100 Amp Wire Size: The Complete Guide for Copper and Aluminum
If you need to install or replace your 100 amp main service or subpanel, one of the first questions is what size wire for 100 amp service you need and whether copper or aluminum is the better choice. Choosing the correct wire gauge means more than just passing inspection. The right wire will prevent dangerous overheating, and avoid unnecessary voltage drops. In this comprehensive guide, we’ll break down the specific National Electrical Code (NEC) requirements for both copper and aluminum wire and compare their differences in home installations. It will also help you size your wiring correctly for detached garages, workshops, and whole-home backup battery integrations.
What Size Wire Do You Need for a 100 Amp Circuit?
Choosing what size wire for 100 amp applications requires understanding how wire gauge, conductor material, and ampacity ratings work together. Wire size amperage charts can provide a useful reference, but NEC requirements, installation methods, and conductor materials ultimately determine the correct wire size. Let’s look at the baseline rules governing copper and aluminum sizing.
Standard Wire Gauges for 100 Amps
Electrical conductors generate heat as current moves through them, and different metals handle electrical capacity differently. Copper and aluminum conductors have different ampacity characteristics, so the required wire size depends on the conductor material. For common 100 amp sub panel wire size requirements, a typical 100-amp feeder or subpanel circuit uses #3 AWG copper or #1 AWG aluminum conductors under standard NEC 75°C terminal ratings. The AWG is a measure of the size of wire. For qualifying dwelling unit service conductors and feeders supplying the entire dwelling load, NEC 310.12 may allow reduced conductor sizes. Here, the higher AWG number is a smaller wire.
Copper Wire Requirements
Copper remains the premium choice for electrical wiring due to its high conductivity and durable physical traits. When connected to standard 75°C rated terminals, #3 AWG copper is the common specification. For qualifying dwelling unit services or feeders supplying the entire dwelling load, NEC 310.12 may permit reduced conductor sizes, such as #4 AWG copper or #2 AWG aluminum. However, these reduced sizes do not apply to every 100A feeder application. Always verify whether your installation meets all local jurisdiction requirements.
Aluminum Wire Requirements
Aluminum wiring is widely preferred for longer runs of wire because of its substantial cost savings and lighter weight. However, aluminum has higher electrical resistance than copper, so it requires a larger cross-sectional area to handle 100 amps safely—typically requiring #1 AWG for standard feeders. Larger aluminum sizes such as 1/0 AWG may even be selected for longer runs. This will lower your voltage drop and provide additional capacity margin.
Application TypeCopper Wire GaugeAluminum Wire GaugeCommon Cable Types
Main Service / Dwelling Feeder (NEC 310.12)#4 AWG Copper#2 AWG Aluminum2-2-2-4 SER / Mobile Home Feeder (MHF)
Standard Feeder / Subpanel (75°C Terminals)#3 AWG Copper #1 AWG or 1/0 AWG AluminumTHHN/THWN-2 in conduit, SER
Continuous Heavy Industrial Load#1 AWG Copper2/0 AWG AluminumTHHN / XHHW-2
EcoFlow DELTA Pro Ultra X Whole-Home Backup PowerEcoFlow DELTA Pro Ultra X Whole-Home Backup Power
How Do Copper and Aluminum Wires Compare for 100 Amps?
It’s not always straightforward to choose between copper and aluminum conductors. Copper provides maximum efficiency in compact spaces, but newer aluminum alloys can offer substantial savings for longer cable runs.
Copper vs. Aluminum Electrical Differences
Copper has lower electrical resistance than aluminum, allowing smaller conductors to carry the same current. Aluminum requires a larger conductor size but can offer significant cost advantages for larger installations, especially for long feeder runs. Modern aluminum conductors commonly use 8000-series alloys, which improve flexibility and reliability when installed according to manufacturer specifications.
Cost and Installation Differences
Installation costs are always important when installing heavy wire across your property. Aluminum conductors are often substantially less expensive than copper alternatives. This is especially true for large residential feeders and long-distance runs. Aluminum is often chosen for long underground feeds to outbuildings or main service entrance cables. But because aluminum wire is of a larger diameter (for example, #1 AWG aluminum instead of #3 AWG copper), you may need larger conduit sizes. This means running a 2 inch conduit at higher cost instead of a 1.5-inch PVC conduit.
