How Much Electricity Does an Induction Hob Use in the UK?
- How Does an Induction Hob Work?
- How Much Electricity Does an Induction Hob Use?
- What Does It Cost to Run an Induction Hob?
- How to Cut Induction Hob Electricity Use
- Can an Induction Hob Work in a Power Cut?
- Solving Induction Cooking Cost and Backup Problems With Home Energy Storage
- Conclusion
- Frequently Asked Questions
A new induction hob rated at 7.2kW might look expensive to run, especially when electricity costs 26.32p per kWh and gas costs 7.97p under the October–December 2026 price cap. But the rating on the appliance tells only part of the story. It shows the maximum power available, not what you will use every time you cook.
Most meals do not require every cooking zone to run at full power. A quick boil, a slow simmer and a meal prepared across two rings all use different amounts of electricity. This guide looks at how induction cooking works, what it costs to use and how to keep consumption down. It also covers power cuts and the role solar panels and home energy storage can play in managing household energy use.
An induction hob heats the pan directly rather than heating a burner and transferring that heat to the cookware. That difference helps it respond quickly when you adjust the temperature and reduces the amount of heat lost around the pan.
How Induction Heats the Pan
So, what is an induction hob? Beneath its glass surface is a coil that creates an alternating magnetic field when you switch on a cooking zone. Just set compatible cookware on the zone and heat is created in the bottom of the pan. The hob surface is not responsible for cooking the food, it is the pan.
The glass still gets hot, but mainly because the hot pan transfers heat back to it. Remove the pan and the hob stops heating it. This is also why you cannot use just any saucepan: the base needs to contain magnetic material.
If you are unsure whether your existing pans will work, try holding a fridge magnet against the base. If it sticks firmly, the pan is generally suitable for induction cooking. Many modern induction hobs also recognise when cookware is missing or incompatible and will not activate the zone.
Why Consumption Differs From Ceramic and Gas
The main difference is where the heat goes. Induction transfers roughly 85–90% of its energy into the cookware. The efficiency of the traditional electric resistance hob is about 70-80%, and that of the gas is 30-50%. The results are indicative of efficiencies, depending on the appliance, pan and test method
A ceramic hob first heats an element and the glass beneath the pan. That takes time, and the surface continues releasing heat after you switch it off. An electric induction hob responds more directly to changes in temperature, so you can lower the setting without waiting for a hot element to cool.
There is one important distinction, though: better efficiency does not always mean a lower bill. Electricity currently costs more per unit than gas, so your final cooking costs depend on both the energy used and the tariff you pay.
Induction hob power usage varies throughout the cooking process. The number of zones in use, the heat setting and the length of time you cook all affect consumption. The rating printed on the appliance is its maximum designed demand, not a prediction of your everyday electricity use.
Power Ratings, Zones and Boost
A typical four-zone induction hob has a combined rating of 7.2–7.4kW, with individual zones ranging from 1.4kW to 3.7kW. Some models also have a boost setting for faster heating. However, the hob doesn't use maximum power all the time. It adjusts the output as the pan heats up, so actual induction hob power consumption depends on the setting and how many zones you're using. For example, one ring averaging 1.95kW uses 1.95kWh in an hour, while gentle simmering uses much less than running several rings at full power.
Hob type or setting | Rated power | Typical supply arrangement | What to expect |
Portable single zone | 1.4–2.8kW | Often a 13A plug | Demand changes with the selected setting |
Plug-in double zone | Around 3kW | 13A plug | Available power is shared between zones |
Four-zone built-in | 7.2–7.4kW | Often a dedicated cooker circuit | Combined rating covers all zones |
Boost on one zone | Up to around 3.6kW | Depends on the model | Higher demand for a short period |
These figures are guides rather than universal specifications. Some appliances include power-management controls that limit the total demand when several zones are running.
Power Supply and Plug-In Models
Before buying a hob, check that your kitchen's electrical installation can support it. The induction hob power supply must be suitable for the appliance's rated load, and many full-size four-zone models require a dedicated cooker circuit and a hard-wired connection. An electrician can check the existing circuit, cable and protective device before installation.
The power requirements for induction hob installations are not identical across all models. Some manufacturers allow certain appliances to operate at a reduced power level on a 13A supply. That option must be stated in the installation instructions; it is not something to assume from the hob's appearance or size.
A portable induction hob is usually simpler to set up. Many single-zone versions plug into a standard UK socket, while a plug in induction hob with two zones may share its available power between them. Check the rating plate and manufacturer's instructions before connecting one. Avoid using an extension lead unless the manufacturer specifically permits it.
