AGM vs. Lithium Battery: Which One Actually Wins
If you're comparing AGM and lithium batteries for an RV, boat, solar setup, or backup system, the differences show up pretty quickly. Lithium batteries are lighter, last longer, and give you more usable energy. AGM batteries cost less upfront and still make sense for some occasional-use setups. Here's how the two compare on capacity, lifespan, weight, charging, and cost.
What Separates AGM From Lithium
AGM and lithium batteries both store electricity, but they use different battery chemistries. AGM stands for Absorbed Glass Mat and is a type of sealed lead-acid battery. Lithium batteries used in portable power systems are commonly lithium iron phosphate (LiFePO4), which has different performance and charging characteristics.
AGM batteries
An AGM battery uses fiberglass mats to hold its electrolyte in place. The sealed design helps prevent spills during normal use, which makes AGM batteries practical for RVs, boats, backup systems, and other applications where a traditional lead-acid battery might be inconvenient.
LiFePO4 batteries
LiFePO4 is a lithium battery chemistry known for its long cycle life and stable chemistry. It’s less prone to thermal runaway than some older lithium-ion chemistries, which is why it’s widely used in portable power stations. This guide to LiFePO4 batteries covers its safety and performance in more detail. The chemistry also affects how long a battery lasts, how much power you can use, and how much it weighs.
Comparing Lifespan, Capacity, and Weight
The biggest differences between AGM and lithium show up in everyday use. Lithium batteries generally last through far more cycles, provide more usable capacity, and weigh much less than AGM batteries.
Factor
AGM
Lithium (LiFePO4)
Typical cycle life
300-500 cycles
3,000-5,000+ cycles
Usable capacity
About 50% of rated Ah
80-100% of rated Ah
Typical 100Ah weight
60-70 lbs
22-31 lbs
Typical service life
3-5 years
8-10+ years
These are typical figures, and actual performance can vary by battery and how you use it. For a closer look at cycle life, how long lithium batteries last explains what affects battery lifespan.
Cycle life
AGM batteries typically provide around 300 to 500 cycles, while LiFePO4 batteries can reach 3,000 to 5,000 or more. That difference becomes especially noticeable if you charge and discharge the battery regularly.
Usable capacity
A 100Ah battery doesn't necessarily give you 100Ah of usable energy. AGM batteries typically provide about 50% of their rated capacity, while LiFePO4 batteries can provide around 80% to 100%. That means you can get more usable power from the same rated capacity with lithium.
Weight
Lithium batteries are also much lighter. A typical 100Ah AGM battery weighs around 60 to 70 pounds, compared with about 22 to 31 pounds for a 100Ah LiFePO4 battery. That's a meaningful difference in an RV, boat, or mobile backup setup.
These differences can make lithium attractive for people who use their batteries often. But if you don't want to build a system around individual batteries, there's another option: a portable power station with the battery, inverter, and charging hardware already built in.
Skipping the Battery Debate With a Power Station
Building a battery bank from separate components takes some planning. You have to choose the battery chemistry, size the charger, and make sure the inverter and wiring are right for the system. A portable power station keeps those pieces together in one unit, with a built-in LiFePO4 battery, charger, and inverter designed to work together.
•1kWh–5kWh Scalable Capacity: Expandable capacity using DELTA 3, DELTA 2, DELTA 2 Max, or DELTA Pro 3 Extra Batteries (via an Alternator Charger XT150 Output Cable). • 1,800W Output with 3,600W Surge: Delivers a continuous 1,800W AC output (3,600W surge) and reaches up to 2,200W with X-Boost™ technology. • 5 Fast Recharging Methods: Supports versatile charging via AC, Solar, 800W Alternator Charger, Smart Generator 3000 (Dual Fuel), and Multicharging. • 5-Year Warranty Protection: Backed by a comprehensive 5-year warranty for long-term reliability and peace of mind.
If you need more battery capacity for a larger setup, the DELTA 3 Max gives you more storage and higher output than the DELTA 3 Plus. It’s a practical step up when you need to run more equipment from the same power station.
