How Much Does Electricity Cost Per Month for an American Households?
The average US electric bill runs around $165 a month, based on typical household usage of about 875 kWh at 18.7 cents per kWh. That's the number, but it hides an enormous amount of variation. Two families with nearly identical habits can pay double or half that depending on where they live. Here's where the national average comes from and why state-by-state numbers swing so widely. We'll also cover which categories drive most of your usage, and the changes that actually bring the total down.
The National Average Electric Bill
The national figure is the starting point for almost every comparison people make. It's useful as a benchmark, but only if you know what it includes. Here's what's behind it. The average US household spends roughly $165 per month on electricity. That comes from about 875 kWh of usage at a residential rate near 18.7 cents per kWh, drawing on U.S. Energy Information Administration data.
Multiply those two and you land right around the reported average. One thing worth knowing: that figure usually reflects energy charges and typically excludes the fixed basic service charge most utilities tack on. Depending on your provider, that flat fee can add another $10 to $25 a month regardless of how much power you use. It's why your actual statement often reads higher than any average you find online. Averages also flatten a huge range. Monthly bills run from around $107 in Utah to roughly $263 in Hawaii. That's not a small gap. It's a difference of nearly $1,900 a year for the same basic household needs. A full breakdown of average electric bills in every state gives a far more useful comparison point than the national number ever will. That wide range comes down to a mix of local rates and regional usage habits.
Why Bills Vary So Much by State
Why Bills Vary So Much by StateWhy Bills Vary So Much by State
Two forces drive the spread, and they don't always push in the same direction. One is what you pay per unit. The other is how many units you use. A state can be expensive on one and cheap on the other.
The Rate You Pay Per Kilowatt-Hour
Rates alone range from about 12 cents per kWh in the cheapest states to over 40 cents in the most expensive. Fuel mix, grid infrastructure, and state energy policy all feed into that. Hawaii imports most of its fuel. New England deals with aging infrastructure and pipeline constraints. States with abundant hydro or wind sit at the low end.
How Much Climate Pushes Your Usage
Climate drives usage just as hard. Hot southern states routinely exceed 1,000 kWh a month because air conditioning runs most of the year. Milder coastal states often stay under 600 kWh. This is why Hawaii can have the country's highest rate but relatively modest consumption, while Louisiana has cheap power and a high bill anyway.
Heating and cooling account for over 30 percent of a typical household's electricity consumption, and in extreme climates that share climbs considerably higher. It's the single biggest swing factor between one state and another.
The Rate Structure Most People Overlook
There's a third factor people miss entirely: how your rate is structured. Some utilities use tiered pricing, where crossing a usage threshold bumps every additional kilowatt-hour into a more expensive bracket. Others use time-of-use pricing tied to the hour of day. In deregulated states like Texas, Ohio, and Pennsylvania, you can shop your supply rate. Households that are never bothered often sit at a default rate well above the market.
If your bill looks high even against your own state's average, something more specific is going on. Working through the usual reasons a bill spikes helps separate a regional cost problem from a household one.
Beyond location, a household's actual bill comes down to how it's using power day to day.
Softening Bill Spikes With Stored Power
Peak-hour rates and sudden usage spikes can push a bill well above your normal monthly average. Running an AC unit hard through a heat wave is the classic example. The usage is unavoidable, but the timing sometimes isn't.
This is where stored power changes the math. Charging a power station during off-peak hours and drawing from it when rates peak shifts part of your load into the cheaper window. On a time-of-use plan, that gap between off-peak and peak pricing can be substantial, and the same unit covers you during an outage. Here are two that fit this use well.
EcoFlow DELTA 3 Plus
•1kWh–5kWh Scalable Capacity: Expandable capacity using DELTA 3, DELTA 2, DELTA 2 Max, or DELTA Pro 3 Extra Batteries (via an Alternator Charger XT150 Output Cable). • 1,800W Output with 3,600W Surge: Delivers a continuous 1,800W AC output (3,600W surge) and reaches up to 2,200W with X-Boost™ technology. • 5 Fast Recharging Methods: Supports versatile charging via AC, Solar, 800W Alternator Charger, Smart Generator 3000 (Dual Fuel), and Multicharging. • 5-Year Warranty Protection: Backed by a comprehensive 5-year warranty for long-term reliability and peace of mind.
