What UK Vacuum Cleaner Electricity Costs Really Add Up To
A vacuum cleaner running for half an hour rarely makes much difference to your electricity bill. The cost becomes more noticeable when you clean several times a week, particularly with a high-powered machine. Understanding UK vacuum cleaner electricity costs gives you a clearer idea of what you actually pay. A 700W model, for instance, uses about 9p of electricity during a 30-minute clean at the current Ofgem rate. Cordless and robot models work differently, so their costs need a slightly different calculation. We'll look at the numbers, the habits that affect them and how home energy storage fits into wider household electricity use.
Modern corded vacuum cleaner being used on carpet in a typical UK living room with home battery storage in the background
How Much Electricity Does a Vacuum Cleaner Use?
A vacuum cleaner's electricity use comes down to its power rating and how long you leave it running. A corded model draws electricity straight from the socket. A cordless one stores electricity in its battery, while a robot vacuum spends much of its time moving around the house at a lower power level.
Typical Wattage by Vacuum Type
The figures below give a useful starting point when comparing an electric vacuum cleaner with cordless and robotic alternatives.
Vacuum type
Typical power use
Corded upright and cylinder
500–900W
Cordless stick
Battery-powered; example uses a 100Wh battery
Robot vacuum
60–100W while cleaning
A 700W corded vacuum running for half an hour uses 0.35kWh. Leave it running for an hour and that doubles to 0.7kWh.
An electric cordless vacuum cleaner has no direct electricity draw while you move around the house. Its battery supplies the motor, and the charger replaces that energy afterwards. The electricity used at the socket is slightly higher than the amount stored because charging produces some heat loss.
Robot vacuums draw less power while cleaning, usually around 60–100W in these examples. They run for longer than a person would spend vacuuming, though. Some also have self-emptying stations that use additional electricity.
There is a UK regulation to consider when looking at older machines. Since September 2017, covered mains-powered vacuum cleaners have been subject to a rated input power limit below 900W. The rules also introduced an annual energy consumption limit below 43kWh under prescribed testing conditions. These requirements do not cover every vacuum category.
Suction Settings and Power Modes
The number on a vacuum's power label tells you how much electricity its motor draws. It does not tell you how much dirt the machine picks up.
That distinction matters when choosing between models. A well-designed 600W vacuum with a good floor head can clean effectively without drawing as much electricity as a less efficient machine.
Eco mode reduces power demand and helps cordless batteries last longer. Auto mode adjusts suction as the machine moves between surfaces. Boost mode gives you extra power for stubborn dirt, thick carpets and pet hair, but it also drains a cordless battery faster. Consider two corded models rated at 600W and 900W. At full power, the second draws 50% more electricity for the same cleaning time. If they do the same job successfully, then the cheaper machine is the lower powered.
How to Calculate UK Vacuum Cleaner Electricity Costs
Working out UK vacuum cleaner electricity costs takes two simple calculations. You need the appliance's wattage, the time spent cleaning and the electricity rate on your bill.
The Formula and Worked Examples
Start by converting the electricity used into kilowatt-hours (kWh). Electricity suppliers charge per kWh, not per watt.
Watts × Hours ÷ 1,000 = Electricity used in kWh
Then multiply the result by your electricity unit rate.
kWh × Electricity rate = Running cost
We'll use 26.32p per kWh throughout this article. This is Ofgem's typical direct debit electricity unit rate in Great Britain for 1st October to 31st December 2026. The 0% VAT rate on domestic electricity is also temporarily extended until March 2027 for England, Scotland and Wales, from October 2026.
Take a 700W vacuum used for 30 minutes:
700 × 0.5 ÷ 1,000 = 0.35kWh
0.35 × 26.32p = 9.21p
This is about 9p per clean. Across three half-hour sessions per week, that adds up to 1.05kWh and costs approximately 28p per week. Over 52 weeks, the total reaches 54.6kWh, or £14.37. Cordless models need a different calculation. Suppose your vacuum has a 100Wh battery and the charger operates at 85% efficiency. About 0.118kWh is taken from the socket on a full charge. At this rate of 26.32p/kWh that equates to approximately 3.1p.
For a robot vacuum rated at 80W, one hour of cleaning uses 0.08kWh. The electricity cost is approximately 2.1p. These are working examples rather than guaranteed figures for every machine. Battery capacity, charging efficiency and power settings all affect actual consumption.