The amount you pay depends on how much electricity the hob actually uses. For the examples in this section, the calculation uses Ofgem's average Direct Debit electricity rate for Great Britain: 26.32p per kWh from 1 October to 31 December 2026. Your own tariff and region may produce a different figure.
Cookware, Zones and Settings
The pans you use and how many rings you have on at once can make a difference to your electricity bill. If you're buying an induction hob cooking set, choose pans with flat, magnetic bases that sit well on your cooking zones. You might not need new ones if your current pans pass the magnet test. Running two rings at the same time uses more electricity, particularly on higher settings. And if you have an induction hob with extractor, remember that the fan adds to your electricity use. How much it uses depends on the model and speed setting.
UK Running Cost Table
You can estimate the cost of a cooking task with a simple calculation:
Power (kW) × cooking time (hours) × electricity rate (p/kWh) = cost in pence
The examples below use an assumed average demand of 1.95kW for boiling, 1kW for simmering and two 1.95kW zones for a family meal.
Cooking task | Assumption | Electricity used | Cost at 26.32p/kWh |
Boil a pan of water | 1.95kW for 0.06 hours | 0.117kWh | 3.1p |
Simmer a sauce | 1kW for 20 minutes | 0.333kWh | 8.8p |
Prepare a family meal | Two 1.95kW zones for 30 minutes | 1.95kWh | 51p |
These figures are estimates, not fixed costs. Actual use depends on what you're cooking, the size of the pan and the heat setting. Even so, they show that a quick cooking task can cost just a few pence.
Induction vs Gas and Ceramic
Which hob is cheaper to run? It comes down to the unit rates and how efficiently each hob uses energy. Gas is cheaper per kWh at the rates used here, but much of its heat escapes around the pan. Induction uses more of its energy to heat the food, although higher electricity prices can cancel out those savings.
Hob type | Illustrative cost per ring for one hour | Illustrative cost to boil a pan |
Induction | 51p | 3.1p |
Gas | 16p | 2.1p |
Ceramic | 43p | 5.3p |
The hourly figures use 1.95kW for induction, 2kW for gas and 1.65kW for ceramic. The boiling costs are illustrative estimates based on differing heat-up times for each hob type (roughly 3.6 minutes for induction, 7.3 minutes for ceramic and 8 minutes for gas), rather than results from a direct test of identical models. Actual cooking times and energy use will vary.
Independent testing gives another useful point of comparison. Which? found that induction hobs boiled a large pan of water in an average of 4.57 minutes. Ceramic took 7.60 minutes, while gas took 12.43 minutes. Faster cooking can help reduce the energy needed for some tasks, but it does not mean induction will always produce the lowest bill.
For anyone comparing induction hobs UK, remember to include installation in the overall cost. A built-in model needs a suitable electrical connection, while gas installation or alteration must be carried out by a Gas Safe registered engineer.
Note: 26.32p/kWh for electricity and 7.97p/kWh for gas are Ofgem’s price cap rates for October to December 2026, and they change each quarter. All costs are representative figures and do not represent the actual costs of all of these services. Visit Ofgem to see the latest cap and the tariff rates for yours. |
You do not need to change the way you cook completely to use less electricity. A few sensible adjustments to your pans, heat settings and cooking times can help reduce waste without making meal preparation more complicated.
Practical Habits
Use a pan that fits the cooking zone rather than one that's much smaller. When boiling or simmering, put a lid on the saucepan. It keeps the heat in and helps food cook faster. Boost is useful when you need to bring water to the boil quickly, but there is little reason to leave it on once the pan is hot. Turn the setting down and use only enough heat to keep the food cooking steadily. A gentle simmer rarely needs the same power as a rapid boil.
You can also switch the zone off shortly before a dish is ready. The pan holds heat, so many meals will finish cooking without the hob running until the last minute. Just avoid leaving an empty pan on an active zone.
Tariffs and Solar
Your electricity tariff and when you cook can both affect your bills. Economy 7 and some smart tariffs offer cheaper rates during off-peak periods, usually overnight. You can also make good use of sunny hours by cooking, boiling water or preparing meals when your solar panels are generating electricity. Any extra power can be stored for later, helping you rely less on the grid in the evening. If you usually cook around 6pm, making meals earlier and reheating them later could be a simpler way to save on electricity.
Induction Hob Energy-Saving Checklist
If you are choosing a new appliance or reviewing your kitchen setup, check these points before making a decision:
Test your existing pans with a magnet before replacing them.
Match pan-base sizes to the cooking zones you use most.
Check whether the hob has a power-limit setting.