The DELTA 3 Plus is the sensible entry point for a household testing whether load shifting is worth the effort. It covers a handful of outlets through the expensive evening window. Where it runs short is a longer peak period or a heavier load list. Say your utility charges premium rates for five or six hours. Or you want the refrigerator and a home office running the whole time. That takes more stored energy behind you.
EcoFlow DELTA 3 Max (2048Wh)
• 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws. • 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. • Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product. • OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. • Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
Beyond timing, a handful of usage categories drive most of a typical bill's total.
What Actually Drives Up a Bill
People tend to blame the wrong things. Lights and electronics get the attention because they're visible, while the real cost sits in systems nobody thinks about. Here's where the money actually goes.
Heating and Cooling Dominates Everything
Heating and cooling is the largest category in most homes by a wide margin. During a brutal July or a January cold snap, it can dominate the entire bill. Everything else combined often doesn't match it.
Household Size Matters Less Than You'd Think
Household size matters less than most people assume. The difference between an average two-person and four-person household bill runs only about $35 to $40 a month. That surprises people, but it makes sense. The furnace, the air conditioner, and the refrigerator run about the same regardless of how many people are home.
Older Appliances Are the Quiet Contributor
Older appliances are the quiet contributor. A refrigerator from 2005 uses noticeably more power than an ENERGY STAR certified model doing the same job. The same goes for water heaters, dryers, and dishwashers. None of it announces itself. It just shows up as a baseline that never drops.
For a closer look at how occupancy actually shakes out, what a four-person household typically pays breaks the usage down in more detail.
With the biggest drivers identified, a few practical changes make the most measurable difference.
Practical Ways to Lower the Number
Practical Ways to Lower the Electricity BillPractical Ways to Lower the Electricity Bill
Not every energy tip is worth the same effort. Some cost nothing and work immediately. Others cost thousands and pay back over years. It helps to go in order.
  • Start with the thermostat, since adjusting it a few degrees during peak heating and cooling months is the single biggest savings opportunity available to most households.
  • It costs nothing, and because heating and cooling dominate usage, small changes compound quickly.
  • Seal gaps around doors and windows and add attic insulation, which directly reduces the load driving most of your bill.
  • Weatherstripping and caulk are cheap, and the payback in an older home is fast.
  • Switch to LED lighting and replace aging appliances with ENERGY STAR certified models to lower what your home draws around the clock.
  • These changes are smaller individually, but they're permanent and they stack.
  • Check your utility's own programs before spending anything, since most offer free or discounted energy audits and many run rebates on insulation, heat pumps, smart thermostats, and appliance upgrades.
  • Ask about budget billing if the month-to-month swings are the real problem rather than the annual total.
  • For a longer-term play, what solar panels save on electricity is worth reviewing, since payback depends heavily on your state's rates and net metering rules.
Heating and cooling before anything else. EcoFlow's DELTA 3 Plus and DELTA 3 Max both let households shift usage off peak-rate hours, which helps soften the swings in a monthly bill.
What is the average electric bill in the US per month?
Around $165, based on roughly 875 kWh of monthly usage, at about 18.7 cents per kWh. That figure typically covers energy charges only. Most utilities add a fixed basic service charge on top, which can push your actual statement $10 to $25 higher.
Why is my electric bill higher than the national average?
Usually climate or rates, and often both. If you're in a hot southern state running AC most of the year, your usage will exceed the national norm. If you're in Hawaii or New England, your rate does damage. Check your state's average before assuming something is wrong.
Does a bigger household always mean a much higher electric bill?
Not really. The gap between an average two-person and four-person household is only about $35 to $40 a month. The largest loads in a home, like heating, cooling, and refrigeration, run largely independent of how many people live there.
What uses the most electricity in a typical home?
Heating and cooling, accounting for over 30 percent of a typical household's consumption and considerably more in extreme climates. Water heating usually comes second. Lighting and electronics matter far less than most people expect.
How can I lower my electric bill without major home upgrades?
Adjust the thermostat a few degrees, seal drafts around doors and windows, and switch to LED bulbs. If your utility offers time-of-use pricing, shifting laundry and dishwashing to off-peak hours costs nothing and lowers the total immediately.
Save Bills