Note: 26.32p/kWh is Ofgem’s price cap rate for October to December 2026 and changes each quarter. The figures given in this article should be regarded as estimates for illustration. See Ofgem for the latest cap and your own tariff rate.
Running Costs Compared by Vacuum Type
Here is how different machines compare over a year. Corded and cordless models are based on three 30-minute cleaning sessions each week. The robot is on for 1 hour each day.
Vacuum type
Cost per hour
Cost per 30-minute clean
Annual electricity
Annual cost
Corded 600W
15.8p
7.9p
46.8kWh
£12.32
Corded 900W
23.7p
11.8p
70.2kWh
£18.48
Corded 1,400W (older model)
36.8p
18.4p
109.2kWh
£28.74
Cordless 100Wh battery
N/A
3.1p per charge
18.4kWh
£4.83
Robot 80W, one hour daily
2.1p
1.1p
29.2kWh
£7.69
The cordless example assumes one full recharge for each cleaning session. The older 1,400W machine is included for comparison, not as a current compliant model for the covered vacuum category.
So, do vacuum cleaners use a lot of electricity? Not usually. Even the 1,400W example uses less than 110kWh annually under this cleaning schedule. That is a small share of a household's annual electricity consumption.
People searching does a vacuum cleaner use a lot of electricity often expect a much higher figure. In reality, annual running costs are modest compared with high-draw appliances like tumble dryers or electric ovens—so regular vacuuming won't put a big dent in your household budget. And do cordless vacuum cleaners use more electricity? Not in this example—provided a single charge covers your 30-minute clean. A full charge costs about 3p, while a 700W corded machine uses roughly 9p over half an hour (though running a cordless vacuum on Boost mode may drain the battery faster and require more frequent charging).
Your Running-Cost Calculator
To calculate your own UK vacuum cleaner electricity costs, start with the rating on the appliance label. For a cordless model, look for its battery capacity in Wh.
Next, work out how many hours you spend cleaning each year:
Minutes per week × 52 ÷ 60 = Annual cleaning hours
Multiply the annual hours by the wattage, divide by 1,000, then multiply by your unit rate. For example, a two-adult flat uses a 700W corded vacuum three times a week for 30 minutes. It also runs an 80W robot vacuum for one hour daily.
The corded machine consumes energy of 54.6kWh per year. The robot consumes a total of 83.8kWh when including the extra 29.2kWh added by the robot. The household pays £22.06 per year for this electricity charge at 26.32p per kWh. This does not include the robot's standby dock consumption.
What Affects UK Vacuum Cleaner Electricity Costs?
Two people with the same vacuum cleaner will not necessarily pay the same amount to run it. Cleaning frequency, floor coverings, power settings and charging habits all make a difference.
Frequency, Floor Type and Charging Habits
How often you clean has the biggest effect on annual consumption. A 700W machine used for 30 minutes every day consumes 127.75kWh a year. That costs approximately £33.62 at the stated electricity rate.
The same machine used three times a week costs £14.37 annually. Nothing has changed about the vacuum itself. The difference comes entirely from how often it runs.
Floor coverings also influence cleaning time. A laminate floor usually needs less effort than a thick bedroom carpet covered in pet hair. Rugs, stairs and busy hallways often require additional passes.
Charging habits matter for cordless machines. When charging, some energy is lost as heat, meaning that the socket provides more energy to the battery than the battery can hold. Also, leaving a charger connected will create a small standby load, depending on the charger's design.
Robot vacuum docks deserve attention too. A dock drawing an illustrative 3W continuously uses 26.28kWh over a year. At 26.32p per kWh, that costs approximately £6.92. Self-emptying stations add further consumption whenever their motors empty the dust container.
Does a Higher Wattage Mean Higher Costs?
A higher wattage means a vacuum draws more electricity when running at that rating. It does not automatically pick up more dirt.
Manufacturers use different motor designs, airflow systems and floor heads. A well-engineered lower-powered machine often cleans just as effectively as a higher-powered alternative.
Look beyond the wattage when comparing models. Check carpet and hard-floor cleaning performance, filtration and the design of the brush head. These details tell you more about what the machine does with the electricity it consumes.