Which Wire Material Should You Choose?
For short interior runs where space for running conduit is tight, copper is often worth the extra material cost due to its easy handling and smaller diameter. Conversely, for feeder runs exceeding 30 or 40 feet, such as powering a subpanel in a detached garage, aluminum may be the smarter, lower cost option.
What Factors Affect 100 Amp Wire Size Selection?
Electrical codes are based on proven science and experience. They protect your home against heat accumulation, voltage drops, and wire insulation failure under high electrical usage. These same considerations apply when planning home backup power systems, where proper wire sizing helps ensure safe connections between backup equipment, transfer switches, and household electrical panels.
Wire Length and Voltage Drop
Voltage drop can be a major concern if your circuit length stretches beyond 100 feet. Understanding ampacity and voltage drop is essential when selecting the right conductor size, as a wire must safely handle the required current while minimizing energy loss over longer distances. The NEC informational notes recommend limiting voltage drop to approximately 3% on individual circuits and 5% total for feeders plus branch circuits. Longer runs mean more voltage drop. If you install a 100-amp subpanel 150 feet away in a backyard shop, you might consider stepping up from #1 AWG aluminum to 1/0 AWG or even 2/0 AWG aluminum. This will reduce voltage drop on a long run.
Ampacity and Temperature Ratings
How many amps a wire can safely handle depends heavily on the temperature rating of both the wire insulation and the connected equipment terminals. Most residential breakers and panel lugs are rated for 75°C. When determining the final allowable ampacity for standard terminals, you must size the wire using the 75°C column in NEC Table 310.16 (though 90°C ratings may be used for derating calculations). Furthermore, when you run multiple wires in a single conduit, you need to reduce the amount of each wire’s total current carrying capacity to account for the heat buildup from other cables.
Installation Methods and Electrical Codes
Where and how you run the wire will determine the required cable jacket style. Direct burial installations commonly use approved underground-rated conductors or cables such as USE-2/XHHW-2 conductors installed in conduit, or UF-B cable where permitted by code. Direct indoor wiring from a main panel to an attached subpanel usually uses Service Entrance (SER) aluminum cable or individual THHN conductors pulled through Schedule 40 or Schedule 80 PVC, EMT, or flexible conduit.
EcoFlow DELTA Pro 3 Portable Power StationEcoFlow DELTA Pro 3 Portable Power Station
Where Are 100 Amp Circuits Commonly Used?
A 100-amp circuit can provide substantial electrical power service to more circuits and fill the gap between small appliance circuits and the full 200-amp main residential service panels.
Residential Service and Subpanels
Older American homes or modest sized homes often have a 100-amp main breaker panel as their primary electrical service. Newer homes often use 200A service, while larger homes may use 400A service, and may have some 100-amp subpanels installed to isolate secondary zones. For example, a dedicated second-floor addition or a finished basement suite may have their own 100 amp panel.
Garages and Detached Buildings
A 100-amp subpanel in an attached or detached garage gives homeowners ample capacity for many applications. They can run Level 2 EV chargers (which often demand 40A to 50A continuous circuits), HVAC heat pumps, or prepare the electrical system for backup solutions such as a portable power station during outages.
Workshops and Outbuildings
Woodworking shops, metal fabrication sheds, and agricultural barns typically call for 100-amp service feeds. This capacity allows for simultaneous operation of dust collection systems, table saws, welders, and lighting without tripping breakers.
How Do You Plan a 100 Amp Residential Electrical System?
Before installing a new 100 amp service, some planning is needed to make sure your 100-amp service can handle current demands with capacity for expansion, including integrated power backup systems.
Match Wire Size With Breaker Ratings
The size of the breaker, which is your overcurrent protection device, must match with the maximum amps your wire can carry. If the breaker setting is at higher amps than the wire can handle, it creates a severe, potential fire hazard. For a standard 100A subpanel feeder, #4 copper is generally insufficient because its 75°C ampacity is below 100A. However, reduced sizing may be permitted for specific dwelling service and feeder applications that meet NEC 310.12 requirements.
