April is winter, and May and October are the shoulder months.
  3. Apply the tiers. Price the first block at $0.0851. Price any kWh above the threshold at the second rate for that season.
  4. Add the extras. Add the $14.00 customer charge, the applicable adjustment times the kWh, and taxes. Under the cited PSWR schedule, substitute the wind rider for the FCA rather than adding both.
What Moves the Monthly Total
  • Cooling load in summer: Air conditioning often drives summer use in Oklahoma, which can push a home past the 1,400 kWh threshold. Above it, each extra kWh costs $0.0957.
  • Winter heating source: The winter drop above 600 kWh matters most to homes that heat with electricity. Homes that heat another way may rarely reach that tier.
  • Shoulder months: May and October use one flat price, so the bill changes with kWh alone.
Worked Examples
These are examples only, and they come before the FCA, taxes, and fees.
Month and use
Math
Base charges
July, 1,000 kWh
$14.00 + (1,000 × $0.0851)
$99.10
July, 1,800 kWh
$14.00 + (1,400 × $0.0851) + (400 × $0.0957)
$171.42
January, 1,000 kWh
$14.00 + (600 × $0.0851) + (400 × $0.0485)
$84.46
October, 800 kWh
$14.00 + (800 × $0.0851)
$82.08
The average cost of electricity a month in Edmond, OK, moves with use. A 1,800 kWh July costs about $72 more in base charges than a 1,000 kWh July. Winter shows the tier drop: 1,000 kWh in January costs less than the same use in July.
To get closer to the real total, multiply the applicable adjustment on the bill by the kWh used. Customers billed under the cited PSWR schedule should use its wind rider instead of the FCA, without adding both.
A Statewide Comparison
For context, the U.S. Energy Information Administration reports Oklahoma's average residential price at 14.82 cents per kWh in August 2026. That figure averages all utilities and all charges. The U.S. average was 18.16 cents. These are statewide numbers, not Edmond's rate.
Household size also affects electricity use, alongside climate, the home's size and features, appliances, and usage patterns. Comparing with the average four-person household bill shows whether a home's use is typical.
Edmond Electric's R-1 rate is $14.00 a month plus $0.0851 per kWh for most use. Summer and winter tiers change the price above set thresholds, and the applicable monthly adjustment sits on top. For customers billed under the cited PSWR schedule, its wind rider replaces the FCA. The average cost of electricity a month in Edmond, OK, comes down to kWh used, the season, and that fuel adjustment.
The simplest way to estimate a bill is to take the kWh from a past statement, apply the seasonal tiers, and add taxes and the applicable adjustment. Use the wind rider instead of the FCA when the cited PSWR schedule applies; do not add both.
Storm season is when outage plans get tested, and a bill cannot help there. For households that want a separate emergency option, the EcoFlow DELTA 3 Classic Portable Power Station can keep essentials like lights, phones, and a Wi-Fi router running for a limited time. It does not change the Edmond Electric rate or the monthly bill. It is a one-time purchase for outage backup, kept apart from the regular electricity budget.
What is the average cost of electricity a month in Edmond, OK?
It depends on use and season. At Edmond Electric's R-1 rate, 1,000 kWh in July comes to $99.10 and 1,000 kWh in January comes to $84.46, before the fuel adjustment and taxes. Both extras appear on the monthly bill for each account.
Who provides electricity in Edmond, Oklahoma?
Most homes get power from Edmond Electric, the city-owned utility. Some Edmond-area addresses may be served by a different company, which uses its own tariff. A recent bill names the provider and shows which rate schedule applies.
Does Edmond Electric have time-of-use rates?
No, it does not. The R-1 residential rate is tiered by season and monthly usage, not by time of day. Within a given tier, a kWh costs the same at any hour, so shifting use to other hours does not change the energy charge.
What is the Fuel Cost Adjustment on an Edmond Electric bill?
It is a monthly per-kWh charge that tracks wholesale power costs. The Director of Edmond Electric or a designee sets it each month, and the Director of Finance approves it. The current amount appears on each bill and can change monthly.
Why is my Edmond electric bill lower in winter?
Winter use above 600 kWh is billed at $0.0485 per kWh, lower than the $0.0851 first-tier rate. Only the kWh above 600 get the lower price, and only from November to April. Below 600 kWh, the winter price matches the other seasons.
Save Bills