The same applies when researching the best lightweight electric vacuum cleaner or best small electric vacuum cleaner. A smaller, lighter machine is easier to carry upstairs and store in a cupboard, but its size alone tells you little about running costs. Compare its rated power, battery capacity and cleaning performance before buying. A compact model that needs several passes to clean a carpet is not necessarily more economical than a larger, more efficient machine.
How to Cut Vacuum Running Costs
You do not need to change your cleaning routine completely to use less electricity. A few adjustments help.
  • Use Eco mode: Save Boost for thick carpets, pet hair and stubborn dirt.
  • Keep filters clean: Wash or replace them according to the manufacturer's instructions. Blocked filters restrict airflow.
  • Check the brush bar: Remove tangled hair and fibres before they affect cleaning performance.
  • Plan robot cleaning: Three or four sessions each week often provide enough coverage for a reasonably tidy home.
  • Follow battery instructions: Avoid unnecessary charging and disconnect the charger when appropriate.
  • Match suction to the floor: Maximum power is unnecessary on every surface.
For an 80W robot vacuum, cutting three one-hour cleaning sessions each week saves 12.48kWh annually. That is approximately £3.28 at the current unit rate.
How Vacuuming Fits Into Wider Household Energy Use
UK vacuum cleaner electricity costs are only one part of a household's electricity bill. The timing of appliance use and the source of that electricity matter just as much when managing energy at home.
Smart Meters, Time-of-Use Tariffs and Daytime Solar
A smart meter helps you see how much electricity your home draws from the grid. Its in-home display also gives you a useful way to compare appliance use.
Switch on the vacuum and watch the reading change. You will get a better idea of its actual demand than you would from the wattage printed on the box alone.
Time-of-use tariffs charge different rates at different times. Octopus Intelligent Go, for example, offers cheaper overnight electricity to eligible customers. Octopus Cosy has several cheaper periods throughout the day. The exact rates depend on the tariff and region.
At 7p per kWh, a 700W vacuum running for 30 minutes costs about 2.5p. At 26.32p, the same clean costs 9.2p. However, nobody needs to vacuum at two in the morning simply to save a few pence.
Solar generation offers a more convenient opportunity. If your panels produce surplus electricity around lunchtime, you can run the vacuum using that generation rather than importing electricity from the grid.
A 700W vacuum needs 0.35kWh for half an hour. If the panels produce enough surplus during that period, they cover the demand directly.
This also reduces the amount of electricity exported through the Smart Export Guarantee. Export payments are often lower than the price households pay to import electricity, so using your own generation first makes financial sense.
Note: Time-of-use tariff availability, eligibility and pricing vary by supplier and change over time. Check your supplier’s current terms and Ofgem’s guidance before switching.
Does a Home Battery Cut Vacuum Costs?
A home battery makes little difference to vacuum running costs on its own. The appliance simply does not use enough electricity to justify buying storage specifically for it.
Does vacuum cleaner use a lot of electricity across a full year? A 700W vacuum used for three half-hour sessions each week consumes 54.6kWh annually. That is around 2% of a household using 2,700kWh a year.
One half-hour clean needs just 0.35kWh. Compared with the nominal 5kWh capacity of a battery, that is a small demand.
People asking does vacuum cleaner use much electricity should look at the annual figure rather than the wattage alone. A powerful motor sounds expensive, but short cleaning sessions keep the overall cost down.
The stronger case for a battery comes from the rest of the household. Evening cooking, lighting, laundry and other appliances use electricity after solar generation has fallen. Stored daytime energy helps cover those demands instead of relying entirely on grid imports.
How to Stop Wasting Surplus Solar Around the Home
Vacuuming takes a small amount of electricity, but the wider household has a bigger timing problem. Solar panels generate most of their electricity during daylight, when many people are out. In the evening, the same household starts cooking, washing clothes and switching on lights.
Home energy storage helps move some of that daytime generation into the hours when the household needs it.
For Homes Without Solar Panels Yet
Starting a solar installation from scratch gives homeowners the opportunity to plan generation and storage together. The EcoFlow STREAM 5000 suits this type of setup, putting UK vacuum cleaner electricity costs into a wider household energy plan rather than treating the vacuum as the main reason to buy a battery. It provides 5kWh / 5024Wh of capacity, expandable up to 90kWh, with 5000W PV input across four MPPT channels rated at 1,250W each. Its 3000W AC output and Intelligent Mode+ automatic energy management support household appliances beyond everyday cleaning. The aim is to keep more of the electricity generated by the panels available for later use and reduce grid imports.