EcoFlow DELTA 3 Max (2,048Wh)
• 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws. • 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. • Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product. • OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. • Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
Charging speed is another key difference between AGM and lithium. Lithium batteries can generally accept more charging power and recharge faster, while AGM batteries take longer to reach a full charge.
Charging Speed and Efficiency
AGM and lithium batteries handle charging differently. AGM batteries generally take longer to reach a full charge, while lithium can accept a higher charging current and get back to full capacity faster.
AGM charging
An AGM battery typically needs around 8 hours for a full three to four-stage charging cycle, depending on the charger and battery condition. The slower final charging stage can take additional time as the battery reaches full capacity. AGM batteries also lose more energy as heat during charging, making them less efficient than lithium for systems that are charged and discharged regularly.
Lithium charging
Lithium batteries can accept higher charging currents and often reach a full charge in five to six hours or less, depending on the battery and charger. That can be helpful when you need a quick recharge between uses or have limited sunlight for solar charging. For proper charging practices, see how to charge a lithium battery. The better choice still depends on how often you'll use the battery and how much you're willing to spend.
Which One Actually Fits Your Budget and Use Case
AGM batteries usually cost less upfront, but the lower price doesn't tell the whole story. You can typically use only about half of an AGM battery's rated capacity, while a lithium battery can provide around 80% to 100%. That means a fair capacity comparison may require two AGM batteries for every one lithium battery.
Which One Fits Your Budget and Use CaseWhich One Fits Your Budget and Use Case
For daily use
Lithium can make more sense when you charge and discharge the battery regularly. Solar storage, RVs, and marine house batteries are common examples where the longer cycle life and higher usable capacity can help spread out the higher upfront cost over time.
For occasional backup
If you only need a battery once in a while or mainly for backup power, AGM can still be a practical choice. If you will mostly not use the battery, the lower price of purchase may be more important than the longer cycle life of lithium. If you're considering lithium, take a look at the different lithium battery types before choosing a specific chemistry.
AGM and lithium batteries can both be useful, but they fit different needs. AGM batteries cost less upfront and can work well for occasional backup use. Lithium batteries offer more usable capacity, a much longer cycle life, lower weight, and faster charging. When comparing the two, look at usable capacity instead of rated amp-hours alone. A 100Ah AGM battery typically gives you about 50Ah of usable capacity. EcoFlow’s DELTA 3 Plus and DELTA 3 Max use built-in LiFePO4 batteries, so you get the benefits of lithium without having to build a separate battery system from individual components.
Is lithium really worth the extra cost over AGM?
It depends on how often you'll use the battery. Lithium is more expensive upfront but gives you more usable capacity and many more cycles of charge. It can make the higher price easier to swallow for daily use in an RV, boat or solar setup. For occasional backup power, AGM may be a better fit if keeping the initial cost down is your priority.
Can I replace an AGM battery with a lithium one directly?
Not always. AGM and LiFePO4 batteries may charge differently, so check if your charger is compatible before swapping. There may also be special requirements for your inverter and other parts of your system. Check the equipment manufacturer's instructions before replacing an AGM battery with lithium.
How much lighter is a lithium battery compared to AGM?
A typical 100Ah AGM battery weighs around 60 to 70 pounds, while a 100Ah LiFePO4 battery typically weighs about 22 to 31 pounds. The exact weight varies by model, but lithium can save a significant amount of weight. That can be especially useful in an RV or boat.
Do lithium batteries need a different charger than AGM?
Yes, lithium batteries can require different charging settings than AGM batteries. LiFePO4 batteries are designed to use a charging profile suited to their chemistry. Before using an existing AGM charger, check whether it supports LiFePO4 batteries and follow the battery manufacturer's charging requirements.
Which battery type is better for a solar power system?
They are both usable in a solar power system but have different advantages. AGM is cheaper initially, but LiFePO4 has a longer cycle life and more usable capacity. If you’re constantly charging and discharging the battery, those differences can add up over time. Your solar setup should also use a charger and inverter that are compatible with the battery you choose.
Portable Power Stations