Plan Future Electrical Loads
Before installing new cable, you must estimate your total connected loads plus potential future additions. If you plan to add a hot tub, induction cooktop, or dual electric vehicle chargers down the road, performing a load calculation upfront will prevent a costly re-wiring project later.
Integrate Backup Power With Transfer Switches
If you plan to integrate a backup power system into a residential utility system, power must be managed safely through a Transfer Switch or Critical Loads Panel. This prevents dangerous backfeeding from your backup power system into the utility grid. When you integrate a backup power system, you must match panel capacity, wire gauges, breaker configurations, and the specific load range your backup solution can sustain.
Critical Load Backup Systems
When you use a Critical Loads Panel to manage essential circuits, such as refrigerators, home office networking, and well pumps, backup storage must deliver clean, high-wattage output. Portable power systems like the EcoFlow DELTA Pro 3 Portable Power Station can provide up to 4,000W of output, making them suitable for supporting selected critical loads such as refrigerators, lighting, networking equipment, and other essential circuits during outages.
Delivers both 120V and 240V outputs with up to 4000W in a single unit, capable of powering a 3-ton central AC and all other essential appliances. Exclusive X-Boost technology allows the unit to exceed its rated output, providing up to 6000W of power when needed.
Whole-Home Backup Systems
For homes requiring backup power coverage across many major appliances and circuits, a larger backup energy ecosystem is essential. High-capacity systems like the EcoFlow DELTA Pro Ultra X Whole-Home Backup Power are ideal for whole-home backup scenarios. The EcoFlow DELTA Pro Ultra X offers expanded power output and high backup power storage capacity. When connected via an approved Transfer Switch or Smart Home Panel, it integrates with 100A and 200A electrical systems to keep major appliances powered during multi-day grid failures.
End-to-end system protection, the highest safety standards. *12kW/12kWh based on standard bundle (1 × EcoFlow DELTA Pro Ultra X Inverter + 2 × Smart Extra Batteries). Max 36 kW / 180 kWh with expansion. Actual performance varies by configuration.
Selecting the best wire size and material for a 100-amp electrical circuit depends on your installation environment and your budget. For standard 100A feeders, #3 AWG copper or #1 AWG aluminum is commonly used. Larger aluminum conductors, such as 1/0 AWG, are often selected for longer runs to reduce voltage drop and provide additional capacity margin. Key factors to consider are demand, voltage drop, conduit sizing, and the use of transfer switches and EcoFlow battery backup. By considering these, you can install a safe, code-compliant, and future-proof electrical system. Always consult a licensed electrician and local building codes before starting any heavy electrical installation.
What Size Aluminum Wire Do I Need for a 100 Amp Circuit?
Under standard 75°C terminal ratings, #1 AWG aluminum is rated for 100 amps and is commonly used for standard 100A feeders. However, 2 AWG aluminum may be permitted for qualifying single-family dwelling services or feeders under NEC 310.12.
Can I Use 3 AWG for 100 Amps?
Yes. Under standard 75°C terminal temperature ratings, #3 AWG copper wire is rated for exactly 100 amps (NEC Table 310.16), making it the standard code-compliant choice for a standard 100A subpanel or feeder line.
Can 2 AWG Aluminum Handle 100 Amps?
Yes, 2 AWG aluminum can handle 100 amps, but strictly when used as a main service entry or main feeder conductor for a single-family dwelling per NEC 310.12. For standard 100A feeders or subpanels not qualifying under NEC 310.12, 2 AWG aluminum does not provide 100A ampacity under the 75°C column and #1 AWG aluminum is typically required.
Is 2-2-2-4 Good for 100 Amp Service?
Yes, 2-2-2-4 SER or MHF aluminum cable is ideal for 100-amp main service feeds to single-family homes. The cable contains three 2 AWG aluminum conductors for hot and neutral lines plus a 4 AWG aluminum ground conductor, fully complying with residential service entry codes.
How Far Can You Run 100 Amp Service Wire?
There is no fixed maximum distance for a 100-amp service wire. However, longer runs may require upsizing conductors to limit voltage drop, especially when the distance exceeds 100 feet.
Home Backup