EcoFlow STREAM 5000
Installed home battery for homes without solar. UK rules require installation, and the setup is designed to be simple 5024Wh capacity, expandable to 90kWh with Expansion Batteries Up to 3000W AC output for high-demand appliances like stoves, dryers or kettles (when solar is generating or an Expansion Battery is paired) 5,000W solar input makes full use of your solar generation Up to 2500W AC charging for fast recharge Smart meter, main unit and solar panels are designed to connect easily, with step-by-step app guidance for setup Compact 45.4kg body with a built-in handle for easier placement during installation Residential-grade protection with pressure-release and fire-resistant materials, designed to reduce thermal runaway risk with high-voltage solar panels Rated for 10,000 cycles Local Mode keeps the system running and communicating even if the network drops
For Homes With Solar Already Installed
Existing solar owners face a different situation. Their panels are already generating electricity, but some of that energy leaves the property during the day before the household needs it in the evening. The EcoFlow STREAM AC 5000 is designed for households adding battery storage to an existing solar installation, making UK vacuum cleaner electricity costs part of a broader discussion about using more self-generated power. It offers 5kWh / 5024Wh of capacity, expandable up to 90kWh, and 3000W AC output. Intelligent Mode+ manages energy automatically, while Local Mode supports operation without an internet connection. More of the household's own solar generation stays available to meet evening electricity demand.
Installed home battery for homes with existing solar. UK rules require installation, and the setup is designed to be simple Works with existing rooftop PV systems, home battery systems and leading third-party meters 5024Wh capacity, expandable to 90kWh with Expansion Batteries Up to 3000W AC output for heavy household appliances (when solar is generating or an Expansion Battery is paired) AC coupling adds storage alongside your current solar setup, and a Gateway simplifies expanding later Compact 44.6kg body designed to fit into spaces around the home Rated for 10,000 cycles
Note: Compliant generation-only plug-in solar kits have been legal to buy and use in Great Britain since 27 August 2026, but these rules do not cover plug-in batteries or solar-plus-storage systems. Home batteries, including the EcoFlow STREAM 5000 and STREAM AC 5000, are not plug-in solar products. They must be professionally installed and must comply with the IET Wiring Regulations (BS 7671) and DNO connection requirements. Follow GOV.UK guidance, and obtain professional advice and guidance from a qualified installer to determine the type of work your home requires.
A 700W vacuum costs about 9p for a 30-minute clean at 26.32p per kWh. Three cleaning sessions each week add approximately £14.37 to the annual bill. Cordless charging costs around 3p per full charge, while an 80W robot uses about 2p an hour. Though the numbers are low, there are still power settings and maintenance considerations to take into account when cleaning. Maintain clean filters, follow “Eco” and don't run the robot vacuums unnecessarily.
A home battery is a whole-household investment, not a purchase justified by vacuuming alone. Its value comes from storing surplus solar for cooking, lighting, laundry and other evening demands. Explore the home energy storage options available from EcoFlow and consider how the STREAM range fits into your household's wider electricity needs. Visit EcoFlow UK to explore the STREAM range and find a suitable solar-plus-storage setup for your home.
Is it worth replacing an old vacuum cleaner to save electricity?
Not usually. At three half-hour cleaning sessions each week, a 1,400W machine costs approximately £14 more annually to run than a 700W model. When replacing a vacuum that is working it is not always cost-effective to do so just to save on electricity. Replace when cleaning inevitably causes performance or reliability issues or repair expenses become an issue.
Does a vacuum cleaner use more electricity than a kettle?
A 30-minute clean with a 700W vacuum uses 0.35kWh. Boiling a litre of water in a typical 3kW kettle uses roughly 0.1kWh, meaning the vacuum consumes more electricity over that session. A kettle actually draws much higher power (3,000W vs 700W), but because it only runs for about two minutes, it uses less total energy per use.
Does a wet-and-dry vacuum cost more to run than a normal one?
Usually, yes, if its motor has a higher rated input. Some wet-and-dry models draw between 800W and 1,500W. A 1,500W machine running for an hour uses 1.5kWh, costing approximately 39.5p at 26.32p per kWh. Occasional use keeps the annual cost down.
