Average Electric Bill for 2 Bedroom Apartment Living: What to Expect and How to Estimate Yours
Before signing a lease, it helps to know what electricity will cost each month. There's no official average for two-bedroom apartments specifically, but federal data gets you close. EIA's Residential Energy Consumption Survey shows how much apartments use, and EIA's monthly data shows what people pay per kilowatt-hour. Your bill depends on your state, season, heating type, and habits. This guide explains how to estimate the average electric bill for 2 bedroom apartment living, what drives it up, how to lower it, and optional outage basics for renters.
Average electric bill for a 2-bedroom apartment: what the data shows
The U.S. Energy Information Administration (EIA) doesn't publish bills by bedroom count. But it does report average use for apartments and the average price per kWh. Multiply the two for a rough national estimate, then adjust for your area.
Here are the numbers to work with:
  • Apartments in buildings with five or more units: 6,093 kWh per year (EIA 2020 RECS, Table CE2.1, electricity in kWh).
  • Apartments in 2 to 4 unit buildings: 6,665 kWh per year (EIA RECS, 2020)
  • All U.S. homes: 10,566 kWh per year (EIA RECS, 2020)
  • U.S. average residential retail price: 18.16 cents per kWh in August 2026 (EIA Electric Power Monthly, Table 5.6.A, preliminary).
For example, 6,093 kWh ÷ 12 is about 508 kWh per month. At the national average retail price of $0.1816 per kWh, that gives a rough monthly bill of $92. This retail average already reflects utility revenue from fixed and variable charges. For your own bill, apply your utility’s tariff to your actual usage.
This estimate combines 2020 RECS consumption data with an August 2026 price. It illustrates the calculation rather than predicting the bill for a specific apartment.
Smaller units have their own numbers. Compare with a 1-bedroom electric bill breakdown.
Lowering the bill is about using less. Backup power is a separate question that only matters if you need it.
Outage basics for renters (optional, not a bill saver)
A power station won't cut your electric bill, because charging and discharging loses some energy. If you also want light, Wi-Fi, and phones during outages, it's a simple renter-friendly option. Skip this section if outages aren't a concern.
If outages are a concern in your building, an EcoFlow portable power station keeps lights, Wi-Fi, and phones on without any wiring changes. It's a backup purchase, not a way to cut your monthly bill.
For a two-bedroom apartment, a 1kWh unit runs lamps, the router, and phones through a typical outage and fits on a shelf.
EcoFlow DELTA 3 Classic (1024Wh)
  • Outage Basics: 1,024Wh LFP battery for lamps, the router, and phones (see estimate below).
  • No Wiring: Plugs in like a wall outlet. Don't connect it to your apartment's wiring.
  • 10ms UPS: Switches over in 10ms, per EcoFlow.
  • Not a Bill Saver: It doesn't reduce your electric bill.
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
Runtime estimate (example only):
Load (example)
Watts used
EcoFlow DELTA 3 Classic (870Wh usable est.)
Router + two LED lamps + phones (placeholders)
about 45W
about 19 hours
Method: Usable capacity (Wh × 0.85) ÷ load (W).
These are estimates, and real runtime depends on what you plug in.
Renters face their own outage limits. Start with apartment blackout preparedness tips.
Back to the bill: what drives it up?
What affects a 2-bedroom apartment electric bill?
Location and heating type matter most. Electric heat and older AC units raise bills fast. Habits and fixed charges add the rest.
These factors move the number most:
  • State electricity prices
  • Electric vs. gas heat
  • AC use and climate
  • Appliance age
  • Number of occupants
  • Utility fixed charges
Prices are also trending up. EIA reported an average residential price of 17.57 cents per kWh in August 2025, so the August 2026 figure of 18.16 cents is higher year over year (note that the 2025 number is final and the 2026 number is preliminary).
State averages vary widely. Check the average electricity bill by state.
Finally, ways to cut it.
A homeowner budgeting for home electricity consumptionA homeowner budgeting for home electricity consumption
How to lower your apartment electric bill?
Renters can still cut their bills. Focus on heating, cooling, and plug loads. Ask your landlord about efficient appliances.
ENERGY STAR reports that certified LEDs use up to 90% less energy than standard bulbs. Beyond lighting, a few simple habits help:
  • Use fans alongside AC
  • Seal drafts with removable products
  • Unplug idle devices
  • Wash in cold water
Small changes add up for renters. Try no-renovation apartment electricity hacks.
EIA does not publish a national average for two-bedroom apartments specifically. Combining 6,093 kWh a year for apartments in larger buildings with the August 2026 residential retail price gives an illustrative monthly bill of about $92. Local rates, heating type and household habits can change the result.
If outages are on your mind, that's a separate decision from the monthly bill. An EcoFlow DELTA 3 Classic keeps lamps, the router, and phones running for hours in an outage, and it fits on a shelf without any wiring changes. It won't reduce what you pay each month, so only consider it if backup power matters to you. If it doesn't, put your effort into the habits above.
1. What is the average electric bill for a 2 bedroom apartment?
There is no official two-bedroom figure. The example using EIA apartment consumption and the August 2026 national residential retail price gives about $92 per month, including charges reflected in that average. Use your own tariff and past bills for a closer estimate.
2. How much electricity does an apartment use?
EIA's 2020 RECS shows about 6,093 kWh a year for apartments in buildings with 5 or more units. Apartments in 2 to 4 unit buildings average 6,665 kWh a year.
3. Why is my apartment electric bill so high?
Electric heat, AC use, older appliances, and high local prices are common causes. Check your past bills for seasonal spikes, then compare your state's rate with the national average.
4. What is the average price of electricity?
EIA reported 18.16 cents per kWh for U.S. residential customers in August 2026 (preliminary). That's up from 17.57 cents in August 2025, so prices rose year over year.
5. Does a power station lower my bill?
No. It provides backup power, and charging and discharging loses some energy. It's only worth considering if you want lights, Wi-Fi, and phones running during outages.
Save Bills