Compare the appliance's combined rating with your home's available electrical supply.
Choose the best induction hob for the way your household cooks, rather than assuming the highest-rated model is automatically the right choice.
An induction hob needs electricity to create its magnetic field. If the mains supply fails, it stops heating. A gas hob may still be usable, but that depends on its ignition system and safety features.
Cooking Without Mains Power
A gas hob with electronic ignition needs electricity to produce the spark that lights the burner. Some models allow you to light the burner manually with a match or lighter if the manufacturer permits it. Others have electrical safety controls that affect whether manual lighting is possible, so check the instructions for your particular appliance.
Cooking method | Needs mains electricity? | Works during a power cut? |
Induction hob | Yes | No, unless supplied by suitable backup power |
Ceramic hob | Yes | No |
Gas hob with electronic ignition | For the spark | Only if manual lighting is supported |
Camping stove | No | Yes, outdoors |
Microwave | Yes | Only with suitable backup power |
Never bring a camping stove or barbecue indoors, even if you open a window. Burning fuel can release carbon monoxide, a colourless, odourless gas that can be fatal. If you want to plan for other cooking appliances during an outage, our guide to using an electric oven in a UK power cut covers the options.
Home Battery Backup for an Induction Hob
To run an induction hob during a power cut, your battery needs enough output to handle its power demand. A standard four-zone hob rated at 7.2kW draws more than a 3,000W battery system can supply. Best suited is a portable 3kW induction hob but first verify the continuous output of the battery. For instance, a 5.024kWh battery would power a 1.95kW load for roughly 2.6 hours until the losses to conversion. If your hob is hard-wired, have a qualified electrician inspect the back-up connection and ensure it is safe.
Home energy storage can help households use more of the solar electricity they generate during the day. Instead of exporting all their surplus, they can store some for later use. That can help cover compatible household loads after sunset, although it does not remove the high power demand of a large cooking appliance. The hob's rating and electrical connection still determine what a battery system can support.
Solar Self-Consumption for a New Setup
If you're installing solar panels, you may want a way to store extra electricity for use in the evening. The EcoFlow STREAM 5000 does this, with 5,024Wh of capacity, expandable to 90kWh. It accepts up to 5,000W of solar input and delivers up to 3,000W of AC output in a supported configuration. That's useful for compatible household appliances, but not a full-size induction hob running several zones at once.
Adding Storage to Existing Solar Panels
Already have rooftop solar but find that much of its generation is exported before you get home to cook? The EcoFlow STREAM AC 5000 is designed for households adding battery storage to an existing solar setup. It provides 5kWh (5,024Wh) of capacity, expandable up to 90kWh, with AC output of up to 3,000W in a supported configuration. It's essential that the system is compatible with the appliances you will actually be using, not assuming that it will be sufficient to heat an over-rated built-in hob at a few locations. Intelligent Mode+ enables energy management at home and Local Mode can be used when there is no internet connection.
An induction hob's maximum rating does not tell you what it will cost to cook an everyday meal. A short boil or gentle simmer uses much less electricity than running several zones at full power for an hour. The pans you use, the settings you choose and the time of day you cook all make a difference. Induction transfers heat efficiently, although gas can still be cheaper to run at current UK unit rates. During a power cut, battery backup is only an option when the system has enough output and a suitable connection for the appliance.
For households looking to make better use of solar generation, EcoFlow UK offers the STREAM range for new solar installations and homes adding storage to existing panels. Check the supported off-grid output before choosing a system, particularly if you want to run a high-powered cooking appliance. Explore the EcoFlow STREAM series to compare the available home energy storage options.
Why does my induction hob make a noise?
A quiet hum, buzz or clicking sound is often part of normal operation. The magnetic field can cause the base of some pans to vibrate, particularly at higher settings or when the cookware has several bonded layers. You may also hear a fan running as the hob cools its internal components. If the noise is unusually loud, new or accompanied by an error message, check the cookware and contact the manufacturer for advice.
Is an induction hob safe around children?
Induction cooking avoids an exposed gas flame, but the glass surface can still become hot from contact with the pan. It may also remain hot for a while after cooking. Use the child-lock function to prevent accidental changes to the settings, and teach children to recognise the residual-heat indicator. Keep pan handles turned inwards and supervise children around the cooking area.
How long does an induction hob last?
Around 10–15 years is a reasonable planning estimate, but there is no guaranteed lifespan for every model. How often you cook, how well the hob is ventilated and the quality of its components all affect how long it lasts. Electronic controls can also fail before the glass or cooking surface shows signs of wear. Check the manufacturer's warranty and care instructions when comparing models.
